# # ChangeLog for / in rtems-docs # # Generated by Trac 1.2.1.dev0 # 04/30/24 13:38:42 Wed, 13 Mar 2019 09:45:52 GMT Sebastian Huber [588b9b2] * eng/index.rst (modified) eng: Reformat Fri, 01 Mar 2019 08:43:53 GMT Sebastian Huber [8ff7024] * c-user/symmetric_multiprocessing_services.rst (modified) c-user: Mention atomic operations API Wed, 06 Mar 2019 11:22:57 GMT Chris Johns [1e342da] * user/testing/tests.rst (modified) user/test: Update with the latest test configuration format. Fri, 01 Mar 2019 02:06:11 GMT Chris Johns [1393ba0] * common/waf.py (modified) waf: Fix argument bug getting extra source. Wed, 27 Feb 2019 21:36:39 GMT Chris Johns [d5b631f] * user/bsps/bsps-powerpc.rst (modified) * user/bsps/bsps-x86_64.rst (modified) * user/bsps/index.rst (modified) * user/exe/initialization.rst (modified) * user/exe/loader.rst (modified) * user/hardware/architectures.rst (modified) * user/hosts/os.rst (modified) * user/hosts/posix.rst (modified) * user/hosts/windows.rst (modified) * user/installation/developer.rst (modified) * user/installation/kernel.rst (modified) * user/installation/releases.rst (modified) * user/rsb/bug-reporting.rst (modified) * user/rsb/commands.rst (modified) * user/rsb/configuration.rst (modified) * user/rsb/cross-canadian-cross.rst (modified) * user/rsb/deployment.rst (modified) * user/rsb/project-sets.rst (modified) * user/rsb/third-party-packages.rst (modified) * user/testing/tftp.rst (modified) * user/tools/bsp-builder.rst (modified) * user/tools/exeinfo.rst (modified) * user/tools/symbols.rst (modified) * user/tools/tester.rst (modified) * user/tracing/captureengine.rst (modified) * user/tracing/examples.rst (modified) * user/tracing/tracelinker.rst (modified) User: Change output block to type none. Wed, 27 Feb 2019 06:28:00 GMT Chris Johns [921037f] * README.txt (modified) Add commands and output to the README. Thu, 21 Feb 2019 02:06:58 GMT Chris Johns [2674d6a] * user/bsps/bsps-powerpc.rst (modified) * user/bsps/bsps-x86_64.rst (modified) * user/exe/debugging.rst (modified) * user/exe/index.rst (modified) * user/exe/initialization.rst (modified) * user/exe/loader.rst (modified) * user/hosts/macos.rst (modified) * user/hosts/os.rst (modified) * user/hosts/posix.rst (modified) * user/hosts/windows.rst (modified) * user/installation/kernel.rst (modified) * user/overview/index.rst (modified) * user/rsb/bug-reporting.rst (modified) * user/rsb/commands.rst (modified) * user/rsb/configuration.rst (modified) * user/rsb/cross-canadian-cross.rst (modified) * user/rsb/deployment.rst (modified) * user/rsb/history.rst (modified) * user/rsb/index.rst (modified) * user/rsb/project-sets.rst (modified) * user/rsb/third-party-packages.rst (modified) * user/rsb/why-build-from-source.rst (modified) * user/start/index.rst (modified) * user/testing/configuration.rst (modified) * user/testing/consoles.rst (modified) * user/testing/gdb-jtag.rst (modified) * user/testing/index.rst (modified) * user/testing/tests.rst (modified) * user/testing/tftp.rst (modified) * user/tracing/captureengine.rst (modified) * user/tracing/examples.rst (modified) * user/tracing/introduction.rst (modified) * user/tracing/tracelinker.rst (modified) * user/wscript (modified) user: Remove nit-picky warnings. Thu, 21 Feb 2019 02:03:07 GMT Chris Johns [2e6f49f] * README.txt (modified) Add a cheetsheet link to the README.txt Wed, 20 Feb 2019 04:40:37 GMT Chris Johns [1a051fc] * common/waf.py (modified) * posix-compliance/wscript (modified) waf: Add support for extra and excluded sources. Tue, 19 Feb 2019 23:11:37 GMT Chris Johns [62efd4c] * README.txt (modified) * common/waf.py (modified) waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit- ... Tue, 19 Feb 2019 23:07:04 GMT Chris Johns [fb72a00] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/unicode.rst (added) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Add unicode support for commonly used characters like copyright. - ... Tue, 19 Feb 2019 22:16:19 GMT Chris Johns [4407039] * common/waf.py (modified) waf: Fix building the images in the src path. Wed, 27 Feb 2019 22:16:57 GMT Chris Johns [1599d99] * posix-compliance/posix_rst.py (modified) * wscript (modified) waf: Fix python3 issues. - Found after updating to FreeBSD-12.0 ... Tue, 26 Feb 2019 22:07:36 GMT Vaibhav Gupta [9c3a383] * user/hosts/posix.rst (modified) * user/tools/tester.rst (modified) Update User Documentation for Host setup for Linux Mention the ... Fri, 15 Feb 2019 05:03:59 GMT Chris Johns [8a73acb] * images/user/libdl-load.png (added) * images/user/libdl-load.puml (added) * images/user/libdl.ditaa (added) * images/user/libdl.png (added) * user/exe/executables.rst (modified) * user/exe/execution.rst (modified) * user/exe/index.rst (modified) * user/exe/loader.rst (added) * user/installation/developer.rst (modified) * user/tools/exeinfo.rst (modified) * user/tools/linker.rst (modified) * user/tools/symbols.rst (modified) user: Add a Dynamic Loader section. Tue, 19 Feb 2019 08:17:57 GMT Sebastian Huber [789b0ca] * c-user/fatal_error.rst (modified) c-user: INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA Update #3507. Tue, 19 Feb 2019 07:29:15 GMT Sebastian Huber [f6be8a1] * user/start/sources.rst (modified) * user/start/tools.rst (modified) user: Fix tense in quick start Tue, 19 Feb 2019 06:11:54 GMT Sebastian Huber [7ad2d12] * user/bsps/bsps-arm.rst (modified) user: Clarify U-Boot commands Wed, 23 Jan 2019 13:33:35 GMT Sebastian Huber [cb4e4e2] * user/start/index.rst (modified) user: Remove obsolete content in quick start Wed, 23 Jan 2019 13:33:06 GMT Sebastian Huber [d7caf8a] * user/start/app.rst (added) * user/start/index.rst (modified) user: Add "Build Your Application" Wed, 23 Jan 2019 13:29:04 GMT Sebastian Huber [d2827cb] * user/start/bsp-test.rst (added) * user/start/index.rst (modified) * user/testing/index.rst (modified) user: Add "Test a Board Support Package (BSP)" Wed, 23 Jan 2019 13:26:47 GMT Sebastian Huber [fa12cab] * user/start/bsp-build.rst (added) * user/start/index.rst (modified) user: Add "Build a Board Support Package (BSP)" Wed, 23 Jan 2019 13:21:39 GMT Sebastian Huber [158d905] * user/start/bootstrap.rst (added) * user/start/index.rst (modified) user: Add "Bootstrap the RTEMS Sources" Wed, 23 Jan 2019 12:52:06 GMT Sebastian Huber [06a1fa2] * user/hardware/architectures.rst (modified) * user/start/index.rst (modified) * user/start/tools.rst (added) user: Add "Install the Tool Suite" section Wed, 23 Jan 2019 12:01:07 GMT Sebastian Huber [947e8eb] * user/start/index.rst (modified) * user/start/sources.rst (added) user: Add "Obtain the Sources" section Fri, 11 Jan 2019 14:47:00 GMT Sebastian Huber [eae5454] * user/hosts/posix.rst (modified) * user/installation/project-sandboxing.rst (modified) * user/start/index.rst (modified) * user/start/prefixes.rst (modified) * user/tools/index.rst (modified) user: Rework Prefixes section Rename it to "Choose an Installation ... Wed, 23 Jan 2019 10:05:12 GMT Sebastian Huber [2445655] * user/hosts/macos.rst (modified) * user/hosts/posix.rst (modified) * user/installation/project-sandboxing.rst (modified) * user/installation/releases.rst (modified) * user/start/prefixes.rst (modified) user: Fix references to prefixes section Wed, 23 Jan 2019 09:55:19 GMT Sebastian Huber [54ead99] * user/rsb/why-build-from-source.rst (modified) * user/start/host.rst (modified) user: Rework "Host Computer Setup" section Rename it to "Prepare ... Mon, 18 Feb 2019 08:16:28 GMT Sebastian Huber [924b9ef] * user/bsps/bsps-arm.rst (modified) user: Add product name Wed, 13 Feb 2019 07:05:33 GMT Sebastian Huber [9f24b6e] * user/bsps/bsps-arm.rst (modified) user: Add basic Intel Cyclone V documentation Thu, 14 Feb 2019 09:04:28 GMT Chris Johns [f7384cc] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/_templates/layout.html (modified) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * rtemsconfig/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Use pathto() on the genindex URL to make it relative. Wed, 13 Feb 2019 22:16:38 GMT Joel Sherrill [603731c] * common/latex.py (modified) common/latex.py: Remove hack for CentOS. Use Texlive per instructions. Wed, 13 Feb 2019 21:42:51 GMT Joel Sherrill [30b5468] * README.txt (modified) README.txt: Fix typos Tue, 12 Feb 2019 23:57:10 GMT Chris Johns [7b36a6b] * common/coverpage/coverpage.html (modified) * wscript (modified) waf: Use the release date in the coverpage Tue, 12 Feb 2019 23:50:50 GMT Chris Johns [d721375] * common/version.py (modified) * wscript (modified) waf: Fix version.py to support older versions of git. Tue, 12 Feb 2019 23:18:43 GMT Chris Johns [5d8b0dd] * bsp-howto/wscript (modified) * c-user/wscript (modified) * cpu-supplement/wscript (modified) * develenv/wscript (modified) * eclipse/wscript (modified) * eng/wscript (modified) * filesystem/wscript (modified) * images/wscript (modified) * networking/wscript (modified) * porting/wscript (modified) * posix-compliance/wscript (modified) * posix-users/wscript (modified) * rtemsconfig/wscript (modified) * shell/wscript (modified) * user/wscript (modified) * wscript (modified) waf: Remove as many sys path hacks as we can. There are still ... Thu, 07 Feb 2019 19:03:43 GMT Chris Johns [ec95748] * common/conf.py (modified) * common/minted.sty (deleted) * common/rtemsstyle.sty (modified) Remove minted from the PDF builds. This is feedback from the Sphinx ... Tue, 05 Feb 2019 10:43:10 GMT Sebastian Huber [fa5a960] * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/index.rst (modified) * c-user/red_black_trees.rst (modified) * c-user/scheduling_concepts.rst (modified) * cpu-supplement/epiphany.rst (modified) * cpu-supplement/index.rst (modified) * cpu-supplement/openrisc_1000.rst (modified) * cpu-supplement/sparc64.rst (modified) Add copyright notices Fri, 08 Feb 2019 08:41:45 GMT Sebastian Huber [6f110cc] * book/conf.py (modified) * book/wscript (modified) * bsp-howto/conf.py (modified) * bsp-howto/wscript (modified) * c-user/conf.py (modified) * c-user/wscript (modified) * cpu-supplement/conf.py (modified) * cpu-supplement/wscript (modified) * develenv/conf.py (modified) * develenv/wscript (modified) * eclipse/conf.py (modified) * eclipse/wscript (modified) * eng/conf.py (modified) * eng/wscript (modified) * filesystem/conf.py (modified) * filesystem/wscript (modified) * images/wscript (modified) * networking/conf.py (modified) * networking/wscript (modified) * porting/conf.py (modified) * porting/wscript (modified) * posix-compliance/conf.py (modified) * posix-compliance/wscript (modified) * posix-users/conf.py (modified) * posix-users/wscript (modified) * rtemsconfig/conf.py (modified) * rtemsconfig/wscript (modified) * shell/conf.py (modified) * shell/wscript (modified) * user/conf.py (modified) * user/wscript (modified) * wscript (modified) build: Prepend project common path This avoids conflicts with ... Thu, 07 Feb 2019 12:06:26 GMT Sebastian Huber [0e46b34] * cpu-supplement/epiphany.rst (moved) * cpu-supplement/index.rst (modified) cpu-supplement: Fix file name Wed, 06 Feb 2019 22:31:33 GMT Chris Johns [98977bf] * wscript (modified) Version change, forgot to add wscript to the commit. Wed, 06 Feb 2019 21:46:53 GMT Chris Johns [6f18d69] * common/version.py (modified) Fix the version logic to make it more robust. Wed, 06 Feb 2019 06:02:18 GMT Chris Johns [a3b0a40] * common/conf.py (modified) * common/waf.py (modified) Fix building with Sphinx 1.8 and later. - Provide the pytnon.ist ... Wed, 06 Feb 2019 05:46:42 GMT Chris Johns [2a68e9d] * common/version.py (added) * wscript (modified) Support VERSION file for releasing and deployment - Shorten the GIT ... Wed, 30 Jan 2019 10:40:05 GMT Sebastian Huber [21c4a44] * user/tracing/captureengine.rst (modified) * user/tracing/eventrecording.rst (added) * user/tracing/index.rst (modified) * user/tracing/introduction.rst (modified) * user/tracing/tracelinker.rst (modified) user: Add basic event recording documentation Update #3665. Wed, 30 Jan 2019 07:28:52 GMT Sebastian Huber [d06b195] * c-user/configuring_a_system.rst (modified) c-user: Add event recording configuration Update #3665. Thu, 31 Jan 2019 06:38:37 GMT Sebastian Huber [362ae68] * bsp-howto/i2c.rst (modified) * bsp-howto/spi.rst (modified) bsp-howto: Fix URLs Wed, 23 Jan 2019 09:35:50 GMT Sebastian Huber [3db6371] * user/rsb/index.rst (modified) * user/rsb/why-build-from-source.rst (modified) user: Use capital letters for acronyms Fix GCC definition. Wed, 23 Jan 2019 09:40:40 GMT Sebastian Huber [63735bc] * user/exe/executables.rst (modified) * user/hardware/targets.rst (modified) * user/hosts/macos.rst (modified) * user/hosts/windows.rst (modified) * user/installation/releases.rst (modified) * user/overview/index.rst (modified) * user/rsb/third-party-packages.rst (modified) * user/rsb/why-build-from-source.rst (modified) * user/start/index.rst (modified) * user/tools/index.rst (modified) * user/tracing/index.rst (modified) user: Spell out third-party Tue, 22 Jan 2019 11:58:09 GMT Sebastian Huber [5973f92] * user/bsps/bsps-riscv.rst (modified) user: Stub documentation for griscv BSP Update #3678. Thu, 17 Jan 2019 08:44:07 GMT Sebastian Huber [d9eb36b] * common/conf.py (modified) Change first copyright year to 1988 The OAR copyright goes back to 1988. Fri, 11 Jan 2019 14:55:37 GMT Sebastian Huber [3ed59ce] * user/start/host.rst (added) * user/start/index.rst (modified) user: Add "Host Computer Setup" to "Quick Start" Fri, 11 Jan 2019 14:28:57 GMT Sebastian Huber [0facb9d] * user/installation/index.rst (modified) * user/installation/project-sandboxing.rst (moved) * user/start/index.rst (modified) * user/start/prefixes.rst (added) user: Move "Prefixes" to "Quick Start" Move "Project Sandboxing" to ... Fri, 11 Jan 2019 13:44:36 GMT Sebastian Huber [3de74ba] * user/bsps/index.rst (modified) * user/exe/index.rst (modified) * user/glossary/index.rst (modified) * user/hardware/architectures.rst (modified) * user/hardware/bsps.rst (deleted) * user/hardware/index.rst (modified) * user/hardware/targets.rst (modified) * user/index.rst (modified) user: Rework "Hardware" chapter Rename it to "Target Hardware". ... Fri, 11 Jan 2019 12:54:10 GMT Sebastian Huber [89a33b3] * user/overview/index.rst (modified) * user/rsb/deployment.rst (added) * user/rsb/index.rst (modified) user: Move deployment details to RSB chapter Fri, 11 Jan 2019 11:54:20 GMT Sebastian Huber [c098290] * user/ecosys/index.rst (deleted) * user/index.rst (modified) * user/overview/index.rst (modified) user: Move "Ecosystem" into "Introduction" Fri, 11 Jan 2019 11:45:30 GMT Sebastian Huber [c4da705] * user/index.rst (modified) * user/overview/index.rst (modified) * user/support/index.rst (deleted) user: Move "Support" to "Introduction" New users may find it useful ... Fri, 11 Jan 2019 09:39:19 GMT Sebastian Huber [b5014fe] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/license.rst (added) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Reformat and update copyright and license notices For everything ... Fri, 11 Jan 2019 09:20:08 GMT Sebastian Huber [60ed99d] * rsb/conf.py (deleted) * rsb/index.rst (deleted) * rsb/wscript (deleted) * user/index.rst (modified) * user/rsb/bug-reporting.rst (moved) * user/rsb/commands.rst (moved) * user/rsb/configuration.rst (moved) * user/rsb/cross-canadian-cross.rst (moved) * user/rsb/history.rst (moved) * user/rsb/index.rst (moved) * user/rsb/project-sets.rst (moved) * user/rsb/third-party-packages.rst (moved) * user/rsb/why-build-from-source.rst (moved) * wscript (modified) user: Add RSB content as a chapter Remove the separate RSB manual. Fri, 11 Jan 2019 13:06:45 GMT Sebastian Huber [1cb70df] * user/bsp/index.rst (deleted) user: Remove unused file Fri, 11 Jan 2019 09:38:34 GMT Sebastian Huber [dec664b] * common/header.rst (modified) common/header: Add missing copyright notice Fri, 11 Jan 2019 06:31:06 GMT Chris Johns [7cef256] * rsb/why-build-from-source.rst (modified) rsb: Reword some sentences Thu, 10 Jan 2019 11:52:25 GMT Sebastian Huber [f95699b] * rsb/building-tools-and-rtems.rst (deleted) * rsb/index.rst (modified) * rsb/project-sets.rst (modified) * rsb/source-builder.rst (modified) rsb: Move content of duplicate section Move "Controlling the Tools ... Thu, 10 Jan 2019 11:52:24 GMT Sebastian Huber [9e18bcb] * rsb/index.rst (modified) * rsb/source-builder.rst (modified) * rsb/why-build-from-source.rst (added) rsb: Move "Why Build from Source?" to own chapter Thu, 10 Jan 2019 11:52:23 GMT Sebastian Huber [633a24f] * rsb/history.rst (added) * rsb/index.rst (modified) * rsb/source-builder.rst (modified) rsb: Move "History" to own chapter Move it to the end of the ... Wed, 09 Jan 2019 15:14:06 GMT Sebastian Huber [e52906b] * book/index_book.rst (modified) * bsp-howto/ada95_interrupt.rst (modified) * bsp-howto/ata.rst (modified) * bsp-howto/clock.rst (modified) * bsp-howto/command.rst (modified) * bsp-howto/console.rst (modified) * bsp-howto/frame_buffer.rst (modified) * bsp-howto/getentropy.rst (modified) * bsp-howto/i2c.rst (modified) * bsp-howto/ide_controller.rst (modified) * bsp-howto/index.rst (modified) * bsp-howto/initilization_code.rst (modified) * bsp-howto/linker_script.rst (modified) * bsp-howto/miscellanous_support.rst (modified) * bsp-howto/networking.rst (modified) * bsp-howto/preface.rst (modified) * bsp-howto/real_time_clock.rst (modified) * bsp-howto/shared_memory_support.rst (modified) * bsp-howto/spi.rst (modified) * bsp-howto/target_dependant_files.rst (modified) * bsp-howto/timer.rst (modified) * c-user/ada_support.rst (modified) * c-user/barrier_manager.rst (modified) * c-user/board_support_packages.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/example_application.rst (modified) * c-user/fatal_error.rst (modified) * c-user/glossary.rst (modified) * c-user/index.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/key_concepts.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/overview.rst (modified) * c-user/partition_manager.rst (modified) * c-user/pci_library.rst (modified) * c-user/preface.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/red_black_trees.rst (modified) * c-user/region_manager.rst (modified) * c-user/rtems_data_types.rst (modified) * c-user/scheduling_concepts.rst (modified) * c-user/self_contained_objects.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/stack_bounds_checker.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) * cpu-supplement/altera_nios_ii.rst (modified) * cpu-supplement/arm.rst (modified) * cpu-supplement/atmel_avr.rst (modified) * cpu-supplement/blackfin.rst (modified) * cpu-supplement/ephiphany.rst (modified) * cpu-supplement/index.rst (modified) * cpu-supplement/intel_amd_x86.rst (modified) * cpu-supplement/lattice_micro32.rst (modified) * cpu-supplement/m68xxx_and_coldfire.rst (modified) * cpu-supplement/mips.rst (modified) * cpu-supplement/openrisc_1000.rst (modified) * cpu-supplement/port.rst (modified) * cpu-supplement/powerpc.rst (modified) * cpu-supplement/preface.rst (modified) * cpu-supplement/renesas_m32c.rst (modified) * cpu-supplement/riscv.rst (modified) * cpu-supplement/sparc.rst (modified) * cpu-supplement/sparc64.rst (modified) * cpu-supplement/sparc_v8_stacks_regwin.rst (modified) * cpu-supplement/superh.rst (modified) * cpu-supplement/xilinx_microblaze.rst (modified) * develenv/command.rst (modified) * develenv/directory.rst (modified) * develenv/index.rst (modified) * develenv/introduction.rst (modified) * develenv/sample.rst (modified) * develenv/utilities.rst (modified) * eclipse/glossary.rst (modified) * eclipse/index.rst (modified) * eclipse/overview.rst (modified) * eclipse/rtems.rst (modified) * eng/appendix-a.rst (modified) * eng/change-management.rst (modified) * eng/change-reports.rst (modified) * eng/coding-80cols.rst (modified) * eng/coding-conventions.rst (modified) * eng/coding-deprecating.rst (modified) * eng/coding-doxygen-bsp.rst (modified) * eng/coding-doxygen.rst (modified) * eng/coding-file-hdr.rst (modified) * eng/coding-gen-patch.rst (modified) * eng/coding-naming.rst (modified) * eng/coding.rst (modified) * eng/index.rst (modified) * eng/issue-tracking.rst (modified) * eng/license-requirements.rst (modified) * eng/management.rst (modified) * eng/preface.rst (modified) * eng/prequalification.rst (modified) * eng/release-mgmt.rst (modified) * eng/stakeholders.rst (modified) * eng/test-plan.rst (modified) * eng/test-suites.rst (modified) * eng/tester.rst (modified) * eng/users-manuals.rst (modified) * eng/vc-authors.rst (modified) * eng/vc-users.rst (modified) * eng/vdd-generation.rst (modified) * eng/why-contribute.rst (modified) * filesystem/call_development.rst (modified) * filesystem/command_and_variable.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/index.rst (modified) * filesystem/minature_in-memory.rst (modified) * filesystem/mounting_and_unmounting.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/preface.rst (modified) * filesystem/system_init.rst (modified) * filesystem/trivial_ftp.rst (modified) * networking/command.rst (modified) * networking/dec_21140.rst (modified) * networking/index.rst (modified) * networking/network_servers.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) * porting/code_tuning.rst (modified) * porting/command.rst (modified) * porting/cpu_init.rst (modified) * porting/cpu_model_variations.rst (modified) * porting/development_tools.rst (modified) * porting/idle_thread.rst (modified) * porting/index.rst (modified) * porting/interrupts.rst (modified) * porting/miscellanous.rst (modified) * porting/preface.rst (modified) * porting/priority_bitmap.rst (modified) * porting/source_code_org.rst (modified) * porting/task_context.rst (modified) * posix-compliance/glossary.rst (modified) * posix-compliance/index.rst (modified) * posix-compliance/preface.rst (modified) * posix-compliance/standards.rst (modified) * posix-users/clock.rst (modified) * posix-users/command.rst (modified) * posix-users/condition_variable.rst (modified) * posix-users/devctl.rst (modified) * posix-users/device_and_class_specific.rst (modified) * posix-users/files_and_directory.rst (modified) * posix-users/index.rst (modified) * posix-users/input_and_output.rst (modified) * posix-users/key.rst (modified) * posix-users/language_specific_services.rst (modified) * posix-users/memory_managment.rst (modified) * posix-users/message_passing.rst (modified) * posix-users/mutex.rst (modified) * posix-users/preface.rst (modified) * posix-users/process_creation_and_execution.rst (modified) * posix-users/process_environment.rst (modified) * posix-users/scheduler.rst (modified) * posix-users/semaphore.rst (modified) * posix-users/services_provided_by_c.rst (modified) * posix-users/services_provided_by_math.rst (modified) * posix-users/signal.rst (modified) * posix-users/status_of_implementation.rst (modified) * posix-users/system_database.rst (modified) * posix-users/thread.rst (modified) * posix-users/thread_cancellation.rst (modified) * posix-users/timer.rst (modified) * rsb/bug-reporting.rst (modified) * rsb/building-tools-and-rtems.rst (modified) * rsb/commands.rst (modified) * rsb/configuration.rst (modified) * rsb/cross-canadian-cross.rst (modified) * rsb/index.rst (modified) * rsb/project-sets.rst (modified) * rsb/source-builder.rst (modified) * rsb/third-party-packages.rst (modified) * rtemsconfig/index.rst (modified) * rtemsconfig/option.rst (modified) * rtemsconfig/rtemsconfig.rst (modified) * shell/concept.rst (modified) * shell/configuration_and_init.rst (modified) * shell/file_and_directory.rst (modified) * shell/function_and_variable.rst (modified) * shell/general_commands.rst (modified) * shell/index.rst (modified) * shell/memory_commands.rst (modified) * shell/network_commands.rst (modified) * shell/preface.rst (modified) * shell/rtems_specific_commands.rst (modified) * user/apps/index.rst (modified) * user/bsp/index.rst (modified) * user/bsps/bsps-aarch64.rst (modified) * user/bsps/bsps-arm.rst (modified) * user/bsps/bsps-bfin.rst (modified) * user/bsps/bsps-epiphany.rst (modified) * user/bsps/bsps-i386.rst (modified) * user/bsps/bsps-lm32.rst (modified) * user/bsps/bsps-m68k.rst (modified) * user/bsps/bsps-microblaze.rst (modified) * user/bsps/bsps-mips.rst (modified) * user/bsps/bsps-moxie.rst (modified) * user/bsps/bsps-nios2.rst (modified) * user/bsps/bsps-or1k.rst (modified) * user/bsps/bsps-powerpc.rst (modified) * user/bsps/bsps-riscv.rst (modified) * user/bsps/bsps-sh.rst (modified) * user/bsps/bsps-sparc.rst (modified) * user/bsps/bsps-sparc64.rst (modified) * user/bsps/bsps-v850.rst (modified) * user/bsps/bsps-x86_64.rst (modified) * user/bsps/index.rst (modified) * user/ecosys/index.rst (modified) * user/exe/debugging.rst (modified) * user/exe/executables.rst (modified) * user/exe/execution.rst (modified) * user/exe/index.rst (modified) * user/exe/initialization.rst (modified) * user/glossary/index.rst (modified) * user/hardware/architectures.rst (modified) * user/hardware/bsps.rst (modified) * user/hardware/index.rst (modified) * user/hardware/targets.rst (modified) * user/hardware/tiers.rst (modified) * user/hosts/index.rst (modified) * user/hosts/macos.rst (modified) * user/hosts/os.rst (modified) * user/hosts/posix.rst (modified) * user/hosts/windows.rst (modified) * user/index.rst (modified) * user/installation/developer.rst (modified) * user/installation/index.rst (modified) * user/installation/kernel.rst (modified) * user/installation/prefixes-sandboxing.rst (modified) * user/installation/releases.rst (modified) * user/overview/index.rst (modified) * user/start/index.rst (modified) * user/support/index.rst (modified) * user/testing/configuration.rst (modified) * user/testing/consoles.rst (modified) * user/testing/gdb-jtag.rst (modified) * user/testing/index.rst (modified) * user/testing/simulation.rst (modified) * user/testing/tests.rst (modified) * user/testing/tftp.rst (modified) * user/tools/bsp-builder.rst (modified) * user/tools/exeinfo.rst (modified) * user/tools/index.rst (modified) * user/tools/linker.rst (modified) * user/tools/symbols.rst (modified) * user/tools/tester.rst (modified) * user/tracing/captureengine.rst (modified) * user/tracing/examples.rst (modified) * user/tracing/index.rst (modified) * user/tracing/introduction.rst (modified) * user/tracing/tracelinker.rst (modified) Simplify SPDX-License-Identifier comment Wed, 09 Jan 2019 15:14:05 GMT Sebastian Huber [12dccfe] * bsp-howto/ada95_interrupt.rst (modified) * bsp-howto/ata.rst (modified) * bsp-howto/clock.rst (modified) * bsp-howto/console.rst (modified) * bsp-howto/frame_buffer.rst (modified) * bsp-howto/getentropy.rst (modified) * bsp-howto/i2c.rst (modified) * bsp-howto/ide_controller.rst (modified) * bsp-howto/initilization_code.rst (modified) * bsp-howto/linker_script.rst (modified) * bsp-howto/miscellanous_support.rst (modified) * bsp-howto/networking.rst (modified) * bsp-howto/preface.rst (modified) * bsp-howto/real_time_clock.rst (modified) * bsp-howto/shared_memory_support.rst (modified) * bsp-howto/spi.rst (modified) * bsp-howto/target_dependant_files.rst (modified) * bsp-howto/timer.rst (modified) * c-user/ada_support.rst (modified) * c-user/barrier_manager.rst (modified) * c-user/board_support_packages.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/example_application.rst (modified) * c-user/fatal_error.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/key_concepts.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/overview.rst (modified) * c-user/partition_manager.rst (modified) * c-user/pci_library.rst (modified) * c-user/preface.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/red_black_trees.rst (modified) * c-user/region_manager.rst (modified) * c-user/rtems_data_types.rst (modified) * c-user/scheduling_concepts.rst (modified) * c-user/self_contained_objects.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/stack_bounds_checker.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) * cpu-supplement/altera_nios_ii.rst (modified) * cpu-supplement/arm.rst (modified) * cpu-supplement/atmel_avr.rst (modified) * cpu-supplement/ephiphany.rst (modified) * cpu-supplement/intel_amd_x86.rst (modified) * cpu-supplement/lattice_micro32.rst (modified) * cpu-supplement/m68xxx_and_coldfire.rst (modified) * cpu-supplement/mips.rst (modified) * cpu-supplement/openrisc_1000.rst (modified) * cpu-supplement/port.rst (modified) * cpu-supplement/powerpc.rst (modified) * cpu-supplement/preface.rst (modified) * cpu-supplement/renesas_m32c.rst (modified) * cpu-supplement/riscv.rst (modified) * cpu-supplement/sparc.rst (modified) * cpu-supplement/sparc64.rst (modified) * cpu-supplement/superh.rst (modified) * cpu-supplement/xilinx_microblaze.rst (modified) * develenv/directory.rst (modified) * develenv/introduction.rst (modified) * eclipse/index.rst (modified) * eclipse/overview.rst (modified) * eclipse/rtems.rst (modified) * filesystem/call_development.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/minature_in-memory.rst (modified) * filesystem/mounting_and_unmounting.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/preface.rst (modified) * filesystem/system_init.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) * porting/code_tuning.rst (modified) * porting/cpu_init.rst (modified) * porting/cpu_model_variations.rst (modified) * porting/development_tools.rst (modified) * porting/idle_thread.rst (modified) * porting/interrupts.rst (modified) * porting/preface.rst (modified) * porting/priority_bitmap.rst (modified) * porting/source_code_org.rst (modified) * porting/task_context.rst (modified) * posix-compliance/preface.rst (modified) * posix-users/condition_variable.rst (modified) * posix-users/devctl.rst (modified) * posix-users/device_and_class_specific.rst (modified) * posix-users/files_and_directory.rst (modified) * posix-users/input_and_output.rst (modified) * posix-users/key.rst (modified) * posix-users/language_specific_services.rst (modified) * posix-users/memory_managment.rst (modified) * posix-users/message_passing.rst (modified) * posix-users/mutex.rst (modified) * posix-users/preface.rst (modified) * posix-users/process_creation_and_execution.rst (modified) * posix-users/process_environment.rst (modified) * posix-users/scheduler.rst (modified) * posix-users/semaphore.rst (modified) * posix-users/services_provided_by_c.rst (modified) * posix-users/services_provided_by_math.rst (modified) * posix-users/signal.rst (modified) * posix-users/system_database.rst (modified) * posix-users/thread.rst (modified) * posix-users/thread_cancellation.rst (modified) * posix-users/timer.rst (modified) * shell/concept.rst (modified) * shell/configuration_and_init.rst (modified) * shell/file_and_directory.rst (modified) * shell/function_and_variable.rst (modified) * shell/general_commands.rst (modified) * shell/index.rst (modified) * shell/memory_commands.rst (modified) * shell/network_commands.rst (modified) * shell/preface.rst (modified) * shell/rtems_specific_commands.rst (modified) * user/apps/index.rst (modified) * user/bsps/index.rst (modified) * user/ecosys/index.rst (modified) * user/exe/debugging.rst (modified) * user/exe/executables.rst (modified) * user/exe/execution.rst (modified) * user/exe/index.rst (modified) * user/exe/initialization.rst (modified) * user/hardware/architectures.rst (modified) * user/hardware/bsps.rst (modified) * user/hardware/index.rst (modified) * user/hardware/targets.rst (modified) * user/hardware/tiers.rst (modified) * user/hosts/index.rst (modified) * user/hosts/macos.rst (modified) * user/hosts/os.rst (modified) * user/hosts/posix.rst (modified) * user/hosts/windows.rst (modified) * user/installation/developer.rst (modified) * user/installation/index.rst (modified) * user/installation/kernel.rst (modified) * user/installation/prefixes-sandboxing.rst (modified) * user/installation/releases.rst (modified) * user/start/index.rst (modified) * user/testing/configuration.rst (modified) * user/testing/consoles.rst (modified) * user/testing/gdb-jtag.rst (modified) * user/testing/index.rst (modified) * user/testing/simulation.rst (modified) * user/testing/tests.rst (modified) * user/testing/tftp.rst (modified) * user/tools/bsp-builder.rst (modified) * user/tools/exeinfo.rst (modified) * user/tools/index.rst (modified) * user/tools/linker.rst (modified) * user/tools/symbols.rst (modified) * user/tools/tester.rst (modified) * user/tracing/captureengine.rst (modified) * user/tracing/examples.rst (modified) * user/tracing/index.rst (modified) * user/tracing/introduction.rst (modified) * user/tracing/tracelinker.rst (modified) Remove superfluous "All rights reserved." Wed, 09 Jan 2019 15:14:04 GMT Sebastian Huber [4886d60] * bsp-howto/ada95_interrupt.rst (modified) * bsp-howto/ata.rst (modified) * bsp-howto/clock.rst (modified) * bsp-howto/console.rst (modified) * bsp-howto/frame_buffer.rst (modified) * bsp-howto/getentropy.rst (modified) * bsp-howto/i2c.rst (modified) * bsp-howto/ide_controller.rst (modified) * bsp-howto/initilization_code.rst (modified) * bsp-howto/linker_script.rst (modified) * bsp-howto/miscellanous_support.rst (modified) * bsp-howto/networking.rst (modified) * bsp-howto/preface.rst (modified) * bsp-howto/real_time_clock.rst (modified) * bsp-howto/shared_memory_support.rst (modified) * bsp-howto/spi.rst (modified) * bsp-howto/target_dependant_files.rst (modified) * bsp-howto/timer.rst (modified) * c-user/ada_support.rst (modified) * c-user/barrier_manager.rst (modified) * c-user/board_support_packages.rst (modified) * c-user/chains.rst (modified) * c-user/clock_manager.rst (modified) * c-user/configuring_a_system.rst (modified) * c-user/constant_bandwidth_server.rst (modified) * c-user/cpu_usage_statistics.rst (modified) * c-user/directive_status_codes.rst (modified) * c-user/dual_ports_memory_manager.rst (modified) * c-user/event_manager.rst (modified) * c-user/example_application.rst (modified) * c-user/fatal_error.rst (modified) * c-user/initialization.rst (modified) * c-user/interrupt_manager.rst (modified) * c-user/io_manager.rst (modified) * c-user/key_concepts.rst (modified) * c-user/linker_sets.rst (modified) * c-user/message_manager.rst (modified) * c-user/multiprocessing.rst (modified) * c-user/object_services.rst (modified) * c-user/overview.rst (modified) * c-user/partition_manager.rst (modified) * c-user/pci_library.rst (modified) * c-user/preface.rst (modified) * c-user/rate_monotonic_manager.rst (modified) * c-user/red_black_trees.rst (modified) * c-user/region_manager.rst (modified) * c-user/rtems_data_types.rst (modified) * c-user/scheduling_concepts.rst (modified) * c-user/self_contained_objects.rst (modified) * c-user/semaphore_manager.rst (modified) * c-user/signal_manager.rst (modified) * c-user/stack_bounds_checker.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) * c-user/task_manager.rst (modified) * c-user/timer_manager.rst (modified) * c-user/timespec_helpers.rst (modified) * c-user/user_extensions.rst (modified) * cpu-supplement/altera_nios_ii.rst (modified) * cpu-supplement/arm.rst (modified) * cpu-supplement/atmel_avr.rst (modified) * cpu-supplement/blackfin.rst (modified) * cpu-supplement/ephiphany.rst (modified) * cpu-supplement/intel_amd_x86.rst (modified) * cpu-supplement/lattice_micro32.rst (modified) * cpu-supplement/m68xxx_and_coldfire.rst (modified) * cpu-supplement/mips.rst (modified) * cpu-supplement/openrisc_1000.rst (modified) * cpu-supplement/port.rst (modified) * cpu-supplement/powerpc.rst (modified) * cpu-supplement/preface.rst (modified) * cpu-supplement/renesas_m32c.rst (modified) * cpu-supplement/riscv.rst (modified) * cpu-supplement/sparc.rst (modified) * cpu-supplement/sparc64.rst (modified) * cpu-supplement/superh.rst (modified) * cpu-supplement/xilinx_microblaze.rst (modified) * develenv/directory.rst (modified) * develenv/introduction.rst (modified) * eclipse/index.rst (modified) * eclipse/overview.rst (modified) * eclipse/rtems.rst (modified) * eng/appendix-a.rst (modified) * eng/change-management.rst (modified) * eng/change-reports.rst (modified) * eng/coding-80cols.rst (modified) * eng/coding-conventions.rst (modified) * eng/coding-deprecating.rst (modified) * eng/coding-doxygen-bsp.rst (modified) * eng/coding-doxygen.rst (modified) * eng/coding-file-hdr.rst (modified) * eng/coding-gen-patch.rst (modified) * eng/coding-naming.rst (modified) * eng/coding.rst (modified) * eng/index.rst (modified) * eng/issue-tracking.rst (modified) * eng/license-requirements.rst (modified) * eng/management.rst (modified) * eng/preface.rst (modified) * eng/prequalification.rst (modified) * eng/release-mgmt.rst (modified) * eng/stakeholders.rst (modified) * eng/test-plan.rst (modified) * eng/test-suites.rst (modified) * eng/tester.rst (modified) * eng/users-manuals.rst (modified) * eng/vc-authors.rst (modified) * eng/vc-users.rst (modified) * eng/vdd-generation.rst (modified) * eng/why-contribute.rst (modified) * filesystem/call_development.rst (modified) * filesystem/fileystem_implmentation.rst (modified) * filesystem/in-memory.rst (modified) * filesystem/minature_in-memory.rst (modified) * filesystem/mounting_and_unmounting.rst (modified) * filesystem/pathname_eval.rst (modified) * filesystem/preface.rst (modified) * filesystem/system_init.rst (modified) * networking/network_task_structure.rst (modified) * networking/networking_driver.rst (modified) * networking/preface.rst (modified) * networking/testing_the_driver.rst (modified) * networking/using_networking_rtems_app.rst (modified) * porting/code_tuning.rst (modified) * porting/cpu_init.rst (modified) * porting/cpu_model_variations.rst (modified) * porting/development_tools.rst (modified) * porting/idle_thread.rst (modified) * porting/interrupts.rst (modified) * porting/preface.rst (modified) * porting/priority_bitmap.rst (modified) * porting/source_code_org.rst (modified) * porting/task_context.rst (modified) * posix-compliance/preface.rst (modified) * posix-compliance/standards.rst (modified) * posix-users/condition_variable.rst (modified) * posix-users/devctl.rst (modified) * posix-users/device_and_class_specific.rst (modified) * posix-users/files_and_directory.rst (modified) * posix-users/input_and_output.rst (modified) * posix-users/key.rst (modified) * posix-users/language_specific_services.rst (modified) * posix-users/memory_managment.rst (modified) * posix-users/message_passing.rst (modified) * posix-users/mutex.rst (modified) * posix-users/preface.rst (modified) * posix-users/process_creation_and_execution.rst (modified) * posix-users/process_environment.rst (modified) * posix-users/scheduler.rst (modified) * posix-users/semaphore.rst (modified) * posix-users/services_provided_by_c.rst (modified) * posix-users/services_provided_by_math.rst (modified) * posix-users/signal.rst (modified) * posix-users/system_database.rst (modified) * posix-users/thread.rst (modified) * posix-users/thread_cancellation.rst (modified) * posix-users/timer.rst (modified) * rsb/bug-reporting.rst (modified) * rsb/building-tools-and-rtems.rst (modified) * rsb/commands.rst (modified) * rsb/configuration.rst (modified) * rsb/cross-canadian-cross.rst (modified) * rsb/project-sets.rst (modified) * rsb/source-builder.rst (modified) * rsb/third-party-packages.rst (modified) * shell/concept.rst (modified) * shell/configuration_and_init.rst (modified) * shell/file_and_directory.rst (modified) * shell/function_and_variable.rst (modified) * shell/general_commands.rst (modified) * shell/index.rst (modified) * shell/memory_commands.rst (modified) * shell/network_commands.rst (modified) * shell/preface.rst (modified) * shell/rtems_specific_commands.rst (modified) * user/apps/index.rst (modified) * user/bsps/bsps-aarch64.rst (modified) * user/bsps/bsps-arm.rst (modified) * user/bsps/bsps-bfin.rst (modified) * user/bsps/bsps-epiphany.rst (modified) * user/bsps/bsps-i386.rst (modified) * user/bsps/bsps-lm32.rst (modified) * user/bsps/bsps-m68k.rst (modified) * user/bsps/bsps-microblaze.rst (modified) * user/bsps/bsps-mips.rst (modified) * user/bsps/bsps-moxie.rst (modified) * user/bsps/bsps-nios2.rst (modified) * user/bsps/bsps-or1k.rst (modified) * user/bsps/bsps-powerpc.rst (modified) * user/bsps/bsps-riscv.rst (modified) * user/bsps/bsps-sh.rst (modified) * user/bsps/bsps-sparc.rst (modified) * user/bsps/bsps-sparc64.rst (modified) * user/bsps/bsps-v850.rst (modified) * user/bsps/bsps-x86_64.rst (modified) * user/bsps/index.rst (modified) * user/ecosys/index.rst (modified) * user/exe/debugging.rst (modified) * user/exe/executables.rst (modified) * user/exe/execution.rst (modified) * user/exe/index.rst (modified) * user/exe/initialization.rst (modified) * user/hardware/architectures.rst (modified) * user/hardware/bsps.rst (modified) * user/hardware/index.rst (modified) * user/hardware/targets.rst (modified) * user/hardware/tiers.rst (modified) * user/hosts/index.rst (modified) * user/hosts/macos.rst (modified) * user/hosts/os.rst (modified) * user/hosts/posix.rst (modified) * user/hosts/windows.rst (modified) * user/installation/developer.rst (modified) * user/installation/index.rst (modified) * user/installation/kernel.rst (modified) * user/installation/prefixes-sandboxing.rst (modified) * user/installation/releases.rst (modified) * user/start/index.rst (modified) * user/testing/configuration.rst (modified) * user/testing/consoles.rst (modified) * user/testing/gdb-jtag.rst (modified) * user/testing/index.rst (modified) * user/testing/simulation.rst (modified) * user/testing/tests.rst (modified) * user/testing/tftp.rst (modified) * user/tools/bsp-builder.rst (modified) * user/tools/exeinfo.rst (modified) * user/tools/index.rst (modified) * user/tools/linker.rst (modified) * user/tools/symbols.rst (modified) * user/tools/tester.rst (modified) * user/tracing/captureengine.rst (modified) * user/tracing/examples.rst (modified) * user/tracing/index.rst (modified) * user/tracing/introduction.rst (modified) * user/tracing/tracelinker.rst (modified) Use standard format for copyright lines Wed, 09 Jan 2019 12:58:14 GMT Sebastian Huber [05d066a] * user/bsps/bsps-arm.rst (modified) * user/bsps/bsps-bfin.rst (modified) * user/bsps/bsps-epiphany.rst (modified) * user/bsps/bsps-i386.rst (modified) * user/bsps/bsps-lm32.rst (modified) * user/bsps/bsps-m68k.rst (modified) * user/bsps/bsps-mips.rst (modified) * user/bsps/bsps-moxie.rst (modified) * user/bsps/bsps-nios2.rst (modified) * user/bsps/bsps-or1k.rst (modified) * user/bsps/bsps-powerpc.rst (modified) * user/bsps/bsps-riscv.rst (modified) * user/bsps/bsps-sh.rst (modified) * user/bsps/bsps-sparc.rst (modified) * user/bsps/bsps-sparc64.rst (modified) * user/bsps/bsps-v850.rst (modified) user: Add TODO entries for all BSP families Update #3464. Wed, 09 Jan 2019 10:48:12 GMT Sebastian Huber [3177018] * rsb/index.rst (modified) rsb: Fix chapter layout Mon, 07 Jan 2019 06:46:08 GMT Sebastian Huber [52f4890] * user/glossary/index.rst (modified) * user/overview/index.rst (modified) * user/start/index.rst (modified) user: Rework overview Move "Overview", "Real-time Applicaiton ... Mon, 07 Jan 2019 06:45:30 GMT Sebastian Huber [65f54a9] * common/header.rst (modified) Update header.rst Remove trailing slashes in URLs. Fix bug ... Fri, 04 Jan 2019 11:01:41 GMT Sebastian Huber [50fbe0d] * bsp-howto/index.rst (modified) * c-user/index.rst (modified) * common/header.rst (added) * cpu-supplement/index.rst (modified) * develenv/index.rst (modified) * eclipse/index.rst (modified) * eng/index.rst (modified) * filesystem/index.rst (modified) * networking/index.rst (modified) * porting/index.rst (modified) * posix-compliance/index.rst (modified) * posix-users/index.rst (modified) * rsb/index.rst (modified) * shell/index.rst (modified) * user/index.rst (modified) Add common header.rst to reduce copy and paste Fri, 04 Jan 2019 10:18:57 GMT Sebastian Huber [5631d58] * common/rtemsstyle.sty (modified) Remove superfluous word "Copyright" The © symbol is sufficient. Fri, 04 Jan 2019 10:09:23 GMT Sebastian Huber [cd408b5] * common/conf.py (modified) Update general copyright notice Update year and add "and contributors". Fri, 04 Jan 2019 10:02:45 GMT Sebastian Huber [3202e31] * common/conf.py (modified) * common/waf.py (modified) * wscript (modified) Replace build date with Git hash and commit date The usage of a ... Mon, 07 Jan 2019 06:45:05 GMT Sebastian Huber [c1d296a] * cpu-supplement/arm.rst (modified) cpu-supplement: Update ARM multilibs Fri, 04 Jan 2019 09:59:12 GMT Frédéric Jouault [4de0da1] * c-user/message_manager.rst (modified) * c-user/rtems_data_types.rst (modified) c-user: Fix typos Close #3261. Thu, 20 Dec 2018 15:19:05 GMT Joel Sherrill [e4087f0] * cpu-supplement/sparc_v8_stacks_regwin.rst (modified) sparc_v8_stacks_regwin.rst: Add middle initail for Peter Magnusson ... Thu, 20 Dec 2018 15:17:09 GMT Joel Sherrill [6682434] * eng/appendix-a.rst (modified) * eng/license-requirements.rst (modified) * eng/prequalification.rst (modified) * eng/test-plan.rst (modified) * eng/users-manuals.rst (modified) * eng/vc-authors.rst (modified) * eng/vc-users.rst (modified) * user/tracing/examples.rst (modified) * user/tracing/introduction.rst (modified) Eliminate UTF-8 characters except superscripted 2 in i2c Thu, 20 Dec 2018 07:19:05 GMT Sebastian Huber [e24c5e9] * eng/vc-users.rst (modified) eng: Unicode char (U+200B) Tue, 18 Dec 2018 17:45:00 GMT Christian Mauderer [a7dc083] * common/waf.py (modified) common/waf.py: Fix indentation. Python 3 produces an error if ... Sun, 09 Dec 2018 15:50:04 GMT Pritish Jain [75f2463] * eng/coding-conventions.rst (modified) eng/coding-conventions.rst: Convert TBD to Rest Format (GCI 2018) Wed, 05 Dec 2018 14:43:00 GMT Marçal Comajoan Cara [cc826d7] * eng/coding-doxygen.rst (modified) eng/coding-doxygen: Fix errors This work was part of GCI 2018. Tue, 04 Dec 2018 19:29:43 GMT Sal [b8b4f14] * eng/coding-file-hdr.rst (modified) eng/coding-file-hdr.rst: Fix file formatting (GCI 2018) Tue, 04 Dec 2018 19:21:54 GMT Joel Sherrill [f5c20a6] * eng/coding-doxygen.rst (modified) eng/coding-doxygen.rst: Clean up and make subsubsections Mon, 03 Dec 2018 09:40:15 GMT zehata [cd6ac10] * eng/coding-doxygen.rst (modified) Converted Doxygen Best Practices Documentation to Rest format (GCI 2018) Mon, 03 Dec 2018 23:40:47 GMT Pritish Jain [edde29e] * eng/coding-naming.rst (modified) coding-naming: Convert TBD to Rest format (GCI 2018) Mon, 03 Dec 2018 18:38:13 GMT Marçal Comajoan Cara [eb34b90] * images/eng/Git-personalrepo.png (modified) * images/eng/Git-personalrepo.svg (added) images/eng/Git-personalrepo: Redrawn image (GCI 2018) Redraw ... Mon, 03 Dec 2018 17:01:40 GMT Marçal Comajoan Cara [7e91a8f] * eng/vc-users.rst (modified) eng/vc-users: Convert wiki page to Rest (GCI 2018) Converted ... Mon, 03 Dec 2018 05:33:31 GMT Marçal Comajoan Cara [f4782c9] * eng/vc-authors.rst (modified) * images/eng/Git-personalrepo.png (added) eng/vc-authors: Convert wiki page to Rest (GCI 2018) Converted ... Sun, 02 Dec 2018 21:13:01 GMT Pritiah Jain [32a4a0a] * eng/management.rst (modified) * eng/why-contribute.rst (added) management: Convert TBD to rest Format (GCI 2018) Sun, 02 Dec 2018 23:02:40 GMT Marçal Comajoan Cara [4ff3787] * eng/conf.py (modified) eng/conf.py: Use new short name of SW Eng Handbook Sun, 02 Dec 2018 17:35:41 GMT Joel Sherrill [ccbaea6] * eng/license-requirements.rst (modified) eng/license-requirements.rst: Add a TBD for BSD info Sun, 02 Dec 2018 17:29:33 GMT Joel Sherrill [9c75517] * eng/coding-doxygen-bsp.rst (modified) * eng/coding-file-hdr.rst (modified) coding-doxygen-bsp.rst, coding-file-hdr.rst: Fix formatting Sat, 01 Dec 2018 20:16:35 GMT Pritish Jain [e55248d] * eng/coding-file-hdr.rst (modified) coding-file-hdr: Convert TBD to Rest Format (GCI 2018) Sun, 02 Dec 2018 08:44:29 GMT Pritish Jain [0184167] * eng/coding-doxygen-bsp.rst (modified) coding-doxygen-bsp: Convert TBD to rest Format(GCI 2018) Sat, 01 Dec 2018 09:27:48 GMT Pritish Jain [65476b4] * eng/coding-gen-patch.rst (modified) coding-gen-patch:Convert TBD to rest Format(GCI 2018) Sat, 01 Dec 2018 17:11:15 GMT Marçal Comajoan Cara [8059b68] * eng/coding-80cols.rst (modified) eng/coding-80cols: Convert wiki page to Rest Converted ... Sat, 01 Dec 2018 14:17:11 GMT Marçal Comajoan Cara [49453ec] * eng/appendix-a.rst (modified) eng/appendix-a: convert to a table Convert text to a table, TBDs ...
