# # ChangeLog for / in rtems-docs # # Generated by Trac 1.2.1.dev0 # 06/17/24 05:33:10 Fri, 28 Jan 2022 13:58:01 GMT Sebastian Huber [fff7d6a] * eng/release-process.rst (modified) eng: Fix indentation Fri, 28 Jan 2022 13:35:37 GMT Sebastian Huber [2924bf7] * eng/release-process.rst (modified) eng: Update version number handling Mon, 24 Jan 2022 22:35:10 GMT Joel Sherrill [7073017] * user/hosts/posix.rst (modified) user/hosts/posix.rst: Replace Cent)S with CentOS Fri, 21 Jan 2022 16:02:27 GMT Sebastian Huber [dd60a4a] * eng/req/howto.rst (modified) eng: Add script usage to how-to Update #3715. Tue, 11 Jan 2022 16:00:49 GMT Sebastian Huber [1ba0f41] * eng/req/items.rst (modified) eng: Document get-string-command-line action Update #4548. Tue, 11 Jan 2022 15:54:01 GMT Sebastian Huber [9fecafa] * eng/req/items.rst (modified) eng: Add runtime performance kinds Tue, 11 Jan 2022 15:51:16 GMT Sebastian Huber [fa1c18e] * eng/req/items.rst (modified) eng: Document get-string-command-line action Close #4548. Tue, 11 Jan 2022 15:50:41 GMT Sebastian Huber [ffcf9dc] * eng/req/items.rst (modified) eng: Fix action requirement patterns Tue, 21 Dec 2021 15:58:56 GMT Sebastian Huber [162925e] * c-user/clock/background.rst (modified) c-user: Use document internal links Tue, 21 Dec 2021 15:50:40 GMT Sebastian Huber [e77e04d] * c-user/clock/background.rst (modified) c-user: Clarify Clock Manager dependencies Update #4572. Tue, 04 Jan 2022 15:57:01 GMT Kinsey Moore [7be2da1] * cpu-supplement/index.rst (modified) cpu-supplement: Add aarch64 to index This was never updated when ... Fri, 17 Dec 2021 21:26:53 GMT Ryan Long [4e22dfe] * user/hosts/posix.rst (modified) Update package list for Ubuntu Updated the latest version ... Thu, 16 Dec 2021 07:20:27 GMT Sebastian Huber [786b89a] * c-user/clock/background.rst (modified) c-user: Clarify time formats Update #4572. Thu, 16 Dec 2021 06:43:20 GMT Sebastian Huber [732d8bc] * c-user/clock/directives.rst (modified) c-user: Fix Clock Manager parameter descriptions Update #4572. Fri, 26 Nov 2021 13:42:03 GMT Sebastian Huber [835ece1] * cpu-supplement/sparc.rst (modified) cpu-supplement: Update trap handling for SPARC Close #4459. Fri, 26 Nov 2021 12:10:05 GMT Sebastian Huber [87d1f4d] * cpu-supplement/sparc.rst (modified) cpu-supplement: Use ``REG`` for SPARC registers Update #4459. Fri, 26 Nov 2021 12:35:49 GMT Sebastian Huber [8731bd6] * cpu-supplement/sparc.rst (modified) cpu-supplement: Update URL Tue, 23 Nov 2021 14:20:06 GMT Sebastian Huber [838b78a] * c-user/clock/directives.rst (modified) * c-user/clock/introduction.rst (modified) c-user: Replace "precision" with "resolution" Resolution is the ... Tue, 16 Nov 2021 08:14:35 GMT Sebastian Huber [513b90d] * c-user/scheduling-concepts/directives.rst (modified) c-user: rtems_scheduler_remove_processor() Update error status ... Mon, 11 Oct 2021 15:05:21 GMT Sebastian Huber [38ec48d] * c-user/clock/directives.rst (modified) * c-user/clock/introduction.rst (modified) c-user: Document new clock manager directives Add new clock manager ... Fri, 19 Nov 2021 07:45:55 GMT Sebastian Huber [61410da] * c-user/task/directives.rst (modified) c-user: Use RTEMS_WHO_AM_I for rtems_task_ident() Tue, 16 Nov 2021 07:17:31 GMT Sebastian Huber [1c8ce33] * c-user/config/bdbuf.rst (modified) * c-user/config/bsp-related.rst (modified) * c-user/config/classic-api.rst (modified) * c-user/config/classic-init-task.rst (modified) * c-user/config/device-driver.rst (modified) * c-user/config/event-record.rst (modified) * c-user/config/filesystem.rst (modified) * c-user/config/general.rst (modified) * c-user/config/idle-task.rst (modified) * c-user/config/mpci.rst (modified) * c-user/config/posix-api.rst (modified) * c-user/config/posix-init-thread.rst (modified) * c-user/config/scheduler-general.rst (modified) * c-user/config/task-stack-alloc.rst (modified) c-user: Use rubric for configuration options Clear the page for ... Tue, 16 Nov 2021 07:00:03 GMT Sebastian Huber [1badb5f] * c-user/config/posix-api.rst (modified) c-user: CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS Fix default value ... Fri, 12 Nov 2021 03:28:57 GMT Amar Takhar [fa25208] * common/coverpage/static/js/jquery.min.js (modified) Update jQuery from 1.12.4 to 3.6.0. Identified by security scans. Mon, 01 Nov 2021 19:40:55 GMT Kinsey Moore [a0bf79c] * c-user/config/device-driver.rst (modified) c-user: Update for application CONFIGURE option This adds the ... Mon, 01 Nov 2021 18:52:52 GMT Kinsey Moore [ac8f461] * cpu-supplement/aarch64.rst (modified) cpu-supplement: Update AArch64 SMP details AArch64 now supports SMP ... Mon, 25 Oct 2021 06:09:00 GMT Sebastian Huber [feb4687] * c-user/rate-monotonic/directives.rst (modified) c-user: rtems_rate_monotonic_get_status() Mention that resetting ... Tue, 19 Oct 2021 14:42:04 GMT Sebastian Huber [46dbb6d] * c-user/config/task-stack-alloc.rst (modified) c-user: Regenerate for IDLE task allocator option Update #4524. Tue, 12 Oct 2021 18:46:11 GMT Joel Sherrill [df5be4c] * c-user/config/task-stack-alloc.rst (modified) task-stack-alloc.rst: Add CONFIGURE_TASK_STACK_FROM_ALLOCATOR ... Wed, 29 Sep 2021 10:45:40 GMT Sebastian Huber [887b8d3] * c-user/glossary.rst (modified) glossary: Add terms Fri, 24 Sep 2021 12:49:43 GMT Sebastian Huber [0ca7adf] * c-user/glossary.rst (modified) glossary: Add OMIP Tue, 21 Sep 2021 16:56:44 GMT Ryan Long [13092ff] * user/hosts/posix.rst (modified) posix.rst: Add info for FreeBSD 13 Add list of additional packages ... Tue, 21 Sep 2021 09:36:17 GMT Chris Johns [7b289f6] * user/testing/configuration.rst (modified) * user/testing/tftp.rst (modified) user/testing: Add the %wait directive Wed, 15 Sep 2021 09:55:52 GMT Sebastian Huber [7afc7a0] * c-user/message/directives.rst (modified) rtems: Fix message manager documentation Correct the description of ... Wed, 15 Sep 2021 15:44:55 GMT Sebastian Huber [28188d4] * c-user/glossary.rst (modified) c-user: Fix use of lower and higher priority Tue, 14 Sep 2021 17:18:31 GMT Sebastian Huber [5fdc744] * c-user/scheduling-concepts/background.rst (modified) * c-user/scheduling-concepts/smp-schedulers.rst (modified) * c-user/task/background.rst (modified) c-user: Clarify task priorities Tue, 14 Sep 2021 13:58:36 GMT Sebastian Huber [c81e148] * c-user/glossary.rst (modified) c-user: Define lower and higher priority Tue, 14 Sep 2021 15:48:35 GMT Sebastian Huber [6198c49] * c-user/message/directives.rst (modified) c-user: Fix message manager documentation Remove bogus return ... Tue, 14 Sep 2021 06:15:25 GMT Sebastian Huber [0bc62ee] * c-user/user-extensions/directives.rst (modified) c-user: Clarify rtems_extension_create() Fri, 10 Sep 2021 08:36:44 GMT Sebastian Huber [023f609] * c-user/cache/directives.rst (added) * c-user/cache/index.rst (added) * c-user/cache/introduction.rst (added) * c-user/index.rst (modified) c-user: Add "Cache Manager" chapter The Cache Manager directives ... Mon, 13 Sep 2021 06:27:45 GMT Sebastian Huber [04bf6a7] * eng/req/items.rst (modified) eng: Fix wording in specification items Fri, 10 Sep 2021 14:22:31 GMT Sebastian Huber [2df0d64] * eng/req/items.rst (modified) eng: Add hidden interface group membership Update #3715. Fri, 10 Sep 2021 14:21:25 GMT Sebastian Huber [60e08fd] * eng/req/items.rst (modified) eng: Make interface definitions optional Update #3715. Fri, 10 Sep 2021 14:26:18 GMT Sebastian Huber [9dd6135] * eng/req/items.rst (modified) eng: Add interface params/return to typedefs Update #3715. Fri, 10 Sep 2021 14:25:59 GMT Sebastian Huber [7b2b1b4] * eng/req/items.rst (modified) eng: Simplify interface return specification Update #3715. Fri, 03 Sep 2021 13:28:50 GMT Sebastian Huber [081ec5d] * c-user/clock/directives.rst (modified) c-user: Document time of day constraints Close #4338. Thu, 02 Sep 2021 09:18:48 GMT Sebastian Huber [8edb899] * eng/coding-conventions.rst (modified) eng: Remove bogus coding rule Declaring functions used only through ... Thu, 02 Sep 2021 09:17:58 GMT Sebastian Huber [dc6b917] * c-user/glossary.rst (modified) c-user: Add LIFO to glossary Wed, 18 Aug 2021 09:27:56 GMT Sebastian Huber [d223ec9] * eng/build-system.rst (modified) * eng/req/items.rst (modified) eng: Document use of BSP family for defaults Update #4468. Mon, 16 Aug 2021 10:27:53 GMT pranav [bd4dedc] * user/bsps/arm/raspberrypi.rst (modified) bsps/raspberrypi: Change firmware version, add SPI & I2C support Fri, 30 Jul 2021 06:51:07 GMT Sebastian Huber [efb8e7c] * c-user/fatal-error/directives.rst (modified) * c-user/index.rst (modified) * c-user/kernel-character-io/directives.rst (added) * c-user/kernel-character-io/index.rst (added) * c-user/kernel-character-io/introduction.rst (added) * c-user/rate-monotonic/directives.rst (modified) * c-user/rate-monotonic/introduction.rst (modified) c-user: Add "Kernel Character I/O Support" chapter Close #4482. Mon, 02 Aug 2021 05:16:38 GMT Sebastian Huber [76b5b81] * eng/req/items.rst (modified) eng: Add freestanding test cases Update #3715. Thu, 15 Jul 2021 13:31:17 GMT Christian Mauderer [238b48f9] * user/bsps/arm/imxrt.rst (modified) user/imxrt: Add notes about problems with EVB There are some ... Wed, 28 Jul 2021 06:45:41 GMT Sebastian Huber [18746fb] * c-user/fatal-error/operations.rst (modified) c-user: Remove _Internal_errors_What_happened This global object no ... Mon, 14 Jun 2021 07:59:59 GMT Sebastian Huber [056886f] * c-user/interrupt/directives.rst (modified) * c-user/interrupt/introduction.rst (modified) c-user: Document interrupt manager extensions Close #3269. Thu, 15 Jul 2021 16:24:35 GMT Stephen Clark [205f755] * README.txt (modified) README: Added centOS 8 instructions Added some instructions for ... Thu, 15 Jul 2021 16:08:41 GMT Stephen Clark [84f7c6a] * README.txt (modified) README: Minor clarifications and fixes Fixed some minor ... Tue, 13 Jul 2021 20:38:42 GMT Stephen Clark [821b624] * user/bsps/aarch64/a53.rst (modified) * user/bsps/aarch64/xilinx-zynqmp.rst (modified) user/bsps/aarch64: Minor formatting fix Fixed formatting error in ... Tue, 13 Jul 2021 20:35:14 GMT Stephen Clark [4ea93d0] * user/bsps/aarch64/xilinx-zynqmp.rst (modified) xilinx-zynqmp.rst: Documented SDIO driver Added documentation for ... Mon, 12 Jul 2021 21:04:53 GMT Kinsey Moore [594fe00] * user/bsps/aarch64/xilinx-zynqmp.rst (modified) user: Update ZynqMP network configuration Network configuration is ... Thu, 01 Jul 2021 19:43:57 GMT Ray Garza [9d61006] * eclipse/conf.py (deleted) * eclipse/glossary.rst (deleted) * eclipse/index.rst (deleted) * eclipse/overview.rst (deleted) * eclipse/rtems.rst (deleted) * eclipse/wscript (deleted) * images/eclipse/eclipse-autotools.png (deleted) * images/eclipse/eclipse-cdt.png (deleted) * images/eclipse/eclipse-gcc-cross.png (deleted) * images/eclipse/eclipse-help-installation.png (deleted) * images/eclipse/eclipse-install-new-software.png (deleted) * images/eclipse/eclipse-new-project.png (deleted) * images/eclipse/eclipse-project-import-existing-code.png (deleted) * images/eclipse/eclipse-project-makefile-existing-code.png (deleted) * images/eclipse/eclipse-rtems-git-build-project-building.png (deleted) * images/eclipse/eclipse-rtems-git-build-project.png (deleted) * images/eclipse/eclipse-rtems-git-built.png (deleted) * images/eclipse/eclipse-rtems-git-convert-autotools-dialog.png (deleted) * images/eclipse/eclipse-rtems-git-convert-autotools.png (deleted) * images/eclipse/eclipse-rtems-git-files.png (deleted) * images/eclipse/eclipse-rtems-git-prop-at-add-opts.png (deleted) * images/eclipse/eclipse-rtems-git-prop-at-prefix.png (deleted) * images/eclipse/eclipse-rtems-git-prop-at-target.png (deleted) * images/eclipse/eclipse-rtems-git-prop-cdt-build.png (deleted) * images/eclipse/eclipse-rtems-git-prop-cdt-env-replace.png (deleted) * images/eclipse/eclipse-rtems-git-prop-cdt-env-var-path-add.png (deleted) * images/eclipse/eclipse-rtems-git-prop-cdt-env-var-path.png (deleted) * images/eclipse/eclipse-rtems-git-prop-cdt-env-var.png (deleted) * images/eclipse/eclipse-rtems-git-prop-cdt-env.png (deleted) * images/eclipse/eclipse-rtems-git-prop-cdt-settings.png (deleted) * images/eclipse/eclipse-rtems-git-properties-menu.png (deleted) * images/eclipse/eclipse-rtems-git-reconfigure-console.png (deleted) * images/eclipse/eclipse-rtems-git-reconfigure.png (deleted) * images/eclipse/eclipse-sdk-details.png (deleted) * wscript (modified) rtems-docs: remove Eclipse Manual Due to RTEMS 6 no longer using ... Fri, 28 May 2021 13:58:41 GMT Christian Mauderer [72ae964] * user/bsps/arm/imxrt.rst (modified) user/bsps/imxrt: Info about ARM PLL frequency Update #4180 Fri, 28 May 2021 13:53:01 GMT Christian Mauderer [78a1ae1] * user/bsps/arm/imxrt.rst (modified) user/bsps/imxrt: Fix typo Thu, 01 Jul 2021 18:25:44 GMT Kinsey Moore [b528508] * user/bsps/aarch64/xilinx-zynqmp.rst (modified) user/bsps: Update ZynqMP for hardware BSPs Update the ZynqMP ... Wed, 23 Jun 2021 02:19:56 GMT Gedare Bloom [7a91021] * user/bsps/aarch64/xilinx-versal.rst (added) * user/bsps/bsps-aarch64.rst (modified) user/bsps: add aarch64 xilinx-versal Sun, 13 Jun 2021 01:28:06 GMT Ida Delphine [335c205] * user/start/app.rst (modified) user: Fixed typo to build hello application Mon, 14 Jun 2021 07:18:23 GMT Sebastian Huber [c70715b] * c-user/barrier/directives.rst (modified) * c-user/clock/directives.rst (modified) * c-user/dual-ported-memory/directives.rst (modified) * c-user/interrupt/directives.rst (modified) * c-user/io/directives.rst (modified) * c-user/message/directives.rst (modified) * c-user/object-services/directives.rst (modified) * c-user/partition/directives.rst (modified) * c-user/rate-monotonic/directives.rst (modified) * c-user/region/directives.rst (modified) * c-user/scheduling-concepts/directives.rst (modified) * c-user/semaphore/directives.rst (modified) * c-user/task/directives.rst (modified) * c-user/timer/directives.rst (modified) * c-user/user-extensions/directives.rst (modified) c-user: Use a common phrase for pointer parameters Mention the type ... Tue, 08 Jun 2021 20:42:26 GMT Gedare Bloom [1a28186] * user/bsps/aarch64/a72.rst (added) * user/bsps/bsps-aarch64.rst (modified) user: add bsps/aarch64/a72.rst Tue, 08 Jun 2021 20:41:16 GMT Gedare Bloom [528a2b6] * user/bsps/aarch64/a53.rst (modified) user: fix typo in aarch64/a53.rst Tue, 01 Jun 2021 21:36:46 GMT Joel Sherrill [a08643b] * posix-compliance/README-csv.txt (modified) * posix-compliance/RTEMS-Standards-Compliance.csv (modified) Update Compliance Tracking CSV file to fix minor bugs Sun, 30 May 2021 21:06:56 GMT Vijay Kumar Banerjee [2295c88] * eng/vc-authors.rst (modified) eng/vc-authors: Add section on migrating personal repo to top-level Wed, 26 May 2021 09:32:55 GMT Christian Mauderer [b05cecc] * c-user/self_contained_objects.rst (modified) c-users: Add rtems_*mutex_try_lock Closes #4440. Mon, 17 May 2021 07:32:21 GMT Christian Mauderer [a3ebe17] * user/bsps/arm/imxrt.rst (modified) bsps/imxrt: Remove superfluous options from dtc The -@ option adds ... Thu, 27 May 2021 05:07:39 GMT Sebastian Huber [2509b62] * c-user/task/directives.rst (modified) c-user: Document new rtems_task_delete() error Close #4414. Mon, 10 May 2021 01:58:45 GMT Chris Johns [1568c2ba] * common/waf.py (modified) Fix the bibtex extension configure test Mon, 10 May 2021 01:57:55 GMT Chris Johns [1361d2c] * common/latex.py (modified) Fix the linux specific include Wed, 05 May 2021 21:31:53 GMT Joel Sherrill [1568ed2f] * posix-compliance/README-csv.txt (modified) * posix-compliance/RTEMS-Standards-Compliance.csv (modified) * posix-compliance/posix_rst.py (modified) * posix-compliance/standards.rst (modified) posix-compliance: Update to include POSIX 1003.1-2017 (Issue 7). Mon, 12 Apr 2021 13:38:04 GMT Joel Sherrill [037104a] * posix-compliance/posix_rst.py (modified) posix-compliance/posix_rst.py: Use proper names of standards in headings Wed, 12 May 2021 01:16:33 GMT Harrison Edward Gerber [1f53868] * user/bld/index.rst (modified) user/bld/index.rst: removed references to legacy network config options Wed, 12 May 2021 19:31:31 GMT Sebastian Huber [2588e8b] * c-user/task/directives.rst (modified) c-user: Constify rtems_task_wake_when() Update #4406. Wed, 12 May 2021 19:05:48 GMT Sebastian Huber [fa98f8d] * c-user/task/directives.rst (modified) c-user: Clarify rtems_task_get_priority() Wed, 12 May 2021 13:05:37 GMT Sebastian Huber [7ded594] * c-user/task/directives.rst (modified) c-user: Document rtems_task_set_scheduler() errors Wed, 12 May 2021 11:41:47 GMT Sebastian Huber [dcd0085] * c-user/glossary.rst (modified) c-user: Add task priority glossary terms Sat, 08 May 2021 08:24:38 GMT Sebastian Huber [ee5718a] * c-user/config/general.rst (modified) c-user: Change format of external function refs Sat, 08 May 2021 08:21:06 GMT Sebastian Huber [b797009] * eng/req/items.rst (modified) eng: Add unspecified interface groups Update #3715. Fri, 07 May 2021 06:18:10 GMT Sebastian Huber [e8cd4d3] * c-user/scheduling-concepts/directives.rst (modified) c-user: rtems_scheduler_get_processor_set() Document changed error ... Fri, 07 May 2021 06:17:14 GMT Sebastian Huber [605cd1f] * c-user/scheduling-concepts/directives.rst (modified) c-user: rtems_scheduler_ident_by_processor_set() Document new error ... Fri, 30 Apr 2021 05:05:15 GMT Sebastian Huber [aa0c495] * eng/req/items.rst (modified) eng: Remove text attribute from acfg options Update #3715. Wed, 28 Apr 2021 07:03:14 GMT Sebastian Huber [4565256] * c-user/config/bdbuf.rst (modified) * c-user/config/bsp-related.rst (modified) * c-user/config/classic-api.rst (modified) * c-user/config/classic-init-task.rst (modified) * c-user/config/device-driver.rst (modified) * c-user/config/event-record.rst (modified) * c-user/config/filesystem.rst (modified) * c-user/config/general.rst (modified) * c-user/config/idle-task.rst (modified) * c-user/config/mpci.rst (modified) * c-user/config/posix-api.rst (modified) * c-user/config/posix-init-thread.rst (modified) * c-user/config/scheduler-general.rst (modified) * c-user/config/task-stack-alloc.rst (modified) c-user: Reformat configuration option constraints If only one ... Thu, 29 Apr 2021 13:00:38 GMT Sebastian Huber [8f1daf7] * c-user/config/bsp-related.rst (modified) c-user: CONFIGURE_BSP_PREREQUISITE_DRIVERS Replace copy and paste ... Thu, 29 Apr 2021 12:58:52 GMT Sebastian Huber [3383686] * c-user/config/scheduler-general.rst (modified) c-user: Add missing "the" Thu, 29 Apr 2021 09:04:38 GMT Sebastian Huber [a95c968] * eng/req/items.rst (modified) eng: Add test suite name Update #3715. Thu, 29 Apr 2021 09:03:57 GMT Sebastian Huber [b6cb057] * eng/req/items.rst (modified) eng: Remove scope from constraints Use links instead of this ... Thu, 29 Apr 2021 05:22:28 GMT Sebastian Huber [e263e84] * eng/req/items.rst (modified) eng: Add unit test link role Update #3715. Wed, 28 Apr 2021 11:22:48 GMT Sebastian Huber [889a5ffc] * eng/req/items.rst (modified) eng: Remove embedded constraints Update #3715. Tue, 27 Apr 2021 11:09:27 GMT Sebastian Huber [35cbb42] * c-user/region/directives.rst (modified) * c-user/region/introduction.rst (modified) c-user: Generate region manager documentation The documentation is ... Fri, 15 Jan 2021 13:08:35 GMT Sebastian Huber [2ae3364] * c-user/fatal-error/background.rst (modified) * c-user/task/directives.rst (modified) * c-user/task/introduction.rst (modified) c-user: Generate task manager documentation The documentation is a ... Tue, 27 Apr 2021 17:54:12 GMT Sebastian Huber [bc66c95] * c-user/message/directives.rst (modified) c-user: Fix typo "cod" -> "code" Tue, 27 Apr 2021 05:36:24 GMT Sebastian Huber [ad16b37] * c-user/barrier/directives.rst (modified) * c-user/clock/directives.rst (modified) * c-user/event/directives.rst (modified) * c-user/message/directives.rst (modified) * c-user/multiprocessing/directives.rst (modified) * c-user/semaphore/directives.rst (modified) c-user: Clarify constraints Tue, 19 Jan 2021 06:25:07 GMT Sebastian Huber [4a3259f] * c-user/scheduling-concepts/directives.rst (modified) * c-user/scheduling-concepts/introduction.rst (modified) c-user: Generate scheduling concepts documentation The ...
