# # ChangeLog for / in rtems-docs # # Generated by Trac 1.2.1.dev0 # 06/17/24 05:33:24 Tue, 04 Oct 2022 06:23:06 GMT Sebastian Huber [4966ed0] * eng/req/items.rst (modified) eng: Remove appl config group member link role Update #3715. Tue, 04 Oct 2022 06:22:26 GMT Sebastian Huber [c909228] * eng/req/items.rst (modified) eng: Refine unspecified interfaces Update #3715. Tue, 04 Oct 2022 06:30:41 GMT Sebastian Huber [1d9f9af] * eng/req/items.rst (modified) eng: Add function implementation link role Update #3715. Tue, 04 Oct 2022 06:29:18 GMT Sebastian Huber [c812323] * eng/req/items.rst (modified) eng: Unify interface function and macro This allows the ... Tue, 04 Oct 2022 06:12:54 GMT Sebastian Huber [889a498d] * eng/req/items.rst (modified) eng: Remove interface container item type Update #3715. Fri, 30 Sep 2022 12:52:01 GMT Sebastian Huber [c98307c] * c-user/interrupt/directives.rst (modified) * c-user/message/directives.rst (modified) * c-user/object-services/directives.rst (modified) * c-user/task/directives.rst (modified) c-user: Add types to macros Thu, 09 Jun 2022 13:21:05 GMT Frank Kühndel [23fc93b] * filesystem/index.rst (modified) * filesystem/trivial_ftp.rst (modified) TFTPFS: New documentation Thu, 29 Sep 2022 08:01:14 GMT Sebastian Huber [278550b] * c-user/region/directives.rst (modified) c-user: Add type roles Fri, 09 Sep 2022 21:38:15 GMT Chris Johns [2a2d33c] * user/deployment/index.rst (added) * user/index.rst (modified) user: Add deployment section Mon, 12 Sep 2022 07:01:50 GMT Sebastian Huber [8f4543f] * user/migration/v5-to-v6.rst (modified) user: Mention that the bsp_specs are gone Update #3250. Mon, 12 Sep 2022 07:01:12 GMT Sebastian Huber [283acbb] * user/migration/v5-to-v6.rst (modified) user: Clarify -fno-common changes Fri, 09 Sep 2022 05:42:54 GMT Sebastian Huber [13be9a2] * user/bsps/arm/fvp.rst (added) * user/bsps/bsps-arm.rst (modified) user: Document arm/fvp BSP Close #4202. Fri, 09 Sep 2022 05:15:08 GMT Sebastian Huber [91e8654] * user/rsb/project-sets.rst (modified) user: Document RSB --with/without-newlib-tls Update #4560. Thu, 08 Sep 2022 06:35:37 GMT Sebastian Huber [c33cca3] * eng/req/items.rst (modified) eng: Document new build item attributes Close #4670. Tue, 06 Sep 2022 22:31:18 GMT Joel Sherrill [8741d2c] * posix-users/process_creation_and_execution.rst (modified) posix-users/process_creation_and_execution.rst: Update ... Fri, 02 Sep 2022 16:25:22 GMT Joel Sherrill [4f9e9e5] * c-user/config/face-technical-standard.rst (added) * c-user/config/index.rst (modified) c-user/config/face.rst: New file -- add ... Wed, 17 Nov 2021 07:46:56 GMT Sebastian Huber [cf9f212] * c-user/config/device-driver.rst (modified) * c-user/config/general.rst (modified) * c-user/config/idle-task.rst (modified) c-user: Clarify BSP related configuration settings Wed, 03 Aug 2022 05:01:43 GMT Chris Johns [f052446] * shell/rtems_specific_commands.rst (modified) commands: Add 'rtems' command Mon, 08 Aug 2022 20:04:29 GMT Ryan Long [1c17ec4] * user/exe/loader.rst (modified) loader.rst: Add documentation for AArch64 support Fri, 12 Aug 2022 06:03:25 GMT Chris Johns [10e8dcc] * common/waf.py (modified) pdf: Set TEXINPUTS to the tex source path Fri, 12 Aug 2022 06:02:48 GMT Chris Johns [94af618] * user/bsps/arm/beagle.rst (modified) user/arm/beagle: Fix image path after section change Wed, 10 Aug 2022 20:40:49 GMT Joel Sherrill [7757c19] * eng/req/howto.rst (modified) eng/req/howto.rst: Fix ./spec2dmodules.py to ./spec2modules.py typo Thu, 11 Aug 2022 06:26:30 GMT Sebastian Huber [657f744] * c-user/config/general.rst (modified) * c-user/config/mpci.rst (modified) * c-user/config/posix-api.rst (modified) c-user: Update OAR copyright and reformat These files are generated ... Wed, 03 Aug 2022 04:24:59 GMT Chris Johns [1d6dcf8] * user/exe/initialization.rst (modified) * user/exe/loader.rst (modified) * user/hosts/os.rst (modified) * user/installation/developer.rst (modified) * user/installation/project-sandboxing.rst (modified) * user/installation/releases.rst (modified) * user/start/app.rst (modified) * user/start/bsp-build.rst (modified) versions: Update user manual Updates #4695 Wed, 03 Aug 2022 04:22:20 GMT Chris Johns [3859073] * user/bsps/bsps-microblaze.rst (modified) * user/bsps/bsps-powerpc.rst (modified) * user/bsps/bsps-riscv.rst (modified) * user/bsps/bsps-x86_64.rst (modified) versions: Update microblaze, powerpc, riscv and x86_64 Updates #4695 Wed, 03 Aug 2022 04:20:52 GMT Chris Johns [f028448] * user/bsps/arm/altera-cyclone-v.rst (modified) * user/bsps/arm/beagle.rst (modified) * user/bsps/arm/imx.rst (modified) * user/bsps/arm/imxrt.rst (modified) * user/bsps/arm/raspberrypi.rst (modified) * user/bsps/arm/xen.rst (modified) * user/bsps/bsps-arm.rst (modified) versions: Update arm Updates #4695 Wed, 03 Aug 2022 04:19:54 GMT Chris Johns [e551cc7] * user/bsps/aarch64/xilinx-zynqmp.rst (modified) versions: Update aarch64 Updates #4695 Wed, 03 Aug 2022 04:13:09 GMT Chris Johns [c935a2c] * README.txt (modified) * common/conf.py (modified) * common/rtemsdomain.py (modified) * common/version.py (modified) building: Add support for an RTEMS version number - Support using a ... Tue, 26 Jul 2022 09:40:21 GMT Sebastian Huber [f4377b4] * c-user/task/directives.rst (modified) c-user: Document new rtems_task_delete() behaviour Update #4679. Wed, 27 Jul 2022 09:18:13 GMT Sebastian Huber [81fd510] * c-user/task/background.rst (modified) c-user: Document task life states Update #4679. Tue, 26 Jul 2022 09:24:01 GMT Sebastian Huber [f1eb94b] * c-user/glossary.rst (modified) * c-user/key_concepts.rst (modified) c-user: Do not mention pseudo-interrupt priority Update #2365. Tue, 19 Jul 2022 19:41:46 GMT Kinsey Moore [3348f19] * user/bsps/aarch64/xilinx-zynqmp.rst (modified) zynqmp: Add commentary about lwIP usage Wed, 15 Jun 2022 15:53:21 GMT Joel Sherrill [582141e] * eng/coding-conventions.rst (modified) eng/coding-conventions.rst: Fix duplicate periods Thu, 09 Jun 2022 14:02:12 GMT Sebastian Huber [5a7acfc] * cpu-supplement/altera_nios_ii.rst (modified) cpu-supplement: Mention that nios2 supports TLS Close #4214. Thu, 09 Jun 2022 07:02:03 GMT Christian Mauderer [be4b767] * user/bsps/arm/imx.rst (modified) user/bsps/arm: Second Ethernet on i.MX This adds information how to ... Mon, 23 May 2022 13:11:52 GMT Sebastian Huber [9f431e7] * user/bsps/arm/xilinx-zynq.rst (modified) user: Document Zynq network Content is from rtems-libbsd/libbsd.txt ... Wed, 18 May 2022 19:01:54 GMT Karel Gardas [d5509d6] * user/bsps/arm/stm32h7.rst (modified) user/bsps/arm: improve stm32h7 BSP description This patch adds kind ... Fri, 20 May 2022 13:45:16 GMT Joel Sherrill [9ba26e7] * c-user/config/general.rst (modified) * c-user/config/mpci.rst (modified) * c-user/config/posix-api.rst (modified) * c-user/symmetric_multiprocessing_services.rst (modified) c-user: Update references to --enable-* configure options. Also ... Wed, 04 May 2022 11:03:38 GMT Sebastian Huber [c16c8c6] * user/overview/index.rst (modified) user: Update architectures supporting TLS Tue, 05 Apr 2022 11:13:55 GMT Karel Gardas [5475c9c] * user/bsps/arm/bsp-stm32h7.rst (deleted) * user/bsps/bsps-arm.rst (modified) user/bsps/arm: remove dangling stm32h7 bsp page The page for ... Tue, 29 Mar 2022 08:54:31 GMT Sebastian Huber [0e200f3] * c-user/task/directives.rst (modified) c-user: Clarify scheduler of created task Fri, 25 Mar 2022 13:36:43 GMT Alan Cudmore [c0d69834] * user/bsps/aarch64/xilinx-zynqmp.rst (modified) rtems-docs: add example booting aarch64 image on Xilinx ZCU102 This ... Fri, 04 Mar 2022 19:47:40 GMT Kinsey Moore [df8261a] * cpu-supplement/aarch64.rst (modified) * cpu-supplement/arm.rst (modified) cpu-supplement: Add note about device memory Add information about ... Thu, 24 Mar 2022 19:18:12 GMT Joel Sherrill [9b6583d] * eng/tester.rst (modified) eng/tester.rst: Reference User Manual for rtems-test This was just ... Tue, 22 Feb 2022 14:42:47 GMT Alex White [bf27a21] * cpu-supplement/xilinx_microblaze.rst (modified) * user/bsps/bsps-microblaze.rst (modified) microblaze: Document BSPs and update CPU supplement Tue, 15 Mar 2022 16:44:12 GMT Sebastian Huber [49f84b7] * c-user/interrupt/directives.rst (modified) * c-user/interrupt/introduction.rst (modified) c-user: Improve interrupt set affinity handling Update #3269. Tue, 22 Feb 2022 14:07:12 GMT Sebastian Huber [2f8be4b] * c-user/config/scheduler-general.rst (modified) c-user: Document CONFIGURE_SCHEDULER_TABLE_ENTRIES Update #4524. Mon, 21 Feb 2022 08:33:47 GMT Christian Mauderer [c11ae8e] * user/bsps/arm/imxrt.rst (modified) bsps/imxrt: Generate correctly aligned device tree The device tree ... Fri, 28 Jan 2022 13:58:58 GMT Sebastian Huber [383b600] * eng/release-process.rst (modified) eng: Add rtems-central.git post branch procedures Fri, 28 Jan 2022 13:58:01 GMT Sebastian Huber [fff7d6a] * eng/release-process.rst (modified) eng: Fix indentation Fri, 28 Jan 2022 13:35:37 GMT Sebastian Huber [2924bf7] * eng/release-process.rst (modified) eng: Update version number handling Mon, 24 Jan 2022 22:35:10 GMT Joel Sherrill [7073017] * user/hosts/posix.rst (modified) user/hosts/posix.rst: Replace Cent)S with CentOS Fri, 21 Jan 2022 16:02:27 GMT Sebastian Huber [dd60a4a] * eng/req/howto.rst (modified) eng: Add script usage to how-to Update #3715. Tue, 11 Jan 2022 16:00:49 GMT Sebastian Huber [1ba0f41] * eng/req/items.rst (modified) eng: Document get-string-command-line action Update #4548. Tue, 11 Jan 2022 15:54:01 GMT Sebastian Huber [9fecafa] * eng/req/items.rst (modified) eng: Add runtime performance kinds Tue, 11 Jan 2022 15:51:16 GMT Sebastian Huber [fa1c18e] * eng/req/items.rst (modified) eng: Document get-string-command-line action Close #4548. Tue, 11 Jan 2022 15:50:41 GMT Sebastian Huber [ffcf9dc] * eng/req/items.rst (modified) eng: Fix action requirement patterns Tue, 21 Dec 2021 15:58:56 GMT Sebastian Huber [162925e] * c-user/clock/background.rst (modified) c-user: Use document internal links Tue, 21 Dec 2021 15:50:40 GMT Sebastian Huber [e77e04d] * c-user/clock/background.rst (modified) c-user: Clarify Clock Manager dependencies Update #4572. Tue, 04 Jan 2022 15:57:01 GMT Kinsey Moore [7be2da1] * cpu-supplement/index.rst (modified) cpu-supplement: Add aarch64 to index This was never updated when ... Fri, 17 Dec 2021 21:26:53 GMT Ryan Long [4e22dfe] * user/hosts/posix.rst (modified) Update package list for Ubuntu Updated the latest version ... Thu, 16 Dec 2021 07:20:27 GMT Sebastian Huber [786b89a] * c-user/clock/background.rst (modified) c-user: Clarify time formats Update #4572. Thu, 16 Dec 2021 06:43:20 GMT Sebastian Huber [732d8bc] * c-user/clock/directives.rst (modified) c-user: Fix Clock Manager parameter descriptions Update #4572. Fri, 26 Nov 2021 13:42:03 GMT Sebastian Huber [835ece1] * cpu-supplement/sparc.rst (modified) cpu-supplement: Update trap handling for SPARC Close #4459. Fri, 26 Nov 2021 12:10:05 GMT Sebastian Huber [87d1f4d] * cpu-supplement/sparc.rst (modified) cpu-supplement: Use ``REG`` for SPARC registers Update #4459. Fri, 26 Nov 2021 12:35:49 GMT Sebastian Huber [8731bd6] * cpu-supplement/sparc.rst (modified) cpu-supplement: Update URL Tue, 23 Nov 2021 14:20:06 GMT Sebastian Huber [838b78a] * c-user/clock/directives.rst (modified) * c-user/clock/introduction.rst (modified) c-user: Replace "precision" with "resolution" Resolution is the ... Tue, 16 Nov 2021 08:14:35 GMT Sebastian Huber [513b90d] * c-user/scheduling-concepts/directives.rst (modified) c-user: rtems_scheduler_remove_processor() Update error status ... Mon, 11 Oct 2021 15:05:21 GMT Sebastian Huber [38ec48d] * c-user/clock/directives.rst (modified) * c-user/clock/introduction.rst (modified) c-user: Document new clock manager directives Add new clock manager ... Fri, 19 Nov 2021 07:45:55 GMT Sebastian Huber [61410da] * c-user/task/directives.rst (modified) c-user: Use RTEMS_WHO_AM_I for rtems_task_ident() Tue, 16 Nov 2021 07:17:31 GMT Sebastian Huber [1c8ce33] * c-user/config/bdbuf.rst (modified) * c-user/config/bsp-related.rst (modified) * c-user/config/classic-api.rst (modified) * c-user/config/classic-init-task.rst (modified) * c-user/config/device-driver.rst (modified) * c-user/config/event-record.rst (modified) * c-user/config/filesystem.rst (modified) * c-user/config/general.rst (modified) * c-user/config/idle-task.rst (modified) * c-user/config/mpci.rst (modified) * c-user/config/posix-api.rst (modified) * c-user/config/posix-init-thread.rst (modified) * c-user/config/scheduler-general.rst (modified) * c-user/config/task-stack-alloc.rst (modified) c-user: Use rubric for configuration options Clear the page for ... Tue, 16 Nov 2021 07:00:03 GMT Sebastian Huber [1badb5f] * c-user/config/posix-api.rst (modified) c-user: CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS Fix default value ... Fri, 12 Nov 2021 03:28:57 GMT Amar Takhar [fa25208] * common/coverpage/static/js/jquery.min.js (modified) Update jQuery from 1.12.4 to 3.6.0. Identified by security scans. Mon, 01 Nov 2021 19:40:55 GMT Kinsey Moore [a0bf79c] * c-user/config/device-driver.rst (modified) c-user: Update for application CONFIGURE option This adds the ... Mon, 01 Nov 2021 18:52:52 GMT Kinsey Moore [ac8f461] * cpu-supplement/aarch64.rst (modified) cpu-supplement: Update AArch64 SMP details AArch64 now supports SMP ... Mon, 25 Oct 2021 06:09:00 GMT Sebastian Huber [feb4687] * c-user/rate-monotonic/directives.rst (modified) c-user: rtems_rate_monotonic_get_status() Mention that resetting ... Tue, 19 Oct 2021 14:42:04 GMT Sebastian Huber [46dbb6d] * c-user/config/task-stack-alloc.rst (modified) c-user: Regenerate for IDLE task allocator option Update #4524. Tue, 12 Oct 2021 18:46:11 GMT Joel Sherrill [df5be4c] * c-user/config/task-stack-alloc.rst (modified) task-stack-alloc.rst: Add CONFIGURE_TASK_STACK_FROM_ALLOCATOR ... Wed, 29 Sep 2021 10:45:40 GMT Sebastian Huber [887b8d3] * c-user/glossary.rst (modified) glossary: Add terms Fri, 24 Sep 2021 12:49:43 GMT Sebastian Huber [0ca7adf] * c-user/glossary.rst (modified) glossary: Add OMIP Tue, 21 Sep 2021 16:56:44 GMT Ryan Long [13092ff] * user/hosts/posix.rst (modified) posix.rst: Add info for FreeBSD 13 Add list of additional packages ... Tue, 21 Sep 2021 09:36:17 GMT Chris Johns [7b289f6] * user/testing/configuration.rst (modified) * user/testing/tftp.rst (modified) user/testing: Add the %wait directive Wed, 15 Sep 2021 09:55:52 GMT Sebastian Huber [7afc7a0] * c-user/message/directives.rst (modified) rtems: Fix message manager documentation Correct the description of ... Wed, 15 Sep 2021 15:44:55 GMT Sebastian Huber [28188d4] * c-user/glossary.rst (modified) c-user: Fix use of lower and higher priority Tue, 14 Sep 2021 17:18:31 GMT Sebastian Huber [5fdc744] * c-user/scheduling-concepts/background.rst (modified) * c-user/scheduling-concepts/smp-schedulers.rst (modified) * c-user/task/background.rst (modified) c-user: Clarify task priorities Tue, 14 Sep 2021 13:58:36 GMT Sebastian Huber [c81e148] * c-user/glossary.rst (modified) c-user: Define lower and higher priority Tue, 14 Sep 2021 15:48:35 GMT Sebastian Huber [6198c49] * c-user/message/directives.rst (modified) c-user: Fix message manager documentation Remove bogus return ... Tue, 14 Sep 2021 06:15:25 GMT Sebastian Huber [0bc62ee] * c-user/user-extensions/directives.rst (modified) c-user: Clarify rtems_extension_create() Fri, 10 Sep 2021 08:36:44 GMT Sebastian Huber [023f609] * c-user/cache/directives.rst (added) * c-user/cache/index.rst (added) * c-user/cache/introduction.rst (added) * c-user/index.rst (modified) c-user: Add "Cache Manager" chapter The Cache Manager directives ... Mon, 13 Sep 2021 06:27:45 GMT Sebastian Huber [04bf6a7] * eng/req/items.rst (modified) eng: Fix wording in specification items Fri, 10 Sep 2021 14:22:31 GMT Sebastian Huber [2df0d64] * eng/req/items.rst (modified) eng: Add hidden interface group membership Update #3715. Fri, 10 Sep 2021 14:21:25 GMT Sebastian Huber [60e08fd] * eng/req/items.rst (modified) eng: Make interface definitions optional Update #3715. Fri, 10 Sep 2021 14:26:18 GMT Sebastian Huber [9dd6135] * eng/req/items.rst (modified) eng: Add interface params/return to typedefs Update #3715. Fri, 10 Sep 2021 14:25:59 GMT Sebastian Huber [7b2b1b4] * eng/req/items.rst (modified) eng: Simplify interface return specification Update #3715. Fri, 03 Sep 2021 13:28:50 GMT Sebastian Huber [081ec5d] * c-user/clock/directives.rst (modified) c-user: Document time of day constraints Close #4338. Thu, 02 Sep 2021 09:18:48 GMT Sebastian Huber [8edb899] * eng/coding-conventions.rst (modified) eng: Remove bogus coding rule Declaring functions used only through ... Thu, 02 Sep 2021 09:17:58 GMT Sebastian Huber [dc6b917] * c-user/glossary.rst (modified) c-user: Add LIFO to glossary Wed, 18 Aug 2021 09:27:56 GMT Sebastian Huber [d223ec9] * eng/build-system.rst (modified) * eng/req/items.rst (modified) eng: Document use of BSP family for defaults Update #4468. Mon, 16 Aug 2021 10:27:53 GMT pranav [bd4dedc] * user/bsps/arm/raspberrypi.rst (modified) bsps/raspberrypi: Change firmware version, add SPI & I2C support Fri, 30 Jul 2021 06:51:07 GMT Sebastian Huber [efb8e7c] * c-user/fatal-error/directives.rst (modified) * c-user/index.rst (modified) * c-user/kernel-character-io/directives.rst (added) * c-user/kernel-character-io/index.rst (added) * c-user/kernel-character-io/introduction.rst (added) * c-user/rate-monotonic/directives.rst (modified) * c-user/rate-monotonic/introduction.rst (modified) c-user: Add "Kernel Character I/O Support" chapter Close #4482.
