# # ChangeLog for spec in rtems-central # # Generated by Trac 1.2.1.dev0 # 05/21/24 05:17:10 Wed, 24 Jun 2020 09:32:43 GMT Sebastian Huber [d860350] * spec/groups/api/classic.yml (modified) * spec/if/rtems/header.yml (added) spec: Specify Mon, 22 Jun 2020 06:36:48 GMT Sebastian Huber [3e061f5] * spec/groups/api/classic/userext.yml (added) * spec/if/impl/interr/code.yml (added) * spec/if/impl/interr/header.yml (added) * spec/if/impl/interr/source.yml (added) * spec/if/impl/userext/fatal.yml (added) * spec/if/impl/userext/table.yml (added) * spec/if/impl/userext/thread-begin.yml (added) * spec/if/impl/userext/thread-create.yml (added) * spec/if/impl/userext/thread-delete.yml (added) * spec/if/impl/userext/thread-exitted.yml (added) * spec/if/impl/userext/thread-restart.yml (added) * spec/if/impl/userext/thread-start.yml (added) * spec/if/impl/userext/thread-switch.yml (added) * spec/if/impl/userext/thread-terminate.yml (added) * spec/if/rtems/userext/create.yml (added) * spec/if/rtems/userext/delete.yml (added) * spec/if/rtems/userext/fatal-code.yml (added) * spec/if/rtems/userext/fatal-source.yml (added) * spec/if/rtems/userext/fatal.yml (added) * spec/if/rtems/userext/header.yml (added) * spec/if/rtems/userext/ident.yml (added) * spec/if/rtems/userext/table.yml (added) * spec/if/rtems/userext/task-begin.yml (added) * spec/if/rtems/userext/task-create.yml (added) * spec/if/rtems/userext/task-delete.yml (added) * spec/if/rtems/userext/task-exitted.yml (added) * spec/if/rtems/userext/task-restart.yml (added) * spec/if/rtems/userext/task-start.yml (added) * spec/if/rtems/userext/task-switch.yml (added) * spec/if/rtems/userext/task-terminate.yml (added) spec: Add /if/rtems/userext/* Mon, 22 Jun 2020 06:36:48 GMT Sebastian Huber [c4fe9f5] * spec/groups/api/classic/timer.yml (added) * spec/if/rtems/timer/cancel.yml (added) * spec/if/rtems/timer/class-bit-not-dormant.yml (added) * spec/if/rtems/timer/class-bit-on-task.yml (added) * spec/if/rtems/timer/class-bit-time-of-day.yml (added) * spec/if/rtems/timer/classes.yml (added) * spec/if/rtems/timer/create.yml (added) * spec/if/rtems/timer/delete.yml (added) * spec/if/rtems/timer/dormant.yml (added) * spec/if/rtems/timer/fire-after.yml (added) * spec/if/rtems/timer/fire-when.yml (added) * spec/if/rtems/timer/get-information.yml (added) * spec/if/rtems/timer/header.yml (added) * spec/if/rtems/timer/ident.yml (added) * spec/if/rtems/timer/information.yml (added) * spec/if/rtems/timer/initiate-server.yml (added) * spec/if/rtems/timer/interval-on-task.yml (added) * spec/if/rtems/timer/interval.yml (added) * spec/if/rtems/timer/reset.yml (added) * spec/if/rtems/timer/server-default-priority.yml (added) * spec/if/rtems/timer/server-fire-after.yml (added) * spec/if/rtems/timer/server-fire-when.yml (added) * spec/if/rtems/timer/service-routine-entry.yml (added) * spec/if/rtems/timer/service-routine.yml (added) * spec/if/rtems/timer/time-of-day-on-task.yml (added) * spec/if/rtems/timer/time-of-day.yml (added) spec: Add /if/rtems/timer/* Mon, 22 Jun 2020 06:36:48 GMT Sebastian Huber [c51ff93] * spec/groups/api/classic/support.yml (added) * spec/if/rtems/support/header.yml (added) * spec/if/rtems/support/is-name-valid.yml (added) * spec/if/rtems/support/microseconds-to-ticks.yml (added) * spec/if/rtems/support/milliseconds-to-microseconds.yml (added) * spec/if/rtems/support/milliseconds-to-ticks.yml (added) * spec/if/rtems/support/name-to-characters.yml (added) * spec/if/rtems/support/workspace-allocate.yml (added) * spec/if/rtems/support/workspace-free.yml (added) * spec/if/rtems/support/workspace-get-information.yml (added) * spec/if/rtems/support/workspace-greedy-allocate-all-except-largest.yml (added) * spec/if/rtems/support/workspace-greedy-allocate.yml (added) * spec/if/rtems/support/workspace-greedy-free.yml (added) spec: Add /if/rtems/support/* Mon, 22 Jun 2020 06:36:48 GMT Sebastian Huber [8c90c5c] * spec/groups/api/classic/signal.yml (added) * spec/if/rtems/signal/asr-entry.yml (added) * spec/if/rtems/signal/asr.yml (added) * spec/if/rtems/signal/catch.yml (added) * spec/if/rtems/signal/header-2.yml (added) * spec/if/rtems/signal/header.yml (added) * spec/if/rtems/signal/send.yml (added) * spec/if/rtems/signal/set.yml (added) * spec/if/rtems/signal/signal-0.yml (added) * spec/if/rtems/signal/signal-1.yml (added) * spec/if/rtems/signal/signal-10.yml (added) * spec/if/rtems/signal/signal-11.yml (added) * spec/if/rtems/signal/signal-12.yml (added) * spec/if/rtems/signal/signal-13.yml (added) * spec/if/rtems/signal/signal-14.yml (added) * spec/if/rtems/signal/signal-15.yml (added) * spec/if/rtems/signal/signal-16.yml (added) * spec/if/rtems/signal/signal-17.yml (added) * spec/if/rtems/signal/signal-18.yml (added) * spec/if/rtems/signal/signal-19.yml (added) * spec/if/rtems/signal/signal-2.yml (added) * spec/if/rtems/signal/signal-20.yml (added) * spec/if/rtems/signal/signal-21.yml (added) * spec/if/rtems/signal/signal-22.yml (added) * spec/if/rtems/signal/signal-23.yml (added) * spec/if/rtems/signal/signal-24.yml (added) * spec/if/rtems/signal/signal-25.yml (added) * spec/if/rtems/signal/signal-26.yml (added) * spec/if/rtems/signal/signal-27.yml (added) * spec/if/rtems/signal/signal-28.yml (added) * spec/if/rtems/signal/signal-29.yml (added) * spec/if/rtems/signal/signal-3.yml (added) * spec/if/rtems/signal/signal-30.yml (added) * spec/if/rtems/signal/signal-31.yml (added) * spec/if/rtems/signal/signal-4.yml (added) * spec/if/rtems/signal/signal-5.yml (added) * spec/if/rtems/signal/signal-6.yml (added) * spec/if/rtems/signal/signal-7.yml (added) * spec/if/rtems/signal/signal-8.yml (added) * spec/if/rtems/signal/signal-9.yml (added) spec: Add /if/rtems/signal/* Mon, 22 Jun 2020 06:36:48 GMT Sebastian Huber [7446038] * spec/groups/api/classic/region.yml (added) * spec/if/impl/heap/header.yml (added) * spec/if/impl/heap/information-block.yml (added) * spec/if/rtems/region/create.yml (added) * spec/if/rtems/region/delete.yml (added) * spec/if/rtems/region/extend.yml (added) * spec/if/rtems/region/get-free-information.yml (added) * spec/if/rtems/region/get-information.yml (added) * spec/if/rtems/region/get-segment-size.yml (added) * spec/if/rtems/region/get-segment.yml (added) * spec/if/rtems/region/header.yml (added) * spec/if/rtems/region/ident.yml (added) * spec/if/rtems/region/resize-segment.yml (added) * spec/if/rtems/region/return-segment.yml (added) spec: Add /if/rtems/region/* Mon, 22 Jun 2020 06:36:48 GMT Sebastian Huber [dc70ea0] * spec/groups/api/classic/ratemon.yml (added) * spec/if/rtems/ratemon/active.yml (added) * spec/if/rtems/ratemon/cancel.yml (added) * spec/if/rtems/ratemon/create.yml (added) * spec/if/rtems/ratemon/delete.yml (added) * spec/if/rtems/ratemon/expired.yml (added) * spec/if/rtems/ratemon/get-statistics.yml (added) * spec/if/rtems/ratemon/get-status.yml (added) * spec/if/rtems/ratemon/header.yml (added) * spec/if/rtems/ratemon/ident.yml (added) * spec/if/rtems/ratemon/inactive.yml (added) * spec/if/rtems/ratemon/period-states.yml (added) * spec/if/rtems/ratemon/period-statistics.yml (added) * spec/if/rtems/ratemon/period-status-define.yml (added) * spec/if/rtems/ratemon/period-status.yml (added) * spec/if/rtems/ratemon/period.yml (added) * spec/if/rtems/ratemon/printer.yml (added) * spec/if/rtems/ratemon/report-statistics-with-plugin.yml (added) * spec/if/rtems/ratemon/report-statistics.yml (added) * spec/if/rtems/ratemon/reset-all-statistics.yml (added) * spec/if/rtems/ratemon/reset-statistics.yml (added) spec: Add /if/rtems/ratemon/* Mon, 22 Jun 2020 06:36:48 GMT Sebastian Huber [42ec363] * spec/groups/api/classic/part.yml (added) * spec/if/rtems/part/create.yml (added) * spec/if/rtems/part/delete.yml (added) * spec/if/rtems/part/get-buffer.yml (added) * spec/if/rtems/part/header.yml (added) * spec/if/rtems/part/ident.yml (added) * spec/if/rtems/part/return-buffer.yml (added) spec: Add /if/rtems/part/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [d40f9a1] * spec/groups/api/classic/object.yml (added) * spec/if/impl/object/apis-last.yml (added) * spec/if/impl/object/build-id.yml (added) * spec/if/impl/object/build-name.yml (added) * spec/if/impl/object/get-api.yml (added) * spec/if/impl/object/get-class.yml (added) * spec/if/impl/object/get-index.yml (added) * spec/if/impl/object/get-node.yml (added) * spec/if/impl/object/id-final-index.yml (added) * spec/if/impl/object/id-final.yml (added) * spec/if/impl/object/id-initial-index.yml (added) * spec/if/impl/object/id-initial.yml (added) * spec/if/impl/object/internal-api.yml (added) * spec/if/impl/object/local-node.yml (added) * spec/if/impl/object/search-all-nodes.yml (added) * spec/if/impl/object/search-local-nodes.yml (added) * spec/if/impl/object/search-other-nodes.yml (added) * spec/if/impl/object/who-am-i.yml (added) * spec/if/rtems/object/api-class-information.yml (added) * spec/if/rtems/object/api-maximum-class.yml (added) * spec/if/rtems/object/api-minimum-class.yml (added) * spec/if/rtems/object/build-id.yml (added) * spec/if/rtems/object/build-name.yml (added) * spec/if/rtems/object/get-api-class-name.yml (added) * spec/if/rtems/object/get-api-name.yml (added) * spec/if/rtems/object/get-class-information.yml (added) * spec/if/rtems/object/get-classic-name.yml (added) * spec/if/rtems/object/get-local-node.yml (added) * spec/if/rtems/object/get-name.yml (added) * spec/if/rtems/object/header.yml (added) * spec/if/rtems/object/id-api-maximum-class.yml (added) * spec/if/rtems/object/id-api-maximum.yml (added) * spec/if/rtems/object/id-api-minimum.yml (added) * spec/if/rtems/object/id-final-index.yml (added) * spec/if/rtems/object/id-final.yml (added) * spec/if/rtems/object/id-get-api.yml (added) * spec/if/rtems/object/id-get-class.yml (added) * spec/if/rtems/object/id-get-index.yml (added) * spec/if/rtems/object/id-get-node.yml (added) * spec/if/rtems/object/id-initial-index.yml (added) * spec/if/rtems/object/id-initial.yml (added) * spec/if/rtems/object/search-all-nodes.yml (added) * spec/if/rtems/object/search-local-node.yml (added) * spec/if/rtems/object/search-other-nodes.yml (added) * spec/if/rtems/object/set-name.yml (added) * spec/if/rtems/object/who-am-i.yml (added) spec: Add /if/rtems/object/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [8e0fe05] * spec/groups/api/classic/mp.yml (added) * spec/if/rtems/mp/announce.yml (added) * spec/if/rtems/mp/header.yml (added) spec: Add /if/rtems/mp/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [af77e87] * spec/groups/api/classic/message.yml (added) * spec/if/rtems/message/broadcast.yml (added) * spec/if/rtems/message/create.yml (added) * spec/if/rtems/message/delete.yml (added) * spec/if/rtems/message/flush.yml (added) * spec/if/rtems/message/get-number-pending.yml (added) * spec/if/rtems/message/header.yml (added) * spec/if/rtems/message/ident.yml (added) * spec/if/rtems/message/receive.yml (added) * spec/if/rtems/message/send.yml (added) * spec/if/rtems/message/urgent.yml (added) spec: Add /if/rtems/message/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [6bad193] * spec/groups/api/classic/io.yml (added) * spec/if/rtems/io/close.yml (added) * spec/if/rtems/io/control.yml (added) * spec/if/rtems/io/device-driver-entry.yml (added) * spec/if/rtems/io/device-driver.yml (added) * spec/if/rtems/io/device-major-number.yml (added) * spec/if/rtems/io/device-minor-number.yml (added) * spec/if/rtems/io/driver-address-table.yml (added) * spec/if/rtems/io/driver-error.yml (added) * spec/if/rtems/io/header.yml (added) * spec/if/rtems/io/initialize.yml (added) * spec/if/rtems/io/open.yml (added) * spec/if/rtems/io/printer.yml (added) * spec/if/rtems/io/read.yml (added) * spec/if/rtems/io/register-driver.yml (added) * spec/if/rtems/io/register-name.yml (added) * spec/if/rtems/io/unregister-driver.yml (added) * spec/if/rtems/io/write.yml (added) spec: Add /if/rtems/io/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [7bbafe6] * spec/groups/api/classic/intr.yml (added) * spec/if/impl/cpu/simple-vectored-interrupts.yml (added) * spec/if/impl/isr/handler-entry.yml (added) * spec/if/impl/isr/handler.yml (added) * spec/if/impl/isr/header-2.yml (added) * spec/if/impl/isr/header-3.yml (added) * spec/if/impl/isr/is-in-progress.yml (added) * spec/if/impl/isr/level.yml (added) * spec/if/impl/isr/local-disable.yml (added) * spec/if/impl/isr/local-enable.yml (added) * spec/if/impl/isr/local-flash.yml (added) * spec/if/impl/isr/lock-context.yml (added) * spec/if/impl/isr/lock-control.yml (added) * spec/if/impl/isr/lock-declare.yml (added) * spec/if/impl/isr/lock-define.yml (added) * spec/if/impl/isr/lock-destroy.yml (added) * spec/if/impl/isr/lock-initialize.yml (added) * spec/if/impl/isr/lock-initializer.yml (added) * spec/if/impl/isr/lock-isr-disable-acquire.yml (added) * spec/if/impl/isr/lock-isr-disable.yml (added) * spec/if/impl/isr/lock-member.yml (added) * spec/if/impl/isr/lock-reference.yml (added) * spec/if/impl/isr/lock-release-isr-enable.yml (added) * spec/if/impl/isr/vector-number.yml (added) * spec/if/impl/smp/header-2.yml (added) * spec/if/impl/smp/lock-acquire.yml (added) * spec/if/impl/smp/lock-release.yml (added) * spec/if/rtems/intr/catch.yml (added) * spec/if/rtems/intr/cause.yml (added) * spec/if/rtems/intr/clear.yml (added) * spec/if/rtems/intr/disable.yml (added) * spec/if/rtems/intr/enable.yml (added) * spec/if/rtems/intr/flash.yml (added) * spec/if/rtems/intr/header.yml (added) * spec/if/rtems/intr/is-in-progress.yml (added) * spec/if/rtems/intr/isr-entry.yml (added) * spec/if/rtems/intr/isr.yml (added) * spec/if/rtems/intr/level.yml (added) * spec/if/rtems/intr/local-disable.yml (added) * spec/if/rtems/intr/local-enable.yml (added) * spec/if/rtems/intr/lock-acquire-isr.yml (added) * spec/if/rtems/intr/lock-acquire.yml (added) * spec/if/rtems/intr/lock-context.yml (added) * spec/if/rtems/intr/lock-declare.yml (added) * spec/if/rtems/intr/lock-define.yml (added) * spec/if/rtems/intr/lock-destroy.yml (added) * spec/if/rtems/intr/lock-initialize.yml (added) * spec/if/rtems/intr/lock-initializer.yml (added) * spec/if/rtems/intr/lock-isr-disable.yml (added) * spec/if/rtems/intr/lock-member.yml (added) * spec/if/rtems/intr/lock-reference.yml (added) * spec/if/rtems/intr/lock-release-isr.yml (added) * spec/if/rtems/intr/lock-release.yml (added) * spec/if/rtems/intr/lock.yml (added) * spec/if/rtems/intr/vector-number.yml (added) spec: Add /if/rtems/intr/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [01643c6] * spec/groups/api/classic/fatal.yml (added) * spec/if/impl/cpu/exception-frame-print.yml (added) * spec/if/impl/cpu/exception-frame.yml (added) * spec/if/impl/interr/terminate.yml (added) * spec/if/rtems/fatal/assert-context.yml (added) * spec/if/rtems/fatal/error-occurred.yml (added) * spec/if/rtems/fatal/exception-frame-print.yml (added) * spec/if/rtems/fatal/exception-frame.yml (added) * spec/if/rtems/fatal/fatal.yml (added) * spec/if/rtems/fatal/header.yml (added) * spec/if/rtems/fatal/internal-error-text.yml (added) * spec/if/rtems/fatal/panic.yml (added) * spec/if/rtems/fatal/source-text.yml (added) spec: Add /if/rtems/fatal/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [5c30755] * spec/groups/api/classic/event.yml (added) * spec/if/rtems/event/all-events.yml (added) * spec/if/rtems/event/event-0.yml (added) * spec/if/rtems/event/event-1.yml (added) * spec/if/rtems/event/event-10.yml (added) * spec/if/rtems/event/event-11.yml (added) * spec/if/rtems/event/event-12.yml (added) * spec/if/rtems/event/event-13.yml (added) * spec/if/rtems/event/event-14.yml (added) * spec/if/rtems/event/event-15.yml (added) * spec/if/rtems/event/event-16.yml (added) * spec/if/rtems/event/event-17.yml (added) * spec/if/rtems/event/event-18.yml (added) * spec/if/rtems/event/event-19.yml (added) * spec/if/rtems/event/event-2.yml (added) * spec/if/rtems/event/event-20.yml (added) * spec/if/rtems/event/event-21.yml (added) * spec/if/rtems/event/event-22.yml (added) * spec/if/rtems/event/event-23.yml (added) * spec/if/rtems/event/event-24.yml (added) * spec/if/rtems/event/event-25.yml (added) * spec/if/rtems/event/event-26.yml (added) * spec/if/rtems/event/event-27.yml (added) * spec/if/rtems/event/event-28.yml (added) * spec/if/rtems/event/event-29.yml (added) * spec/if/rtems/event/event-3.yml (added) * spec/if/rtems/event/event-30.yml (added) * spec/if/rtems/event/event-31.yml (added) * spec/if/rtems/event/event-4.yml (added) * spec/if/rtems/event/event-5.yml (added) * spec/if/rtems/event/event-6.yml (added) * spec/if/rtems/event/event-7.yml (added) * spec/if/rtems/event/event-8.yml (added) * spec/if/rtems/event/event-9.yml (added) * spec/if/rtems/event/header.yml (added) * spec/if/rtems/event/pending-events.yml (added) * spec/if/rtems/event/receive.yml (added) * spec/if/rtems/event/send.yml (added) * spec/if/rtems/event/set.yml (added) * spec/if/rtems/event/system-network-close.yml (added) * spec/if/rtems/event/system-network-sbwait.yml (added) * spec/if/rtems/event/system-network-sosleep.yml (added) * spec/if/rtems/event/system-receive.yml (added) * spec/if/rtems/event/system-send.yml (added) * spec/if/rtems/event/system-server-resume.yml (added) * spec/if/rtems/event/system-server.yml (added) * spec/if/rtems/event/system-transient.yml (added) * spec/if/rtems/event/transient-clear.yml (added) * spec/if/rtems/event/transient-receive.yml (added) * spec/if/rtems/event/transient-send.yml (added) spec: Add /if/rtems/event/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [a720122] * spec/groups/api/classic/dpmem.yml (added) * spec/if/rtems/dpmem/create.yml (added) * spec/if/rtems/dpmem/delete.yml (added) * spec/if/rtems/dpmem/external-to-internal.yml (added) * spec/if/rtems/dpmem/header.yml (added) * spec/if/rtems/dpmem/ident.yml (added) * spec/if/rtems/dpmem/internal-to-external.yml (added) spec: Add /if/rtems/dpmem/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [9beb12d] * spec/groups/api/classic/clock.yml (added) * spec/if/c/timespec.yml (added) * spec/if/c/timeval.yml (added) * spec/if/impl/tod-to-seconds.yml (added) * spec/if/impl/tod-validate.yml (added) * spec/if/impl/watchdog/ticks-per-second.yml (added) * spec/if/impl/watchdog/ticks-since-boot.yml (added) * spec/if/rtems/clock/get-seconds-since-epoch.yml (added) * spec/if/rtems/clock/get-ticks-per-second.yml (added) * spec/if/rtems/clock/get-ticks-since-boot.yml (added) * spec/if/rtems/clock/get-tod-timeval.yml (added) * spec/if/rtems/clock/get-tod.yml (added) * spec/if/rtems/clock/get-uptime-nanoseconds.yml (added) * spec/if/rtems/clock/get-uptime-seconds.yml (added) * spec/if/rtems/clock/get-uptime-timeval.yml (added) * spec/if/rtems/clock/get-uptime.yml (added) * spec/if/rtems/clock/header.yml (added) * spec/if/rtems/clock/set.yml (added) * spec/if/rtems/clock/tick-before.yml (added) * spec/if/rtems/clock/tick-later-usec.yml (added) * spec/if/rtems/clock/tick-later.yml (added) * spec/if/rtems/clock/tick.yml (added) spec: Add /if/rtems/clock/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [99ef74b] * spec/groups/api/classic/cache.yml (added) * spec/if/rtems/cache/aligned-malloc.yml (added) * spec/if/rtems/cache/coherent-add-area.yml (added) * spec/if/rtems/cache/coherent-allocate.yml (added) * spec/if/rtems/cache/coherent-free.yml (added) * spec/if/rtems/cache/disable-data.yml (added) * spec/if/rtems/cache/disable-instruction.yml (added) * spec/if/rtems/cache/enable-data.yml (added) * spec/if/rtems/cache/enable-instruction.yml (added) * spec/if/rtems/cache/flush-entire-data.yml (added) * spec/if/rtems/cache/flush-multiple-data-lines.yml (added) * spec/if/rtems/cache/freeze-data.yml (added) * spec/if/rtems/cache/freeze-instruction.yml (added) * spec/if/rtems/cache/get-data-line-size.yml (added) * spec/if/rtems/cache/get-data-size.yml (added) * spec/if/rtems/cache/get-instruction-line-size.yml (added) * spec/if/rtems/cache/get-instruction-size.yml (added) * spec/if/rtems/cache/get-maximal-line-size.yml (added) * spec/if/rtems/cache/header.yml (added) * spec/if/rtems/cache/instruction-sync-after-code-change.yml (added) * spec/if/rtems/cache/invalidate-entire-data.yml (added) * spec/if/rtems/cache/invalidate-entire-instruction.yml (added) * spec/if/rtems/cache/invalidate-multiple-data-lines.yml (added) * spec/if/rtems/cache/invalidate-multiple-instruction-lines.yml (added) * spec/if/rtems/cache/unfreeze-data.yml (added) * spec/if/rtems/cache/unfreeze-instruction.yml (added) spec: Add /if/rtems/cache/* Mon, 22 Jun 2020 06:36:47 GMT Sebastian Huber [e27600e] * spec/groups/api/classic/barrier.yml (added) * spec/if/rtems/barrier/create.yml (added) * spec/if/rtems/barrier/delete.yml (added) * spec/if/rtems/barrier/header.yml (added) * spec/if/rtems/barrier/ident.yml (added) * spec/if/rtems/barrier/release.yml (added) * spec/if/rtems/barrier/wait.yml (added) spec: Add /if/rtems/barrier/* Mon, 15 Jun 2020 11:35:00 GMT Sebastian Huber [7d87ad3] * spec/groups/api/classic/sem.yml (added) * spec/if/rtems/sem/create.yml (added) * spec/if/rtems/sem/delete.yml (added) * spec/if/rtems/sem/flush.yml (added) * spec/if/rtems/sem/header.yml (added) * spec/if/rtems/sem/ident.yml (added) * spec/if/rtems/sem/obtain.yml (added) * spec/if/rtems/sem/release.yml (added) * spec/if/rtems/sem/set-priority.yml (added) spec: Add /if/rtems/sem/* Fri, 05 Jun 2020 07:56:10 GMT Sebastian Huber [a243fc6] * spec/groups/api/classic/tasks.yml (added) * spec/if/c/cpu_set_t.yml (added) * spec/if/impl/cpu/uint32ptr.yml (added) * spec/if/impl/maximum-priority.yml (added) * spec/if/impl/object/id-of-self.yml (added) * spec/if/impl/smp/get-current-processor.yml (added) * spec/if/impl/smp/get-processor-maximum.yml (added) * spec/if/impl/stack/minimum-size.yml (added) * spec/if/impl/watchdog/no-timeout.yml (added) * spec/if/rtems/config/api-table.yml (modified) * spec/if/rtems/scheduler/add-processor.yml (added) * spec/if/rtems/scheduler/get-maximum-priority.yml (added) * spec/if/rtems/scheduler/get-processor-maximum.yml (added) * spec/if/rtems/scheduler/get-processor-set.yml (added) * spec/if/rtems/scheduler/get-processor.yml (added) * spec/if/rtems/scheduler/ident-by-processor-set.yml (added) * spec/if/rtems/scheduler/ident-by-processor.yml (added) * spec/if/rtems/scheduler/ident.yml (added) * spec/if/rtems/scheduler/map-priority-from-posix.yml (added) * spec/if/rtems/scheduler/map-priority-to-posix.yml (added) * spec/if/rtems/scheduler/remove-processor.yml (added) * spec/if/rtems/tasks/argument.yml (added) * spec/if/rtems/tasks/build.yml (added) * spec/if/rtems/tasks/config.yml (added) * spec/if/rtems/tasks/configured-minimum-stack-size.yml (added) * spec/if/rtems/tasks/create.yml (added) * spec/if/rtems/tasks/current-priority.yml (added) * spec/if/rtems/tasks/delete.yml (added) * spec/if/rtems/tasks/entry.yml (added) * spec/if/rtems/tasks/exit.yml (added) * spec/if/rtems/tasks/get-affinity.yml (added) * spec/if/rtems/tasks/get-priority.yml (added) * spec/if/rtems/tasks/get-scheduler.yml (added) * spec/if/rtems/tasks/header.yml (added) * spec/if/rtems/tasks/ident.yml (added) * spec/if/rtems/tasks/initialization-table.yml (added) * spec/if/rtems/tasks/is-suspended.yml (added) * spec/if/rtems/tasks/iterate.yml (added) * spec/if/rtems/tasks/maximum-priority.yml (added) * spec/if/rtems/tasks/minimum-priority.yml (added) * spec/if/rtems/tasks/minimum-stack-size.yml (added) * spec/if/rtems/tasks/mode.yml (added) * spec/if/rtems/tasks/no-priority.yml (added) * spec/if/rtems/tasks/priority.yml (added) * spec/if/rtems/tasks/restart.yml (added) * spec/if/rtems/tasks/resume.yml (added) * spec/if/rtems/tasks/self-define.yml (added) * spec/if/rtems/tasks/self.yml (added) * spec/if/rtems/tasks/set-affinity.yml (added) * spec/if/rtems/tasks/set-priority.yml (added) * spec/if/rtems/tasks/set-scheduler.yml (added) * spec/if/rtems/tasks/start.yml (added) * spec/if/rtems/tasks/suspend.yml (added) * spec/if/rtems/tasks/task.yml (added) * spec/if/rtems/tasks/tcb.yml (added) * spec/if/rtems/tasks/visitor.yml (added) * spec/if/rtems/tasks/wake-after.yml (added) * spec/if/rtems/tasks/wake-when.yml (added) * spec/if/rtems/tasks/yield-processor.yml (added) spec: Add /if/rtems/tasks/* Fri, 05 Jun 2020 12:19:45 GMT Sebastian Huber [54e2231] * spec/groups/api/classic/attr.yml (added) * spec/if/rtems/attr/application-task.yml (added) * spec/if/rtems/attr/attribute.yml (added) * spec/if/rtems/attr/barrier-automatic-release.yml (added) * spec/if/rtems/attr/barrier-manual-release.yml (added) * spec/if/rtems/attr/binary-semaphore.yml (added) * spec/if/rtems/attr/counting-semaphore.yml (added) * spec/if/rtems/attr/default-attributes.yml (added) * spec/if/rtems/attr/fifo.yml (added) * spec/if/rtems/attr/floating-point.yml (added) * spec/if/rtems/attr/global.yml (added) * spec/if/rtems/attr/header.yml (added) * spec/if/rtems/attr/inherit-priority.yml (added) * spec/if/rtems/attr/local.yml (added) * spec/if/rtems/attr/multiprocessor-resource-sharing.yml (added) * spec/if/rtems/attr/no-floating-point.yml (added) * spec/if/rtems/attr/no-inherit-priority.yml (added) * spec/if/rtems/attr/no-multiprocessor-resource-sharing.yml (added) * spec/if/rtems/attr/no-priority-ceiling.yml (added) * spec/if/rtems/attr/priority-ceiling.yml (added) * spec/if/rtems/attr/priority.yml (added) * spec/if/rtems/attr/semaphore-class.yml (added) * spec/if/rtems/attr/simple-binary-semaphore.yml (added) * spec/if/rtems/attr/system-task.yml (added) spec: Add /if/rtems/attr/* Fri, 29 May 2020 08:17:44 GMT Sebastian Huber [94f668f] * spec/groups/api/classic/types.yml (added) * spec/if/c/sys-cpuset.yml (added) * spec/if/c/sys-impl-timespec.yml (added) * spec/if/c/sys-impl-timeval.yml (added) * spec/if/impl/cpu/header.yml (added) * spec/if/impl/cpu/interrupt-frame.yml (added) * spec/if/impl/cpu/isr-passes-frame-pointer.yml (added) * spec/if/impl/mpci/configuration-type.yml (added) * spec/if/impl/mpci/control.yml (added) * spec/if/impl/mpci/entry.yml (added) * spec/if/impl/mpci/get-packet-entry.yml (added) * spec/if/impl/mpci/header-2.yml (added) * spec/if/impl/mpci/initialization-entry.yml (added) * spec/if/impl/mpci/packet-classes.yml (added) * spec/if/impl/mpci/packet-minimum-hetero-conversion.yml (added) * spec/if/impl/mpci/packet-minimum-size.yml (added) * spec/if/impl/mpci/packet-prefix.yml (added) * spec/if/impl/mpci/receive-entry.yml (added) * spec/if/impl/mpci/return-packet-entry.yml (added) * spec/if/impl/mpci/send-entry.yml (added) * spec/if/impl/object/id-none.yml (added) * spec/if/impl/object/id.yml (added) * spec/if/impl/watchdog/interval.yml (added) * spec/if/rtems/types/header.yml (modified) * spec/if/rtems/types/id-none.yml (added) * spec/if/rtems/types/id.yml (added) * spec/if/rtems/types/interval.yml (added) * spec/if/rtems/types/minimum-packet-size.yml (added) * spec/if/rtems/types/minimun-hetero-conversion.yml (added) * spec/if/rtems/types/mp-packet-classes.yml (added) * spec/if/rtems/types/mpci-entry.yml (added) * spec/if/rtems/types/mpci-get-packet-entry.yml (added) * spec/if/rtems/types/mpci-initialization-entry.yml (added) * spec/if/rtems/types/mpci-receive-packet-entry.yml (added) * spec/if/rtems/types/mpci-return-packet-entry.yml (added) * spec/if/rtems/types/mpci-send-packet-entry.yml (added) * spec/if/rtems/types/mpci-table.yml (added) * spec/if/rtems/types/multiprocessing-table.yml (added) * spec/if/rtems/types/name.yml (added) * spec/if/rtems/types/no-timeout.yml (added) * spec/if/rtems/types/packet-prefix.yml (added) * spec/if/rtems/types/time-of-day.yml (added) spec: Add /if/rtems/types/* Thu, 04 Jun 2020 17:53:20 GMT Sebastian Huber [01ae66a] * spec/groups/api/classic/options.yml (added) * spec/if/rtems/options/default-options.yml (added) * spec/if/rtems/options/event-all.yml (added) * spec/if/rtems/options/event-any.yml (added) * spec/if/rtems/options/header.yml (added) * spec/if/rtems/options/no-wait.yml (added) * spec/if/rtems/options/option.yml (added) * spec/if/rtems/options/wait.yml (added) spec: Add /if/rtems/options/* Thu, 04 Jun 2020 14:57:10 GMT Sebastian Huber [773e572] * spec/groups/api/classic/modes.yml (added) * spec/if/impl/cpu/modes-interrupt-mask.yml (added) * spec/if/rtems/modes/all-mode-masks.yml (added) * spec/if/rtems/modes/asr-mask.yml (added) * spec/if/rtems/modes/asr.yml (added) * spec/if/rtems/modes/current-mode.yml (added) * spec/if/rtems/modes/default-modes.yml (added) * spec/if/rtems/modes/header.yml (added) * spec/if/rtems/modes/interrupt-level-body.yml (added) * spec/if/rtems/modes/interrupt-level.yml (added) * spec/if/rtems/modes/interrupt-mask-variable.yml (added) * spec/if/rtems/modes/interrupt-mask.yml (added) * spec/if/rtems/modes/mode.yml (added) * spec/if/rtems/modes/no-asr.yml (added) * spec/if/rtems/modes/no-preempt.yml (added) * spec/if/rtems/modes/no-timeslice.yml (added) * spec/if/rtems/modes/preempt-mask.yml (added) * spec/if/rtems/modes/preempt.yml (added) * spec/if/rtems/modes/timeslice-mask.yml (added) * spec/if/rtems/modes/timeslice.yml (added) spec: Add /if/rtems/modes/* Wed, 24 Jun 2020 09:09:24 GMT Sebastian Huber [37b4b1d] * spec/if/impl/cpu/hardware-fp.yml (added) * spec/if/rtems/config/get-copyright-notice.yml (added) * spec/if/rtems/config/get-user-multiprocessing-table.yml (modified) * spec/if/rtems/config/get-version-string.yml (added) * spec/if/rtems/config/has-hardware-fp.yml (added) spec: Add /if/rtems/config/* Wed, 24 Jun 2020 10:44:15 GMT Sebastian Huber [fb558c8] * spec/if/compiler/asm.yml (added) * spec/if/rtems/basedefs/compiler-memory-barrier.yml (modified) * spec/if/rtems/basedefs/define-global-symbol.yml (modified) * spec/if/rtems/basedefs/obfuscate-variable.yml (modified) spec: Improve /if/rtems/basedefs/* Tue, 16 Jun 2020 09:09:53 GMT Sebastian Huber [c6aa66b] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/func.yml (modified) * rtemsqual/tests/test_interface.py (modified) * spec/if/rtems/config/api-table.yml (modified) interface: Support automatic Doxygen links Tue, 30 Jun 2020 06:10:01 GMT Richi Dubey [26c1df5] * spec/glossary/apa.yml (added) * spec/glossary/strongapa.yml (added) * spec/glossary/weakapa.yml (added) Added APA terms in glossary Wed, 17 Jun 2020 13:51:05 GMT Sebastian Huber [5ccfba6] * spec/acfg/opt/disablebspsettings.yml (modified) * spec/acfg/opt/filesystemall.yml (modified) * spec/acfg/opt/imfsmemfilebytesperblock.yml (modified) * spec/acfg/opt/scheduleruser.yml (modified) * spec/acfg/opt/taskstackallocator.yml (modified) * spec/acfg/opt/taskstackallocatorinit.yml (modified) * spec/acfg/opt/taskstackdeallocator.yml (modified) * spec/acfg/opt/usedevfsasbasefilesystem.yml (modified) * spec/acfg/opt/useminiimfsasbasefilesystem.yml (modified) spec: Use * for list items Wed, 17 Jun 2020 07:12:03 GMT Sebastian Huber [5d3f70a] * spec/spec/requirement-action-transition.yml (modified) * spec/spec/requirement-action.yml (modified) spec: Clarify action requirements Wed, 10 Jun 2020 09:09:44 GMT Sebastian Huber [4c5c9c3] * spec/spec/requirement-action.yml (modified) spec: Fix typo Wed, 10 Jun 2020 07:52:45 GMT Sebastian Huber [ca159fc] * spec/spec/requirement-action-test-header.yml (added) * spec/spec/requirement-action-test-run-param-list.yml (added) * spec/spec/requirement-action-test-run-param.yml (added) * spec/spec/requirement-action.yml (modified) spec: Specify action requirement test headers Fri, 05 Jun 2020 05:11:12 GMT Sebastian Huber [7bd6817] * spec/spec/requirement-functional-generic.yml (added) * spec/spec/requirement-functional-type.yml (deleted) * spec/spec/requirement-functional.yml (modified) staging: Fix functional requirement item types Thu, 04 Jun 2020 13:23:48 GMT Sebastian Huber [021e0eb] * spec/glossary/abi.yml (modified) * spec/glossary/api.yml (modified) * spec/glossary/asr.yml (modified) * spec/glossary/bsp.yml (modified) * spec/glossary/ccb.yml (modified) * spec/glossary/cpu.yml (modified) * spec/glossary/crt.yml (modified) * spec/glossary/ears.yml (modified) * spec/glossary/elf.yml (modified) * spec/glossary/fifo.yml (modified) * spec/glossary/gcc.yml (modified) * spec/glossary/gnu.yml (modified) * spec/glossary/io.yml (modified) * spec/glossary/isr.yml (modified) * spec/glossary/isvv.yml (modified) * spec/glossary/mcs.yml (modified) * spec/glossary/mpci.yml (modified) * spec/glossary/numa.yml (modified) * spec/glossary/ptcb.yml (modified) * spec/glossary/pxcb.yml (modified) * spec/glossary/qcb.yml (modified) * spec/glossary/reqif.yml (modified) * spec/glossary/rncb.yml (modified) * spec/glossary/rtems.yml (modified) * spec/glossary/smcb.yml (modified) * spec/glossary/smp.yml (modified) * spec/glossary/tas.yml (modified) * spec/glossary/tcb.yml (modified) * spec/glossary/tls.yml (modified) * spec/glossary/tmcb.yml (modified) * spec/glossary/ttas.yml (modified) * spec/glossary/yaml.yml (modified) spec: Use a complete sentence for acronyms Mon, 08 Jun 2020 06:45:01 GMT Sebastian Huber [1a58bbe] * spec/spec/interface-function-role.yml (modified) * spec/spec/requirement-action-condition-list.yml (moved) * spec/spec/requirement-action-condition.yml (moved) * spec/spec/requirement-action-name.yml (moved) * spec/spec/requirement-action-state-list.yml (moved) * spec/spec/requirement-action-state.yml (moved) * spec/spec/requirement-action-test-context-list.yml (moved) * spec/spec/requirement-action-test-context.yml (moved) * spec/spec/requirement-action-test-fixture.yml (moved) * spec/spec/requirement-action-transition-list.yml (moved) * spec/spec/requirement-action-transition-post.yml (moved) * spec/spec/requirement-action-transition-pre-states.yml (moved) * spec/spec/requirement-action-transition-pre.yml (moved) * spec/spec/requirement-action-transition.yml (moved) * spec/spec/requirement-action.yml (moved) spec: Generalize directive to action requirements Fri, 05 Jun 2020 05:25:50 GMT Sebastian Huber [17e293d] * spec/spec/requirement-directive-test-fixture.yml (modified) spec: Fix specification type Thu, 04 Jun 2020 07:57:22 GMT Sebastian Huber [9c978899] * spec/spec/interface-function-role.yml (added) * spec/spec/requirement-directive-condition-list.yml (added) * spec/spec/requirement-directive-condition.yml (added) * spec/spec/requirement-directive-name.yml (added) * spec/spec/requirement-directive-state-list.yml (added) * spec/spec/requirement-directive-state.yml (added) * spec/spec/requirement-directive-test-context-list.yml (added) * spec/spec/requirement-directive-test-context.yml (added) * spec/spec/requirement-directive-test-fixture.yml (added) * spec/spec/requirement-directive-transition-list.yml (added) * spec/spec/requirement-directive-transition-post.yml (added) * spec/spec/requirement-directive-transition-pre-states.yml (added) * spec/spec/requirement-directive-transition-pre.yml (added) * spec/spec/requirement-directive-transition.yml (added) * spec/spec/requirement-directive.yml (added) * spec/spec/requirement-functional-type.yml (modified) spec: Specify directive requirement items Thu, 04 Jun 2020 08:53:57 GMT Sebastian Huber [e5d1f8d] * rtemsqual/specdoc.py (modified) * rtemsqual/specverify.py (modified) * rtemsqual/tests/spec-doc/b.yml (modified) * rtemsqual/tests/spec-doc/root.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-attributes.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-dict.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-generic-attributes.yml (modified) * rtemsqual/tests/spec-verify/spec2/any-dict.yml (modified) * rtemsqual/tests/test_specdoc.py (modified) * rtemsqual/tests/test_specverify.py (modified) * spec/spec/build-action-set-test-state.yml (modified) * spec/spec/spec-attributes.yml (modified) * spec/spec/spec-dict.yml (modified) * spec/spec/spec-generic-attributes.yml (modified) spec: Define generic attribute key types Thu, 04 Jun 2020 08:34:56 GMT Sebastian Huber [9499f8b] * rtemsqual/specdoc.py (modified) * rtemsqual/specverify.py (modified) * rtemsqual/tests/spec-doc/a.yml (modified) * rtemsqual/tests/spec-doc/b.yml (modified) * rtemsqual/tests/spec-doc/c.yml (modified) * rtemsqual/tests/spec-doc/d.yml (modified) * rtemsqual/tests/spec-doc/root.yml (modified) * rtemsqual/tests/spec-verify/spec/enabled-by.yml (modified) * rtemsqual/tests/spec-verify/spec/link.yml (modified) * rtemsqual/tests/spec-verify/spec/root.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-float-list.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-float.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-int-list.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-int.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-str-list.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-str.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-attribute-value.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-attributes.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-bool.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-dict.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-float.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-generic-attributes.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-info.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-int.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-list.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-mandatory-attributes.yml (moved) * rtemsqual/tests/spec-verify/spec/spec-member.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-refinement.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-str.yml (modified) * rtemsqual/tests/spec-verify/spec/spec.yml (modified) * rtemsqual/tests/spec-verify/spec2/any-dict.yml (modified) * rtemsqual/tests/spec-verify/spec2/c.yml (modified) * rtemsqual/tests/spec-verify/spec2/d-a.yml (modified) * rtemsqual/tests/spec-verify/spec2/d.yml (modified) * rtemsqual/tests/spec-verify/spec2/invalid.yml (modified) * rtemsqual/tests/spec-verify/spec2/keys-at-least-one.yml (modified) * rtemsqual/tests/spec-verify/spec2/keys-at-most-one.yml (modified) * rtemsqual/tests/spec-verify/spec2/keys-exactly-one.yml (modified) * rtemsqual/tests/spec-verify/spec2/some-dict.yml (modified) * rtemsqual/tests/test_specdoc.py (modified) * rtemsqual/tests/test_specverify.py (modified) * spec/spec/appl-config-group-member.yml (modified) * spec/spec/appl-config-group.yml (modified) * spec/spec/appl-config-option-constraints.yml (modified) * spec/spec/appl-config-option-feature-enable.yml (modified) * spec/spec/appl-config-option-feature.yml (modified) * spec/spec/appl-config-option-value.yml (modified) * spec/spec/appl-config-option.yml (modified) * spec/spec/build-action-check-cc.yml (modified) * spec/spec/build-action-check-cxx.yml (modified) * spec/spec/build-action-set-test-state.yml (modified) * spec/spec/build-action.yml (modified) * spec/spec/build-ada-test-program.yml (modified) * spec/spec/build-bsp.yml (modified) * spec/spec/build-config-file.yml (modified) * spec/spec/build-config-header.yml (modified) * spec/spec/build-default-by-variant.yml (modified) * spec/spec/build-dependency.yml (modified) * spec/spec/build-group.yml (modified) * spec/spec/build-install.yml (modified) * spec/spec/build-library.yml (modified) * spec/spec/build-objects.yml (modified) * spec/spec/build-option.yml (modified) * spec/spec/build-script.yml (modified) * spec/spec/build-start-file.yml (modified) * spec/spec/build-test-program.yml (modified) * spec/spec/build.yml (modified) * spec/spec/constraint-role.yml (modified) * spec/spec/constraint.yml (modified) * spec/spec/enabled-by.yml (modified) * spec/spec/glossary-group.yml (modified) * spec/spec/glossary-member.yml (modified) * spec/spec/glossary-term.yml (modified) * spec/spec/glossary.yml (modified) * spec/spec/interface-compound.yml (modified) * spec/spec/interface-container.yml (modified) * spec/spec/interface-define.yml (modified) * spec/spec/interface-definition-directive.yml (modified) * spec/spec/interface-definition-variant.yml (modified) * spec/spec/interface-domain.yml (modified) * spec/spec/interface-enabled-by.yml (modified) * spec/spec/interface-enum.yml (modified) * spec/spec/interface-enumerator-role.yml (modified) * spec/spec/interface-enumerator.yml (modified) * spec/spec/interface-forward-declaration.yml (modified) * spec/spec/interface-function-definition-directive.yml (modified) * spec/spec/interface-function-definition-variant.yml (modified) * spec/spec/interface-function-definition.yml (modified) * spec/spec/interface-function.yml (modified) * spec/spec/interface-group.yml (modified) * spec/spec/interface-header-file.yml (modified) * spec/spec/interface-include.yml (modified) * spec/spec/interface-ingroup.yml (modified) * spec/spec/interface-macro.yml (modified) * spec/spec/interface-member-compound.yml (modified) * spec/spec/interface-member-declaration.yml (modified) * spec/spec/interface-member-definition-directive.yml (modified) * spec/spec/interface-member-definition-variant.yml (modified) * spec/spec/interface-member-definition.yml (modified) * spec/spec/interface-param.yml (modified) * spec/spec/interface-placement.yml (modified) * spec/spec/interface-return-directive.yml (modified) * spec/spec/interface-return-value.yml (modified) * spec/spec/interface-target.yml (modified) * spec/spec/interface-typedef.yml (modified) * spec/spec/interface-unspecified.yml (modified) * spec/spec/interface-variable.yml (modified) * spec/spec/interface.yml (modified) * spec/spec/link.yml (modified) * spec/spec/requirement-functional.yml (modified) * spec/spec/requirement-non-functional.yml (modified) * spec/spec/requirement-reference.yml (modified) * spec/spec/requirement-refinement.yml (modified) * spec/spec/requirement-validation-role.yml (modified) * spec/spec/requirement-validation.yml (modified) * spec/spec/requirement.yml (modified) * spec/spec/root.yml (modified) * spec/spec/spec-assert-float.yml (modified) * spec/spec/spec-assert-int.yml (modified) * spec/spec/spec-assert-str.yml (modified) * spec/spec/spec-attribute-value.yml (modified) * spec/spec/spec-attributes.yml (modified) * spec/spec/spec-bool.yml (modified) * spec/spec/spec-dict.yml (modified) * spec/spec/spec-float.yml (modified) * spec/spec/spec-generic-attributes.yml (modified) * spec/spec/spec-info.yml (modified) * spec/spec/spec-int.yml (modified) * spec/spec/spec-list.yml (modified) * spec/spec/spec-mandatory-attributes.yml (moved) * spec/spec/spec-member.yml (modified) * spec/spec/spec-refinement.yml (modified) * spec/spec/spec-str.yml (modified) * spec/spec/spec.yml (modified) * spec/spec/test-case-action.yml (modified) * spec/spec/test-case-check.yml (modified) * spec/spec/test-case.yml (modified) * spec/spec/test-platform.yml (modified) * spec/spec/test-procedure.yml (modified) * spec/spec/test-suite.yml (modified) spec: Rename required in mandatory attributes The term "required" ... Thu, 04 Jun 2020 07:56:51 GMT Sebastian Huber [f990475] * spec/spec/spec.yml (modified) * spec/spec/test-case.yml (modified) spec: Canonicalize descriptions Wed, 03 Jun 2020 14:52:55 GMT Sebastian Huber [d073590] * spec/spec/requirement.yml (modified) * spec/spec/test-platform.yml (modified) spec: Fix attribute order Fri, 29 May 2020 07:09:47 GMT Sebastian Huber [c17dd4c] * spec/if/rtems/config/get-api-configuration.yml (modified) * spec/if/rtems/config/header.yml (modified) spec: Fix /if/rtems/config/* Fri, 29 May 2020 06:18:51 GMT Sebastian Huber [fbc190c] * spec/spec/test-platform.yml (added) * spec/spec/test-procedure.yml (added) spec: Add test procedure and platform types Thu, 04 Jun 2020 12:15:49 GMT Sebastian Huber [84280e6] * config.yml (modified) * rtemsqual/glossary.py (modified) * rtemsqual/tests/spec-glossary/g.yml (moved) * rtemsqual/tests/spec-glossary/glossary/t.yml (moved) * rtemsqual/tests/spec-glossary/glossary/u.yml (moved) * rtemsqual/tests/spec-glossary/glossary/v.yml (moved) * rtemsqual/tests/test_glossary.py (modified) * spec/glossary-general.yml (moved) * spec/glossary/abi.yml (moved) * spec/glossary/active.yml (moved) * spec/glossary/aperiodictask.yml (moved) * spec/glossary/api.yml (moved) * spec/glossary/application.yml (moved) * spec/glossary/asr.yml (moved) * spec/glossary/assemblerlanguage.yml (moved) * spec/glossary/asynchronous.yml (moved) * spec/glossary/asynchronoussignalroutine.yml (moved) * spec/glossary/atomicoperations.yml (moved) * spec/glossary/awakened.yml (moved) * spec/glossary/bigendian.yml (moved) * spec/glossary/bitmapped.yml (moved) * spec/glossary/block.yml (moved) * spec/glossary/blockedtask.yml (moved) * spec/glossary/boardsupportpackage.yml (moved) * spec/glossary/broadcast.yml (moved) * spec/glossary/bsp.yml (moved) * spec/glossary/buffer.yml (moved) * spec/glossary/c11.yml (moved) * spec/glossary/callingconvention.yml (moved) * spec/glossary/ccb.yml (moved) * spec/glossary/centralprocessingunit.yml (moved) * spec/glossary/chain.yml (moved) * spec/glossary/clanguage.yml (moved) * spec/glossary/cluster.yml (moved) * spec/glossary/coalesce.yml (moved) * spec/glossary/configurationtable.yml (moved) * spec/glossary/context.yml (moved) * spec/glossary/contextswitch.yml (moved) * spec/glossary/controlblock.yml (moved) * spec/glossary/core.yml (moved) * spec/glossary/cpu.yml (moved) * spec/glossary/criticalsection.yml (moved) * spec/glossary/crt.yml (moved) * spec/glossary/cxx11.yml (moved) * spec/glossary/deadline.yml (moved) * spec/glossary/device.yml (moved) * spec/glossary/devicedriver.yml (moved) * spec/glossary/devicedrivertable.yml (moved) * spec/glossary/directives.yml (moved) * spec/glossary/dispatch.yml (moved) * spec/glossary/doorstop.yml (moved) * spec/glossary/dormant.yml (moved) * spec/glossary/dualported.yml (moved) * spec/glossary/ears.yml (moved) * spec/glossary/elf.yml (moved) * spec/glossary/embedded.yml (moved) * spec/glossary/entrypoint.yml (moved) * spec/glossary/envelope.yml (moved) * spec/glossary/errorcode.yml (moved) * spec/glossary/events.yml (moved) * spec/glossary/exception.yml (moved) * spec/glossary/executingtask.yml (moved) * spec/glossary/executive.yml (moved) * spec/glossary/exported.yml (moved) * spec/glossary/externaladdress.yml (moved) * spec/glossary/fifo.yml (moved) * spec/glossary/firstinfirstout.yml (moved) * spec/glossary/floatingpointcoprocessor.yml (moved) * spec/glossary/freed.yml (moved) * spec/glossary/gcc.yml (moved) * spec/glossary/global.yml (moved) * spec/glossary/gnat.yml (moved) * spec/glossary/gnu.yml (moved) * spec/glossary/handler.yml (moved) * spec/glossary/hardrealtimesystem.yml (moved) * spec/glossary/heap.yml (moved) * spec/glossary/heirtask.yml (moved) * spec/glossary/heterogeneous.yml (moved) * spec/glossary/homogeneous.yml (moved) * spec/glossary/id.yml (moved) * spec/glossary/idletask.yml (moved) * spec/glossary/interface.yml (moved) * spec/glossary/internaladdress.yml (moved) * spec/glossary/interrupt.yml (moved) * spec/glossary/interruptlevel.yml (moved) * spec/glossary/interruptservice.yml (moved) * spec/glossary/interruptserviceroutine.yml (moved) * spec/glossary/io.yml (moved) * spec/glossary/isr.yml (moved) * spec/glossary/isvv.yml (moved) * spec/glossary/kernel.yml (moved) * spec/glossary/list.yml (moved) * spec/glossary/littleendian.yml (moved) * spec/glossary/local.yml (moved) * spec/glossary/localoperation.yml (moved) * spec/glossary/logicaladdress.yml (moved) * spec/glossary/looselycoupled.yml (moved) * spec/glossary/majornumber.yml (moved) * spec/glossary/manager.yml (moved) * spec/glossary/mcs.yml (moved) * spec/glossary/memorypool.yml (moved) * spec/glossary/message.yml (moved) * spec/glossary/messagebuffer.yml (moved) * spec/glossary/messagequeue.yml (moved) * spec/glossary/messagequeuecontrolblock.yml (moved) * spec/glossary/minornumber.yml (moved) * spec/glossary/mode.yml (moved) * spec/glossary/mpci.yml (moved) * spec/glossary/multiprocessing.yml (moved) * spec/glossary/multiprocessor.yml (moved) * spec/glossary/multiprocessorcommunicationsinterfacelayer.yml (moved) * spec/glossary/multiprocessorconfigurationtable.yml (moved) * spec/glossary/multitasking.yml (moved) * spec/glossary/mutualexclusion.yml (moved) * spec/glossary/nested.yml (moved) * spec/glossary/node.yml (moved) * spec/glossary/nonexistent.yml (moved) * spec/glossary/numa.yml (moved) * spec/glossary/numericcoprocessor.yml (moved) * spec/glossary/object.yml (moved) * spec/glossary/objectoriented.yml (moved) * spec/glossary/operatingsystem.yml (moved) * spec/glossary/overhead.yml (moved) * spec/glossary/packet.yml (moved) * spec/glossary/partition.yml (moved) * spec/glossary/partitioncontrolblock.yml (moved) * spec/glossary/pending.yml (moved) * spec/glossary/periodictask.yml (moved) * spec/glossary/physicaladdress.yml (moved) * spec/glossary/poll.yml (moved) * spec/glossary/pool.yml (moved) * spec/glossary/portability.yml (moved) * spec/glossary/posting.yml (moved) * spec/glossary/preempt.yml (moved) * spec/glossary/priority.yml (moved) * spec/glossary/priorityboosting.yml (moved) * spec/glossary/priorityinheritance.yml (moved) * spec/glossary/priorityinversion.yml (moved) * spec/glossary/processorutilization.yml (moved) * spec/glossary/proxy.yml (moved) * spec/glossary/proxycontrolblock.yml (moved) * spec/glossary/ptcb.yml (moved) * spec/glossary/pxcb.yml (moved) * spec/glossary/qcb.yml (moved) * spec/glossary/quantum.yml (moved) * spec/glossary/queue.yml (moved) * spec/glossary/readytask.yml (moved) * spec/glossary/realtime.yml (moved) * spec/glossary/reentrant.yml (moved) * spec/glossary/region.yml (moved) * spec/glossary/regioncontrolblock.yml (moved) * spec/glossary/registers.yml (moved) * spec/glossary/remote.yml (moved) * spec/glossary/remoteoperation.yml (moved) * spec/glossary/reqif.yml (moved) * spec/glossary/resource.yml (moved) * spec/glossary/resume.yml (moved) * spec/glossary/returncode.yml (moved) * spec/glossary/returnvalue.yml (moved) * spec/glossary/rncb.yml (moved) * spec/glossary/roundrobin.yml (moved) * spec/glossary/rs232.yml (moved) * spec/glossary/rtems.yml (moved) * spec/glossary/running.yml (moved) * spec/glossary/schedulable.yml (moved) * spec/glossary/schedule.yml (moved) * spec/glossary/scheduledtask.yml (moved) * spec/glossary/scheduler.yml (moved) * spec/glossary/schedulerinstance.yml (moved) * spec/glossary/segments.yml (moved) * spec/glossary/semaphore.yml (moved) * spec/glossary/semaphorecontrolblock.yml (moved) * spec/glossary/sharedmemory.yml (moved) * spec/glossary/signal.yml (moved) * spec/glossary/signalset.yml (moved) * spec/glossary/smcb.yml (moved) * spec/glossary/smp.yml (moved) * spec/glossary/smpbarriers.yml (moved) * spec/glossary/smplocks.yml (moved) * spec/glossary/softrealtimesystem.yml (moved) * spec/glossary/softwarecomponent.yml (moved) * spec/glossary/softwareitem.yml (moved) * spec/glossary/softwareproduct.yml (moved) * spec/glossary/softwareunit.yml (moved) * spec/glossary/sourcecode.yml (moved) * spec/glossary/sporadictask.yml (moved) * spec/glossary/stack.yml (moved) * spec/glossary/statuscode.yml (moved) * spec/glossary/suspend.yml (moved) * spec/glossary/synchronous.yml (moved) * spec/glossary/systemcall.yml (moved) * spec/glossary/target.yml (moved) * spec/glossary/tas.yml (moved) * spec/glossary/task.yml (moved) * spec/glossary/taskcontrolblock.yml (moved) * spec/glossary/taskmigration.yml (moved) * spec/glossary/taskprocessoraffinity.yml (moved) * spec/glossary/taskswitch.yml (moved) * spec/glossary/tcb.yml (moved) * spec/glossary/thread.yml (moved) * spec/glossary/threaddispatch.yml (moved) * spec/glossary/tick.yml (moved) * spec/glossary/tightlycoupled.yml (moved) * spec/glossary/timeout.yml (moved) * spec/glossary/timer.yml (moved) * spec/glossary/timercontrolblock.yml (moved) * spec/glossary/timeslice.yml (moved) * spec/glossary/timeslicing.yml (moved) * spec/glossary/tls.yml (moved) * spec/glossary/tmcb.yml (moved) * spec/glossary/transientoverload.yml (moved) * spec/glossary/ttas.yml (moved) * spec/glossary/userextensions.yml (moved) * spec/glossary/userextensiontable.yml (moved) * spec/glossary/userinitializationtaskstable.yml (moved) * spec/glossary/userprovided.yml (moved) * spec/glossary/usersupplied.yml (moved) * spec/glossary/vector.yml (moved) * spec/glossary/waitqueue.yml (moved) * spec/glossary/yaml.yml (moved) * spec/glossary/yield.yml (moved) * spec/spec/interface.yml (modified) * spec/spec/requirement-validation.yml (modified) * spec/spec/root.yml (modified) spec: Move glossary terms The previous structure was a relict of ... Thu, 04 Jun 2020 12:17:31 GMT Sebastian Huber [41d93f4] * spec/applconfig.yml (modified) * spec/glossary.yml (modified) spec: Add missing references attributes Thu, 28 May 2020 08:26:10 GMT Sebastian Huber [51d5741] * spec/spec/requirement-reference-list.yml (added) * spec/spec/requirement-reference-type.yml (added) * spec/spec/requirement-reference.yml (added) * spec/spec/requirement.yml (modified) spec: Add requirement references Thu, 28 May 2020 08:04:45 GMT Sebastian Huber [8832112] * spec/spec/interface.yml (modified) * spec/spec/link.yml (modified) * spec/spec/requirement-validation.yml (modified) * spec/spec/root.yml (modified) spec: Add content from engineering manual Thu, 28 May 2020 06:54:25 GMT Sebastian Huber [614b988] * spec/spec/build-ada-test-program.yml (modified) * spec/spec/build-bsp.yml (modified) * spec/spec/build-config-file.yml (modified) * spec/spec/build-group.yml (modified) * spec/spec/build-library.yml (modified) * spec/spec/build-objects.yml (modified) * spec/spec/build-option.yml (modified) * spec/spec/build-script.yml (modified) * spec/spec/build-start-file.yml (modified) * spec/spec/build-test-program.yml (modified) * spec/spec/enabled-by.yml (modified) * spec/spec/requirement.yml (modified) spec: Add examples Thu, 28 May 2020 06:47:13 GMT Sebastian Huber [f4eac19] * spec/spec/appl-config-option.yml (modified) * spec/spec/interface-description.yml (modified) spec: Reuse interface description and notes Thu, 28 May 2020 06:42:59 GMT Sebastian Huber [adb6e23] * rtemsqual/specverify.py (modified) * spec/spec/requirement-text.yml (modified) specverify: Improve contains operation Thu, 28 May 2020 05:08:55 GMT Sebastian Huber [a469257] * spec/spec/copyright.yml (modified) * spec/spec/requirement-functional-type.yml (modified) * spec/spec/requirement-non-functional-type.yml (modified) * spec/spec/spdx-license-identifier.yml (modified) * spec/spec/spec-assert-float-list.yml (modified) * spec/spec/spec-assert-float.yml (modified) * spec/spec/spec-assert-int-list.yml (modified) * spec/spec/spec-assert-int.yml (modified) * spec/spec/spec-assert-str-list.yml (modified) * spec/spec/spec-assert-str.yml (modified) * spec/spec/spec-attribute-value.yml (modified) * spec/spec/spec-attributes.yml (modified) * spec/spec/spec-bool.yml (modified) * spec/spec/spec-dict.yml (modified) * spec/spec/spec-float.yml (modified) * spec/spec/spec-generic-attributes.yml (modified) * spec/spec/spec-int.yml (modified) * spec/spec/spec-list.yml (modified) * spec/spec/spec-required-attributes.yml (modified) * spec/spec/spec-str.yml (modified) spec: Canonicalize specification of items Wed, 27 May 2020 14:18:19 GMT Sebastian Huber [f313e56] * rtemsqual/specdoc.py (modified) * rtemsqual/tests/spec-doc/root.yml (modified) * rtemsqual/tests/test_specdoc.py (modified) * spec/spec/appl-config-option-constraints.yml (modified) * spec/spec/appl-config-option.yml (modified) * spec/spec/build-action-set-test-state.yml (modified) * spec/spec/build-action.yml (modified) * spec/spec/build-ada-test-program.yml (modified) * spec/spec/build-config-file.yml (modified) * spec/spec/build-include.yml (modified) * spec/spec/build-install-path.yml (modified) * spec/spec/build-library.yml (modified) * spec/spec/build-test-program.yml (modified) * spec/spec/interface-container.yml (modified) * spec/spec/interface-domain.yml (modified) * spec/spec/interface-forward-declaration.yml (modified) * spec/spec/interface-header-file.yml (modified) * spec/spec/requirement-validation.yml (modified) specdoc: Use mapper substitutions for descriptions Wed, 27 May 2020 09:40:06 GMT Sebastian Huber [08c0232] * config.yml (modified) * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/command-line.yml (modified) * rtemsqual/tests/spec-interface/domain-abc.yml (moved) * rtemsqual/tests/spec-interface/domain-c.yml (moved) * rtemsqual/tests/spec-interface/domain-command-line.yml (added) * rtemsqual/tests/spec-interface/h.yml (modified) * rtemsqual/tests/spec-interface/h2.yml (modified) * rtemsqual/tests/spec-interface/h3.yml (modified) * rtemsqual/tests/spec-interface/h4.yml (modified) * rtemsqual/tests/spec-interface/math.yml (modified) * rtemsqual/tests/spec-interface/stdint.yml (modified) * rtemsqual/tests/test_interface.py (modified) * spec/if/build-options/ada.yml (modified) * spec/if/build-options/container.yml (added) * spec/if/build-options/cpuopts.yml (modified) * spec/if/build-options/debug.yml (modified) * spec/if/build-options/drvmgr.yml (modified) * spec/if/build-options/multiprocessing.yml (modified) * spec/if/build-options/networking.yml (modified) * spec/if/build-options/paravirt.yml (modified) * spec/if/build-options/posix.yml (modified) * spec/if/build-options/profiling.yml (modified) * spec/if/build-options/smp.yml (modified) * spec/if/c/stdatomic.yml (modified) * spec/if/c/stdbool.yml (modified) * spec/if/c/stddef.yml (modified) * spec/if/c/stdint.yml (modified) * spec/if/c/string.yml (modified) * spec/if/c/sys-types.yml (modified) * spec/if/c/time.yml (modified) * spec/if/compiler/builtin-choose-expr.yml (modified) * spec/if/compiler/builtin-expect.yml (modified) * spec/if/compiler/builtin-return-address.yml (modified) * spec/if/compiler/builtin-types-compatible-p.yml (modified) * spec/if/compiler/builtin-unreachable.yml (modified) * spec/if/compiler/container.yml (added) * spec/if/compiler/cplusplus.yml (modified) * spec/if/compiler/gnuc.yml (modified) * spec/if/compiler/stdc-version.yml (modified) * spec/if/compiler/typeof.yml (modified) * spec/if/compiler/user-label-prefix.yml (modified) * spec/if/domains/api.yml (added) * spec/if/domains/build-options.yml (added) * spec/if/domains/c.yml (added) * spec/if/domains/compiler.yml (added) * spec/if/domains/implementation.yml (added) * spec/if/domains/use.yml (added) * spec/if/impl/isr/header.yml (modified) * spec/if/impl/memory/header.yml (modified) * spec/if/impl/mpci/header.yml (modified) * spec/if/impl/object/header.yml (modified) * spec/if/impl/smp/header.yml (modified) * spec/if/impl/stack/header.yml (modified) * spec/if/impl/thread/header.yml (modified) * spec/if/impl/userext/header.yml (modified) * spec/if/impl/watchdog/header.yml (modified) * spec/if/impl/wkspace/header.yml (modified) * spec/if/rtems/basedefs/header.yml (modified) * spec/if/rtems/config/header-2.yml (modified) * spec/if/rtems/config/header.yml (modified) * spec/if/rtems/init/header.yml (modified) * spec/if/rtems/status/header.yml (modified) * spec/if/rtems/types/header.yml (modified) * spec/if/use/asm.yml (modified) * spec/if/use/container.yml (moved) * spec/if/use/false.yml (modified) * spec/if/use/true.yml (modified) * spec/spec/interface-container.yml (modified) * spec/spec/interface-domain.yml (added) * spec/spec/interface-header-file.yml (modified) spec: Add interface domain items Wed, 27 May 2020 09:29:14 GMT Sebastian Huber [c58ecfe] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/forward-decl.yml (modified) * spec/spec/interface-forward-declaration.yml (modified) * spec/spec/interface-target.yml (added) spec: Add interface-target link role Wed, 27 May 2020 08:51:43 GMT Sebastian Huber [ea17655] * spec/acfg/opt/constraintbspappmin.yml (modified) * spec/acfg/opt/constraintidlestackarea.yml (modified) * spec/acfg/opt/constraintisrstackalign.yml (modified) * spec/acfg/opt/constraintisrstackarea.yml (modified) * spec/acfg/opt/constraintmemsz.yml (modified) * spec/acfg/opt/constraintposix.yml (modified) * spec/acfg/opt/constraintprioclassic.yml (modified) * spec/acfg/opt/constraintstackspace.yml (modified) * spec/acfg/opt/constraintunlimited.yml (modified) * spec/acfg/opt/constraintwkspace.yml (modified) * spec/spec/constraint-role.yml (added) * spec/spec/constraint.yml (modified) spec: Add dedicated constraint items Tue, 26 May 2020 15:19:07 GMT Sebastian Huber [b211c8d] * spec/spec/requirement-validation-method.yml (added) * spec/spec/requirement-validation-role.yml (added) * spec/spec/requirement-validation.yml (added) spec: Add specification of requirement validation Tue, 26 May 2020 14:08:20 GMT Sebastian Huber [53d462f] * spec/spec/appl-config-group.yml (modified) * spec/spec/appl-config-option-constraints.yml (modified) * spec/spec/appl-config-option-feature-enable.yml (modified) * spec/spec/appl-config-option-feature.yml (modified) * spec/spec/appl-config-option-name.yml (modified) * spec/spec/appl-config-option-value.yml (modified) * spec/spec/appl-config-option.yml (modified) * spec/spec/build-asflag.yml (modified) * spec/spec/build-config-file.yml (modified) * spec/spec/build-config-header.yml (modified) * spec/spec/build-cppflag.yml (modified) * spec/spec/build-group.yml (modified) * spec/spec/build-install.yml (modified) * spec/spec/build-option-name.yml (modified) * spec/spec/build-script.yml (modified) * spec/spec/build-start-file.yml (modified) * spec/spec/build.yml (modified) * spec/spec/glossary-group.yml (modified) * spec/spec/glossary-term.yml (modified) * spec/spec/glossary.yml (modified) * spec/spec/interface-forward-declaration.yml (modified) * spec/spec/interface-include.yml (modified) * spec/spec/interface.yml (modified) * spec/spec/link.yml (modified) * spec/spec/links.yml (modified) * spec/spec/requirement-functional.yml (modified) * spec/spec/requirement-non-functional.yml (modified) * spec/spec/requirement.yml (modified) * spec/spec/root.yml (modified) * spec/spec/spdx-license-identifier.yml (modified) * spec/spec/spec-attribute-value.yml (modified) * spec/spec/spec-bool.yml (modified) * spec/spec/spec-dict.yml (modified) * spec/spec/spec-float.yml (modified) * spec/spec/spec-generic-attributes.yml (modified) * spec/spec/spec-info.yml (modified) * spec/spec/spec-int.yml (modified) * spec/spec/spec-list.yml (modified) * spec/spec/spec-refinement.yml (modified) * spec/spec/spec-str.yml (modified) * spec/spec/spec.yml (modified) spec: Canonicalize specification of specification Tue, 26 May 2020 14:10:36 GMT Sebastian Huber [95c3f2c] * spec/acfg/opt/constraintbspappmin.yml (modified) * spec/acfg/opt/constraintidlestackarea.yml (modified) * spec/acfg/opt/constraintisrstackalign.yml (modified) * spec/acfg/opt/constraintisrstackarea.yml (modified) * spec/acfg/opt/constraintmemsz.yml (modified) * spec/acfg/opt/constraintposix.yml (modified) * spec/acfg/opt/constraintprioclassic.yml (modified) * spec/acfg/opt/constraintstackspace.yml (modified) * spec/acfg/opt/constraintunlimited.yml (modified) * spec/acfg/opt/constraintwkspace.yml (modified) * spec/applconfig.yml (modified) * spec/glossary.yml (modified) * spec/spec/requirement.yml (modified) spec: Add rationale attribute to requirements Tue, 26 May 2020 13:02:04 GMT Sebastian Huber [7dfca46] * rtemsqual/applconfig.py (modified) * rtemsqual/tests/spec-applconfig/c.yml (modified) * rtemsqual/tests/spec-applconfig/h.yml (modified) * rtemsqual/tests/spec-applconfig/k.yml (modified) * spec/acfg/opt/applextradrivers.yml (modified) * spec/acfg/opt/applprerequisitedrivers.yml (modified) * spec/acfg/opt/bdbufbuffermaxsize.yml (modified) * spec/acfg/opt/bspidletaskbody.yml (modified) * spec/acfg/opt/bspinitialextension.yml (modified) * spec/acfg/opt/bspprerequisitedrivers.yml (modified) * spec/acfg/opt/idletaskbody.yml (modified) * spec/acfg/opt/initialextensions.yml (modified) * spec/acfg/opt/inittaskarguments.yml (modified) * spec/acfg/opt/inittaskattributes.yml (modified) * spec/acfg/opt/inittaskentrypoint.yml (modified) * spec/acfg/opt/inittaskinitialmodes.yml (modified) * spec/acfg/opt/inittaskname.yml (modified) * spec/acfg/opt/maxdrivers.yml (modified) * spec/acfg/opt/microsecondspertick.yml (modified) * spec/acfg/opt/mpextraserverstack.yml (modified) * spec/acfg/opt/mpmpcitablepointer.yml (modified) * spec/acfg/opt/posixinitthreadentrypoint.yml (modified) * spec/acfg/opt/recordperprocessoritems.yml (modified) * spec/acfg/opt/schedulerassignments.yml (modified) * spec/acfg/opt/schedulername.yml (modified) * spec/acfg/opt/taskstackallocator.yml (modified) * spec/acfg/opt/taskstackallocatorinit.yml (modified) * spec/acfg/opt/taskstackdeallocator.yml (modified) * spec/acfg/opt/taskstackfromalloc.yml (modified) * spec/acfg/opt/unlimitedallocationsize.yml (modified) * spec/spec/appl-config-option-constraints.yml (modified) * spec/spec/requirement-text-list.yml (added) Rename custom constraints attribute Uses "texts" to be in line with ... Tue, 26 May 2020 12:33:41 GMT Sebastian Huber [325e5bb] * rtemsqual/applconfig.py (modified) * rtemsqual/tests/spec-applconfig/c.yml (modified) * rtemsqual/tests/spec-applconfig/e.yml (modified) * rtemsqual/tests/spec-applconfig/f.yml (modified) * rtemsqual/tests/spec-applconfig/h.yml (modified) * rtemsqual/tests/spec-applconfig/i.yml (modified) * rtemsqual/tests/spec-applconfig/j.yml (modified) * rtemsqual/tests/spec-applconfig/k.yml (modified) * rtemsqual/tests/spec-applconfig/l.yml (modified) * rtemsqual/tests/spec-applconfig/m.yml (modified) * spec/acfg/opt/atadrivertaskpriority.yml (modified) * spec/acfg/opt/bdbufreadaheadtaskpriority.yml (modified) * spec/acfg/opt/bdbuftaskstacksize.yml (modified) * spec/acfg/opt/bspidletaskstacksize.yml (modified) * spec/acfg/opt/bspinterruptstacksize.yml (modified) * spec/acfg/opt/cbsmaximumservers.yml (modified) * spec/acfg/opt/executiveramsize.yml (modified) * spec/acfg/opt/extrataskstacks.yml (modified) * spec/acfg/opt/idletaskstacksize.yml (modified) * spec/acfg/opt/inittaskpriority.yml (modified) * spec/acfg/opt/inittaskstacksize.yml (modified) * spec/acfg/opt/interruptstacksize.yml (modified) * spec/acfg/opt/maxbarriers.yml (modified) * spec/acfg/opt/maxdrivers.yml (modified) * spec/acfg/opt/maxfiledescriptors.yml (modified) * spec/acfg/opt/maxmessagequeues.yml (modified) * spec/acfg/opt/maxpartitions.yml (modified) * spec/acfg/opt/maxperiods.yml (modified) * spec/acfg/opt/maxports.yml (modified) * spec/acfg/opt/maxposixkeys.yml (modified) * spec/acfg/opt/maxposixkeyvaluepairs.yml (modified) * spec/acfg/opt/maxposixmessagequeues.yml (modified) * spec/acfg/opt/maxposixqueuedsignals.yml (modified) * spec/acfg/opt/maxposixsemaphores.yml (modified) * spec/acfg/opt/maxposixshms.yml (modified) * spec/acfg/opt/maxposixthreads.yml (modified) * spec/acfg/opt/maxposixtimers.yml (modified) * spec/acfg/opt/maxregions.yml (modified) * spec/acfg/opt/maxsemaphores.yml (modified) * spec/acfg/opt/maxtasks.yml (modified) * spec/acfg/opt/maxthreadnamesize.yml (modified) * spec/acfg/opt/maxtimers.yml (modified) * spec/acfg/opt/maxuserextensions.yml (modified) * spec/acfg/opt/memoryoverhead.yml (modified) * spec/acfg/opt/messagebuffermemory.yml (modified) * spec/acfg/opt/minposixthreadstacksize.yml (modified) * spec/acfg/opt/mintaskstacksize.yml (modified) * spec/acfg/opt/posixinitthreadstacksize.yml (modified) * spec/acfg/opt/recordperprocessoritems.yml (modified) * spec/acfg/opt/swapouttaskpriority.yml (modified) * spec/acfg/opt/swapoutworkertaskpriority.yml (modified) * spec/spec/appl-config-option-constraints.yml (modified) * spec/spec/constraint.yml (added) Add constraint link role Tue, 26 May 2020 12:20:52 GMT Sebastian Huber [92ea0a0] * rtemsqual/applconfig.py (modified) * rtemsqual/tests/spec-applconfig/a.yml (modified) * rtemsqual/tests/spec-applconfig/b.yml (modified) * rtemsqual/tests/spec-applconfig/c.yml (modified) * rtemsqual/tests/spec-applconfig/e.yml (modified) * rtemsqual/tests/spec-applconfig/f.yml (modified) * rtemsqual/tests/spec-applconfig/g.yml (modified) * rtemsqual/tests/spec-applconfig/h.yml (modified) * rtemsqual/tests/spec-applconfig/i.yml (modified) * rtemsqual/tests/spec-applconfig/j.yml (modified) * rtemsqual/tests/spec-applconfig/k.yml (modified) * rtemsqual/tests/spec-applconfig/l.yml (modified) * rtemsqual/tests/spec-applconfig/m.yml (modified) * spec/acfg/bdbuf.yml (modified) * spec/acfg/bsp.yml (modified) * spec/acfg/classic.yml (modified) * spec/acfg/classicinit.yml (modified) * spec/acfg/devdrv.yml (modified) * spec/acfg/eventrecord.yml (modified) * spec/acfg/filesystem.yml (modified) * spec/acfg/general.yml (modified) * spec/acfg/idle.yml (modified) * spec/acfg/mpci.yml (modified) * spec/acfg/opt/appldisablefilesystem.yml (modified) * spec/acfg/opt/appldoesnotneedclockdriver.yml (modified) * spec/acfg/opt/applextradrivers.yml (modified) * spec/acfg/opt/applneedsatadriver.yml (modified) * spec/acfg/opt/applneedsclockdriver.yml (modified) * spec/acfg/opt/applneedsconsoledriver.yml (modified) * spec/acfg/opt/applneedsframebufferdriver.yml (modified) * spec/acfg/opt/applneedsidedriver.yml (modified) * spec/acfg/opt/applneedslibblock.yml (modified) * spec/acfg/opt/applneedsnulldriver.yml (modified) * spec/acfg/opt/applneedsrtcdriver.yml (modified) * spec/acfg/opt/applneedssimpleconsoledriver.yml (modified) * spec/acfg/opt/applneedssimpletaskconsoledriver.yml (modified) * spec/acfg/opt/applneedsstubdriver.yml (modified) * spec/acfg/opt/applneedstimerdriver.yml (modified) * spec/acfg/opt/applneedswatchdogdriver.yml (modified) * spec/acfg/opt/applneedszerodriver.yml (modified) * spec/acfg/opt/applprerequisitedrivers.yml (modified) * spec/acfg/opt/atadrivertaskpriority.yml (modified) * spec/acfg/opt/bdbufbuffermaxsize.yml (modified) * spec/acfg/opt/bdbufbufferminsize.yml (modified) * spec/acfg/opt/bdbufcachememorysize.yml (modified) * spec/acfg/opt/bdbufmaxreadaheadblocks.yml (modified) * spec/acfg/opt/bdbufmaxwriteblocks.yml (modified) * spec/acfg/opt/bdbufreadaheadtaskpriority.yml (modified) * spec/acfg/opt/bdbuftaskstacksize.yml (modified) * spec/acfg/opt/bspidletaskbody.yml (modified) * spec/acfg/opt/bspidletaskstacksize.yml (modified) * spec/acfg/opt/bspinitialextension.yml (modified) * spec/acfg/opt/bspinterruptstacksize.yml (modified) * spec/acfg/opt/bspprerequisitedrivers.yml (modified) * spec/acfg/opt/cbsmaximumservers.yml (modified) * spec/acfg/opt/dirtymemory.yml (modified) * spec/acfg/opt/disablebspsettings.yml (modified) * spec/acfg/opt/disablenewlibreentrancy.yml (modified) * spec/acfg/opt/executiveramsize.yml (modified) * spec/acfg/opt/extrataskstacks.yml (modified) * spec/acfg/opt/filesystemall.yml (modified) * spec/acfg/opt/filesystemdosfs.yml (modified) * spec/acfg/opt/filesystemftpfs.yml (modified) * spec/acfg/opt/filesystemimfs.yml (modified) * spec/acfg/opt/filesystemjffs2.yml (modified) * spec/acfg/opt/filesystemnfs.yml (modified) * spec/acfg/opt/filesystemrfs.yml (modified) * spec/acfg/opt/filesystemtftpfs.yml (modified) * spec/acfg/opt/idletaskbody.yml (modified) * spec/acfg/opt/idletaskinitappl.yml (modified) * spec/acfg/opt/idletaskstacksize.yml (modified) * spec/acfg/opt/imfsdisablechmod.yml (modified) * spec/acfg/opt/imfsdisablechown.yml (modified) * spec/acfg/opt/imfsdisablelink.yml (modified) * spec/acfg/opt/imfsdisablemknod.yml (modified) * spec/acfg/opt/imfsdisablemknoddevice.yml (modified) * spec/acfg/opt/imfsdisablemknodfile.yml (modified) * spec/acfg/opt/imfsdisablemount.yml (modified) * spec/acfg/opt/imfsdisablereaddir.yml (modified) * spec/acfg/opt/imfsdisablereadlink.yml (modified) * spec/acfg/opt/imfsdisablerename.yml (modified) * spec/acfg/opt/imfsdisablermnod.yml (modified) * spec/acfg/opt/imfsdisablesymlink.yml (modified) * spec/acfg/opt/imfsdisableunmount.yml (modified) * spec/acfg/opt/imfsdisableutime.yml (modified) * spec/acfg/opt/imfsenablemkfifo.yml (modified) * spec/acfg/opt/imfsmemfilebytesperblock.yml (modified) * spec/acfg/opt/initialextensions.yml (modified) * spec/acfg/opt/inittaskarguments.yml (modified) * spec/acfg/opt/inittaskattributes.yml (modified) * spec/acfg/opt/inittaskentrypoint.yml (modified) * spec/acfg/opt/inittaskinitialmodes.yml (modified) * spec/acfg/opt/inittaskname.yml (modified) * spec/acfg/opt/inittaskpriority.yml (modified) * spec/acfg/opt/inittaskstacksize.yml (modified) * spec/acfg/opt/interruptstacksize.yml (modified) * spec/acfg/opt/mallocbspsupportssbrk.yml (modified) * spec/acfg/opt/mallocdirty.yml (modified) * spec/acfg/opt/maxbarriers.yml (modified) * spec/acfg/opt/maxdrivers.yml (modified) * spec/acfg/opt/maxfiledescriptors.yml (modified) * spec/acfg/opt/maxmessagequeues.yml (modified) * spec/acfg/opt/maxpartitions.yml (modified) * spec/acfg/opt/maxperiods.yml (modified) * spec/acfg/opt/maxports.yml (modified) * spec/acfg/opt/maxposixkeys.yml (modified) * spec/acfg/opt/maxposixkeyvaluepairs.yml (modified) * spec/acfg/opt/maxposixmessagequeues.yml (modified) * spec/acfg/opt/maxposixqueuedsignals.yml (modified) * spec/acfg/opt/maxposixsemaphores.yml (modified) * spec/acfg/opt/maxposixshms.yml (modified) * spec/acfg/opt/maxposixthreads.yml (modified) * spec/acfg/opt/maxposixtimers.yml (modified) * spec/acfg/opt/maxpriority.yml (modified) * spec/acfg/opt/maxprocessors.yml (modified) * spec/acfg/opt/maxregions.yml (modified) * spec/acfg/opt/maxsemaphores.yml (modified) * spec/acfg/opt/maxtasks.yml (modified) * spec/acfg/opt/maxthreadnamesize.yml (modified) * spec/acfg/opt/maxtimers.yml (modified) * spec/acfg/opt/maxuserextensions.yml (modified) * spec/acfg/opt/memoryoverhead.yml (modified) * spec/acfg/opt/messagebuffermemory.yml (modified) * spec/acfg/opt/microsecondspertick.yml (modified) * spec/acfg/opt/minposixthreadstacksize.yml (modified) * spec/acfg/opt/mintaskstacksize.yml (modified) * spec/acfg/opt/mpappl.yml (modified) * spec/acfg/opt/mpextraserverstack.yml (modified) * spec/acfg/opt/mpmaxglobalobjects.yml (modified) * spec/acfg/opt/mpmaxnodes.yml (modified) * spec/acfg/opt/mpmaxproxies.yml (modified) * spec/acfg/opt/mpmpcitablepointer.yml (modified) * spec/acfg/opt/mpnodenumber.yml (modified) * spec/acfg/opt/posixinitthreadentrypoint.yml (modified) * spec/acfg/opt/posixinitthreadstacksize.yml (modified) * spec/acfg/opt/posixinitthreadtable.yml (modified) * spec/acfg/opt/recordextensionsenabled.yml (modified) * spec/acfg/opt/recordfataldumpbase64.yml (modified) * spec/acfg/opt/recordfataldumpbase64zlib.yml (modified) * spec/acfg/opt/recordperprocessoritems.yml (modified) * spec/acfg/opt/rtemsinittaskstable.yml (modified) * spec/acfg/opt/schedulerassignments.yml (modified) * spec/acfg/opt/schedulercbs.yml (modified) * spec/acfg/opt/scheduleredf.yml (modified) * spec/acfg/opt/scheduleredfsmp.yml (modified) * spec/acfg/opt/schedulername.yml (modified) * spec/acfg/opt/schedulerpriority.yml (modified) * spec/acfg/opt/schedulerpriorityaffinitysmp.yml (modified) * spec/acfg/opt/schedulerprioritysmp.yml (modified) * spec/acfg/opt/schedulersimple.yml (modified) * spec/acfg/opt/schedulersimplesmp.yml (modified) * spec/acfg/opt/schedulerstrongapa.yml (modified) * spec/acfg/opt/scheduleruser.yml (modified) * spec/acfg/opt/stackcheckerenabled.yml (modified) * spec/acfg/opt/swapoutblockhold.yml (modified) * spec/acfg/opt/swapoutswapperiod.yml (modified) * spec/acfg/opt/swapouttaskpriority.yml (modified) * spec/acfg/opt/swapoutworkertaskpriority.yml (modified) * spec/acfg/opt/swapoutworkertasks.yml (modified) * spec/acfg/opt/taskstackallocator.yml (modified) * spec/acfg/opt/taskstackallocatorinit.yml (modified) * spec/acfg/opt/taskstackdeallocator.yml (modified) * spec/acfg/opt/taskstackfromalloc.yml (modified) * spec/acfg/opt/taskstacknowkspace.yml (modified) * spec/acfg/opt/tickspertimeslice.yml (modified) * spec/acfg/opt/unifiedworkareas.yml (modified) * spec/acfg/opt/unlimitedallocationsize.yml (modified) * spec/acfg/opt/unlimitedobjects.yml (modified) * spec/acfg/opt/usedevfsasbasefilesystem.yml (modified) * spec/acfg/opt/useminiimfsasbasefilesystem.yml (modified) * spec/acfg/opt/verbosesysteminit.yml (modified) * spec/acfg/opt/zeroworkspaceautomatically.yml (modified) * spec/acfg/posix.yml (modified) * spec/acfg/posixinit.yml (modified) * spec/acfg/schedgeneral.yml (modified) * spec/acfg/stackalloc.yml (modified) * spec/spec/appl-config-group.yml (modified) * spec/spec/appl-config-option-constraints.yml (moved) * spec/spec/appl-config-option-feature.yml (modified) * spec/spec/appl-config-option-value.yml (modified) * spec/spec/appl-config-option.yml (modified) Rename application configuration attributes Tue, 26 May 2020 06:33:20 GMT Sebastian Huber [d8f8125] * spec/spec/test-case-action-list.yml (added) * spec/spec/test-case-action.yml (added) * spec/spec/test-case-check-list.yml (added) * spec/spec/test-case-check.yml (added) * spec/spec/test-case.yml (added) * spec/spec/test-name.yml (added) * spec/spec/test-suite.yml (added) spec: Add specification of test items Tue, 26 May 2020 09:44:55 GMT Sebastian Huber [ad3bc01] * rtemsqual/tests/spec-validation/ts.yml (modified) * rtemsqual/validation.py (modified) * spec/testsuites/validation/profile.yml (modified) Rename test suite attributes Tue, 26 May 2020 06:33:00 GMT Sebastian Huber [fa461cb4] * rtemsqual/tests/spec-validation/tc.yml (modified) * rtemsqual/tests/spec-validation/tc2.yml (modified) * rtemsqual/tests/spec-validation/tc3.yml (modified) * rtemsqual/tests/spec-validation/tc4.yml (modified) * rtemsqual/tests/spec-validation/ts.yml (modified) * rtemsqual/validation.py (modified) * spec/testsuites/validation/c-library.yml (modified) * spec/testsuites/validation/classic-barrier.yml (modified) * spec/testsuites/validation/profile.yml (modified) Rename test case attributes Mon, 25 May 2020 07:42:37 GMT Sebastian Huber [06c7b22] * spec/spec/interface-brief.yml (added) * spec/spec/interface-compound-definition-kind.yml (added) * spec/spec/interface-compound.yml (added) * spec/spec/interface-container.yml (added) * spec/spec/interface-define.yml (added) * spec/spec/interface-definition-directive.yml (added) * spec/spec/interface-definition-variant-list.yml (added) * spec/spec/interface-definition-variant.yml (added) * spec/spec/interface-definition.yml (added) * spec/spec/interface-description.yml (added) * spec/spec/interface-enabled-by-list.yml (added) * spec/spec/interface-enabled-by.yml (added) * spec/spec/interface-enum-definition-kind.yml (added) * spec/spec/interface-enum.yml (added) * spec/spec/interface-enumerator-role.yml (added) * spec/spec/interface-enumerator.yml (added) * spec/spec/interface-forward-declaration.yml (added) * spec/spec/interface-function-definition-directive.yml (added) * spec/spec/interface-function-definition-variant-list.yml (added) * spec/spec/interface-function-definition-variant.yml (added) * spec/spec/interface-function-definition.yml (added) * spec/spec/interface-function.yml (added) * spec/spec/interface-group.yml (modified) * spec/spec/interface-header-file.yml (added) * spec/spec/interface-macro.yml (added) * spec/spec/interface-member-compound.yml (added) * spec/spec/interface-member-declaration.yml (added) * spec/spec/interface-member-definition-directive-list.yml (added) * spec/spec/interface-member-definition-directive.yml (added) * spec/spec/interface-member-definition-variant-list.yml (added) * spec/spec/interface-member-definition-variant.yml (added) * spec/spec/interface-member-definition.yml (added) * spec/spec/interface-notes.yml (added) * spec/spec/interface-param-dir.yml (added) * spec/spec/interface-param-list.yml (added) * spec/spec/interface-param.yml (added) * spec/spec/interface-return-directive.yml (added) * spec/spec/interface-return-value-list.yml (added) * spec/spec/interface-return-value.yml (added) * spec/spec/interface-typedef.yml (added) * spec/spec/interface-unspecified.yml (added) * spec/spec/interface-variable.yml (added) spec: Add specification of interface items Mon, 25 May 2020 11:18:46 GMT Sebastian Huber [0f5d1db] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/func.yml (modified) * rtemsqual/tests/spec-interface/func3.yml (modified) * rtemsqual/tests/spec-interface/func4.yml (modified) * spec/if/impl/dequalify-types-not-compatible.yml (modified) * spec/if/rtems/config/get-api-configuration.yml (modified) * spec/if/rtems/config/get-maximum-barriers.yml (modified) * spec/if/rtems/config/get-maximum-extensions.yml (modified) * spec/if/rtems/config/get-maximum-message-queues.yml (modified) * spec/if/rtems/config/get-maximum-partitions.yml (modified) * spec/if/rtems/config/get-maximum-periods.yml (modified) * spec/if/rtems/config/get-maximum-ports.yml (modified) * spec/if/rtems/config/get-maximum-regions.yml (modified) * spec/if/rtems/config/get-maximum-semaphores.yml (modified) * spec/if/rtems/config/get-maximum-tasks.yml (modified) * spec/if/rtems/config/get-maximum-timers.yml (modified) * spec/if/rtems/config/get-stack-space-size.yml (modified) * spec/if/rtems/init/initialize-executive.yml (modified) * spec/if/rtems/init/shutdown-executive.yml (modified) * spec/if/rtems/status/code-to-errno.yml (modified) * spec/if/rtems/status/text.yml (modified) spec: Add function body attribute Mon, 25 May 2020 11:36:29 GMT Sebastian Huber [ae796fd] * spec/if/c/bool.yml (modified) * spec/if/c/false.yml (modified) * spec/if/c/int16_t.yml (modified) * spec/if/c/int32_t.yml (modified) * spec/if/c/int64_t.yml (modified) * spec/if/c/int8_t.yml (modified) * spec/if/c/intmax_t.yml (modified) * spec/if/c/intptr_t.yml (modified) * spec/if/c/null.yml (modified) * spec/if/c/size_t.yml (modified) * spec/if/c/time_t.yml (modified) * spec/if/c/true.yml (modified) * spec/if/c/uint16_t.yml (modified) * spec/if/c/uint32_t.yml (modified) * spec/if/c/uint64_t.yml (modified) * spec/if/c/uint8_t.yml (modified) * spec/if/c/uintmax_t.yml (modified) * spec/if/c/uintptr_t.yml (modified) spec: Remove superfluous domain attribute Mon, 25 May 2020 08:28:42 GMT Sebastian Huber [bb86745] * spec/if/build-options/ada.yml (modified) * spec/if/build-options/debug.yml (modified) * spec/if/build-options/drvmgr.yml (modified) * spec/if/build-options/multiprocessing.yml (modified) * spec/if/build-options/networking.yml (modified) * spec/if/build-options/paravirt.yml (modified) * spec/if/build-options/posix.yml (modified) * spec/if/build-options/profiling.yml (modified) * spec/if/build-options/smp.yml (modified) * spec/if/c/bool.yml (modified) * spec/if/c/false.yml (modified) * spec/if/c/int16_t.yml (modified) * spec/if/c/int32_t.yml (modified) * spec/if/c/int64_t.yml (modified) * spec/if/c/int8_t.yml (modified) * spec/if/c/intmax_t.yml (modified) * spec/if/c/intptr_t.yml (modified) * spec/if/c/null.yml (modified) * spec/if/c/offsetof.yml (modified) * spec/if/c/size_t.yml (modified) * spec/if/c/time_t.yml (modified) * spec/if/c/true.yml (modified) * spec/if/c/uint16_t.yml (modified) * spec/if/c/uint32_t.yml (modified) * spec/if/c/uint64_t.yml (modified) * spec/if/c/uint8_t.yml (modified) * spec/if/c/uintmax_t.yml (modified) * spec/if/c/uintptr_t.yml (modified) * spec/if/compiler/builtin-choose-expr.yml (modified) * spec/if/compiler/builtin-expect.yml (modified) * spec/if/compiler/builtin-return-address.yml (modified) * spec/if/compiler/builtin-types-compatible-p.yml (modified) * spec/if/compiler/builtin-unreachable.yml (modified) * spec/if/compiler/cplusplus.yml (modified) * spec/if/compiler/gnuc.yml (modified) * spec/if/compiler/stdc-version.yml (modified) * spec/if/compiler/typeof.yml (modified) * spec/if/compiler/user-label-prefix.yml (modified) * spec/if/impl/isr/stack-size.yml (modified) * spec/if/impl/memory/zero-before-use.yml (modified) * spec/if/impl/mpci/configuration.yml (modified) * spec/if/impl/object/is-unlimited.yml (modified) * spec/if/impl/object/maximum-per-allocation.yml (modified) * spec/if/impl/object/unlimited-objects.yml (modified) * spec/if/impl/smp/processor-configured-maximum.yml (modified) * spec/if/impl/stack/allocator-allocate-type.yml (modified) * spec/if/impl/stack/allocator-allocate.yml (modified) * spec/if/impl/stack/allocator-avoids-workspace.yml (modified) * spec/if/impl/stack/allocator-free-type.yml (modified) * spec/if/impl/stack/allocator-free.yml (modified) * spec/if/impl/stack/allocator-initialize-type.yml (modified) * spec/if/impl/stack/allocator-initialize.yml (modified) * spec/if/impl/thread/idle-body.yml (modified) * spec/if/impl/thread/idle-stack-size.yml (modified) * spec/if/impl/userext/initial-count.yml (modified) * spec/if/impl/userext/initial-extensions.yml (modified) * spec/if/impl/watchdog/microseconds-per-tick.yml (modified) * spec/if/impl/watchdog/nanoseconds-per-tick.yml (modified) * spec/if/impl/watchdog/ticks-per-timeslice.yml (modified) * spec/if/impl/wkspace/is-unified.yml (modified) * spec/if/impl/wkspace/size.yml (modified) * spec/if/use/asm.yml (modified) * spec/if/use/false.yml (modified) * spec/if/use/true.yml (modified) spec: Add unspecified interface type Mon, 25 May 2020 07:52:00 GMT Sebastian Huber [8821c7d] * config.yml (modified) * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/asm.yml (modified) * rtemsqual/tests/spec-interface/command-line.yml (modified) * rtemsqual/tests/spec-interface/define-a.yml (modified) * rtemsqual/tests/spec-interface/define-b.yml (modified) * rtemsqual/tests/spec-interface/define-c.yml (modified) * rtemsqual/tests/spec-interface/define.yml (modified) * rtemsqual/tests/spec-interface/enum.yml (modified) * rtemsqual/tests/spec-interface/enum2.yml (modified) * rtemsqual/tests/spec-interface/enum3.yml (modified) * rtemsqual/tests/spec-interface/enum4.yml (modified) * rtemsqual/tests/spec-interface/enumerator-0.yml (modified) * rtemsqual/tests/spec-interface/enumerator-1.yml (modified) * rtemsqual/tests/spec-interface/enumerator-2.yml (modified) * rtemsqual/tests/spec-interface/enumerator-a.yml (modified) * rtemsqual/tests/spec-interface/enumerator-b.yml (modified) * rtemsqual/tests/spec-interface/float_t.yml (modified) * rtemsqual/tests/spec-interface/func.yml (modified) * rtemsqual/tests/spec-interface/func2.yml (modified) * rtemsqual/tests/spec-interface/func3.yml (modified) * rtemsqual/tests/spec-interface/func4.yml (modified) * rtemsqual/tests/spec-interface/h.yml (modified) * rtemsqual/tests/spec-interface/h2.yml (modified) * rtemsqual/tests/spec-interface/h3.yml (modified) * rtemsqual/tests/spec-interface/h4.yml (modified) * rtemsqual/tests/spec-interface/macro.yml (modified) * rtemsqual/tests/spec-interface/macro2.yml (modified) * rtemsqual/tests/spec-interface/math.yml (modified) * rtemsqual/tests/spec-interface/s.yml (modified) * rtemsqual/tests/spec-interface/smp.yml (modified) * rtemsqual/tests/spec-interface/stdint.yml (modified) * rtemsqual/tests/spec-interface/td.yml (modified) * rtemsqual/tests/spec-interface/td3.yml (modified) * rtemsqual/tests/spec-interface/uint32_t.yml (modified) * rtemsqual/tests/spec-interface/var.yml (modified) * rtemsqual/tests/test_interface.py (modified) * spec/if/build-options/ada.yml (modified) * spec/if/build-options/cpuopts.yml (modified) * spec/if/build-options/debug.yml (modified) * spec/if/build-options/domain.yml (modified) * spec/if/build-options/drvmgr.yml (modified) * spec/if/build-options/multiprocessing.yml (modified) * spec/if/build-options/networking.yml (modified) * spec/if/build-options/paravirt.yml (modified) * spec/if/build-options/posix.yml (modified) * spec/if/build-options/profiling.yml (modified) * spec/if/build-options/smp.yml (modified) * spec/if/c/bool.yml (modified) * spec/if/c/false.yml (modified) * spec/if/c/int16_t.yml (modified) * spec/if/c/int32_t.yml (modified) * spec/if/c/int64_t.yml (modified) * spec/if/c/int8_t.yml (modified) * spec/if/c/intmax_t.yml (modified) * spec/if/c/intptr_t.yml (modified) * spec/if/c/null.yml (modified) * spec/if/c/offsetof.yml (modified) * spec/if/c/size_t.yml (modified) * spec/if/c/stdatomic.yml (modified) * spec/if/c/stdbool.yml (modified) * spec/if/c/stddef.yml (modified) * spec/if/c/stdint.yml (modified) * spec/if/c/string.yml (modified) * spec/if/c/sys-types.yml (modified) * spec/if/c/time.yml (modified) * spec/if/c/time_t.yml (modified) * spec/if/c/true.yml (modified) * spec/if/c/uint16_t.yml (modified) * spec/if/c/uint32_t.yml (modified) * spec/if/c/uint64_t.yml (modified) * spec/if/c/uint8_t.yml (modified) * spec/if/c/uintmax_t.yml (modified) * spec/if/c/uintptr_t.yml (modified) * spec/if/compiler/builtin-choose-expr.yml (modified) * spec/if/compiler/builtin-expect.yml (modified) * spec/if/compiler/builtin-return-address.yml (modified) * spec/if/compiler/builtin-types-compatible-p.yml (modified) * spec/if/compiler/builtin-unreachable.yml (modified) * spec/if/compiler/cplusplus.yml (modified) * spec/if/compiler/domain.yml (modified) * spec/if/compiler/gnuc.yml (modified) * spec/if/compiler/stdc-version.yml (modified) * spec/if/compiler/typeof.yml (modified) * spec/if/compiler/user-label-prefix.yml (modified) * spec/if/impl/assert-unreachable.yml (modified) * spec/if/impl/dequalify-types-not-compatible.yml (modified) * spec/if/impl/isr/header.yml (modified) * spec/if/impl/isr/stack-size.yml (modified) * spec/if/impl/memory/header.yml (modified) * spec/if/impl/memory/zero-before-use.yml (modified) * spec/if/impl/mpci/configuration.yml (modified) * spec/if/impl/mpci/header.yml (modified) * spec/if/impl/object/header.yml (modified) * spec/if/impl/object/is-unlimited.yml (modified) * spec/if/impl/object/maximum-per-allocation.yml (modified) * spec/if/impl/object/unlimited-objects.yml (modified) * spec/if/impl/smp/header.yml (modified) * spec/if/impl/smp/processor-configured-maximum.yml (modified) * spec/if/impl/stack/allocator-allocate-type.yml (modified) * spec/if/impl/stack/allocator-allocate.yml (modified) * spec/if/impl/stack/allocator-avoids-workspace.yml (modified) * spec/if/impl/stack/allocator-free-type.yml (modified) * spec/if/impl/stack/allocator-free.yml (modified) * spec/if/impl/stack/allocator-initialize-type.yml (modified) * spec/if/impl/stack/allocator-initialize.yml (modified) * spec/if/impl/stack/header.yml (modified) * spec/if/impl/thread/header.yml (modified) * spec/if/impl/thread/idle-body.yml (modified) * spec/if/impl/thread/idle-stack-size.yml (modified) * spec/if/impl/userext/header.yml (modified) * spec/if/impl/userext/initial-count.yml (modified) * spec/if/impl/userext/initial-extensions.yml (modified) * spec/if/impl/watchdog/header.yml (modified) * spec/if/impl/watchdog/microseconds-per-tick.yml (modified) * spec/if/impl/watchdog/nanoseconds-per-tick.yml (modified) * spec/if/impl/watchdog/ticks-per-timeslice.yml (modified) * spec/if/impl/wkspace/header.yml (modified) * spec/if/impl/wkspace/is-unified.yml (modified) * spec/if/impl/wkspace/size.yml (modified) * spec/if/rtems/basedefs/alias.yml (modified) * spec/if/rtems/basedefs/aligned.yml (modified) * spec/if/rtems/basedefs/alloc-align.yml (modified) * spec/if/rtems/basedefs/alloc-size-2.yml (modified) * spec/if/rtems/basedefs/alloc-size.yml (modified) * spec/if/rtems/basedefs/array-size.yml (modified) * spec/if/rtems/basedefs/compiler-deprecated-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-memory-barrier.yml (modified) * spec/if/rtems/basedefs/compiler-no-return-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-packed-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-pure-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-used-attribute.yml (modified) * spec/if/rtems/basedefs/concat.yml (modified) * spec/if/rtems/basedefs/const.yml (modified) * spec/if/rtems/basedefs/container-of.yml (modified) * spec/if/rtems/basedefs/declare-global-symbol.yml (modified) * spec/if/rtems/basedefs/deconst.yml (modified) * spec/if/rtems/basedefs/define-global-symbol.yml (modified) * spec/if/rtems/basedefs/deprecated.yml (modified) * spec/if/rtems/basedefs/dequalify-depthx.yml (modified) * spec/if/rtems/basedefs/dequalify.yml (modified) * spec/if/rtems/basedefs/devolatile.yml (modified) * spec/if/rtems/basedefs/expand.yml (modified) * spec/if/rtems/basedefs/false.yml (modified) * spec/if/rtems/basedefs/have-member-same-type.yml (modified) * spec/if/rtems/basedefs/header.yml (modified) * spec/if/rtems/basedefs/inline-routine.yml (modified) * spec/if/rtems/basedefs/malloclike.yml (modified) * spec/if/rtems/basedefs/no-inline.yml (modified) * spec/if/rtems/basedefs/no-return.yml (modified) * spec/if/rtems/basedefs/obfuscate-variable.yml (modified) * spec/if/rtems/basedefs/packed.yml (modified) * spec/if/rtems/basedefs/predict-false.yml (modified) * spec/if/rtems/basedefs/predict-true.yml (modified) * spec/if/rtems/basedefs/printflike.yml (modified) * spec/if/rtems/basedefs/pure.yml (modified) * spec/if/rtems/basedefs/return-address.yml (modified) * spec/if/rtems/basedefs/section.yml (modified) * spec/if/rtems/basedefs/static-assert.yml (modified) * spec/if/rtems/basedefs/string.yml (modified) * spec/if/rtems/basedefs/symbol-name.yml (modified) * spec/if/rtems/basedefs/true.yml (modified) * spec/if/rtems/basedefs/typeof-refx.yml (modified) * spec/if/rtems/basedefs/unreachable.yml (modified) * spec/if/rtems/basedefs/unused.yml (modified) * spec/if/rtems/basedefs/used.yml (modified) * spec/if/rtems/basedefs/warn-unused-result.yml (modified) * spec/if/rtems/basedefs/weak-alias.yml (modified) * spec/if/rtems/basedefs/weak.yml (modified) * spec/if/rtems/basedefs/xconcat.yml (modified) * spec/if/rtems/basedefs/xstring.yml (modified) * spec/if/rtems/basedefs/zero-length-array.yml (modified) * spec/if/rtems/config/api-table.yml (modified) * spec/if/rtems/config/get-api-configuration.yml (modified) * spec/if/rtems/config/get-do-zero-of-workspace.yml (modified) * spec/if/rtems/config/get-idle-task-stack-size.yml (modified) * spec/if/rtems/config/get-idle-task.yml (modified) * spec/if/rtems/config/get-interrupt-stack-size.yml (modified) * spec/if/rtems/config/get-maximum-barriers.yml (modified) * spec/if/rtems/config/get-maximum-extensions.yml (modified) * spec/if/rtems/config/get-maximum-message-queues.yml (modified) * spec/if/rtems/config/get-maximum-partitions.yml (modified) * spec/if/rtems/config/get-maximum-periods.yml (modified) * spec/if/rtems/config/get-maximum-ports.yml (modified) * spec/if/rtems/config/get-maximum-processors.yml (modified) * spec/if/rtems/config/get-maximum-regions.yml (modified) * spec/if/rtems/config/get-maximum-semaphores.yml (modified) * spec/if/rtems/config/get-maximum-tasks.yml (modified) * spec/if/rtems/config/get-maximum-timers.yml (modified) * spec/if/rtems/config/get-microseconds-per-tick.yml (modified) * spec/if/rtems/config/get-milliseconds-per-tick.yml (modified) * spec/if/rtems/config/get-nanoseconds-per-tick.yml (modified) * spec/if/rtems/config/get-number-of-initial-extensions.yml (modified) * spec/if/rtems/config/get-stack-allocate-hook.yml (modified) * spec/if/rtems/config/get-stack-allocate-init-hook.yml (modified) * spec/if/rtems/config/get-stack-allocator-avoids-work-space.yml (modified) * spec/if/rtems/config/get-stack-free-hook.yml (modified) * spec/if/rtems/config/get-stack-space-size.yml (modified) * spec/if/rtems/config/get-ticks-per-timeslice.yml (modified) * spec/if/rtems/config/get-unified-work-area.yml (modified) * spec/if/rtems/config/get-user-extension-table.yml (modified) * spec/if/rtems/config/get-user-multiprocessing-table.yml (modified) * spec/if/rtems/config/get-work-space-size.yml (modified) * spec/if/rtems/config/header-2.yml (modified) * spec/if/rtems/config/header.yml (modified) * spec/if/rtems/config/resource-is-unlimited.yml (modified) * spec/if/rtems/config/resource-maximum-per-allocation.yml (modified) * spec/if/rtems/config/resource-unlimited.yml (modified) * spec/if/rtems/config/stack-allocate-hook.yml (modified) * spec/if/rtems/config/stack-allocate-init-hook.yml (modified) * spec/if/rtems/config/stack-free-hook.yml (modified) * spec/if/rtems/config/unlimited-objects.yml (modified) * spec/if/rtems/init/header.yml (modified) * spec/if/rtems/init/initialize-executive.yml (modified) * spec/if/rtems/init/shutdown-executive.yml (modified) * spec/if/rtems/status/already-suspended.yml (modified) * spec/if/rtems/status/called-from-isr.yml (modified) * spec/if/rtems/status/code-to-errno.yml (modified) * spec/if/rtems/status/code.yml (modified) * spec/if/rtems/status/first.yml (modified) * spec/if/rtems/status/header.yml (modified) * spec/if/rtems/status/illegal-on-remote-object.yml (modified) * spec/if/rtems/status/illegal-on-self.yml (modified) * spec/if/rtems/status/incorrect-state.yml (modified) * spec/if/rtems/status/internal-error.yml (modified) * spec/if/rtems/status/interrupted.yml (modified) * spec/if/rtems/status/invalid-address.yml (modified) * spec/if/rtems/status/invalid-clock.yml (modified) * spec/if/rtems/status/invalid-id.yml (modified) * spec/if/rtems/status/invalid-name.yml (modified) * spec/if/rtems/status/invalid-node.yml (modified) * spec/if/rtems/status/invalid-number.yml (modified) * spec/if/rtems/status/invalid-priority.yml (modified) * spec/if/rtems/status/invalid-size.yml (modified) * spec/if/rtems/status/io-error.yml (modified) * spec/if/rtems/status/is-equal.yml (modified) * spec/if/rtems/status/is-successful.yml (modified) * spec/if/rtems/status/last.yml (modified) * spec/if/rtems/status/mp-not-configured.yml (modified) * spec/if/rtems/status/no-memory.yml (modified) * spec/if/rtems/status/not-configured.yml (modified) * spec/if/rtems/status/not-defined.yml (modified) * spec/if/rtems/status/not-implemented.yml (modified) * spec/if/rtems/status/not-owner-of-resource.yml (modified) * spec/if/rtems/status/object-was-deleted.yml (modified) * spec/if/rtems/status/proxy-blocking.yml (modified) * spec/if/rtems/status/resource-in-use.yml (modified) * spec/if/rtems/status/successful.yml (modified) * spec/if/rtems/status/task-exitted.yml (modified) * spec/if/rtems/status/text.yml (modified) * spec/if/rtems/status/timeout.yml (modified) * spec/if/rtems/status/too-many.yml (modified) * spec/if/rtems/status/unsatisfied.yml (modified) * spec/if/rtems/types/header.yml (modified) * spec/if/use/asm.yml (modified) * spec/if/use/domain.yml (modified) * spec/if/use/false.yml (modified) * spec/if/use/true.yml (modified) Rename interface attributes Mon, 25 May 2020 07:29:03 GMT Sebastian Huber [37d648b] * spec/spec/interface-group-identifier.yml (added) * spec/spec/interface-group.yml (added) spec: Add specification of interface group items Mon, 25 May 2020 11:22:56 GMT Sebastian Huber [adb26ed] * spec/glos/term/abi.yml (modified) * spec/glos/term/active.yml (modified) * spec/glos/term/aperiodictask.yml (modified) * spec/glos/term/api.yml (modified) * spec/glos/term/application.yml (modified) * spec/glos/term/asr.yml (modified) * spec/glos/term/assemblerlanguage.yml (modified) * spec/glos/term/asynchronous.yml (modified) * spec/glos/term/asynchronoussignalroutine.yml (modified) * spec/glos/term/atomicoperations.yml (modified) * spec/glos/term/awakened.yml (modified) * spec/glos/term/bigendian.yml (modified) * spec/glos/term/bitmapped.yml (modified) * spec/glos/term/block.yml (modified) * spec/glos/term/blockedtask.yml (modified) * spec/glos/term/boardsupportpackage.yml (modified) * spec/glos/term/broadcast.yml (modified) * spec/glos/term/bsp.yml (modified) * spec/glos/term/buffer.yml (modified) * spec/glos/term/c11.yml (modified) * spec/glos/term/callingconvention.yml (modified) * spec/glos/term/ccb.yml (modified) * spec/glos/term/centralprocessingunit.yml (modified) * spec/glos/term/chain.yml (modified) * spec/glos/term/clanguage.yml (modified) * spec/glos/term/cluster.yml (modified) * spec/glos/term/coalesce.yml (modified) * spec/glos/term/configurationtable.yml (modified) * spec/glos/term/context.yml (modified) * spec/glos/term/contextswitch.yml (modified) * spec/glos/term/controlblock.yml (modified) * spec/glos/term/core.yml (modified) * spec/glos/term/cpu.yml (modified) * spec/glos/term/criticalsection.yml (modified) * spec/glos/term/crt.yml (modified) * spec/glos/term/cxx11.yml (modified) * spec/glos/term/deadline.yml (modified) * spec/glos/term/device.yml (modified) * spec/glos/term/devicedriver.yml (modified) * spec/glos/term/devicedrivertable.yml (modified) * spec/glos/term/directives.yml (modified) * spec/glos/term/dispatch.yml (modified) * spec/glos/term/doorstop.yml (modified) * spec/glos/term/dormant.yml (modified) * spec/glos/term/dualported.yml (modified) * spec/glos/term/ears.yml (modified) * spec/glos/term/elf.yml (modified) * spec/glos/term/embedded.yml (modified) * spec/glos/term/entrypoint.yml (modified) * spec/glos/term/envelope.yml (modified) * spec/glos/term/errorcode.yml (modified) * spec/glos/term/events.yml (modified) * spec/glos/term/exception.yml (modified) * spec/glos/term/executingtask.yml (modified) * spec/glos/term/executive.yml (modified) * spec/glos/term/exported.yml (modified) * spec/glos/term/externaladdress.yml (modified) * spec/glos/term/fifo.yml (modified) * spec/glos/term/firstinfirstout.yml (modified) * spec/glos/term/floatingpointcoprocessor.yml (modified) * spec/glos/term/freed.yml (modified) * spec/glos/term/gcc.yml (modified) * spec/glos/term/global.yml (modified) * spec/glos/term/gnat.yml (modified) * spec/glos/term/gnu.yml (modified) * spec/glos/term/handler.yml (modified) * spec/glos/term/hardrealtimesystem.yml (modified) * spec/glos/term/heap.yml (modified) * spec/glos/term/heirtask.yml (modified) * spec/glos/term/heterogeneous.yml (modified) * spec/glos/term/homogeneous.yml (modified) * spec/glos/term/id.yml (modified) * spec/glos/term/idletask.yml (modified) * spec/glos/term/interface.yml (modified) * spec/glos/term/internaladdress.yml (modified) * spec/glos/term/interrupt.yml (modified) * spec/glos/term/interruptlevel.yml (modified) * spec/glos/term/interruptservice.yml (modified) * spec/glos/term/interruptserviceroutine.yml (modified) * spec/glos/term/io.yml (modified) * spec/glos/term/isr.yml (modified) * spec/glos/term/isvv.yml (modified) * spec/glos/term/kernel.yml (modified) * spec/glos/term/list.yml (modified) * spec/glos/term/littleendian.yml (modified) * spec/glos/term/local.yml (modified) * spec/glos/term/localoperation.yml (modified) * spec/glos/term/logicaladdress.yml (modified) * spec/glos/term/looselycoupled.yml (modified) * spec/glos/term/majornumber.yml (modified) * spec/glos/term/manager.yml (modified) * spec/glos/term/mcs.yml (modified) * spec/glos/term/memorypool.yml (modified) * spec/glos/term/message.yml (modified) * spec/glos/term/messagebuffer.yml (modified) * spec/glos/term/messagequeue.yml (modified) * spec/glos/term/messagequeuecontrolblock.yml (modified) * spec/glos/term/minornumber.yml (modified) * spec/glos/term/mode.yml (modified) * spec/glos/term/mpci.yml (modified) * spec/glos/term/multiprocessing.yml (modified) * spec/glos/term/multiprocessor.yml (modified) * spec/glos/term/multiprocessorcommunicationsinterfacelayer.yml (modified) * spec/glos/term/multiprocessorconfigurationtable.yml (modified) * spec/glos/term/multitasking.yml (modified) * spec/glos/term/mutualexclusion.yml (modified) * spec/glos/term/nested.yml (modified) * spec/glos/term/node.yml (modified) * spec/glos/term/nonexistent.yml (modified) * spec/glos/term/numa.yml (modified) * spec/glos/term/numericcoprocessor.yml (modified) * spec/glos/term/object.yml (modified) * spec/glos/term/objectoriented.yml (modified) * spec/glos/term/operatingsystem.yml (modified) * spec/glos/term/overhead.yml (modified) * spec/glos/term/packet.yml (modified) * spec/glos/term/partition.yml (modified) * spec/glos/term/partitioncontrolblock.yml (modified) * spec/glos/term/pending.yml (modified) * spec/glos/term/periodictask.yml (modified) * spec/glos/term/physicaladdress.yml (modified) * spec/glos/term/poll.yml (modified) * spec/glos/term/pool.yml (modified) * spec/glos/term/portability.yml (modified) * spec/glos/term/posting.yml (modified) * spec/glos/term/preempt.yml (modified) * spec/glos/term/priority.yml (modified) * spec/glos/term/priorityboosting.yml (modified) * spec/glos/term/priorityinheritance.yml (modified) * spec/glos/term/priorityinversion.yml (modified) * spec/glos/term/processorutilization.yml (modified) * spec/glos/term/proxy.yml (modified) * spec/glos/term/proxycontrolblock.yml (modified) * spec/glos/term/ptcb.yml (modified) * spec/glos/term/pxcb.yml (modified) * spec/glos/term/qcb.yml (modified) * spec/glos/term/quantum.yml (modified) * spec/glos/term/queue.yml (modified) * spec/glos/term/readytask.yml (modified) * spec/glos/term/realtime.yml (modified) * spec/glos/term/reentrant.yml (modified) * spec/glos/term/region.yml (modified) * spec/glos/term/regioncontrolblock.yml (modified) * spec/glos/term/registers.yml (modified) * spec/glos/term/remote.yml (modified) * spec/glos/term/remoteoperation.yml (modified) * spec/glos/term/reqif.yml (modified) * spec/glos/term/resource.yml (modified) * spec/glos/term/resume.yml (modified) * spec/glos/term/returncode.yml (modified) * spec/glos/term/returnvalue.yml (modified) * spec/glos/term/rncb.yml (modified) * spec/glos/term/roundrobin.yml (modified) * spec/glos/term/rs232.yml (modified) * spec/glos/term/rtems.yml (modified) * spec/glos/term/running.yml (modified) * spec/glos/term/schedulable.yml (modified) * spec/glos/term/schedule.yml (modified) * spec/glos/term/scheduledtask.yml (modified) * spec/glos/term/scheduler.yml (modified) * spec/glos/term/schedulerinstance.yml (modified) * spec/glos/term/segments.yml (modified) * spec/glos/term/semaphore.yml (modified) * spec/glos/term/semaphorecontrolblock.yml (modified) * spec/glos/term/sharedmemory.yml (modified) * spec/glos/term/signal.yml (modified) * spec/glos/term/signalset.yml (modified) * spec/glos/term/smcb.yml (modified) * spec/glos/term/smp.yml (modified) * spec/glos/term/smpbarriers.yml (modified) * spec/glos/term/smplocks.yml (modified) * spec/glos/term/softrealtimesystem.yml (modified) * spec/glos/term/softwarecomponent.yml (modified) * spec/glos/term/softwareitem.yml (modified) * spec/glos/term/softwareproduct.yml (modified) * spec/glos/term/softwareunit.yml (modified) * spec/glos/term/sourcecode.yml (modified) * spec/glos/term/sporadictask.yml (modified) * spec/glos/term/stack.yml (modified) * spec/glos/term/statuscode.yml (modified) * spec/glos/term/suspend.yml (modified) * spec/glos/term/synchronous.yml (modified) * spec/glos/term/systemcall.yml (modified) * spec/glos/term/target.yml (modified) * spec/glos/term/tas.yml (modified) * spec/glos/term/task.yml (modified) * spec/glos/term/taskcontrolblock.yml (modified) * spec/glos/term/taskmigration.yml (modified) * spec/glos/term/taskprocessoraffinity.yml (modified) * spec/glos/term/taskswitch.yml (modified) * spec/glos/term/tcb.yml (modified) * spec/glos/term/thread.yml (modified) * spec/glos/term/threaddispatch.yml (modified) * spec/glos/term/tick.yml (modified) * spec/glos/term/tightlycoupled.yml (modified) * spec/glos/term/timeout.yml (modified) * spec/glos/term/timer.yml (modified) * spec/glos/term/timercontrolblock.yml (modified) * spec/glos/term/timeslice.yml (modified) * spec/glos/term/timeslicing.yml (modified) * spec/glos/term/tls.yml (modified) * spec/glos/term/tmcb.yml (modified) * spec/glos/term/transientoverload.yml (modified) * spec/glos/term/ttas.yml (modified) * spec/glos/term/userextensions.yml (modified) * spec/glos/term/userextensiontable.yml (modified) * spec/glos/term/userinitializationtaskstable.yml (modified) * spec/glos/term/userprovided.yml (modified) * spec/glos/term/usersupplied.yml (modified) * spec/glos/term/vector.yml (modified) * spec/glos/term/waitqueue.yml (modified) * spec/glos/term/yaml.yml (modified) * spec/glos/term/yield.yml (modified) * spec/spec/build-action-check-cc.yml (modified) * spec/spec/build-action-check-cxx.yml (modified) * spec/spec/build-action-set-test-state.yml (modified) * spec/spec/build-action.yml (modified) * spec/spec/build-config-header.yml (modified) * spec/spec/build-default-by-variant.yml (modified) * spec/spec/build-option.yml (modified) * spec/spec/build-script.yml (modified) * spec/spec/requirement.yml (modified) spec: Sort attributes Mon, 25 May 2020 07:17:36 GMT Sebastian Huber [7bc6441] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/ga.yml (modified) * rtemsqual/tests/spec-interface/gb.yml (modified) * rtemsqual/tests/spec-interface/gc.yml (modified) * spec/groups/api.yml (modified) * spec/groups/api/basedefs.yml (modified) * spec/groups/api/classic.yml (modified) * spec/groups/api/classic/init.yml (modified) * spec/groups/api/classic/status.yml (modified) * spec/groups/api/config.yml (modified) Rename interface group attributes Thu, 14 May 2020 06:29:58 GMT Sebastian Huber [cae542a] * spec/groups/api/classic.yml (added) * spec/groups/api/classic/init.yml (added) * spec/groups/api/classic/status.yml (added) * spec/groups/api/config.yml (added) * spec/if/c/bool.yml (added) * spec/if/impl/assert-unreachable.yml (modified) * spec/if/impl/dequalify-types-not-compatible.yml (modified) * spec/if/impl/isr/header.yml (added) * spec/if/impl/isr/stack-size.yml (added) * spec/if/impl/memory/header.yml (added) * spec/if/impl/memory/zero-before-use.yml (added) * spec/if/impl/mpci/configuration.yml (added) * spec/if/impl/mpci/header.yml (added) * spec/if/impl/object/header.yml (added) * spec/if/impl/object/is-unlimited.yml (added) * spec/if/impl/object/maximum-per-allocation.yml (added) * spec/if/impl/object/unlimited-objects.yml (added) * spec/if/impl/smp/header.yml (added) * spec/if/impl/smp/processor-configured-maximum.yml (added) * spec/if/impl/stack/allocator-allocate-type.yml (added) * spec/if/impl/stack/allocator-allocate.yml (added) * spec/if/impl/stack/allocator-avoids-workspace.yml (added) * spec/if/impl/stack/allocator-free-type.yml (added) * spec/if/impl/stack/allocator-free.yml (added) * spec/if/impl/stack/allocator-initialize-type.yml (added) * spec/if/impl/stack/allocator-initialize.yml (added) * spec/if/impl/stack/header.yml (added) * spec/if/impl/thread/header.yml (added) * spec/if/impl/thread/idle-body.yml (added) * spec/if/impl/thread/idle-stack-size.yml (added) * spec/if/impl/userext/header.yml (added) * spec/if/impl/userext/initial-count.yml (added) * spec/if/impl/userext/initial-extensions.yml (added) * spec/if/impl/watchdog/header.yml (added) * spec/if/impl/watchdog/microseconds-per-tick.yml (added) * spec/if/impl/watchdog/nanoseconds-per-tick.yml (added) * spec/if/impl/watchdog/ticks-per-timeslice.yml (added) * spec/if/impl/wkspace/header.yml (added) * spec/if/impl/wkspace/is-unified.yml (added) * spec/if/impl/wkspace/size.yml (added) * spec/if/rtems/basedefs/alias.yml (modified) * spec/if/rtems/basedefs/aligned.yml (modified) * spec/if/rtems/basedefs/alloc-align.yml (modified) * spec/if/rtems/basedefs/alloc-size-2.yml (modified) * spec/if/rtems/basedefs/alloc-size.yml (modified) * spec/if/rtems/basedefs/array-size.yml (modified) * spec/if/rtems/basedefs/compiler-deprecated-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-memory-barrier.yml (modified) * spec/if/rtems/basedefs/compiler-no-return-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-packed-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-pure-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-used-attribute.yml (modified) * spec/if/rtems/basedefs/concat.yml (modified) * spec/if/rtems/basedefs/const.yml (modified) * spec/if/rtems/basedefs/container-of.yml (modified) * spec/if/rtems/basedefs/declare-global-symbol.yml (modified) * spec/if/rtems/basedefs/deconst.yml (modified) * spec/if/rtems/basedefs/define-global-symbol.yml (modified) * spec/if/rtems/basedefs/deprecated.yml (modified) * spec/if/rtems/basedefs/dequalify-depthx.yml (modified) * spec/if/rtems/basedefs/dequalify.yml (modified) * spec/if/rtems/basedefs/devolatile.yml (modified) * spec/if/rtems/basedefs/expand.yml (modified) * spec/if/rtems/basedefs/false.yml (modified) * spec/if/rtems/basedefs/have-member-same-type.yml (modified) * spec/if/rtems/basedefs/inline-routine.yml (modified) * spec/if/rtems/basedefs/malloclike.yml (modified) * spec/if/rtems/basedefs/no-inline.yml (modified) * spec/if/rtems/basedefs/no-return.yml (modified) * spec/if/rtems/basedefs/obfuscate-variable.yml (modified) * spec/if/rtems/basedefs/packed.yml (modified) * spec/if/rtems/basedefs/predict-false.yml (modified) * spec/if/rtems/basedefs/predict-true.yml (modified) * spec/if/rtems/basedefs/printflike.yml (modified) * spec/if/rtems/basedefs/pure.yml (modified) * spec/if/rtems/basedefs/return-address.yml (modified) * spec/if/rtems/basedefs/section.yml (modified) * spec/if/rtems/basedefs/static-assert.yml (modified) * spec/if/rtems/basedefs/string.yml (modified) * spec/if/rtems/basedefs/symbol-name.yml (modified) * spec/if/rtems/basedefs/true.yml (modified) * spec/if/rtems/basedefs/typeof-refx.yml (modified) * spec/if/rtems/basedefs/unreachable.yml (modified) * spec/if/rtems/basedefs/unused.yml (modified) * spec/if/rtems/basedefs/used.yml (modified) * spec/if/rtems/basedefs/warn-unused-result.yml (modified) * spec/if/rtems/basedefs/weak-alias.yml (modified) * spec/if/rtems/basedefs/weak.yml (modified) * spec/if/rtems/basedefs/xconcat.yml (modified) * spec/if/rtems/basedefs/xstring.yml (modified) * spec/if/rtems/basedefs/zero-length-array.yml (modified) * spec/if/rtems/config/api-table.yml (added) * spec/if/rtems/config/get-api-configuration.yml (added) * spec/if/rtems/config/get-do-zero-of-workspace.yml (added) * spec/if/rtems/config/get-idle-task-stack-size.yml (added) * spec/if/rtems/config/get-idle-task.yml (added) * spec/if/rtems/config/get-interrupt-stack-size.yml (added) * spec/if/rtems/config/get-maximum-barriers.yml (added) * spec/if/rtems/config/get-maximum-extensions.yml (added) * spec/if/rtems/config/get-maximum-message-queues.yml (added) * spec/if/rtems/config/get-maximum-partitions.yml (added) * spec/if/rtems/config/get-maximum-periods.yml (added) * spec/if/rtems/config/get-maximum-ports.yml (added) * spec/if/rtems/config/get-maximum-processors.yml (added) * spec/if/rtems/config/get-maximum-regions.yml (added) * spec/if/rtems/config/get-maximum-semaphores.yml (added) * spec/if/rtems/config/get-maximum-tasks.yml (added) * spec/if/rtems/config/get-maximum-timers.yml (added) * spec/if/rtems/config/get-microseconds-per-tick.yml (added) * spec/if/rtems/config/get-milliseconds-per-tick.yml (added) * spec/if/rtems/config/get-nanoseconds-per-tick.yml (added) * spec/if/rtems/config/get-number-of-initial-extensions.yml (added) * spec/if/rtems/config/get-stack-allocate-hook.yml (added) * spec/if/rtems/config/get-stack-allocate-init-hook.yml (added) * spec/if/rtems/config/get-stack-allocator-avoids-work-space.yml (added) * spec/if/rtems/config/get-stack-free-hook.yml (added) * spec/if/rtems/config/get-stack-space-size.yml (added) * spec/if/rtems/config/get-ticks-per-timeslice.yml (added) * spec/if/rtems/config/get-unified-work-area.yml (added) * spec/if/rtems/config/get-user-extension-table.yml (added) * spec/if/rtems/config/get-user-multiprocessing-table.yml (added) * spec/if/rtems/config/get-work-space-size.yml (added) * spec/if/rtems/config/header-2.yml (added) * spec/if/rtems/config/header.yml (added) * spec/if/rtems/config/resource-is-unlimited.yml (added) * spec/if/rtems/config/resource-maximum-per-allocation.yml (added) * spec/if/rtems/config/resource-unlimited.yml (added) * spec/if/rtems/config/stack-allocate-hook.yml (added) * spec/if/rtems/config/stack-allocate-init-hook.yml (added) * spec/if/rtems/config/stack-free-hook.yml (added) * spec/if/rtems/config/unlimited-objects.yml (added) * spec/if/rtems/init/header.yml (added) * spec/if/rtems/init/initialize-executive.yml (added) * spec/if/rtems/init/shutdown-executive.yml (added) * spec/if/rtems/status/already-suspended.yml (added) * spec/if/rtems/status/called-from-isr.yml (added) * spec/if/rtems/status/code-to-errno.yml (added) * spec/if/rtems/status/code.yml (added) * spec/if/rtems/status/first.yml (added) * spec/if/rtems/status/header.yml (added) * spec/if/rtems/status/illegal-on-remote-object.yml (added) * spec/if/rtems/status/illegal-on-self.yml (added) * spec/if/rtems/status/incorrect-state.yml (added) * spec/if/rtems/status/internal-error.yml (added) * spec/if/rtems/status/interrupted.yml (added) * spec/if/rtems/status/invalid-address.yml (added) * spec/if/rtems/status/invalid-clock.yml (added) * spec/if/rtems/status/invalid-id.yml (added) * spec/if/rtems/status/invalid-name.yml (added) * spec/if/rtems/status/invalid-node.yml (added) * spec/if/rtems/status/invalid-number.yml (added) * spec/if/rtems/status/invalid-priority.yml (added) * spec/if/rtems/status/invalid-size.yml (added) * spec/if/rtems/status/io-error.yml (added) * spec/if/rtems/status/is-equal.yml (added) * spec/if/rtems/status/is-successful.yml (added) * spec/if/rtems/status/last.yml (added) * spec/if/rtems/status/mp-not-configured.yml (added) * spec/if/rtems/status/no-memory.yml (added) * spec/if/rtems/status/not-configured.yml (added) * spec/if/rtems/status/not-defined.yml (added) * spec/if/rtems/status/not-implemented.yml (added) * spec/if/rtems/status/not-owner-of-resource.yml (added) * spec/if/rtems/status/object-was-deleted.yml (added) * spec/if/rtems/status/proxy-blocking.yml (added) * spec/if/rtems/status/resource-in-use.yml (added) * spec/if/rtems/status/successful.yml (added) * spec/if/rtems/status/task-exitted.yml (added) * spec/if/rtems/status/text.yml (added) * spec/if/rtems/status/timeout.yml (added) * spec/if/rtems/status/too-many.yml (added) * spec/if/rtems/status/unsatisfied.yml (added) * spec/if/rtems/types/header.yml (added) spec: Add more interface specification items Mon, 25 May 2020 06:48:50 GMT Sebastian Huber [f9cff66] * spec/glos/general.yml (modified) * spec/glossary.yml (modified) * spec/spec/glossary-group.yml (added) * spec/spec/glossary-term.yml (added) * spec/spec/glossary.yml (added) * spec/spec/requirement-non-functional-type.yml (modified) spec: Add specification of glossary items Mon, 25 May 2020 06:37:49 GMT Sebastian Huber [f641d56] * rtemsqual/content.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/tests/spec-glossary/glos/g.yml (modified) * rtemsqual/tests/spec-glossary/glos/term/t.yml (modified) * rtemsqual/tests/spec-glossary/glos/term/u.yml (modified) * rtemsqual/tests/spec-glossary/glos/term/v.yml (modified) * rtemsqual/tests/spec-sphinx/x.yml (modified) * rtemsqual/tests/test_content_sphinx.py (modified) * spec/glos/general.yml (modified) * spec/glos/term/abi.yml (modified) * spec/glos/term/active.yml (modified) * spec/glos/term/aperiodictask.yml (modified) * spec/glos/term/api.yml (modified) * spec/glos/term/application.yml (modified) * spec/glos/term/asr.yml (modified) * spec/glos/term/assemblerlanguage.yml (modified) * spec/glos/term/asynchronous.yml (modified) * spec/glos/term/asynchronoussignalroutine.yml (modified) * spec/glos/term/atomicoperations.yml (modified) * spec/glos/term/awakened.yml (modified) * spec/glos/term/bigendian.yml (modified) * spec/glos/term/bitmapped.yml (modified) * spec/glos/term/block.yml (modified) * spec/glos/term/blockedtask.yml (modified) * spec/glos/term/boardsupportpackage.yml (modified) * spec/glos/term/broadcast.yml (modified) * spec/glos/term/bsp.yml (modified) * spec/glos/term/buffer.yml (modified) * spec/glos/term/c11.yml (modified) * spec/glos/term/callingconvention.yml (modified) * spec/glos/term/ccb.yml (modified) * spec/glos/term/centralprocessingunit.yml (modified) * spec/glos/term/chain.yml (modified) * spec/glos/term/clanguage.yml (modified) * spec/glos/term/cluster.yml (modified) * spec/glos/term/coalesce.yml (modified) * spec/glos/term/configurationtable.yml (modified) * spec/glos/term/context.yml (modified) * spec/glos/term/contextswitch.yml (modified) * spec/glos/term/controlblock.yml (modified) * spec/glos/term/core.yml (modified) * spec/glos/term/cpu.yml (modified) * spec/glos/term/criticalsection.yml (modified) * spec/glos/term/crt.yml (modified) * spec/glos/term/cxx11.yml (modified) * spec/glos/term/deadline.yml (modified) * spec/glos/term/device.yml (modified) * spec/glos/term/devicedriver.yml (modified) * spec/glos/term/devicedrivertable.yml (modified) * spec/glos/term/directives.yml (modified) * spec/glos/term/dispatch.yml (modified) * spec/glos/term/doorstop.yml (modified) * spec/glos/term/dormant.yml (modified) * spec/glos/term/dualported.yml (modified) * spec/glos/term/ears.yml (modified) * spec/glos/term/elf.yml (modified) * spec/glos/term/embedded.yml (modified) * spec/glos/term/entrypoint.yml (modified) * spec/glos/term/envelope.yml (modified) * spec/glos/term/errorcode.yml (modified) * spec/glos/term/events.yml (modified) * spec/glos/term/exception.yml (modified) * spec/glos/term/executingtask.yml (modified) * spec/glos/term/executive.yml (modified) * spec/glos/term/exported.yml (modified) * spec/glos/term/externaladdress.yml (modified) * spec/glos/term/fifo.yml (modified) * spec/glos/term/firstinfirstout.yml (modified) * spec/glos/term/floatingpointcoprocessor.yml (modified) * spec/glos/term/freed.yml (modified) * spec/glos/term/gcc.yml (modified) * spec/glos/term/global.yml (modified) * spec/glos/term/gnat.yml (modified) * spec/glos/term/gnu.yml (modified) * spec/glos/term/handler.yml (modified) * spec/glos/term/hardrealtimesystem.yml (modified) * spec/glos/term/heap.yml (modified) * spec/glos/term/heirtask.yml (modified) * spec/glos/term/heterogeneous.yml (modified) * spec/glos/term/homogeneous.yml (modified) * spec/glos/term/id.yml (modified) * spec/glos/term/idletask.yml (modified) * spec/glos/term/interface.yml (modified) * spec/glos/term/internaladdress.yml (modified) * spec/glos/term/interrupt.yml (modified) * spec/glos/term/interruptlevel.yml (modified) * spec/glos/term/interruptservice.yml (modified) * spec/glos/term/interruptserviceroutine.yml (modified) * spec/glos/term/io.yml (modified) * spec/glos/term/isr.yml (modified) * spec/glos/term/isvv.yml (modified) * spec/glos/term/kernel.yml (modified) * spec/glos/term/list.yml (modified) * spec/glos/term/littleendian.yml (modified) * spec/glos/term/local.yml (modified) * spec/glos/term/localoperation.yml (modified) * spec/glos/term/logicaladdress.yml (modified) * spec/glos/term/looselycoupled.yml (modified) * spec/glos/term/majornumber.yml (modified) * spec/glos/term/manager.yml (modified) * spec/glos/term/mcs.yml (modified) * spec/glos/term/memorypool.yml (modified) * spec/glos/term/message.yml (modified) * spec/glos/term/messagebuffer.yml (modified) * spec/glos/term/messagequeue.yml (modified) * spec/glos/term/messagequeuecontrolblock.yml (modified) * spec/glos/term/minornumber.yml (modified) * spec/glos/term/mode.yml (modified) * spec/glos/term/mpci.yml (modified) * spec/glos/term/multiprocessing.yml (modified) * spec/glos/term/multiprocessor.yml (modified) * spec/glos/term/multiprocessorcommunicationsinterfacelayer.yml (modified) * spec/glos/term/multiprocessorconfigurationtable.yml (modified) * spec/glos/term/multitasking.yml (modified) * spec/glos/term/mutualexclusion.yml (modified) * spec/glos/term/nested.yml (modified) * spec/glos/term/node.yml (modified) * spec/glos/term/nonexistent.yml (modified) * spec/glos/term/numa.yml (modified) * spec/glos/term/numericcoprocessor.yml (modified) * spec/glos/term/object.yml (modified) * spec/glos/term/objectoriented.yml (modified) * spec/glos/term/operatingsystem.yml (modified) * spec/glos/term/overhead.yml (modified) * spec/glos/term/packet.yml (modified) * spec/glos/term/partition.yml (modified) * spec/glos/term/partitioncontrolblock.yml (modified) * spec/glos/term/pending.yml (modified) * spec/glos/term/periodictask.yml (modified) * spec/glos/term/physicaladdress.yml (modified) * spec/glos/term/poll.yml (modified) * spec/glos/term/pool.yml (modified) * spec/glos/term/portability.yml (modified) * spec/glos/term/posting.yml (modified) * spec/glos/term/preempt.yml (modified) * spec/glos/term/priority.yml (modified) * spec/glos/term/priorityboosting.yml (modified) * spec/glos/term/priorityinheritance.yml (modified) * spec/glos/term/priorityinversion.yml (modified) * spec/glos/term/processorutilization.yml (modified) * spec/glos/term/proxy.yml (modified) * spec/glos/term/proxycontrolblock.yml (modified) * spec/glos/term/ptcb.yml (modified) * spec/glos/term/pxcb.yml (modified) * spec/glos/term/qcb.yml (modified) * spec/glos/term/quantum.yml (modified) * spec/glos/term/queue.yml (modified) * spec/glos/term/readytask.yml (modified) * spec/glos/term/realtime.yml (modified) * spec/glos/term/reentrant.yml (modified) * spec/glos/term/region.yml (modified) * spec/glos/term/regioncontrolblock.yml (modified) * spec/glos/term/registers.yml (modified) * spec/glos/term/remote.yml (modified) * spec/glos/term/remoteoperation.yml (modified) * spec/glos/term/reqif.yml (modified) * spec/glos/term/resource.yml (modified) * spec/glos/term/resume.yml (modified) * spec/glos/term/returncode.yml (modified) * spec/glos/term/returnvalue.yml (modified) * spec/glos/term/rncb.yml (modified) * spec/glos/term/roundrobin.yml (modified) * spec/glos/term/rs232.yml (modified) * spec/glos/term/rtems.yml (modified) * spec/glos/term/running.yml (modified) * spec/glos/term/schedulable.yml (modified) * spec/glos/term/schedule.yml (modified) * spec/glos/term/scheduledtask.yml (modified) * spec/glos/term/scheduler.yml (modified) * spec/glos/term/schedulerinstance.yml (modified) * spec/glos/term/segments.yml (modified) * spec/glos/term/semaphore.yml (modified) * spec/glos/term/semaphorecontrolblock.yml (modified) * spec/glos/term/sharedmemory.yml (modified) * spec/glos/term/signal.yml (modified) * spec/glos/term/signalset.yml (modified) * spec/glos/term/smcb.yml (modified) * spec/glos/term/smp.yml (modified) * spec/glos/term/smpbarriers.yml (modified) * spec/glos/term/smplocks.yml (modified) * spec/glos/term/softrealtimesystem.yml (modified) * spec/glos/term/softwarecomponent.yml (modified) * spec/glos/term/softwareitem.yml (modified) * spec/glos/term/softwareproduct.yml (modified) * spec/glos/term/softwareunit.yml (modified) * spec/glos/term/sourcecode.yml (modified) * spec/glos/term/sporadictask.yml (modified) * spec/glos/term/stack.yml (modified) * spec/glos/term/statuscode.yml (modified) * spec/glos/term/suspend.yml (modified) * spec/glos/term/synchronous.yml (modified) * spec/glos/term/systemcall.yml (modified) * spec/glos/term/target.yml (modified) * spec/glos/term/tas.yml (modified) * spec/glos/term/task.yml (modified) * spec/glos/term/taskcontrolblock.yml (modified) * spec/glos/term/taskmigration.yml (modified) * spec/glos/term/taskprocessoraffinity.yml (modified) * spec/glos/term/taskswitch.yml (modified) * spec/glos/term/tcb.yml (modified) * spec/glos/term/thread.yml (modified) * spec/glos/term/threaddispatch.yml (modified) * spec/glos/term/tick.yml (modified) * spec/glos/term/tightlycoupled.yml (modified) * spec/glos/term/timeout.yml (modified) * spec/glos/term/timer.yml (modified) * spec/glos/term/timercontrolblock.yml (modified) * spec/glos/term/timeslice.yml (modified) * spec/glos/term/timeslicing.yml (modified) * spec/glos/term/tls.yml (modified) * spec/glos/term/tmcb.yml (modified) * spec/glos/term/transientoverload.yml (modified) * spec/glos/term/ttas.yml (modified) * spec/glos/term/userextensions.yml (modified) * spec/glos/term/userextensiontable.yml (modified) * spec/glos/term/userinitializationtaskstable.yml (modified) * spec/glos/term/userprovided.yml (modified) * spec/glos/term/usersupplied.yml (modified) * spec/glos/term/vector.yml (modified) * spec/glos/term/waitqueue.yml (modified) * spec/glos/term/yaml.yml (modified) * spec/glos/term/yield.yml (modified) Rename glossary attributes Rename "glossary-term" in "term". ... Fri, 22 May 2020 16:33:19 GMT Sebastian Huber [2a2fd6d] * spec/spec/bool-or-int-or-str.yml (added) * spec/spec/build-action-check-cc.yml (added) * spec/spec/build-action-check-cxx.yml (added) * spec/spec/build-action-list.yml (added) * spec/spec/build-action-set-test-state.yml (added) * spec/spec/build-action.yml (added) * spec/spec/build-ada-test-program.yml (added) * spec/spec/build-asflag.yml (added) * spec/spec/build-asflags.yml (added) * spec/spec/build-bsp.yml (modified) * spec/spec/build-config-file.yml (added) * spec/spec/build-config-header.yml (added) * spec/spec/build-default-by-variant-list.yml (added) * spec/spec/build-default-by-variant.yml (added) * spec/spec/build-group.yml (added) * spec/spec/build-include.yml (modified) * spec/spec/build-install-path.yml (added) * spec/spec/build-ldflag.yml (added) * spec/spec/build-ldflags.yml (added) * spec/spec/build-library.yml (added) * spec/spec/build-objects.yml (added) * spec/spec/build-option-name.yml (added) * spec/spec/build-option-value.yml (added) * spec/spec/build-option.yml (added) * spec/spec/build-script.yml (added) * spec/spec/build-start-file.yml (added) * spec/spec/build-target.yml (added) * spec/spec/build-test-program.yml (added) * spec/spec/build-test-state.yml (added) * spec/spec/build-use-after-list.yml (added) * spec/spec/build-use-after.yml (added) * spec/spec/build-use-before-list.yml (added) * spec/spec/build-use-before.yml (added) spec: Add specification of build items Thu, 21 May 2020 13:10:43 GMT Sebastian Huber [b75c6be] * spec/spec/appl-config-group-member.yml (added) * spec/spec/appl-config-group.yml (added) * spec/spec/appl-config-option-constraint.yml (added) * spec/spec/appl-config-option-feature-enable.yml (added) * spec/spec/appl-config-option-feature.yml (added) * spec/spec/appl-config-option-name.yml (added) * spec/spec/appl-config-option-value.yml (added) * spec/spec/appl-config-option.yml (added) * spec/spec/build-bsp.yml (added) * spec/spec/build-cflag.yml (added) * spec/spec/build-cflags.yml (added) * spec/spec/build-cppflag.yml (added) * spec/spec/build-cppflags.yml (added) * spec/spec/build-cxxflag.yml (added) * spec/spec/build-cxxflags.yml (added) * spec/spec/build-dependency.yml (added) * spec/spec/build-include.yml (added) * spec/spec/build-includes.yml (added) * spec/spec/build-install-list.yml (added) * spec/spec/build-install.yml (added) * spec/spec/build-source-list.yml (added) * spec/spec/build-source.yml (added) * spec/spec/build.yml (added) * spec/spec/glossary-member.yml (added) * spec/spec/int-or-str.yml (added) * spec/spec/interface-include.yml (added) * spec/spec/interface-ingroup.yml (added) * spec/spec/interface-placement.yml (added) * spec/spec/interface.yml (added) * spec/spec/list-int-or-str.yml (added) * spec/spec/list-str.yml (modified) * spec/spec/list-uid.yml (added) * spec/spec/requirement-functional-type.yml (added) * spec/spec/requirement-functional.yml (added) * spec/spec/requirement-non-functional-type.yml (added) * spec/spec/requirement-non-functional.yml (added) * spec/spec/requirement-refinement.yml (added) * spec/spec/requirement-text.yml (added) * spec/spec/requirement.yml (added) * spec/spec/spec-member.yml (modified) * spec/spec/spec-refinement.yml (modified) spec: Add specification of specification items Fri, 22 May 2020 12:13:55 GMT Sebastian Huber [0aba520] * spec/applconfig.yml (modified) spec: Add requirement types Fri, 22 May 2020 12:08:39 GMT Sebastian Huber [6aaf56c] * spec/acfg/opt/constraintbspappmin.yml (modified) * spec/acfg/opt/constraintidlestackarea.yml (modified) * spec/acfg/opt/constraintisrstackalign.yml (modified) * spec/acfg/opt/constraintisrstackarea.yml (modified) * spec/acfg/opt/constraintmemsz.yml (modified) * spec/acfg/opt/constraintposix.yml (modified) * spec/acfg/opt/constraintprioclassic.yml (modified) * spec/acfg/opt/constraintstackspace.yml (modified) * spec/acfg/opt/constraintunlimited.yml (modified) * spec/acfg/opt/constraintwkspace.yml (modified) spec: Make constraints non-functional requirements Fri, 22 May 2020 09:17:45 GMT Sebastian Huber [b4f60b6] * spec/acfg/bdbuf.yml (modified) * spec/acfg/bsp.yml (modified) * spec/acfg/classic.yml (modified) * spec/acfg/classicinit.yml (modified) * spec/acfg/devdrv.yml (modified) * spec/acfg/eventrecord.yml (modified) * spec/acfg/filesystem.yml (modified) * spec/acfg/general.yml (modified) * spec/acfg/idle.yml (modified) * spec/acfg/mpci.yml (modified) * spec/acfg/posix.yml (modified) * spec/acfg/posixinit.yml (modified) * spec/acfg/schedgeneral.yml (modified) * spec/acfg/stackalloc.yml (modified) * spec/glos/general.yml (modified) spec: Add requirement-refinement link role Fri, 22 May 2020 09:13:52 GMT Sebastian Huber [e1e1bed] * spec/glos/term/abi.yml (modified) * spec/glos/term/active.yml (modified) * spec/glos/term/aperiodictask.yml (modified) * spec/glos/term/api.yml (modified) * spec/glos/term/application.yml (modified) * spec/glos/term/asr.yml (modified) * spec/glos/term/assemblerlanguage.yml (modified) * spec/glos/term/asynchronous.yml (modified) * spec/glos/term/asynchronoussignalroutine.yml (modified) * spec/glos/term/atomicoperations.yml (modified) * spec/glos/term/awakened.yml (modified) * spec/glos/term/bigendian.yml (modified) * spec/glos/term/bitmapped.yml (modified) * spec/glos/term/block.yml (modified) * spec/glos/term/blockedtask.yml (modified) * spec/glos/term/boardsupportpackage.yml (modified) * spec/glos/term/broadcast.yml (modified) * spec/glos/term/bsp.yml (modified) * spec/glos/term/buffer.yml (modified) * spec/glos/term/c11.yml (modified) * spec/glos/term/callingconvention.yml (modified) * spec/glos/term/ccb.yml (modified) * spec/glos/term/centralprocessingunit.yml (modified) * spec/glos/term/chain.yml (modified) * spec/glos/term/clanguage.yml (modified) * spec/glos/term/cluster.yml (modified) * spec/glos/term/coalesce.yml (modified) * spec/glos/term/configurationtable.yml (modified) * spec/glos/term/context.yml (modified) * spec/glos/term/contextswitch.yml (modified) * spec/glos/term/controlblock.yml (modified) * spec/glos/term/core.yml (modified) * spec/glos/term/cpu.yml (modified) * spec/glos/term/criticalsection.yml (modified) * spec/glos/term/crt.yml (modified) * spec/glos/term/cxx11.yml (modified) * spec/glos/term/deadline.yml (modified) * spec/glos/term/device.yml (modified) * spec/glos/term/devicedriver.yml (modified) * spec/glos/term/devicedrivertable.yml (modified) * spec/glos/term/directives.yml (modified) * spec/glos/term/dispatch.yml (modified) * spec/glos/term/doorstop.yml (modified) * spec/glos/term/dormant.yml (modified) * spec/glos/term/dualported.yml (modified) * spec/glos/term/ears.yml (modified) * spec/glos/term/elf.yml (modified) * spec/glos/term/embedded.yml (modified) * spec/glos/term/entrypoint.yml (modified) * spec/glos/term/envelope.yml (modified) * spec/glos/term/errorcode.yml (modified) * spec/glos/term/events.yml (modified) * spec/glos/term/exception.yml (modified) * spec/glos/term/executingtask.yml (modified) * spec/glos/term/executive.yml (modified) * spec/glos/term/exported.yml (modified) * spec/glos/term/externaladdress.yml (modified) * spec/glos/term/fifo.yml (modified) * spec/glos/term/firstinfirstout.yml (modified) * spec/glos/term/floatingpointcoprocessor.yml (modified) * spec/glos/term/freed.yml (modified) * spec/glos/term/gcc.yml (modified) * spec/glos/term/global.yml (modified) * spec/glos/term/gnat.yml (modified) * spec/glos/term/gnu.yml (modified) * spec/glos/term/handler.yml (modified) * spec/glos/term/hardrealtimesystem.yml (modified) * spec/glos/term/heap.yml (modified) * spec/glos/term/heirtask.yml (modified) * spec/glos/term/heterogeneous.yml (modified) * spec/glos/term/homogeneous.yml (modified) * spec/glos/term/id.yml (modified) * spec/glos/term/idletask.yml (modified) * spec/glos/term/interface.yml (modified) * spec/glos/term/internaladdress.yml (modified) * spec/glos/term/interrupt.yml (modified) * spec/glos/term/interruptlevel.yml (modified) * spec/glos/term/interruptservice.yml (modified) * spec/glos/term/interruptserviceroutine.yml (modified) * spec/glos/term/io.yml (modified) * spec/glos/term/isr.yml (modified) * spec/glos/term/isvv.yml (modified) * spec/glos/term/kernel.yml (modified) * spec/glos/term/list.yml (modified) * spec/glos/term/littleendian.yml (modified) * spec/glos/term/local.yml (modified) * spec/glos/term/localoperation.yml (modified) * spec/glos/term/logicaladdress.yml (modified) * spec/glos/term/looselycoupled.yml (modified) * spec/glos/term/majornumber.yml (modified) * spec/glos/term/manager.yml (modified) * spec/glos/term/mcs.yml (modified) * spec/glos/term/memorypool.yml (modified) * spec/glos/term/message.yml (modified) * spec/glos/term/messagebuffer.yml (modified) * spec/glos/term/messagequeue.yml (modified) * spec/glos/term/messagequeuecontrolblock.yml (modified) * spec/glos/term/minornumber.yml (modified) * spec/glos/term/mode.yml (modified) * spec/glos/term/mpci.yml (modified) * spec/glos/term/multiprocessing.yml (modified) * spec/glos/term/multiprocessor.yml (modified) * spec/glos/term/multiprocessorcommunicationsinterfacelayer.yml (modified) * spec/glos/term/multiprocessorconfigurationtable.yml (modified) * spec/glos/term/multitasking.yml (modified) * spec/glos/term/mutualexclusion.yml (modified) * spec/glos/term/nested.yml (modified) * spec/glos/term/node.yml (modified) * spec/glos/term/nonexistent.yml (modified) * spec/glos/term/numa.yml (modified) * spec/glos/term/numericcoprocessor.yml (modified) * spec/glos/term/object.yml (modified) * spec/glos/term/objectoriented.yml (modified) * spec/glos/term/operatingsystem.yml (modified) * spec/glos/term/overhead.yml (modified) * spec/glos/term/packet.yml (modified) * spec/glos/term/partition.yml (modified) * spec/glos/term/partitioncontrolblock.yml (modified) * spec/glos/term/pending.yml (modified) * spec/glos/term/periodictask.yml (modified) * spec/glos/term/physicaladdress.yml (modified) * spec/glos/term/poll.yml (modified) * spec/glos/term/pool.yml (modified) * spec/glos/term/portability.yml (modified) * spec/glos/term/posting.yml (modified) * spec/glos/term/preempt.yml (modified) * spec/glos/term/priority.yml (modified) * spec/glos/term/priorityboosting.yml (modified) * spec/glos/term/priorityinheritance.yml (modified) * spec/glos/term/priorityinversion.yml (modified) * spec/glos/term/processorutilization.yml (modified) * spec/glos/term/proxy.yml (modified) * spec/glos/term/proxycontrolblock.yml (modified) * spec/glos/term/ptcb.yml (modified) * spec/glos/term/pxcb.yml (modified) * spec/glos/term/qcb.yml (modified) * spec/glos/term/quantum.yml (modified) * spec/glos/term/queue.yml (modified) * spec/glos/term/readytask.yml (modified) * spec/glos/term/realtime.yml (modified) * spec/glos/term/reentrant.yml (modified) * spec/glos/term/region.yml (modified) * spec/glos/term/regioncontrolblock.yml (modified) * spec/glos/term/registers.yml (modified) * spec/glos/term/remote.yml (modified) * spec/glos/term/remoteoperation.yml (modified) * spec/glos/term/reqif.yml (modified) * spec/glos/term/resource.yml (modified) * spec/glos/term/resume.yml (modified) * spec/glos/term/returncode.yml (modified) * spec/glos/term/returnvalue.yml (modified) * spec/glos/term/rncb.yml (modified) * spec/glos/term/roundrobin.yml (modified) * spec/glos/term/rs232.yml (modified) * spec/glos/term/rtems.yml (modified) * spec/glos/term/running.yml (modified) * spec/glos/term/schedulable.yml (modified) * spec/glos/term/schedule.yml (modified) * spec/glos/term/scheduledtask.yml (modified) * spec/glos/term/scheduler.yml (modified) * spec/glos/term/schedulerinstance.yml (modified) * spec/glos/term/segments.yml (modified) * spec/glos/term/semaphore.yml (modified) * spec/glos/term/semaphorecontrolblock.yml (modified) * spec/glos/term/sharedmemory.yml (modified) * spec/glos/term/signal.yml (modified) * spec/glos/term/signalset.yml (modified) * spec/glos/term/smcb.yml (modified) * spec/glos/term/smp.yml (modified) * spec/glos/term/smpbarriers.yml (modified) * spec/glos/term/smplocks.yml (modified) * spec/glos/term/softrealtimesystem.yml (modified) * spec/glos/term/softwarecomponent.yml (modified) * spec/glos/term/softwareitem.yml (modified) * spec/glos/term/softwareproduct.yml (modified) * spec/glos/term/softwareunit.yml (modified) * spec/glos/term/sourcecode.yml (modified) * spec/glos/term/sporadictask.yml (modified) * spec/glos/term/stack.yml (modified) * spec/glos/term/statuscode.yml (modified) * spec/glos/term/suspend.yml (modified) * spec/glos/term/synchronous.yml (modified) * spec/glos/term/systemcall.yml (modified) * spec/glos/term/target.yml (modified) * spec/glos/term/tas.yml (modified) * spec/glos/term/task.yml (modified) * spec/glos/term/taskcontrolblock.yml (modified) * spec/glos/term/taskmigration.yml (modified) * spec/glos/term/taskprocessoraffinity.yml (modified) * spec/glos/term/taskswitch.yml (modified) * spec/glos/term/tcb.yml (modified) * spec/glos/term/thread.yml (modified) * spec/glos/term/threaddispatch.yml (modified) * spec/glos/term/tick.yml (modified) * spec/glos/term/tightlycoupled.yml (modified) * spec/glos/term/timeout.yml (modified) * spec/glos/term/timer.yml (modified) * spec/glos/term/timercontrolblock.yml (modified) * spec/glos/term/timeslice.yml (modified) * spec/glos/term/timeslicing.yml (modified) * spec/glos/term/tls.yml (modified) * spec/glos/term/tmcb.yml (modified) * spec/glos/term/transientoverload.yml (modified) * spec/glos/term/ttas.yml (modified) * spec/glos/term/userextensions.yml (modified) * spec/glos/term/userextensiontable.yml (modified) * spec/glos/term/userinitializationtaskstable.yml (modified) * spec/glos/term/userprovided.yml (modified) * spec/glos/term/usersupplied.yml (modified) * spec/glos/term/vector.yml (modified) * spec/glos/term/waitqueue.yml (modified) * spec/glos/term/yaml.yml (modified) * spec/glos/term/yield.yml (modified) spec: Add glossary-member link role Fri, 22 May 2020 08:34:35 GMT Sebastian Huber [e12cfeb] * rtemsqual/tests/spec-verify/spec/spdx-license-identifier.yml (modified) * spec/spec/spdx-license-identifier.yml (modified) spec: Fix description Fri, 22 May 2020 08:07:56 GMT Sebastian Huber [9f46eeb] * spec/acfg/opt/appldisablefilesystem.yml (modified) * spec/acfg/opt/appldoesnotneedclockdriver.yml (modified) * spec/acfg/opt/applextradrivers.yml (modified) * spec/acfg/opt/applneedsatadriver.yml (modified) * spec/acfg/opt/applneedsclockdriver.yml (modified) * spec/acfg/opt/applneedsconsoledriver.yml (modified) * spec/acfg/opt/applneedsframebufferdriver.yml (modified) * spec/acfg/opt/applneedsidedriver.yml (modified) * spec/acfg/opt/applneedslibblock.yml (modified) * spec/acfg/opt/applneedsnulldriver.yml (modified) * spec/acfg/opt/applneedsrtcdriver.yml (modified) * spec/acfg/opt/applneedssimpleconsoledriver.yml (modified) * spec/acfg/opt/applneedssimpletaskconsoledriver.yml (modified) * spec/acfg/opt/applneedsstubdriver.yml (modified) * spec/acfg/opt/applneedstimerdriver.yml (modified) * spec/acfg/opt/applneedswatchdogdriver.yml (modified) * spec/acfg/opt/applneedszerodriver.yml (modified) * spec/acfg/opt/applprerequisitedrivers.yml (modified) * spec/acfg/opt/atadrivertaskpriority.yml (modified) * spec/acfg/opt/bdbufbuffermaxsize.yml (modified) * spec/acfg/opt/bdbufbufferminsize.yml (modified) * spec/acfg/opt/bdbufcachememorysize.yml (modified) * spec/acfg/opt/bdbufmaxreadaheadblocks.yml (modified) * spec/acfg/opt/bdbufmaxwriteblocks.yml (modified) * spec/acfg/opt/bdbufreadaheadtaskpriority.yml (modified) * spec/acfg/opt/bdbuftaskstacksize.yml (modified) * spec/acfg/opt/bspidletaskbody.yml (modified) * spec/acfg/opt/bspidletaskstacksize.yml (modified) * spec/acfg/opt/bspinitialextension.yml (modified) * spec/acfg/opt/bspinterruptstacksize.yml (modified) * spec/acfg/opt/bspprerequisitedrivers.yml (modified) * spec/acfg/opt/cbsmaximumservers.yml (modified) * spec/acfg/opt/dirtymemory.yml (modified) * spec/acfg/opt/disablebspsettings.yml (modified) * spec/acfg/opt/disablenewlibreentrancy.yml (modified) * spec/acfg/opt/executiveramsize.yml (modified) * spec/acfg/opt/extrataskstacks.yml (modified) * spec/acfg/opt/filesystemall.yml (modified) * spec/acfg/opt/filesystemdosfs.yml (modified) * spec/acfg/opt/filesystemftpfs.yml (modified) * spec/acfg/opt/filesystemimfs.yml (modified) * spec/acfg/opt/filesystemjffs2.yml (modified) * spec/acfg/opt/filesystemnfs.yml (modified) * spec/acfg/opt/filesystemrfs.yml (modified) * spec/acfg/opt/filesystemtftpfs.yml (modified) * spec/acfg/opt/idletaskbody.yml (modified) * spec/acfg/opt/idletaskinitappl.yml (modified) * spec/acfg/opt/idletaskstacksize.yml (modified) * spec/acfg/opt/imfsdisablechmod.yml (modified) * spec/acfg/opt/imfsdisablechown.yml (modified) * spec/acfg/opt/imfsdisablelink.yml (modified) * spec/acfg/opt/imfsdisablemknod.yml (modified) * spec/acfg/opt/imfsdisablemknoddevice.yml (modified) * spec/acfg/opt/imfsdisablemknodfile.yml (modified) * spec/acfg/opt/imfsdisablemount.yml (modified) * spec/acfg/opt/imfsdisablereaddir.yml (modified) * spec/acfg/opt/imfsdisablereadlink.yml (modified) * spec/acfg/opt/imfsdisablerename.yml (modified) * spec/acfg/opt/imfsdisablermnod.yml (modified) * spec/acfg/opt/imfsdisablesymlink.yml (modified) * spec/acfg/opt/imfsdisableunmount.yml (modified) * spec/acfg/opt/imfsdisableutime.yml (modified) * spec/acfg/opt/imfsenablemkfifo.yml (modified) * spec/acfg/opt/imfsmemfilebytesperblock.yml (modified) * spec/acfg/opt/initialextensions.yml (modified) * spec/acfg/opt/inittaskarguments.yml (modified) * spec/acfg/opt/inittaskattributes.yml (modified) * spec/acfg/opt/inittaskentrypoint.yml (modified) * spec/acfg/opt/inittaskinitialmodes.yml (modified) * spec/acfg/opt/inittaskname.yml (modified) * spec/acfg/opt/inittaskpriority.yml (modified) * spec/acfg/opt/inittaskstacksize.yml (modified) * spec/acfg/opt/interruptstacksize.yml (modified) * spec/acfg/opt/mallocbspsupportssbrk.yml (modified) * spec/acfg/opt/mallocdirty.yml (modified) * spec/acfg/opt/maxbarriers.yml (modified) * spec/acfg/opt/maxdrivers.yml (modified) * spec/acfg/opt/maxfiledescriptors.yml (modified) * spec/acfg/opt/maxmessagequeues.yml (modified) * spec/acfg/opt/maxpartitions.yml (modified) * spec/acfg/opt/maxperiods.yml (modified) * spec/acfg/opt/maxports.yml (modified) * spec/acfg/opt/maxposixkeys.yml (modified) * spec/acfg/opt/maxposixkeyvaluepairs.yml (modified) * spec/acfg/opt/maxposixmessagequeues.yml (modified) * spec/acfg/opt/maxposixqueuedsignals.yml (modified) * spec/acfg/opt/maxposixsemaphores.yml (modified) * spec/acfg/opt/maxposixshms.yml (modified) * spec/acfg/opt/maxposixthreads.yml (modified) * spec/acfg/opt/maxposixtimers.yml (modified) * spec/acfg/opt/maxpriority.yml (modified) * spec/acfg/opt/maxprocessors.yml (modified) * spec/acfg/opt/maxregions.yml (modified) * spec/acfg/opt/maxsemaphores.yml (modified) * spec/acfg/opt/maxtasks.yml (modified) * spec/acfg/opt/maxthreadnamesize.yml (modified) * spec/acfg/opt/maxtimers.yml (modified) * spec/acfg/opt/maxuserextensions.yml (modified) * spec/acfg/opt/memoryoverhead.yml (modified) * spec/acfg/opt/messagebuffermemory.yml (modified) * spec/acfg/opt/microsecondspertick.yml (modified) * spec/acfg/opt/minposixthreadstacksize.yml (modified) * spec/acfg/opt/mintaskstacksize.yml (modified) * spec/acfg/opt/mpappl.yml (modified) * spec/acfg/opt/mpextraserverstack.yml (modified) * spec/acfg/opt/mpmaxglobalobjects.yml (modified) * spec/acfg/opt/mpmaxnodes.yml (modified) * spec/acfg/opt/mpmaxproxies.yml (modified) * spec/acfg/opt/mpmpcitablepointer.yml (modified) * spec/acfg/opt/mpnodenumber.yml (modified) * spec/acfg/opt/posixinitthreadentrypoint.yml (modified) * spec/acfg/opt/posixinitthreadstacksize.yml (modified) * spec/acfg/opt/posixinitthreadtable.yml (modified) * spec/acfg/opt/recordextensionsenabled.yml (modified) * spec/acfg/opt/recordfataldumpbase64.yml (modified) * spec/acfg/opt/recordfataldumpbase64zlib.yml (modified) * spec/acfg/opt/recordperprocessoritems.yml (modified) * spec/acfg/opt/rtemsinittaskstable.yml (modified) * spec/acfg/opt/schedulerassignments.yml (modified) * spec/acfg/opt/schedulercbs.yml (modified) * spec/acfg/opt/scheduleredf.yml (modified) * spec/acfg/opt/scheduleredfsmp.yml (modified) * spec/acfg/opt/schedulername.yml (modified) * spec/acfg/opt/schedulerpriority.yml (modified) * spec/acfg/opt/schedulerpriorityaffinitysmp.yml (modified) * spec/acfg/opt/schedulerprioritysmp.yml (modified) * spec/acfg/opt/schedulersimple.yml (modified) * spec/acfg/opt/schedulersimplesmp.yml (modified) * spec/acfg/opt/schedulerstrongapa.yml (modified) * spec/acfg/opt/scheduleruser.yml (modified) * spec/acfg/opt/stackcheckerenabled.yml (modified) * spec/acfg/opt/swapoutblockhold.yml (modified) * spec/acfg/opt/swapoutswapperiod.yml (modified) * spec/acfg/opt/swapouttaskpriority.yml (modified) * spec/acfg/opt/swapoutworkertaskpriority.yml (modified) * spec/acfg/opt/swapoutworkertasks.yml (modified) * spec/acfg/opt/taskstackallocator.yml (modified) * spec/acfg/opt/taskstackallocatorinit.yml (modified) * spec/acfg/opt/taskstackdeallocator.yml (modified) * spec/acfg/opt/taskstackfromalloc.yml (modified) * spec/acfg/opt/taskstacknowkspace.yml (modified) * spec/acfg/opt/tickspertimeslice.yml (modified) * spec/acfg/opt/unifiedworkareas.yml (modified) * spec/acfg/opt/unlimitedallocationsize.yml (modified) * spec/acfg/opt/unlimitedobjects.yml (modified) * spec/acfg/opt/usedevfsasbasefilesystem.yml (modified) * spec/acfg/opt/useminiimfsasbasefilesystem.yml (modified) * spec/acfg/opt/verbosesysteminit.yml (modified) * spec/acfg/opt/zeroworkspaceautomatically.yml (modified) spec: Add appl-config-group-member link role Mon, 18 May 2020 08:20:58 GMT Sebastian Huber [b9f3aa7] * spec/spec/copyright.yml (added) * spec/spec/copyrights.yml (added) * spec/spec/enabled-by-list.yml (added) * spec/spec/enabled-by.yml (added) * spec/spec/link.yml (added) * spec/spec/links.yml (added) * spec/spec/list-str.yml (added) * spec/spec/optional-str.yml (added) * spec/spec/root.yml (added) * spec/spec/spdx-license-identifier.yml (added) * spec/spec/spec-assert-float-list.yml (added) * spec/spec/spec-assert-float.yml (added) * spec/spec/spec-assert-int-list.yml (added) * spec/spec/spec-assert-int.yml (added) * spec/spec/spec-assert-str-list.yml (added) * spec/spec/spec-assert-str.yml (added) * spec/spec/spec-attribute-value.yml (added) * spec/spec/spec-attributes.yml (added) * spec/spec/spec-bool.yml (added) * spec/spec/spec-dict.yml (added) * spec/spec/spec-float.yml (added) * spec/spec/spec-generic-attributes.yml (added) * spec/spec/spec-info.yml (added) * spec/spec/spec-int.yml (added) * spec/spec/spec-list.yml (added) * spec/spec/spec-member.yml (added) * spec/spec/spec-refinement.yml (added) * spec/spec/spec-required-attributes.yml (added) * spec/spec/spec-str.yml (added) * spec/spec/spec.yml (added) spec: Add specification of specification items Mon, 18 May 2020 06:58:02 GMT Sebastian Huber [68478a0] * spec/applconfig.yml (modified) * spec/glossary.yml (modified) spec: Add missing license and copyrights Mon, 18 May 2020 06:19:46 GMT Sebastian Huber [3501795] * rtemsqual/content.py (modified) * rtemsqual/interface.py (modified) * rtemsqual/items.py (modified) * rtemsqual/tests/spec-applconfig/a.yml (modified) * rtemsqual/tests/spec-applconfig/b.yml (modified) * rtemsqual/tests/spec-applconfig/c.yml (modified) * rtemsqual/tests/spec-applconfig/d.yml (modified) * rtemsqual/tests/spec-applconfig/e.yml (modified) * rtemsqual/tests/spec-applconfig/f.yml (modified) * rtemsqual/tests/spec-applconfig/g.yml (modified) * rtemsqual/tests/spec-applconfig/h.yml (modified) * rtemsqual/tests/spec-applconfig/i.yml (modified) * rtemsqual/tests/spec-applconfig/j.yml (modified) * rtemsqual/tests/spec-applconfig/k.yml (modified) * rtemsqual/tests/spec-applconfig/l.yml (modified) * rtemsqual/tests/spec-applconfig/m.yml (modified) * rtemsqual/tests/spec-build/bsp.yml (modified) * rtemsqual/tests/spec-build/bsp2.yml (modified) * rtemsqual/tests/spec-build/g.yml (modified) * rtemsqual/tests/spec-build/o.yml (modified) * rtemsqual/tests/spec-build/x.yml (modified) * rtemsqual/tests/spec-interface/asm.yml (modified) * rtemsqual/tests/spec-interface/command-line.yml (modified) * rtemsqual/tests/spec-interface/define-a.yml (modified) * rtemsqual/tests/spec-interface/define-b.yml (modified) * rtemsqual/tests/spec-interface/define-c.yml (modified) * rtemsqual/tests/spec-interface/define.yml (modified) * rtemsqual/tests/spec-interface/enum.yml (modified) * rtemsqual/tests/spec-interface/enum2.yml (modified) * rtemsqual/tests/spec-interface/enum3.yml (modified) * rtemsqual/tests/spec-interface/enum4.yml (modified) * rtemsqual/tests/spec-interface/enumerator-0.yml (modified) * rtemsqual/tests/spec-interface/enumerator-1.yml (modified) * rtemsqual/tests/spec-interface/enumerator-2.yml (modified) * rtemsqual/tests/spec-interface/enumerator-a.yml (modified) * rtemsqual/tests/spec-interface/enumerator-b.yml (modified) * rtemsqual/tests/spec-interface/float_t.yml (modified) * rtemsqual/tests/spec-interface/forward-decl.yml (modified) * rtemsqual/tests/spec-interface/func.yml (modified) * rtemsqual/tests/spec-interface/func2.yml (modified) * rtemsqual/tests/spec-interface/func3.yml (modified) * rtemsqual/tests/spec-interface/func4.yml (modified) * rtemsqual/tests/spec-interface/ga.yml (modified) * rtemsqual/tests/spec-interface/gb.yml (modified) * rtemsqual/tests/spec-interface/gc.yml (modified) * rtemsqual/tests/spec-interface/h3.yml (modified) * rtemsqual/tests/spec-interface/h4.yml (modified) * rtemsqual/tests/spec-interface/macro.yml (modified) * rtemsqual/tests/spec-interface/macro2.yml (modified) * rtemsqual/tests/spec-interface/math.yml (modified) * rtemsqual/tests/spec-interface/other.yml (modified) * rtemsqual/tests/spec-interface/other2.yml (modified) * rtemsqual/tests/spec-interface/other3.yml (modified) * rtemsqual/tests/spec-interface/s.yml (modified) * rtemsqual/tests/spec-interface/smp.yml (modified) * rtemsqual/tests/spec-interface/stdint.yml (modified) * rtemsqual/tests/spec-interface/td.yml (modified) * rtemsqual/tests/spec-interface/td3.yml (modified) * rtemsqual/tests/spec-interface/uint32_t.yml (modified) * rtemsqual/tests/spec-validation/tc.yml (modified) * rtemsqual/tests/spec-validation/tc2.yml (modified) * rtemsqual/tests/spec-validation/tc3.yml (modified) * rtemsqual/tests/spec-validation/tc4.yml (modified) * rtemsqual/tests/spec-validation/tp.yml (modified) * rtemsqual/tests/spec-validation/ts.yml (modified) * rtemsqual/tests/test_content.py (modified) * rtemsqual/tests/test_items_item.py (modified) * spec/acfg/bdbuf.yml (modified) * spec/acfg/bsp.yml (modified) * spec/acfg/classic.yml (modified) * spec/acfg/classicinit.yml (modified) * spec/acfg/devdrv.yml (modified) * spec/acfg/eventrecord.yml (modified) * spec/acfg/filesystem.yml (modified) * spec/acfg/general.yml (modified) * spec/acfg/idle.yml (modified) * spec/acfg/mpci.yml (modified) * spec/acfg/opt/appldisablefilesystem.yml (modified) * spec/acfg/opt/appldoesnotneedclockdriver.yml (modified) * spec/acfg/opt/applextradrivers.yml (modified) * spec/acfg/opt/applneedsatadriver.yml (modified) * spec/acfg/opt/applneedsclockdriver.yml (modified) * spec/acfg/opt/applneedsconsoledriver.yml (modified) * spec/acfg/opt/applneedsframebufferdriver.yml (modified) * spec/acfg/opt/applneedsidedriver.yml (modified) * spec/acfg/opt/applneedslibblock.yml (modified) * spec/acfg/opt/applneedsnulldriver.yml (modified) * spec/acfg/opt/applneedsrtcdriver.yml (modified) * spec/acfg/opt/applneedssimpleconsoledriver.yml (modified) * spec/acfg/opt/applneedssimpletaskconsoledriver.yml (modified) * spec/acfg/opt/applneedsstubdriver.yml (modified) * spec/acfg/opt/applneedstimerdriver.yml (modified) * spec/acfg/opt/applneedswatchdogdriver.yml (modified) * spec/acfg/opt/applneedszerodriver.yml (modified) * spec/acfg/opt/applprerequisitedrivers.yml (modified) * spec/acfg/opt/atadrivertaskpriority.yml (modified) * spec/acfg/opt/bdbufbuffermaxsize.yml (modified) * spec/acfg/opt/bdbufbufferminsize.yml (modified) * spec/acfg/opt/bdbufcachememorysize.yml (modified) * spec/acfg/opt/bdbufmaxreadaheadblocks.yml (modified) * spec/acfg/opt/bdbufmaxwriteblocks.yml (modified) * spec/acfg/opt/bdbufreadaheadtaskpriority.yml (modified) * spec/acfg/opt/bdbuftaskstacksize.yml (modified) * spec/acfg/opt/bspidletaskbody.yml (modified) * spec/acfg/opt/bspidletaskstacksize.yml (modified) * spec/acfg/opt/bspinitialextension.yml (modified) * spec/acfg/opt/bspinterruptstacksize.yml (modified) * spec/acfg/opt/bspprerequisitedrivers.yml (modified) * spec/acfg/opt/cbsmaximumservers.yml (modified) * spec/acfg/opt/constraintbspappmin.yml (modified) * spec/acfg/opt/constraintidlestackarea.yml (modified) * spec/acfg/opt/constraintisrstackalign.yml (modified) * spec/acfg/opt/constraintisrstackarea.yml (modified) * spec/acfg/opt/constraintmemsz.yml (modified) * spec/acfg/opt/constraintposix.yml (modified) * spec/acfg/opt/constraintprioclassic.yml (modified) * spec/acfg/opt/constraintstackspace.yml (modified) * spec/acfg/opt/constraintunlimited.yml (modified) * spec/acfg/opt/constraintwkspace.yml (modified) * spec/acfg/opt/dirtymemory.yml (modified) * spec/acfg/opt/disablebspsettings.yml (modified) * spec/acfg/opt/disablenewlibreentrancy.yml (modified) * spec/acfg/opt/executiveramsize.yml (modified) * spec/acfg/opt/extrataskstacks.yml (modified) * spec/acfg/opt/filesystemall.yml (modified) * spec/acfg/opt/filesystemdosfs.yml (modified) * spec/acfg/opt/filesystemftpfs.yml (modified) * spec/acfg/opt/filesystemimfs.yml (modified) * spec/acfg/opt/filesystemjffs2.yml (modified) * spec/acfg/opt/filesystemnfs.yml (modified) * spec/acfg/opt/filesystemrfs.yml (modified) * spec/acfg/opt/filesystemtftpfs.yml (modified) * spec/acfg/opt/idletaskbody.yml (modified) * spec/acfg/opt/idletaskinitappl.yml (modified) * spec/acfg/opt/idletaskstacksize.yml (modified) * spec/acfg/opt/imfsdisablechmod.yml (modified) * spec/acfg/opt/imfsdisablechown.yml (modified) * spec/acfg/opt/imfsdisablelink.yml (modified) * spec/acfg/opt/imfsdisablemknod.yml (modified) * spec/acfg/opt/imfsdisablemknoddevice.yml (modified) * spec/acfg/opt/imfsdisablemknodfile.yml (modified) * spec/acfg/opt/imfsdisablemount.yml (modified) * spec/acfg/opt/imfsdisablereaddir.yml (modified) * spec/acfg/opt/imfsdisablereadlink.yml (modified) * spec/acfg/opt/imfsdisablerename.yml (modified) * spec/acfg/opt/imfsdisablermnod.yml (modified) * spec/acfg/opt/imfsdisablesymlink.yml (modified) * spec/acfg/opt/imfsdisableunmount.yml (modified) * spec/acfg/opt/imfsdisableutime.yml (modified) * spec/acfg/opt/imfsenablemkfifo.yml (modified) * spec/acfg/opt/imfsmemfilebytesperblock.yml (modified) * spec/acfg/opt/initialextensions.yml (modified) * spec/acfg/opt/inittaskarguments.yml (modified) * spec/acfg/opt/inittaskattributes.yml (modified) * spec/acfg/opt/inittaskentrypoint.yml (modified) * spec/acfg/opt/inittaskinitialmodes.yml (modified) * spec/acfg/opt/inittaskname.yml (modified) * spec/acfg/opt/inittaskpriority.yml (modified) * spec/acfg/opt/inittaskstacksize.yml (modified) * spec/acfg/opt/interruptstacksize.yml (modified) * spec/acfg/opt/mallocbspsupportssbrk.yml (modified) * spec/acfg/opt/mallocdirty.yml (modified) * spec/acfg/opt/maxbarriers.yml (modified) * spec/acfg/opt/maxdrivers.yml (modified) * spec/acfg/opt/maxfiledescriptors.yml (modified) * spec/acfg/opt/maxmessagequeues.yml (modified) * spec/acfg/opt/maxpartitions.yml (modified) * spec/acfg/opt/maxperiods.yml (modified) * spec/acfg/opt/maxports.yml (modified) * spec/acfg/opt/maxposixkeys.yml (modified) * spec/acfg/opt/maxposixkeyvaluepairs.yml (modified) * spec/acfg/opt/maxposixmessagequeues.yml (modified) * spec/acfg/opt/maxposixqueuedsignals.yml (modified) * spec/acfg/opt/maxposixsemaphores.yml (modified) * spec/acfg/opt/maxposixshms.yml (modified) * spec/acfg/opt/maxposixthreads.yml (modified) * spec/acfg/opt/maxposixtimers.yml (modified) * spec/acfg/opt/maxpriority.yml (modified) * spec/acfg/opt/maxprocessors.yml (modified) * spec/acfg/opt/maxregions.yml (modified) * spec/acfg/opt/maxsemaphores.yml (modified) * spec/acfg/opt/maxtasks.yml (modified) * spec/acfg/opt/maxthreadnamesize.yml (modified) * spec/acfg/opt/maxtimers.yml (modified) * spec/acfg/opt/maxuserextensions.yml (modified) * spec/acfg/opt/memoryoverhead.yml (modified) * spec/acfg/opt/messagebuffermemory.yml (modified) * spec/acfg/opt/microsecondspertick.yml (modified) * spec/acfg/opt/minposixthreadstacksize.yml (modified) * spec/acfg/opt/mintaskstacksize.yml (modified) * spec/acfg/opt/mpappl.yml (modified) * spec/acfg/opt/mpextraserverstack.yml (modified) * spec/acfg/opt/mpmaxglobalobjects.yml (modified) * spec/acfg/opt/mpmaxnodes.yml (modified) * spec/acfg/opt/mpmaxproxies.yml (modified) * spec/acfg/opt/mpmpcitablepointer.yml (modified) * spec/acfg/opt/mpnodenumber.yml (modified) * spec/acfg/opt/posixinitthreadentrypoint.yml (modified) * spec/acfg/opt/posixinitthreadstacksize.yml (modified) * spec/acfg/opt/posixinitthreadtable.yml (modified) * spec/acfg/opt/recordextensionsenabled.yml (modified) * spec/acfg/opt/recordfataldumpbase64.yml (modified) * spec/acfg/opt/recordfataldumpbase64zlib.yml (modified) * spec/acfg/opt/recordperprocessoritems.yml (modified) * spec/acfg/opt/rtemsinittaskstable.yml (modified) * spec/acfg/opt/schedulerassignments.yml (modified) * spec/acfg/opt/schedulercbs.yml (modified) * spec/acfg/opt/scheduleredf.yml (modified) * spec/acfg/opt/scheduleredfsmp.yml (modified) * spec/acfg/opt/schedulername.yml (modified) * spec/acfg/opt/schedulerpriority.yml (modified) * spec/acfg/opt/schedulerpriorityaffinitysmp.yml (modified) * spec/acfg/opt/schedulerprioritysmp.yml (modified) * spec/acfg/opt/schedulersimple.yml (modified) * spec/acfg/opt/schedulersimplesmp.yml (modified) * spec/acfg/opt/schedulerstrongapa.yml (modified) * spec/acfg/opt/scheduleruser.yml (modified) * spec/acfg/opt/stackcheckerenabled.yml (modified) * spec/acfg/opt/swapoutblockhold.yml (modified) * spec/acfg/opt/swapoutswapperiod.yml (modified) * spec/acfg/opt/swapouttaskpriority.yml (modified) * spec/acfg/opt/swapoutworkertaskpriority.yml (modified) * spec/acfg/opt/swapoutworkertasks.yml (modified) * spec/acfg/opt/taskstackallocator.yml (modified) * spec/acfg/opt/taskstackallocatorinit.yml (modified) * spec/acfg/opt/taskstackdeallocator.yml (modified) * spec/acfg/opt/taskstackfromalloc.yml (modified) * spec/acfg/opt/taskstacknowkspace.yml (modified) * spec/acfg/opt/tickspertimeslice.yml (modified) * spec/acfg/opt/unifiedworkareas.yml (modified) * spec/acfg/opt/unlimitedallocationsize.yml (modified) * spec/acfg/opt/unlimitedobjects.yml (modified) * spec/acfg/opt/usedevfsasbasefilesystem.yml (modified) * spec/acfg/opt/useminiimfsasbasefilesystem.yml (modified) * spec/acfg/opt/verbosesysteminit.yml (modified) * spec/acfg/opt/zeroworkspaceautomatically.yml (modified) * spec/acfg/posix.yml (modified) * spec/acfg/posixinit.yml (modified) * spec/acfg/schedgeneral.yml (modified) * spec/acfg/stackalloc.yml (modified) * spec/applconfig.yml (modified) * spec/glos/general.yml (modified) * spec/glos/term/abi.yml (modified) * spec/glos/term/active.yml (modified) * spec/glos/term/aperiodictask.yml (modified) * spec/glos/term/api.yml (modified) * spec/glos/term/application.yml (modified) * spec/glos/term/asr.yml (modified) * spec/glos/term/assemblerlanguage.yml (modified) * spec/glos/term/asynchronous.yml (modified) * spec/glos/term/asynchronoussignalroutine.yml (modified) * spec/glos/term/atomicoperations.yml (modified) * spec/glos/term/awakened.yml (modified) * spec/glos/term/bigendian.yml (modified) * spec/glos/term/bitmapped.yml (modified) * spec/glos/term/block.yml (modified) * spec/glos/term/blockedtask.yml (modified) * spec/glos/term/boardsupportpackage.yml (modified) * spec/glos/term/broadcast.yml (modified) * spec/glos/term/bsp.yml (modified) * spec/glos/term/buffer.yml (modified) * spec/glos/term/c11.yml (modified) * spec/glos/term/callingconvention.yml (modified) * spec/glos/term/ccb.yml (modified) * spec/glos/term/centralprocessingunit.yml (modified) * spec/glos/term/chain.yml (modified) * spec/glos/term/clanguage.yml (modified) * spec/glos/term/cluster.yml (modified) * spec/glos/term/coalesce.yml (modified) * spec/glos/term/configurationtable.yml (modified) * spec/glos/term/context.yml (modified) * spec/glos/term/contextswitch.yml (modified) * spec/glos/term/controlblock.yml (modified) * spec/glos/term/core.yml (modified) * spec/glos/term/cpu.yml (modified) * spec/glos/term/criticalsection.yml (modified) * spec/glos/term/crt.yml (modified) * spec/glos/term/cxx11.yml (modified) * spec/glos/term/deadline.yml (modified) * spec/glos/term/device.yml (modified) * spec/glos/term/devicedriver.yml (modified) * spec/glos/term/devicedrivertable.yml (modified) * spec/glos/term/directives.yml (modified) * spec/glos/term/dispatch.yml (modified) * spec/glos/term/doorstop.yml (modified) * spec/glos/term/dormant.yml (modified) * spec/glos/term/dualported.yml (modified) * spec/glos/term/ears.yml (modified) * spec/glos/term/elf.yml (modified) * spec/glos/term/embedded.yml (modified) * spec/glos/term/entrypoint.yml (modified) * spec/glos/term/envelope.yml (modified) * spec/glos/term/errorcode.yml (modified) * spec/glos/term/events.yml (modified) * spec/glos/term/exception.yml (modified) * spec/glos/term/executingtask.yml (modified) * spec/glos/term/executive.yml (modified) * spec/glos/term/exported.yml (modified) * spec/glos/term/externaladdress.yml (modified) * spec/glos/term/fifo.yml (modified) * spec/glos/term/firstinfirstout.yml (modified) * spec/glos/term/floatingpointcoprocessor.yml (modified) * spec/glos/term/freed.yml (modified) * spec/glos/term/gcc.yml (modified) * spec/glos/term/global.yml (modified) * spec/glos/term/gnat.yml (modified) * spec/glos/term/gnu.yml (modified) * spec/glos/term/handler.yml (modified) * spec/glos/term/hardrealtimesystem.yml (modified) * spec/glos/term/heap.yml (modified) * spec/glos/term/heirtask.yml (modified) * spec/glos/term/heterogeneous.yml (modified) * spec/glos/term/homogeneous.yml (modified) * spec/glos/term/id.yml (modified) * spec/glos/term/idletask.yml (modified) * spec/glos/term/interface.yml (modified) * spec/glos/term/internaladdress.yml (modified) * spec/glos/term/interrupt.yml (modified) * spec/glos/term/interruptlevel.yml (modified) * spec/glos/term/interruptservice.yml (modified) * spec/glos/term/interruptserviceroutine.yml (modified) * spec/glos/term/io.yml (modified) * spec/glos/term/isr.yml (modified) * spec/glos/term/isvv.yml (modified) * spec/glos/term/kernel.yml (modified) * spec/glos/term/list.yml (modified) * spec/glos/term/littleendian.yml (modified) * spec/glos/term/local.yml (modified) * spec/glos/term/localoperation.yml (modified) * spec/glos/term/logicaladdress.yml (modified) * spec/glos/term/looselycoupled.yml (modified) * spec/glos/term/majornumber.yml (modified) * spec/glos/term/manager.yml (modified) * spec/glos/term/mcs.yml (modified) * spec/glos/term/memorypool.yml (modified) * spec/glos/term/message.yml (modified) * spec/glos/term/messagebuffer.yml (modified) * spec/glos/term/messagequeue.yml (modified) * spec/glos/term/messagequeuecontrolblock.yml (modified) * spec/glos/term/minornumber.yml (modified) * spec/glos/term/mode.yml (modified) * spec/glos/term/mpci.yml (modified) * spec/glos/term/multiprocessing.yml (modified) * spec/glos/term/multiprocessor.yml (modified) * spec/glos/term/multiprocessorcommunicationsinterfacelayer.yml (modified) * spec/glos/term/multiprocessorconfigurationtable.yml (modified) * spec/glos/term/multitasking.yml (modified) * spec/glos/term/mutualexclusion.yml (modified) * spec/glos/term/nested.yml (modified) * spec/glos/term/node.yml (modified) * spec/glos/term/nonexistent.yml (modified) * spec/glos/term/numa.yml (modified) * spec/glos/term/numericcoprocessor.yml (modified) * spec/glos/term/object.yml (modified) * spec/glos/term/objectoriented.yml (modified) * spec/glos/term/operatingsystem.yml (modified) * spec/glos/term/overhead.yml (modified) * spec/glos/term/packet.yml (modified) * spec/glos/term/partition.yml (modified) * spec/glos/term/partitioncontrolblock.yml (modified) * spec/glos/term/pending.yml (modified) * spec/glos/term/periodictask.yml (modified) * spec/glos/term/physicaladdress.yml (modified) * spec/glos/term/poll.yml (modified) * spec/glos/term/pool.yml (modified) * spec/glos/term/portability.yml (modified) * spec/glos/term/posting.yml (modified) * spec/glos/term/preempt.yml (modified) * spec/glos/term/priority.yml (modified) * spec/glos/term/priorityboosting.yml (modified) * spec/glos/term/priorityinheritance.yml (modified) * spec/glos/term/priorityinversion.yml (modified) * spec/glos/term/processorutilization.yml (modified) * spec/glos/term/proxy.yml (modified) * spec/glos/term/proxycontrolblock.yml (modified) * spec/glos/term/ptcb.yml (modified) * spec/glos/term/pxcb.yml (modified) * spec/glos/term/qcb.yml (modified) * spec/glos/term/quantum.yml (modified) * spec/glos/term/queue.yml (modified) * spec/glos/term/readytask.yml (modified) * spec/glos/term/realtime.yml (modified) * spec/glos/term/reentrant.yml (modified) * spec/glos/term/region.yml (modified) * spec/glos/term/regioncontrolblock.yml (modified) * spec/glos/term/registers.yml (modified) * spec/glos/term/remote.yml (modified) * spec/glos/term/remoteoperation.yml (modified) * spec/glos/term/reqif.yml (modified) * spec/glos/term/resource.yml (modified) * spec/glos/term/resume.yml (modified) * spec/glos/term/returncode.yml (modified) * spec/glos/term/returnvalue.yml (modified) * spec/glos/term/rncb.yml (modified) * spec/glos/term/roundrobin.yml (modified) * spec/glos/term/rs232.yml (modified) * spec/glos/term/rtems.yml (modified) * spec/glos/term/running.yml (modified) * spec/glos/term/schedulable.yml (modified) * spec/glos/term/schedule.yml (modified) * spec/glos/term/scheduledtask.yml (modified) * spec/glos/term/scheduler.yml (modified) * spec/glos/term/schedulerinstance.yml (modified) * spec/glos/term/segments.yml (modified) * spec/glos/term/semaphore.yml (modified) * spec/glos/term/semaphorecontrolblock.yml (modified) * spec/glos/term/sharedmemory.yml (modified) * spec/glos/term/signal.yml (modified) * spec/glos/term/signalset.yml (modified) * spec/glos/term/smcb.yml (modified) * spec/glos/term/smp.yml (modified) * spec/glos/term/smpbarriers.yml (modified) * spec/glos/term/smplocks.yml (modified) * spec/glos/term/softrealtimesystem.yml (modified) * spec/glos/term/softwarecomponent.yml (modified) * spec/glos/term/softwareitem.yml (modified) * spec/glos/term/softwareproduct.yml (modified) * spec/glos/term/softwareunit.yml (modified) * spec/glos/term/sourcecode.yml (modified) * spec/glos/term/sporadictask.yml (modified) * spec/glos/term/stack.yml (modified) * spec/glos/term/statuscode.yml (modified) * spec/glos/term/suspend.yml (modified) * spec/glos/term/synchronous.yml (modified) * spec/glos/term/systemcall.yml (modified) * spec/glos/term/target.yml (modified) * spec/glos/term/tas.yml (modified) * spec/glos/term/task.yml (modified) * spec/glos/term/taskcontrolblock.yml (modified) * spec/glos/term/taskmigration.yml (modified) * spec/glos/term/taskprocessoraffinity.yml (modified) * spec/glos/term/taskswitch.yml (modified) * spec/glos/term/tcb.yml (modified) * spec/glos/term/thread.yml (modified) * spec/glos/term/threaddispatch.yml (modified) * spec/glos/term/tick.yml (modified) * spec/glos/term/tightlycoupled.yml (modified) * spec/glos/term/timeout.yml (modified) * spec/glos/term/timer.yml (modified) * spec/glos/term/timercontrolblock.yml (modified) * spec/glos/term/timeslice.yml (modified) * spec/glos/term/timeslicing.yml (modified) * spec/glos/term/tls.yml (modified) * spec/glos/term/tmcb.yml (modified) * spec/glos/term/transientoverload.yml (modified) * spec/glos/term/ttas.yml (modified) * spec/glos/term/userextensions.yml (modified) * spec/glos/term/userextensiontable.yml (modified) * spec/glos/term/userinitializationtaskstable.yml (modified) * spec/glos/term/userprovided.yml (modified) * spec/glos/term/usersupplied.yml (modified) * spec/glos/term/vector.yml (modified) * spec/glos/term/waitqueue.yml (modified) * spec/glos/term/yaml.yml (modified) * spec/glos/term/yield.yml (modified) * spec/glossary.yml (modified) * spec/groups/api.yml (modified) * spec/groups/api/basedefs.yml (modified) * spec/if/build-options/ada.yml (modified) * spec/if/build-options/cpuopts.yml (modified) * spec/if/build-options/debug.yml (modified) * spec/if/build-options/domain.yml (modified) * spec/if/build-options/drvmgr.yml (modified) * spec/if/build-options/multiprocessing.yml (modified) * spec/if/build-options/networking.yml (modified) * spec/if/build-options/paravirt.yml (modified) * spec/if/build-options/posix.yml (modified) * spec/if/build-options/profiling.yml (modified) * spec/if/build-options/smp.yml (modified) * spec/if/c/false.yml (modified) * spec/if/c/int16_t.yml (modified) * spec/if/c/int32_t.yml (modified) * spec/if/c/int64_t.yml (modified) * spec/if/c/int8_t.yml (modified) * spec/if/c/intmax_t.yml (modified) * spec/if/c/intptr_t.yml (modified) * spec/if/c/null.yml (modified) * spec/if/c/offsetof.yml (modified) * spec/if/c/size_t.yml (modified) * spec/if/c/stdatomic.yml (modified) * spec/if/c/stdbool.yml (modified) * spec/if/c/stddef.yml (modified) * spec/if/c/stdint.yml (modified) * spec/if/c/string.yml (modified) * spec/if/c/sys-types.yml (modified) * spec/if/c/time.yml (modified) * spec/if/c/time_t.yml (modified) * spec/if/c/true.yml (modified) * spec/if/c/uint16_t.yml (modified) * spec/if/c/uint32_t.yml (modified) * spec/if/c/uint64_t.yml (modified) * spec/if/c/uint8_t.yml (modified) * spec/if/c/uintmax_t.yml (modified) * spec/if/c/uintptr_t.yml (modified) * spec/if/compiler/builtin-choose-expr.yml (modified) * spec/if/compiler/builtin-expect.yml (modified) * spec/if/compiler/builtin-return-address.yml (modified) * spec/if/compiler/builtin-types-compatible-p.yml (modified) * spec/if/compiler/builtin-unreachable.yml (modified) * spec/if/compiler/cplusplus.yml (modified) * spec/if/compiler/domain.yml (modified) * spec/if/compiler/gnuc.yml (modified) * spec/if/compiler/stdc-version.yml (modified) * spec/if/compiler/typeof.yml (modified) * spec/if/compiler/user-label-prefix.yml (modified) * spec/if/impl/assert-unreachable.yml (modified) * spec/if/rtems/basedefs/alias.yml (modified) * spec/if/rtems/basedefs/aligned.yml (modified) * spec/if/rtems/basedefs/alloc-align.yml (modified) * spec/if/rtems/basedefs/alloc-size-2.yml (modified) * spec/if/rtems/basedefs/alloc-size.yml (modified) * spec/if/rtems/basedefs/array-size.yml (modified) * spec/if/rtems/basedefs/compiler-deprecated-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-memory-barrier.yml (modified) * spec/if/rtems/basedefs/compiler-no-return-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-packed-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-pure-attribute.yml (modified) * spec/if/rtems/basedefs/compiler-used-attribute.yml (modified) * spec/if/rtems/basedefs/concat.yml (modified) * spec/if/rtems/basedefs/const.yml (modified) * spec/if/rtems/basedefs/container-of.yml (modified) * spec/if/rtems/basedefs/declare-global-symbol.yml (modified) * spec/if/rtems/basedefs/deconst.yml (modified) * spec/if/rtems/basedefs/define-global-symbol.yml (modified) * spec/if/rtems/basedefs/deprecated.yml (modified) * spec/if/rtems/basedefs/dequalify-depthx.yml (modified) * spec/if/rtems/basedefs/dequalify.yml (modified) * spec/if/rtems/basedefs/devolatile.yml (modified) * spec/if/rtems/basedefs/expand.yml (modified) * spec/if/rtems/basedefs/have-member-same-type.yml (modified) * spec/if/rtems/basedefs/header.yml (modified) * spec/if/rtems/basedefs/inline-routine.yml (modified) * spec/if/rtems/basedefs/malloclike.yml (modified) * spec/if/rtems/basedefs/no-inline.yml (modified) * spec/if/rtems/basedefs/no-return.yml (modified) * spec/if/rtems/basedefs/obfuscate-variable.yml (modified) * spec/if/rtems/basedefs/packed.yml (modified) * spec/if/rtems/basedefs/predict-false.yml (modified) * spec/if/rtems/basedefs/predict-true.yml (modified) * spec/if/rtems/basedefs/printflike.yml (modified) * spec/if/rtems/basedefs/pure.yml (modified) * spec/if/rtems/basedefs/return-address.yml (modified) * spec/if/rtems/basedefs/section.yml (modified) * spec/if/rtems/basedefs/static-assert.yml (modified) * spec/if/rtems/basedefs/string.yml (modified) * spec/if/rtems/basedefs/symbol-name.yml (modified) * spec/if/rtems/basedefs/typeof-refx.yml (modified) * spec/if/rtems/basedefs/unreachable.yml (modified) * spec/if/rtems/basedefs/unused.yml (modified) * spec/if/rtems/basedefs/used.yml (modified) * spec/if/rtems/basedefs/warn-unused-result.yml (modified) * spec/if/rtems/basedefs/weak-alias.yml (modified) * spec/if/rtems/basedefs/weak.yml (modified) * spec/if/rtems/basedefs/xconcat.yml (modified) * spec/if/rtems/basedefs/xstring.yml (modified) * spec/if/rtems/basedefs/zero-length-array.yml (modified) * spec/if/use/asm.yml (modified) * spec/if/use/domain.yml (modified) * spec/if/use/false.yml (modified) * spec/if/use/true.yml (modified) * spec/testsuites/validation/c-library.yml (modified) * spec/testsuites/validation/classic-barrier.yml (modified) * spec/testsuites/validation/profile.yml (modified) Change format of enabled-by attribute Wed, 06 May 2020 10:44:23 GMT Sebastian Huber [31a305f] * config.yml (modified) * rtems_spec_to_x.py (modified) * spec/groups/api.yml (added) * spec/groups/api/basedefs.yml (added) * spec/if/build-options/ada.yml (added) * spec/if/build-options/cpuopts.yml (added) * spec/if/build-options/debug.yml (added) * spec/if/build-options/domain.yml (added) * spec/if/build-options/drvmgr.yml (added) * spec/if/build-options/multiprocessing.yml (added) * spec/if/build-options/networking.yml (added) * spec/if/build-options/paravirt.yml (added) * spec/if/build-options/posix.yml (added) * spec/if/build-options/profiling.yml (added) * spec/if/build-options/smp.yml (added) * spec/if/c/false.yml (added) * spec/if/c/int16_t.yml (added) * spec/if/c/int32_t.yml (added) * spec/if/c/int64_t.yml (added) * spec/if/c/int8_t.yml (added) * spec/if/c/intmax_t.yml (added) * spec/if/c/intptr_t.yml (added) * spec/if/c/null.yml (added) * spec/if/c/offsetof.yml (added) * spec/if/c/size_t.yml (added) * spec/if/c/stdatomic.yml (added) * spec/if/c/stdbool.yml (added) * spec/if/c/stddef.yml (added) * spec/if/c/stdint.yml (added) * spec/if/c/string.yml (added) * spec/if/c/sys-types.yml (added) * spec/if/c/time.yml (added) * spec/if/c/time_t.yml (added) * spec/if/c/true.yml (added) * spec/if/c/uint16_t.yml (added) * spec/if/c/uint32_t.yml (added) * spec/if/c/uint64_t.yml (added) * spec/if/c/uint8_t.yml (added) * spec/if/c/uintmax_t.yml (added) * spec/if/c/uintptr_t.yml (added) * spec/if/compiler/builtin-choose-expr.yml (added) * spec/if/compiler/builtin-expect.yml (added) * spec/if/compiler/builtin-return-address.yml (added) * spec/if/compiler/builtin-types-compatible-p.yml (added) * spec/if/compiler/builtin-unreachable.yml (added) * spec/if/compiler/cplusplus.yml (added) * spec/if/compiler/domain.yml (added) * spec/if/compiler/gnuc.yml (added) * spec/if/compiler/stdc-version.yml (added) * spec/if/compiler/typeof.yml (added) * spec/if/compiler/user-label-prefix.yml (added) * spec/if/impl/assert-unreachable.yml (added) * spec/if/impl/dequalify-types-not-compatible.yml (added) * spec/if/rtems/basedefs/alias.yml (added) * spec/if/rtems/basedefs/aligned.yml (added) * spec/if/rtems/basedefs/alloc-align.yml (added) * spec/if/rtems/basedefs/alloc-size-2.yml (added) * spec/if/rtems/basedefs/alloc-size.yml (added) * spec/if/rtems/basedefs/array-size.yml (added) * spec/if/rtems/basedefs/compiler-deprecated-attribute.yml (added) * spec/if/rtems/basedefs/compiler-memory-barrier.yml (added) * spec/if/rtems/basedefs/compiler-no-return-attribute.yml (added) * spec/if/rtems/basedefs/compiler-packed-attribute.yml (added) * spec/if/rtems/basedefs/compiler-pure-attribute.yml (added) * spec/if/rtems/basedefs/compiler-used-attribute.yml (added) * spec/if/rtems/basedefs/concat.yml (added) * spec/if/rtems/basedefs/const.yml (added) * spec/if/rtems/basedefs/container-of.yml (added) * spec/if/rtems/basedefs/declare-global-symbol.yml (added) * spec/if/rtems/basedefs/deconst.yml (added) * spec/if/rtems/basedefs/define-global-symbol.yml (added) * spec/if/rtems/basedefs/deprecated.yml (added) * spec/if/rtems/basedefs/dequalify-depthx.yml (added) * spec/if/rtems/basedefs/dequalify.yml (added) * spec/if/rtems/basedefs/devolatile.yml (added) * spec/if/rtems/basedefs/expand.yml (added) * spec/if/rtems/basedefs/false.yml (added) * spec/if/rtems/basedefs/have-member-same-type.yml (added) * spec/if/rtems/basedefs/header.yml (added) * spec/if/rtems/basedefs/inline-routine.yml (added) * spec/if/rtems/basedefs/malloclike.yml (added) * spec/if/rtems/basedefs/no-inline.yml (added) * spec/if/rtems/basedefs/no-return.yml (added) * spec/if/rtems/basedefs/obfuscate-variable.yml (added) * spec/if/rtems/basedefs/packed.yml (added) * spec/if/rtems/basedefs/predict-false.yml (added) * spec/if/rtems/basedefs/predict-true.yml (added) * spec/if/rtems/basedefs/printflike.yml (added) * spec/if/rtems/basedefs/pure.yml (added) * spec/if/rtems/basedefs/return-address.yml (added) * spec/if/rtems/basedefs/section.yml (added) * spec/if/rtems/basedefs/static-assert.yml (added) * spec/if/rtems/basedefs/string.yml (added) * spec/if/rtems/basedefs/symbol-name.yml (added) * spec/if/rtems/basedefs/true.yml (added) * spec/if/rtems/basedefs/typeof-refx.yml (added) * spec/if/rtems/basedefs/unreachable.yml (added) * spec/if/rtems/basedefs/unused.yml (added) * spec/if/rtems/basedefs/used.yml (added) * spec/if/rtems/basedefs/warn-unused-result.yml (added) * spec/if/rtems/basedefs/weak-alias.yml (added) * spec/if/rtems/basedefs/weak.yml (added) * spec/if/rtems/basedefs/xconcat.yml (added) * spec/if/rtems/basedefs/xstring.yml (added) * spec/if/rtems/basedefs/zero-length-array.yml (added) * spec/if/use/asm.yml (added) * spec/if/use/domain.yml (added) * spec/if/use/false.yml (added) * spec/if/use/true.yml (added) spec: Add some interface items Wed, 06 May 2020 08:31:57 GMT Sebastian Huber [a5f3cc1] * rtemsqual/content.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/tests/spec-glossary/glos/term/t.yml (modified) * rtemsqual/tests/spec-sphinx/x.yml (added) * rtemsqual/tests/test_content_sphinx.py (modified) * rtemsqual/tests/test_glossary.py (modified) * spec/glos/term/asr.yml (modified) * spec/glos/term/assemblerlanguage.yml (modified) * spec/glos/term/atomicoperations.yml (modified) * spec/glos/term/bsp.yml (modified) * spec/glos/term/clanguage.yml (modified) * spec/glos/term/cpu.yml (modified) * spec/glos/term/errorcode.yml (modified) * spec/glos/term/fifo.yml (modified) * spec/glos/term/gnat.yml (modified) * spec/glos/term/interruptservice.yml (modified) * spec/glos/term/isr.yml (modified) * spec/glos/term/mpci.yml (modified) * spec/glos/term/partition.yml (modified) * spec/glos/term/ptcb.yml (modified) * spec/glos/term/pxcb.yml (modified) * spec/glos/term/qcb.yml (modified) * spec/glos/term/returncode.yml (modified) * spec/glos/term/returnvalue.yml (modified) * spec/glos/term/rncb.yml (modified) * spec/glos/term/smcb.yml (modified) * spec/glos/term/softwarecomponent.yml (modified) * spec/glos/term/softwareitem.yml (modified) * spec/glos/term/softwareproduct.yml (modified) * spec/glos/term/softwareunit.yml (modified) * spec/glos/term/statuscode.yml (modified) * spec/glos/term/task.yml (modified) * spec/glos/term/tcb.yml (modified) * spec/glos/term/thread.yml (modified) * spec/glos/term/tls.yml (modified) * spec/glos/term/tmcb.yml (modified) * spec/glos/term/usersupplied.yml (modified) spec: Use item mapper for glossary terms Fri, 24 Apr 2020 12:49:27 GMT Sebastian Huber [0dee9e4] * config.yml (modified) * rtems_spec_to_x.py (modified) * spec/testsuites/validation/c-library.yml (added) * spec/testsuites/validation/classic-barrier.yml (added) * spec/testsuites/validation/profile.yml (added) Generate a test suite with two test cases Mon, 20 Apr 2020 05:26:15 GMT Sebastian Huber [71d8b3c] * config.yml (modified) * rtems_spec_to_x.py (modified) * rtemsqual/applconfig.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/items.py (modified) * rtemsqual/tests/spec-applconfig/a.yml (modified) * rtemsqual/tests/spec-applconfig/b.yml (modified) * rtemsqual/tests/spec-applconfig/c.yml (modified) * rtemsqual/tests/spec-applconfig/e.yml (modified) * rtemsqual/tests/spec-applconfig/f.yml (modified) * rtemsqual/tests/spec-applconfig/h.yml (modified) * rtemsqual/tests/spec-applconfig/i.yml (modified) * rtemsqual/tests/spec-applconfig/j.yml (modified) * rtemsqual/tests/spec-applconfig/k.yml (modified) * rtemsqual/tests/spec-applconfig/l.yml (modified) * rtemsqual/tests/spec-applconfig/m.yml (modified) * rtemsqual/tests/spec-build/bsp.yml (modified) * rtemsqual/tests/spec-build/o.yml (modified) * rtemsqual/tests/spec-glossary/glos/g.yml (moved) * rtemsqual/tests/spec-glossary/glos/term/t.yml (moved) * rtemsqual/tests/spec-glossary/glos/term/u.yml (moved) * rtemsqual/tests/spec-glossary/glos/term/v.yml (moved) * rtemsqual/tests/spec-item-cache/d/c.yml (modified) * rtemsqual/tests/test_applconfig.py (modified) * rtemsqual/tests/test_build.py (modified) * rtemsqual/tests/test_glossary.py (modified) * rtemsqual/tests/test_items_item.py (modified) * rtemsqual/tests/test_items_itemcache.py (modified) * spec/.doorstop.yml (deleted) * spec/RTEMS-GLOSSARY.yml (deleted) * spec/acfg/.doorstop.yml (deleted) * spec/acfg/bdbuf.yml (moved) * spec/acfg/bsp.yml (moved) * spec/acfg/classic.yml (moved) * spec/acfg/classicinit.yml (moved) * spec/acfg/devdrv.yml (moved) * spec/acfg/eventrecord.yml (moved) * spec/acfg/filesystem.yml (moved) * spec/acfg/general.yml (moved) * spec/acfg/idle.yml (moved) * spec/acfg/mpci.yml (moved) * spec/acfg/opt/.doorstop.yml (deleted) * spec/acfg/opt/appldisablefilesystem.yml (moved) * spec/acfg/opt/appldoesnotneedclockdriver.yml (moved) * spec/acfg/opt/applextradrivers.yml (moved) * spec/acfg/opt/applneedsatadriver.yml (moved) * spec/acfg/opt/applneedsclockdriver.yml (moved) * spec/acfg/opt/applneedsconsoledriver.yml (moved) * spec/acfg/opt/applneedsframebufferdriver.yml (moved) * spec/acfg/opt/applneedsidedriver.yml (moved) * spec/acfg/opt/applneedslibblock.yml (moved) * spec/acfg/opt/applneedsnulldriver.yml (moved) * spec/acfg/opt/applneedsrtcdriver.yml (moved) * spec/acfg/opt/applneedssimpleconsoledriver.yml (moved) * spec/acfg/opt/applneedssimpletaskconsoledriver.yml (moved) * spec/acfg/opt/applneedsstubdriver.yml (moved) * spec/acfg/opt/applneedstimerdriver.yml (moved) * spec/acfg/opt/applneedswatchdogdriver.yml (moved) * spec/acfg/opt/applneedszerodriver.yml (moved) * spec/acfg/opt/applprerequisitedrivers.yml (moved) * spec/acfg/opt/atadrivertaskpriority.yml (moved) * spec/acfg/opt/bdbufbuffermaxsize.yml (moved) * spec/acfg/opt/bdbufbufferminsize.yml (moved) * spec/acfg/opt/bdbufcachememorysize.yml (moved) * spec/acfg/opt/bdbufmaxreadaheadblocks.yml (moved) * spec/acfg/opt/bdbufmaxwriteblocks.yml (moved) * spec/acfg/opt/bdbufreadaheadtaskpriority.yml (moved) * spec/acfg/opt/bdbuftaskstacksize.yml (moved) * spec/acfg/opt/bspidletaskbody.yml (moved) * spec/acfg/opt/bspidletaskstacksize.yml (moved) * spec/acfg/opt/bspinitialextension.yml (moved) * spec/acfg/opt/bspinterruptstacksize.yml (moved) * spec/acfg/opt/bspprerequisitedrivers.yml (moved) * spec/acfg/opt/cbsmaximumservers.yml (moved) * spec/acfg/opt/constraintbspappmin.yml (moved) * spec/acfg/opt/constraintidlestackarea.yml (moved) * spec/acfg/opt/constraintisrstackalign.yml (moved) * spec/acfg/opt/constraintisrstackarea.yml (moved) * spec/acfg/opt/constraintmemsz.yml (moved) * spec/acfg/opt/constraintposix.yml (moved) * spec/acfg/opt/constraintprioclassic.yml (moved) * spec/acfg/opt/constraintstackspace.yml (moved) * spec/acfg/opt/constraintunlimited.yml (moved) * spec/acfg/opt/constraintwkspace.yml (moved) * spec/acfg/opt/dirtymemory.yml (moved) * spec/acfg/opt/disablebspsettings.yml (moved) * spec/acfg/opt/disablenewlibreentrancy.yml (moved) * spec/acfg/opt/executiveramsize.yml (moved) * spec/acfg/opt/extrataskstacks.yml (moved) * spec/acfg/opt/filesystemall.yml (moved) * spec/acfg/opt/filesystemdosfs.yml (moved) * spec/acfg/opt/filesystemftpfs.yml (moved) * spec/acfg/opt/filesystemimfs.yml (moved) * spec/acfg/opt/filesystemjffs2.yml (moved) * spec/acfg/opt/filesystemnfs.yml (moved) * spec/acfg/opt/filesystemrfs.yml (moved) * spec/acfg/opt/filesystemtftpfs.yml (moved) * spec/acfg/opt/idletaskbody.yml (moved) * spec/acfg/opt/idletaskinitappl.yml (moved) * spec/acfg/opt/idletaskstacksize.yml (moved) * spec/acfg/opt/imfsdisablechmod.yml (moved) * spec/acfg/opt/imfsdisablechown.yml (moved) * spec/acfg/opt/imfsdisablelink.yml (moved) * spec/acfg/opt/imfsdisablemknod.yml (moved) * spec/acfg/opt/imfsdisablemknoddevice.yml (moved) * spec/acfg/opt/imfsdisablemknodfile.yml (moved) * spec/acfg/opt/imfsdisablemount.yml (moved) * spec/acfg/opt/imfsdisablereaddir.yml (moved) * spec/acfg/opt/imfsdisablereadlink.yml (moved) * spec/acfg/opt/imfsdisablerename.yml (moved) * spec/acfg/opt/imfsdisablermnod.yml (moved) * spec/acfg/opt/imfsdisablesymlink.yml (moved) * spec/acfg/opt/imfsdisableunmount.yml (moved) * spec/acfg/opt/imfsdisableutime.yml (moved) * spec/acfg/opt/imfsenablemkfifo.yml (moved) * spec/acfg/opt/imfsmemfilebytesperblock.yml (moved) * spec/acfg/opt/initialextensions.yml (moved) * spec/acfg/opt/inittaskarguments.yml (moved) * spec/acfg/opt/inittaskattributes.yml (moved) * spec/acfg/opt/inittaskentrypoint.yml (moved) * spec/acfg/opt/inittaskinitialmodes.yml (moved) * spec/acfg/opt/inittaskname.yml (moved) * spec/acfg/opt/inittaskpriority.yml (moved) * spec/acfg/opt/inittaskstacksize.yml (moved) * spec/acfg/opt/interruptstacksize.yml (moved) * spec/acfg/opt/mallocbspsupportssbrk.yml (moved) * spec/acfg/opt/mallocdirty.yml (moved) * spec/acfg/opt/maxbarriers.yml (moved) * spec/acfg/opt/maxdrivers.yml (moved) * spec/acfg/opt/maxfiledescriptors.yml (moved) * spec/acfg/opt/maxmessagequeues.yml (moved) * spec/acfg/opt/maxpartitions.yml (moved) * spec/acfg/opt/maxperiods.yml (moved) * spec/acfg/opt/maxports.yml (moved) * spec/acfg/opt/maxposixkeys.yml (moved) * spec/acfg/opt/maxposixkeyvaluepairs.yml (moved) * spec/acfg/opt/maxposixmessagequeues.yml (moved) * spec/acfg/opt/maxposixqueuedsignals.yml (moved) * spec/acfg/opt/maxposixsemaphores.yml (moved) * spec/acfg/opt/maxposixshms.yml (moved) * spec/acfg/opt/maxposixthreads.yml (moved) * spec/acfg/opt/maxposixtimers.yml (moved) * spec/acfg/opt/maxpriority.yml (moved) * spec/acfg/opt/maxprocessors.yml (moved) * spec/acfg/opt/maxregions.yml (moved) * spec/acfg/opt/maxsemaphores.yml (moved) * spec/acfg/opt/maxtasks.yml (moved) * spec/acfg/opt/maxthreadnamesize.yml (moved) * spec/acfg/opt/maxtimers.yml (moved) * spec/acfg/opt/maxuserextensions.yml (moved) * spec/acfg/opt/memoryoverhead.yml (moved) * spec/acfg/opt/messagebuffermemory.yml (moved) * spec/acfg/opt/microsecondspertick.yml (moved) * spec/acfg/opt/minposixthreadstacksize.yml (moved) * spec/acfg/opt/mintaskstacksize.yml (moved) * spec/acfg/opt/mpappl.yml (moved) * spec/acfg/opt/mpextraserverstack.yml (moved) * spec/acfg/opt/mpmaxglobalobjects.yml (moved) * spec/acfg/opt/mpmaxnodes.yml (moved) * spec/acfg/opt/mpmaxproxies.yml (moved) * spec/acfg/opt/mpmpcitablepointer.yml (moved) * spec/acfg/opt/mpnodenumber.yml (moved) * spec/acfg/opt/posixinitthreadentrypoint.yml (moved) * spec/acfg/opt/posixinitthreadstacksize.yml (moved) * spec/acfg/opt/posixinitthreadtable.yml (moved) * spec/acfg/opt/recordextensionsenabled.yml (moved) * spec/acfg/opt/recordfataldumpbase64.yml (moved) * spec/acfg/opt/recordfataldumpbase64zlib.yml (moved) * spec/acfg/opt/recordperprocessoritems.yml (moved) * spec/acfg/opt/rtemsinittaskstable.yml (moved) * spec/acfg/opt/schedulerassignments.yml (moved) * spec/acfg/opt/schedulercbs.yml (moved) * spec/acfg/opt/scheduleredf.yml (moved) * spec/acfg/opt/scheduleredfsmp.yml (moved) * spec/acfg/opt/schedulername.yml (moved) * spec/acfg/opt/schedulerpriority.yml (moved) * spec/acfg/opt/schedulerpriorityaffinitysmp.yml (moved) * spec/acfg/opt/schedulerprioritysmp.yml (moved) * spec/acfg/opt/schedulersimple.yml (moved) * spec/acfg/opt/schedulersimplesmp.yml (moved) * spec/acfg/opt/schedulerstrongapa.yml (moved) * spec/acfg/opt/scheduleruser.yml (moved) * spec/acfg/opt/stackcheckerenabled.yml (moved) * spec/acfg/opt/swapoutblockhold.yml (moved) * spec/acfg/opt/swapoutswapperiod.yml (moved) * spec/acfg/opt/swapouttaskpriority.yml (moved) * spec/acfg/opt/swapoutworkertaskpriority.yml (moved) * spec/acfg/opt/swapoutworkertasks.yml (moved) * spec/acfg/opt/taskstackallocator.yml (moved) * spec/acfg/opt/taskstackallocatorinit.yml (moved) * spec/acfg/opt/taskstackdeallocator.yml (moved) * spec/acfg/opt/taskstackfromalloc.yml (moved) * spec/acfg/opt/taskstacknowkspace.yml (moved) * spec/acfg/opt/tickspertimeslice.yml (moved) * spec/acfg/opt/unifiedworkareas.yml (moved) * spec/acfg/opt/unlimitedallocationsize.yml (moved) * spec/acfg/opt/unlimitedobjects.yml (moved) * spec/acfg/opt/usedevfsasbasefilesystem.yml (moved) * spec/acfg/opt/useminiimfsasbasefilesystem.yml (moved) * spec/acfg/opt/verbosesysteminit.yml (moved) * spec/acfg/opt/zeroworkspaceautomatically.yml (moved) * spec/acfg/posix.yml (moved) * spec/acfg/posixinit.yml (moved) * spec/acfg/schedgeneral.yml (moved) * spec/acfg/stackalloc.yml (moved) * spec/applconfig.yml (moved) * spec/glos/.doorstop.yml (deleted) * spec/glos/general.yml (moved) * spec/glos/term/.doorstop.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ASR.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ATOMICOPERATIONS.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-BSP.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-CPU.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ERRORCODE.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-FIFO.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-GNAT.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ISR.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-MPCI.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-PTCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-PXCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-QCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-RETURNCODE.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-RNCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-SMCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREITEM.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREPRODUCT.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-TCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-THREAD.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-TMCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-USERSUPPLIED.yml (deleted) * spec/glos/term/abi.yml (moved) * spec/glos/term/active.yml (moved) * spec/glos/term/aperiodictask.yml (moved) * spec/glos/term/api.yml (moved) * spec/glos/term/application.yml (moved) * spec/glos/term/asr.yml (added) * spec/glos/term/assemblerlanguage.yml (moved) * spec/glos/term/asynchronous.yml (moved) * spec/glos/term/asynchronoussignalroutine.yml (moved) * spec/glos/term/atomicoperations.yml (added) * spec/glos/term/awakened.yml (moved) * spec/glos/term/bigendian.yml (moved) * spec/glos/term/bitmapped.yml (moved) * spec/glos/term/block.yml (moved) * spec/glos/term/blockedtask.yml (moved) * spec/glos/term/boardsupportpackage.yml (moved) * spec/glos/term/broadcast.yml (moved) * spec/glos/term/bsp.yml (added) * spec/glos/term/buffer.yml (moved) * spec/glos/term/c11.yml (moved) * spec/glos/term/callingconvention.yml (moved) * spec/glos/term/ccb.yml (moved) * spec/glos/term/centralprocessingunit.yml (moved) * spec/glos/term/chain.yml (moved) * spec/glos/term/clanguage.yml (moved) * spec/glos/term/cluster.yml (moved) * spec/glos/term/coalesce.yml (moved) * spec/glos/term/configurationtable.yml (moved) * spec/glos/term/context.yml (moved) * spec/glos/term/contextswitch.yml (moved) * spec/glos/term/controlblock.yml (moved) * spec/glos/term/core.yml (moved) * spec/glos/term/cpu.yml (added) * spec/glos/term/criticalsection.yml (moved) * spec/glos/term/crt.yml (moved) * spec/glos/term/cxx11.yml (moved) * spec/glos/term/deadline.yml (moved) * spec/glos/term/device.yml (moved) * spec/glos/term/devicedriver.yml (moved) * spec/glos/term/devicedrivertable.yml (moved) * spec/glos/term/directives.yml (moved) * spec/glos/term/dispatch.yml (moved) * spec/glos/term/doorstop.yml (moved) * spec/glos/term/dormant.yml (moved) * spec/glos/term/dualported.yml (moved) * spec/glos/term/ears.yml (moved) * spec/glos/term/elf.yml (moved) * spec/glos/term/embedded.yml (moved) * spec/glos/term/entrypoint.yml (moved) * spec/glos/term/envelope.yml (moved) * spec/glos/term/errorcode.yml (added) * spec/glos/term/events.yml (moved) * spec/glos/term/exception.yml (moved) * spec/glos/term/executingtask.yml (moved) * spec/glos/term/executive.yml (moved) * spec/glos/term/exported.yml (moved) * spec/glos/term/externaladdress.yml (moved) * spec/glos/term/fifo.yml (added) * spec/glos/term/firstinfirstout.yml (moved) * spec/glos/term/floatingpointcoprocessor.yml (moved) * spec/glos/term/freed.yml (moved) * spec/glos/term/gcc.yml (moved) * spec/glos/term/global.yml (moved) * spec/glos/term/gnat.yml (added) * spec/glos/term/gnu.yml (moved) * spec/glos/term/handler.yml (moved) * spec/glos/term/hardrealtimesystem.yml (moved) * spec/glos/term/heap.yml (moved) * spec/glos/term/heirtask.yml (moved) * spec/glos/term/heterogeneous.yml (moved) * spec/glos/term/homogeneous.yml (moved) * spec/glos/term/id.yml (moved) * spec/glos/term/idletask.yml (moved) * spec/glos/term/interface.yml (moved) * spec/glos/term/internaladdress.yml (moved) * spec/glos/term/interrupt.yml (moved) * spec/glos/term/interruptlevel.yml (moved) * spec/glos/term/interruptservice.yml (moved) * spec/glos/term/interruptserviceroutine.yml (moved) * spec/glos/term/io.yml (moved) * spec/glos/term/isr.yml (added) * spec/glos/term/isvv.yml (moved) * spec/glos/term/kernel.yml (moved) * spec/glos/term/list.yml (moved) * spec/glos/term/littleendian.yml (moved) * spec/glos/term/local.yml (moved) * spec/glos/term/localoperation.yml (moved) * spec/glos/term/logicaladdress.yml (moved) * spec/glos/term/looselycoupled.yml (moved) * spec/glos/term/majornumber.yml (moved) * spec/glos/term/manager.yml (moved) * spec/glos/term/mcs.yml (moved) * spec/glos/term/memorypool.yml (moved) * spec/glos/term/message.yml (moved) * spec/glos/term/messagebuffer.yml (moved) * spec/glos/term/messagequeue.yml (moved) * spec/glos/term/messagequeuecontrolblock.yml (moved) * spec/glos/term/minornumber.yml (moved) * spec/glos/term/mode.yml (moved) * spec/glos/term/mpci.yml (added) * spec/glos/term/multiprocessing.yml (moved) * spec/glos/term/multiprocessor.yml (moved) * spec/glos/term/multiprocessorcommunicationsinterfacelayer.yml (moved) * spec/glos/term/multiprocessorconfigurationtable.yml (moved) * spec/glos/term/multitasking.yml (moved) * spec/glos/term/mutualexclusion.yml (moved) * spec/glos/term/nested.yml (moved) * spec/glos/term/node.yml (moved) * spec/glos/term/nonexistent.yml (moved) * spec/glos/term/numa.yml (moved) * spec/glos/term/numericcoprocessor.yml (moved) * spec/glos/term/object.yml (moved) * spec/glos/term/objectoriented.yml (moved) * spec/glos/term/operatingsystem.yml (moved) * spec/glos/term/overhead.yml (moved) * spec/glos/term/packet.yml (moved) * spec/glos/term/partition.yml (moved) * spec/glos/term/partitioncontrolblock.yml (moved) * spec/glos/term/pending.yml (moved) * spec/glos/term/periodictask.yml (moved) * spec/glos/term/physicaladdress.yml (moved) * spec/glos/term/poll.yml (moved) * spec/glos/term/pool.yml (moved) * spec/glos/term/portability.yml (moved) * spec/glos/term/posting.yml (moved) * spec/glos/term/preempt.yml (moved) * spec/glos/term/priority.yml (moved) * spec/glos/term/priorityboosting.yml (moved) * spec/glos/term/priorityinheritance.yml (moved) * spec/glos/term/priorityinversion.yml (moved) * spec/glos/term/processorutilization.yml (moved) * spec/glos/term/proxy.yml (moved) * spec/glos/term/proxycontrolblock.yml (moved) * spec/glos/term/ptcb.yml (added) * spec/glos/term/pxcb.yml (added) * spec/glos/term/qcb.yml (added) * spec/glos/term/quantum.yml (moved) * spec/glos/term/queue.yml (moved) * spec/glos/term/readytask.yml (moved) * spec/glos/term/realtime.yml (moved) * spec/glos/term/reentrant.yml (moved) * spec/glos/term/region.yml (moved) * spec/glos/term/regioncontrolblock.yml (moved) * spec/glos/term/registers.yml (moved) * spec/glos/term/remote.yml (moved) * spec/glos/term/remoteoperation.yml (moved) * spec/glos/term/reqif.yml (moved) * spec/glos/term/resource.yml (moved) * spec/glos/term/resume.yml (moved) * spec/glos/term/returncode.yml (added) * spec/glos/term/returnvalue.yml (moved) * spec/glos/term/rncb.yml (added) * spec/glos/term/roundrobin.yml (moved) * spec/glos/term/rs232.yml (moved) * spec/glos/term/rtems.yml (moved) * spec/glos/term/running.yml (moved) * spec/glos/term/schedulable.yml (moved) * spec/glos/term/schedule.yml (moved) * spec/glos/term/scheduledtask.yml (moved) * spec/glos/term/scheduler.yml (moved) * spec/glos/term/schedulerinstance.yml (moved) * spec/glos/term/segments.yml (moved) * spec/glos/term/semaphore.yml (moved) * spec/glos/term/semaphorecontrolblock.yml (moved) * spec/glos/term/sharedmemory.yml (moved) * spec/glos/term/signal.yml (moved) * spec/glos/term/signalset.yml (moved) * spec/glos/term/smcb.yml (added) * spec/glos/term/smp.yml (moved) * spec/glos/term/smpbarriers.yml (moved) * spec/glos/term/smplocks.yml (moved) * spec/glos/term/softrealtimesystem.yml (moved) * spec/glos/term/softwarecomponent.yml (moved) * spec/glos/term/softwareitem.yml (added) * spec/glos/term/softwareproduct.yml (added) * spec/glos/term/softwareunit.yml (moved) * spec/glos/term/sourcecode.yml (moved) * spec/glos/term/sporadictask.yml (moved) * spec/glos/term/stack.yml (moved) * spec/glos/term/statuscode.yml (moved) * spec/glos/term/suspend.yml (moved) * spec/glos/term/synchronous.yml (moved) * spec/glos/term/systemcall.yml (moved) * spec/glos/term/target.yml (moved) * spec/glos/term/tas.yml (moved) * spec/glos/term/task.yml (moved) * spec/glos/term/taskcontrolblock.yml (moved) * spec/glos/term/taskmigration.yml (moved) * spec/glos/term/taskprocessoraffinity.yml (moved) * spec/glos/term/taskswitch.yml (moved) * spec/glos/term/tcb.yml (added) * spec/glos/term/thread.yml (added) * spec/glos/term/threaddispatch.yml (moved) * spec/glos/term/tick.yml (moved) * spec/glos/term/tightlycoupled.yml (moved) * spec/glos/term/timeout.yml (moved) * spec/glos/term/timer.yml (moved) * spec/glos/term/timercontrolblock.yml (moved) * spec/glos/term/timeslice.yml (moved) * spec/glos/term/timeslicing.yml (moved) * spec/glos/term/tls.yml (moved) * spec/glos/term/tmcb.yml (added) * spec/glos/term/transientoverload.yml (moved) * spec/glos/term/ttas.yml (moved) * spec/glos/term/userextensions.yml (moved) * spec/glos/term/userextensiontable.yml (moved) * spec/glos/term/userinitializationtaskstable.yml (moved) * spec/glos/term/userprovided.yml (moved) * spec/glos/term/usersupplied.yml (added) * spec/glos/term/vector.yml (moved) * spec/glos/term/waitqueue.yml (moved) * spec/glos/term/yaml.yml (moved) * spec/glos/term/yield.yml (moved) * spec/glossary.yml (added) Remove Doorstop specifics Thu, 02 Apr 2020 07:51:01 GMT Sebastian Huber [ce63431] * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPRIORITY.yml (modified) spec: Move option Wed, 01 Apr 2020 06:55:00 GMT Sebastian Huber [210dbc11] * spec/acfg/opt/RTEMS-ACFG-OPT-CONSTRAINTPOSIX.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPOSIXQUEUEDSIGNALS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPOSIXTIMERS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPROCESSORS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MPAPPL.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MPEXTRASERVERSTACK.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MPMAXGLOBALOBJECTS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MPMAXNODES.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MPMAXPROXIES.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MPMPCITABLEPOINTER.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MPNODENUMBER.yml (modified) spec: Clarify config options use Wed, 01 Apr 2020 06:48:07 GMT Sebastian Huber [a48a2e5] * spec/acfg/opt/RTEMS-ACFG-OPT-BDBUFBUFFERMAXSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-BDBUFBUFFERMINSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-BDBUFCACHEMEMORYSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-BDBUFMAXWRITEBLOCKS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-BDBUFREADAHEADTASKPRIORITY.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-BDBUFTASKSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-BSPIDLETASKSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-BSPINTERRUPTSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-DISABLEBSPSETTINGS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMALL.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMFTPFS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMJFFS2.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMNFS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMTFTPFS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLECHMOD.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLECHOWN.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLELINK.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLEMKNOD.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLEMKNODDEVICE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLEMKNODFILE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLEMOUNT.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLEREADDIR.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLEREADLINK.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLERENAME.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLERMNOD.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLESYMLINK.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLEUNMOUNT.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLEUTIME.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSENABLEMKFIFO.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-INITTASKARGUMENTS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-INITTASKATTRIBUTES.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-INITTASKINITIALMODES.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-INITTASKPRIORITY.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-INITTASKSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MINPOSIXTHREADSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MPEXTRASERVERSTACK.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MPMAXNODES.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-POSIXINITTHREADSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-SWAPOUTBLOCKHOLD.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-SWAPOUTSWAPPERIOD.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-SWAPOUTTASKPRIORITY.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-SWAPOUTWORKERTASKPRIORITY.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-SWAPOUTWORKERTASKS.yml (modified) spec: Use null if no notes are present Wed, 01 Apr 2020 05:49:47 GMT Sebastian Huber [0417df4] * spec/acfg/opt/RTEMS-ACFG-OPT-ATADRIVERTASKPRIORITY.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-BDBUFREADAHEADTASKPRIORITY.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-CONSTRAINTPRIOCLASSIC.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-INITTASKPRIORITY.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-SWAPOUTTASKPRIORITY.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-SWAPOUTWORKERTASKPRIORITY.yml (modified) spec: Add and use constraint Tue, 31 Mar 2020 14:40:49 GMT Sebastian Huber [b4b639f] * spec/acfg/opt/RTEMS-ACFG-OPT-APPLNEEDSATADRIVER.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-APPLNEEDSIDEDRIVER.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-ATADRIVERTASKPRIORITY.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-CBSMAXIMUMSERVERS.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-DIRTYMEMORY.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-DISABLENEWLIBREENTRANCY.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-EXECUTIVERAMSIZE.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMALL.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMDOSFS.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMFTPFS.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMIMFS.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMJFFS2.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMNFS.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMRFS.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-FILESYSTEMTFTPFS.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-IMFSDISABLEMKNODDEVICE.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-MALLOCDIRTY.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPOSIXSHMS.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-MPEXTRASERVERSTACK.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-SCHEDULERASSIGNMENTS.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-SCHEDULERSTRONGAPA.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-TASKSTACKFROMALLOC.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-TASKSTACKNOWKSPACE.yml (added) spec: Add undocumented configuration options Tue, 31 Mar 2020 14:48:33 GMT Sebastian Huber [37699db] * spec/acfg/opt/.doorstop.yml (modified) spec: New option template Tue, 31 Mar 2020 06:06:47 GMT Sebastian Huber [592ad7b] * spec/glos/term/RTEMS-GLOS-TERM-ASSEMBLERLANGUAGE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CLANGUAGE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ELF.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERRUPTSERVICE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWARECOMPONENT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREUNIT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASK.yml (modified) spec: Update glossary of terms Mon, 30 Mar 2020 13:03:59 GMT Sebastian Huber [f67c6e9] * spec/acfg/opt/RTEMS-ACFG-OPT-INITTASKENTRYPOINT.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-POSIXINITTHREADENTRYPOINT.yml (modified) spec: Clarify role in configuration option Mon, 30 Mar 2020 11:26:38 GMT Sebastian Huber [210d3247] * spec/acfg/opt/RTEMS-ACFG-OPT-BDBUFTASKSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-BSPIDLETASKSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-BSPINTERRUPTSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-CONSTRAINTBSPAPPMIN.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-CONSTRAINTIDLESTACKAREA.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-CONSTRAINTISRSTACKALIGN.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-CONSTRAINTISRSTACKAREA.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-CONSTRAINTMEMSZ.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-CONSTRAINTSTACKSPACE.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-CONSTRAINTUNLIMITED.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-CONSTRAINTWKSPACE.yml (added) * spec/acfg/opt/RTEMS-ACFG-OPT-EXTRATASKSTACKS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-IDLETASKSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-INITTASKARGUMENTS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-INITTASKSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-INTERRUPTSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXBARRIERS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXDRIVERS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXFILEDESCRIPTORS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXMESSAGEQUEUES.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPARTITIONS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPERIODS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPORTS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPOSIXKEYS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPOSIXKEYVALUEPAIRS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPOSIXMESSAGEQUEUES.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPOSIXQUEUEDSIGNALS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPOSIXSEMAPHORES.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPOSIXTHREADS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXPOSIXTIMERS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXREGIONS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXSEMAPHORES.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXTASKS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXTHREADNAMESIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXTIMERS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MAXUSEREXTENSIONS.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MEMORYOVERHEAD.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MESSAGEBUFFERMEMORY.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MINPOSIXTHREADSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-MINTASKSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-POSIXINITTHREADSTACKSIZE.yml (modified) * spec/acfg/opt/RTEMS-ACFG-OPT-RECORDPERPROCESSORITEMS.yml (modified) spec: Use constraint links
