# # ChangeLog for spec/spec in rtems-central # # Generated by Trac 1.2.1.dev0 # 05/15/24 04:15:55 Tue, 04 Aug 2020 07:04:40 GMT Sebastian Huber [e3e1de7] * rtemsspec/tests/spec-validation/action2.yml (modified) * rtemsspec/tests/spec-validation/directive.yml (modified) * rtemsspec/tests/test_validation.py (modified) * rtemsspec/validation.py (modified) * spec/req/rtems/ident-local.yml (modified) * spec/req/rtems/ident.yml (modified) * spec/req/rtems/tasks/ident.yml (modified) * spec/spec/requirement-action.yml (modified) validation: Add test cleanup Tue, 04 Aug 2020 05:08:38 GMT Sebastian Huber [c127fb3] * rtemsspec/tests/spec-validation/action2.yml (modified) * rtemsspec/tests/spec-validation/directive.yml (modified) * rtemsspec/tests/test_validation.py (modified) * rtemsspec/validation.py (modified) * spec/req/rtems/ident-local.yml (modified) * spec/req/rtems/ident.yml (modified) * spec/req/rtems/tasks/ident.yml (modified) * spec/spec/requirement-action.yml (modified) validation: Add test early preparation Wed, 19 Aug 2020 08:18:31 GMT Sebastian Huber [6df984e] * rtemsspec/tests/spec-validation/action2.yml (modified) * rtemsspec/tests/spec-validation/directive.yml (modified) * rtemsspec/tests/spec-validation/tc.yml (modified) * rtemsspec/tests/spec-validation/tc2.yml (modified) * rtemsspec/tests/spec-validation/tc3.yml (modified) * rtemsspec/tests/spec-validation/tc4.yml (modified) * rtemsspec/tests/spec-validation/ts.yml (modified) * spec/if/acfg/min-task-stack-size.yml (modified) * spec/if/rtems/barrier/group.yml (modified) * spec/if/rtems/clock/tick-before.yml (modified) * spec/if/rtems/clock/tick-later-usec.yml (modified) * spec/if/rtems/clock/tick-later.yml (modified) * spec/if/rtems/event/send.yml (modified) * spec/if/rtems/event/system-server-resume.yml (modified) * spec/if/rtems/event/system-server.yml (modified) * spec/if/rtems/event/system-transient.yml (modified) * spec/if/rtems/fatal/panic.yml (modified) * spec/if/rtems/intr/lock-reference.yml (modified) * spec/if/rtems/object/get-local-node.yml (modified) * spec/if/rtems/options/no-wait.yml (modified) * spec/if/rtems/ratemon/period-status-define.yml (modified) * spec/if/rtems/scheduler/get-processor-maximum.yml (modified) * spec/if/rtems/timer/service-routine-entry.yml (modified) * spec/req/rtems/barrier/val/ident.yml (modified) * spec/req/rtems/ident-local.yml (modified) * spec/req/rtems/ident.yml (modified) * spec/req/rtems/message/val/ident.yml (modified) * spec/req/rtems/part/val/ident.yml (modified) * spec/req/rtems/ratemon/val/ident.yml (modified) * spec/req/rtems/sem/val/ident.yml (modified) * spec/req/rtems/tasks/ident.yml (modified) * spec/req/rtems/timer/val/ident.yml (modified) * spec/req/rtems/userext/val/ident.yml (modified) * spec/spec/interface-brief.yml (modified) * spec/system.yml (modified) spec: Fix item format Thu, 06 Aug 2020 12:26:29 GMT Sebastian Huber [61376c4] * spec/if/build-options/ada.yml (modified) * spec/if/build-options/debug.yml (modified) * spec/if/build-options/drvmgr.yml (modified) * spec/if/build-options/multiprocessing.yml (modified) * spec/if/build-options/networking.yml (modified) * spec/if/build-options/paravirt.yml (modified) * spec/if/build-options/posix.yml (modified) * spec/if/build-options/profiling.yml (modified) * spec/if/build-options/smp.yml (modified) * spec/if/c/bool.yml (modified) * spec/if/c/chmod.yml (modified) * spec/if/c/chown.yml (modified) * spec/if/c/cpu_set_t.yml (modified) * spec/if/c/errno.yml (modified) * spec/if/c/false.yml (modified) * spec/if/c/free.yml (modified) * spec/if/c/int16_t.yml (modified) * spec/if/c/int32_t.yml (modified) * spec/if/c/int64_t.yml (modified) * spec/if/c/int8_t.yml (modified) * spec/if/c/intmax_t.yml (modified) * spec/if/c/intptr_t.yml (modified) * spec/if/c/link.yml (modified) * spec/if/c/malloc.yml (modified) * spec/if/c/mkfifo.yml (modified) * spec/if/c/mknod.yml (modified) * spec/if/c/null.yml (modified) * spec/if/c/offsetof.yml (modified) * spec/if/c/printf.yml (modified) * spec/if/c/pthread_setspecific.yml (modified) * spec/if/c/readdir.yml (modified) * spec/if/c/readlink.yml (modified) * spec/if/c/rename.yml (modified) * spec/if/c/rmnod.yml (modified) * spec/if/c/sbrk.yml (modified) * spec/if/c/sem_init.yml (modified) * spec/if/c/sem_open.yml (modified) * spec/if/c/size_max.yml (modified) * spec/if/c/size_t.yml (modified) * spec/if/c/symlink.yml (modified) * spec/if/c/time_t.yml (modified) * spec/if/c/timespec.yml (modified) * spec/if/c/timeval.yml (modified) * spec/if/c/true.yml (modified) * spec/if/c/uint16_t.yml (modified) * spec/if/c/uint32_max.yml (modified) * spec/if/c/uint32_t.yml (modified) * spec/if/c/uint64_t.yml (modified) * spec/if/c/uint8_t.yml (modified) * spec/if/c/uintmax_t.yml (modified) * spec/if/c/uintptr_max.yml (modified) * spec/if/c/uintptr_t.yml (modified) * spec/if/c/utime.yml (modified) * spec/if/compiler/asm.yml (modified) * spec/if/compiler/builtin-choose-expr.yml (modified) * spec/if/compiler/builtin-expect.yml (modified) * spec/if/compiler/builtin-return-address.yml (modified) * spec/if/compiler/builtin-types-compatible-p.yml (modified) * spec/if/compiler/builtin-unreachable.yml (modified) * spec/if/compiler/cplusplus.yml (modified) * spec/if/compiler/gnuc.yml (modified) * spec/if/compiler/stdc-version.yml (modified) * spec/if/compiler/typeof.yml (modified) * spec/if/compiler/user-label-prefix.yml (modified) * spec/if/impl/cpu/exception-frame-print.yml (modified) * spec/if/impl/cpu/exception-frame.yml (modified) * spec/if/impl/cpu/hardware-fp.yml (modified) * spec/if/impl/cpu/interrupt-frame.yml (modified) * spec/if/impl/cpu/interrupt-stack-alignment.yml (modified) * spec/if/impl/cpu/isr-passes-frame-pointer.yml (modified) * spec/if/impl/cpu/maximum-processors.yml (modified) * spec/if/impl/cpu/modes-interrupt-mask.yml (modified) * spec/if/impl/cpu/simple-vectored-interrupts.yml (modified) * spec/if/impl/cpu/stack-minimum-size.yml (modified) * spec/if/impl/cpu/uint32ptr.yml (modified) * spec/if/impl/heap/information-block.yml (modified) * spec/if/impl/interr/code.yml (modified) * spec/if/impl/interr/source.yml (modified) * spec/if/impl/interr/terminate.yml (modified) * spec/if/impl/isr/handler-entry.yml (modified) * spec/if/impl/isr/handler.yml (modified) * spec/if/impl/isr/is-in-progress.yml (modified) * spec/if/impl/isr/level.yml (modified) * spec/if/impl/isr/local-disable.yml (modified) * spec/if/impl/isr/local-enable.yml (modified) * spec/if/impl/isr/local-flash.yml (modified) * spec/if/impl/isr/lock-context.yml (modified) * spec/if/impl/isr/lock-control.yml (modified) * spec/if/impl/isr/lock-declare.yml (modified) * spec/if/impl/isr/lock-define.yml (modified) * spec/if/impl/isr/lock-destroy.yml (modified) * spec/if/impl/isr/lock-initialize.yml (modified) * spec/if/impl/isr/lock-initializer.yml (modified) * spec/if/impl/isr/lock-isr-disable-acquire.yml (modified) * spec/if/impl/isr/lock-isr-disable.yml (modified) * spec/if/impl/isr/lock-member.yml (modified) * spec/if/impl/isr/lock-reference.yml (modified) * spec/if/impl/isr/lock-release-isr-enable.yml (modified) * spec/if/impl/isr/stack-size.yml (modified) * spec/if/impl/isr/vector-number.yml (modified) * spec/if/impl/memory/zero-before-use.yml (modified) * spec/if/impl/mpci/configuration-type.yml (modified) * spec/if/impl/mpci/configuration.yml (modified) * spec/if/impl/mpci/control.yml (modified) * spec/if/impl/mpci/entry.yml (modified) * spec/if/impl/mpci/get-packet-entry.yml (modified) * spec/if/impl/mpci/initialization-entry.yml (modified) * spec/if/impl/mpci/packet-classes.yml (modified) * spec/if/impl/mpci/packet-minimum-hetero-conversion.yml (modified) * spec/if/impl/mpci/packet-minimum-size.yml (modified) * spec/if/impl/mpci/packet-prefix.yml (modified) * spec/if/impl/mpci/receive-entry.yml (modified) * spec/if/impl/mpci/return-packet-entry.yml (modified) * spec/if/impl/mpci/send-entry.yml (modified) * spec/if/impl/object/apis-last.yml (modified) * spec/if/impl/object/build-id.yml (modified) * spec/if/impl/object/build-name.yml (modified) * spec/if/impl/object/get-api.yml (modified) * spec/if/impl/object/get-class.yml (modified) * spec/if/impl/object/get-index.yml (modified) * spec/if/impl/object/get-node.yml (modified) * spec/if/impl/object/id-final-index.yml (modified) * spec/if/impl/object/id-final.yml (modified) * spec/if/impl/object/id-initial-index.yml (modified) * spec/if/impl/object/id-initial.yml (modified) * spec/if/impl/object/id-none.yml (modified) * spec/if/impl/object/id-of-self.yml (modified) * spec/if/impl/object/id.yml (modified) * spec/if/impl/object/internal-api.yml (modified) * spec/if/impl/object/is-unlimited.yml (modified) * spec/if/impl/object/local-node.yml (modified) * spec/if/impl/object/maximum-per-allocation.yml (modified) * spec/if/impl/object/search-all-nodes.yml (modified) * spec/if/impl/object/search-local-nodes.yml (modified) * spec/if/impl/object/search-other-nodes.yml (modified) * spec/if/impl/object/unlimited-objects.yml (modified) * spec/if/impl/object/who-am-i.yml (modified) * spec/if/impl/smp/get-current-processor.yml (modified) * spec/if/impl/smp/get-processor-maximum.yml (modified) * spec/if/impl/smp/lock-acquire.yml (modified) * spec/if/impl/smp/lock-release.yml (modified) * spec/if/impl/smp/processor-configured-maximum.yml (modified) * spec/if/impl/stack/allocator-allocate-type.yml (modified) * spec/if/impl/stack/allocator-allocate.yml (modified) * spec/if/impl/stack/allocator-avoids-workspace.yml (modified) * spec/if/impl/stack/allocator-free-type.yml (modified) * spec/if/impl/stack/allocator-free.yml (modified) * spec/if/impl/stack/allocator-initialize-type.yml (modified) * spec/if/impl/stack/allocator-initialize.yml (modified) * spec/if/impl/stack/minimum-size.yml (modified) * spec/if/impl/thread/idle-body.yml (modified) * spec/if/impl/thread/idle-stack-size.yml (modified) * spec/if/impl/userext/fatal.yml (modified) * spec/if/impl/userext/initial-count.yml (modified) * spec/if/impl/userext/initial-extensions.yml (modified) * spec/if/impl/userext/table.yml (modified) * spec/if/impl/userext/thread-begin.yml (modified) * spec/if/impl/userext/thread-create.yml (modified) * spec/if/impl/userext/thread-delete.yml (modified) * spec/if/impl/userext/thread-exitted.yml (modified) * spec/if/impl/userext/thread-restart.yml (modified) * spec/if/impl/userext/thread-start.yml (modified) * spec/if/impl/userext/thread-switch.yml (modified) * spec/if/impl/userext/thread-terminate.yml (modified) * spec/if/impl/watchdog/interval.yml (modified) * spec/if/impl/watchdog/microseconds-per-tick.yml (modified) * spec/if/impl/watchdog/nanoseconds-per-tick.yml (modified) * spec/if/impl/watchdog/no-timeout.yml (modified) * spec/if/impl/watchdog/ticks-per-second.yml (modified) * spec/if/impl/watchdog/ticks-per-timeslice.yml (modified) * spec/if/impl/watchdog/ticks-since-boot.yml (modified) * spec/if/impl/wkspace/is-unified.yml (modified) * spec/if/impl/wkspace/size.yml (modified) * spec/if/rtems/io/getchark.yml (modified) * spec/if/rtems/io/mount.yml (modified) * spec/if/rtems/io/printk.yml (modified) * spec/if/rtems/io/putc.yml (modified) * spec/if/rtems/io/unmount.yml (modified) * spec/if/use/asm.yml (modified) * spec/if/use/false.yml (modified) * spec/if/use/true.yml (modified) * spec/spec/interface-unspecified.yml (modified) spec: Add reference to unspecified interfaces Thu, 06 Aug 2020 08:26:49 GMT Sebastian Huber [48e355a] * spec/spec/interface-unspecified.yml (modified) spec: Add more unspecified interfaces Tue, 28 Jul 2020 04:57:22 GMT Sebastian Huber [3e303ed] * spec/spec/interface-brief.yml (modified) * spec/spec/interface-header-file.yml (modified) spec: Clarify and use interface brief Mon, 27 Jul 2020 12:54:13 GMT Sebastian Huber [55e17d2] * rtemsspec/tests/spec-validation/action2.yml (modified) * rtemsspec/tests/spec-validation/directive.yml (modified) * rtemsspec/tests/test_validation.py (modified) * rtemsspec/validation.py (modified) * spec/req/rtems/ident-local.yml (modified) * spec/req/rtems/ident.yml (modified) * spec/req/rtems/tasks/ident.yml (modified) * spec/spec/requirement-action-skip-reasons.yml (added) * spec/spec/requirement-action-transition-post.yml (modified) * spec/spec/requirement-action.yml (modified) validation: Add ability to skip action transitions Mon, 27 Jul 2020 07:23:13 GMT Sebastian Huber [244b277] * rtemsspec/tests/spec-validation/action2.yml (modified) * rtemsspec/tests/test_validation.py (modified) * rtemsspec/validation.py (modified) * spec/spec/requirement-action-name.yml (modified) * spec/spec/requirement-action-transition-pre-states.yml (modified) validation: Support N/A in the action transitions Sometimes the ... Fri, 24 Jul 2020 18:44:56 GMT Sebastian Huber [86dbbfa4] * spec/if/api.yml (modified) * spec/if/rtems/attr/group.yml (modified) * spec/if/rtems/barrier/group.yml (modified) * spec/if/rtems/basedefs/group.yml (modified) * spec/if/rtems/cache/group.yml (modified) * spec/if/rtems/clock/group.yml (modified) * spec/if/rtems/config/group.yml (modified) * spec/if/rtems/dpmem/group.yml (modified) * spec/if/rtems/event/group.yml (modified) * spec/if/rtems/fatal/group.yml (modified) * spec/if/rtems/group.yml (modified) * spec/if/rtems/init/group.yml (modified) * spec/if/rtems/intr/group.yml (modified) * spec/if/rtems/io/group.yml (modified) * spec/if/rtems/message/group.yml (modified) * spec/if/rtems/modes/group.yml (modified) * spec/if/rtems/mp/group.yml (modified) * spec/if/rtems/object/group.yml (modified) * spec/if/rtems/options/group.yml (modified) * spec/if/rtems/part/group.yml (modified) * spec/if/rtems/ratemon/group.yml (modified) * spec/if/rtems/region/group.yml (modified) * spec/if/rtems/sem/group.yml (modified) * spec/if/rtems/signal/group.yml (modified) * spec/if/rtems/status/group.yml (modified) * spec/if/rtems/support/group.yml (modified) * spec/if/rtems/tasks/group.yml (modified) * spec/if/rtems/timer/group.yml (modified) * spec/if/rtems/types/group.yml (modified) * spec/if/rtems/userext/group.yml (modified) * spec/spec/interface-group.yml (modified) spec: Add requirements text to groups Fri, 24 Jul 2020 10:25:31 GMT Sebastian Huber [4ad78f2] * rtemsspec/interface.py (modified) * rtemsspec/tests/spec-interface/h.yml (modified) * rtemsspec/tests/spec-interface/h2.yml (modified) * rtemsspec/tests/spec-interface/h3.yml (modified) * rtemsspec/tests/spec-interface/h4.yml (modified) * rtemsspec/tests/spec-interface/math.yml (modified) * rtemsspec/tests/spec-interface/stdint.yml (modified) * rtemsspec/tests/test_interface.py (modified) * spec/if/build-options/cpuopts.yml (modified) * spec/if/c/stdatomic.yml (modified) * spec/if/c/stdbool.yml (modified) * spec/if/c/stddef.yml (modified) * spec/if/c/stdint.yml (modified) * spec/if/c/string.yml (modified) * spec/if/c/sys-cpuset.yml (modified) * spec/if/c/sys-impl-timespec.yml (modified) * spec/if/c/sys-impl-timeval.yml (modified) * spec/if/c/sys-types.yml (modified) * spec/if/c/time.yml (modified) * spec/if/impl/cpu/header.yml (modified) * spec/if/impl/heap/header.yml (modified) * spec/if/impl/interr/header.yml (modified) * spec/if/impl/isr/header-2.yml (modified) * spec/if/impl/isr/header-3.yml (modified) * spec/if/impl/isr/header.yml (modified) * spec/if/impl/memory/header.yml (modified) * spec/if/impl/mpci/header-2.yml (modified) * spec/if/impl/mpci/header.yml (modified) * spec/if/impl/object/header.yml (modified) * spec/if/impl/smp/header-2.yml (modified) * spec/if/impl/smp/header.yml (modified) * spec/if/impl/stack/header.yml (modified) * spec/if/impl/thread/header.yml (modified) * spec/if/impl/userext/header.yml (modified) * spec/if/impl/watchdog/header.yml (modified) * spec/if/impl/wkspace/header.yml (modified) * spec/if/rtems/attr/header.yml (modified) * spec/if/rtems/barrier/header.yml (modified) * spec/if/rtems/basedefs/header.yml (modified) * spec/if/rtems/cache/header.yml (modified) * spec/if/rtems/clock/header.yml (modified) * spec/if/rtems/config/header-2.yml (modified) * spec/if/rtems/config/header.yml (modified) * spec/if/rtems/dpmem/header.yml (modified) * spec/if/rtems/event/header.yml (modified) * spec/if/rtems/fatal/header.yml (modified) * spec/if/rtems/header.yml (modified) * spec/if/rtems/init/header.yml (modified) * spec/if/rtems/intr/header.yml (modified) * spec/if/rtems/io/header.yml (modified) * spec/if/rtems/message/header.yml (modified) * spec/if/rtems/modes/header.yml (modified) * spec/if/rtems/mp/header.yml (modified) * spec/if/rtems/object/header.yml (modified) * spec/if/rtems/options/header.yml (modified) * spec/if/rtems/part/header.yml (modified) * spec/if/rtems/ratemon/header.yml (modified) * spec/if/rtems/region/header.yml (modified) * spec/if/rtems/sem/header.yml (modified) * spec/if/rtems/signal/header-2.yml (modified) * spec/if/rtems/signal/header.yml (modified) * spec/if/rtems/status/header.yml (modified) * spec/if/rtems/support/header.yml (modified) * spec/if/rtems/tasks/header.yml (modified) * spec/if/rtems/timer/header.yml (modified) * spec/if/rtems/types/header.yml (modified) * spec/if/rtems/userext/header.yml (modified) * spec/spec/interface-header-file.yml (modified) spec: Add header file brief descriptions Fri, 03 Jul 2020 08:25:58 GMT Sebastian Huber [041521b] * spec/spec/build-config-file.yml (modified) spec: Fix typo Wed, 17 Jun 2020 07:12:03 GMT Sebastian Huber [5d3f70a] * spec/spec/requirement-action-transition.yml (modified) * spec/spec/requirement-action.yml (modified) spec: Clarify action requirements Wed, 10 Jun 2020 09:09:44 GMT Sebastian Huber [4c5c9c3] * spec/spec/requirement-action.yml (modified) spec: Fix typo Wed, 10 Jun 2020 07:52:45 GMT Sebastian Huber [ca159fc] * spec/spec/requirement-action-test-header.yml (added) * spec/spec/requirement-action-test-run-param-list.yml (added) * spec/spec/requirement-action-test-run-param.yml (added) * spec/spec/requirement-action.yml (modified) spec: Specify action requirement test headers Fri, 05 Jun 2020 05:11:12 GMT Sebastian Huber [7bd6817] * spec/spec/requirement-functional-generic.yml (added) * spec/spec/requirement-functional-type.yml (deleted) * spec/spec/requirement-functional.yml (modified) staging: Fix functional requirement item types Mon, 08 Jun 2020 06:45:01 GMT Sebastian Huber [1a58bbe] * spec/spec/interface-function-role.yml (modified) * spec/spec/requirement-action-condition-list.yml (moved) * spec/spec/requirement-action-condition.yml (moved) * spec/spec/requirement-action-name.yml (moved) * spec/spec/requirement-action-state-list.yml (moved) * spec/spec/requirement-action-state.yml (moved) * spec/spec/requirement-action-test-context-list.yml (moved) * spec/spec/requirement-action-test-context.yml (moved) * spec/spec/requirement-action-test-fixture.yml (moved) * spec/spec/requirement-action-transition-list.yml (moved) * spec/spec/requirement-action-transition-post.yml (moved) * spec/spec/requirement-action-transition-pre-states.yml (moved) * spec/spec/requirement-action-transition-pre.yml (moved) * spec/spec/requirement-action-transition.yml (moved) * spec/spec/requirement-action.yml (moved) spec: Generalize directive to action requirements Fri, 05 Jun 2020 05:25:50 GMT Sebastian Huber [17e293d] * spec/spec/requirement-directive-test-fixture.yml (modified) spec: Fix specification type Thu, 04 Jun 2020 07:57:22 GMT Sebastian Huber [9c978899] * spec/spec/interface-function-role.yml (added) * spec/spec/requirement-directive-condition-list.yml (added) * spec/spec/requirement-directive-condition.yml (added) * spec/spec/requirement-directive-name.yml (added) * spec/spec/requirement-directive-state-list.yml (added) * spec/spec/requirement-directive-state.yml (added) * spec/spec/requirement-directive-test-context-list.yml (added) * spec/spec/requirement-directive-test-context.yml (added) * spec/spec/requirement-directive-test-fixture.yml (added) * spec/spec/requirement-directive-transition-list.yml (added) * spec/spec/requirement-directive-transition-post.yml (added) * spec/spec/requirement-directive-transition-pre-states.yml (added) * spec/spec/requirement-directive-transition-pre.yml (added) * spec/spec/requirement-directive-transition.yml (added) * spec/spec/requirement-directive.yml (added) * spec/spec/requirement-functional-type.yml (modified) spec: Specify directive requirement items Thu, 04 Jun 2020 08:53:57 GMT Sebastian Huber [e5d1f8d] * rtemsqual/specdoc.py (modified) * rtemsqual/specverify.py (modified) * rtemsqual/tests/spec-doc/b.yml (modified) * rtemsqual/tests/spec-doc/root.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-attributes.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-dict.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-generic-attributes.yml (modified) * rtemsqual/tests/spec-verify/spec2/any-dict.yml (modified) * rtemsqual/tests/test_specdoc.py (modified) * rtemsqual/tests/test_specverify.py (modified) * spec/spec/build-action-set-test-state.yml (modified) * spec/spec/spec-attributes.yml (modified) * spec/spec/spec-dict.yml (modified) * spec/spec/spec-generic-attributes.yml (modified) spec: Define generic attribute key types Thu, 04 Jun 2020 08:34:56 GMT Sebastian Huber [9499f8b] * rtemsqual/specdoc.py (modified) * rtemsqual/specverify.py (modified) * rtemsqual/tests/spec-doc/a.yml (modified) * rtemsqual/tests/spec-doc/b.yml (modified) * rtemsqual/tests/spec-doc/c.yml (modified) * rtemsqual/tests/spec-doc/d.yml (modified) * rtemsqual/tests/spec-doc/root.yml (modified) * rtemsqual/tests/spec-verify/spec/enabled-by.yml (modified) * rtemsqual/tests/spec-verify/spec/link.yml (modified) * rtemsqual/tests/spec-verify/spec/root.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-float-list.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-float.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-int-list.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-int.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-str-list.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-assert-str.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-attribute-value.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-attributes.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-bool.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-dict.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-float.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-generic-attributes.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-info.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-int.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-list.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-mandatory-attributes.yml (moved) * rtemsqual/tests/spec-verify/spec/spec-member.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-refinement.yml (modified) * rtemsqual/tests/spec-verify/spec/spec-str.yml (modified) * rtemsqual/tests/spec-verify/spec/spec.yml (modified) * rtemsqual/tests/spec-verify/spec2/any-dict.yml (modified) * rtemsqual/tests/spec-verify/spec2/c.yml (modified) * rtemsqual/tests/spec-verify/spec2/d-a.yml (modified) * rtemsqual/tests/spec-verify/spec2/d.yml (modified) * rtemsqual/tests/spec-verify/spec2/invalid.yml (modified) * rtemsqual/tests/spec-verify/spec2/keys-at-least-one.yml (modified) * rtemsqual/tests/spec-verify/spec2/keys-at-most-one.yml (modified) * rtemsqual/tests/spec-verify/spec2/keys-exactly-one.yml (modified) * rtemsqual/tests/spec-verify/spec2/some-dict.yml (modified) * rtemsqual/tests/test_specdoc.py (modified) * rtemsqual/tests/test_specverify.py (modified) * spec/spec/appl-config-group-member.yml (modified) * spec/spec/appl-config-group.yml (modified) * spec/spec/appl-config-option-constraints.yml (modified) * spec/spec/appl-config-option-feature-enable.yml (modified) * spec/spec/appl-config-option-feature.yml (modified) * spec/spec/appl-config-option-value.yml (modified) * spec/spec/appl-config-option.yml (modified) * spec/spec/build-action-check-cc.yml (modified) * spec/spec/build-action-check-cxx.yml (modified) * spec/spec/build-action-set-test-state.yml (modified) * spec/spec/build-action.yml (modified) * spec/spec/build-ada-test-program.yml (modified) * spec/spec/build-bsp.yml (modified) * spec/spec/build-config-file.yml (modified) * spec/spec/build-config-header.yml (modified) * spec/spec/build-default-by-variant.yml (modified) * spec/spec/build-dependency.yml (modified) * spec/spec/build-group.yml (modified) * spec/spec/build-install.yml (modified) * spec/spec/build-library.yml (modified) * spec/spec/build-objects.yml (modified) * spec/spec/build-option.yml (modified) * spec/spec/build-script.yml (modified) * spec/spec/build-start-file.yml (modified) * spec/spec/build-test-program.yml (modified) * spec/spec/build.yml (modified) * spec/spec/constraint-role.yml (modified) * spec/spec/constraint.yml (modified) * spec/spec/enabled-by.yml (modified) * spec/spec/glossary-group.yml (modified) * spec/spec/glossary-member.yml (modified) * spec/spec/glossary-term.yml (modified) * spec/spec/glossary.yml (modified) * spec/spec/interface-compound.yml (modified) * spec/spec/interface-container.yml (modified) * spec/spec/interface-define.yml (modified) * spec/spec/interface-definition-directive.yml (modified) * spec/spec/interface-definition-variant.yml (modified) * spec/spec/interface-domain.yml (modified) * spec/spec/interface-enabled-by.yml (modified) * spec/spec/interface-enum.yml (modified) * spec/spec/interface-enumerator-role.yml (modified) * spec/spec/interface-enumerator.yml (modified) * spec/spec/interface-forward-declaration.yml (modified) * spec/spec/interface-function-definition-directive.yml (modified) * spec/spec/interface-function-definition-variant.yml (modified) * spec/spec/interface-function-definition.yml (modified) * spec/spec/interface-function.yml (modified) * spec/spec/interface-group.yml (modified) * spec/spec/interface-header-file.yml (modified) * spec/spec/interface-include.yml (modified) * spec/spec/interface-ingroup.yml (modified) * spec/spec/interface-macro.yml (modified) * spec/spec/interface-member-compound.yml (modified) * spec/spec/interface-member-declaration.yml (modified) * spec/spec/interface-member-definition-directive.yml (modified) * spec/spec/interface-member-definition-variant.yml (modified) * spec/spec/interface-member-definition.yml (modified) * spec/spec/interface-param.yml (modified) * spec/spec/interface-placement.yml (modified) * spec/spec/interface-return-directive.yml (modified) * spec/spec/interface-return-value.yml (modified) * spec/spec/interface-target.yml (modified) * spec/spec/interface-typedef.yml (modified) * spec/spec/interface-unspecified.yml (modified) * spec/spec/interface-variable.yml (modified) * spec/spec/interface.yml (modified) * spec/spec/link.yml (modified) * spec/spec/requirement-functional.yml (modified) * spec/spec/requirement-non-functional.yml (modified) * spec/spec/requirement-reference.yml (modified) * spec/spec/requirement-refinement.yml (modified) * spec/spec/requirement-validation-role.yml (modified) * spec/spec/requirement-validation.yml (modified) * spec/spec/requirement.yml (modified) * spec/spec/root.yml (modified) * spec/spec/spec-assert-float.yml (modified) * spec/spec/spec-assert-int.yml (modified) * spec/spec/spec-assert-str.yml (modified) * spec/spec/spec-attribute-value.yml (modified) * spec/spec/spec-attributes.yml (modified) * spec/spec/spec-bool.yml (modified) * spec/spec/spec-dict.yml (modified) * spec/spec/spec-float.yml (modified) * spec/spec/spec-generic-attributes.yml (modified) * spec/spec/spec-info.yml (modified) * spec/spec/spec-int.yml (modified) * spec/spec/spec-list.yml (modified) * spec/spec/spec-mandatory-attributes.yml (moved) * spec/spec/spec-member.yml (modified) * spec/spec/spec-refinement.yml (modified) * spec/spec/spec-str.yml (modified) * spec/spec/spec.yml (modified) * spec/spec/test-case-action.yml (modified) * spec/spec/test-case-check.yml (modified) * spec/spec/test-case.yml (modified) * spec/spec/test-platform.yml (modified) * spec/spec/test-procedure.yml (modified) * spec/spec/test-suite.yml (modified) spec: Rename required in mandatory attributes The term "required" ... Thu, 04 Jun 2020 07:56:51 GMT Sebastian Huber [f990475] * spec/spec/spec.yml (modified) * spec/spec/test-case.yml (modified) spec: Canonicalize descriptions Wed, 03 Jun 2020 14:52:55 GMT Sebastian Huber [d073590] * spec/spec/requirement.yml (modified) * spec/spec/test-platform.yml (modified) spec: Fix attribute order Fri, 29 May 2020 06:18:51 GMT Sebastian Huber [fbc190c] * spec/spec/test-platform.yml (added) * spec/spec/test-procedure.yml (added) spec: Add test procedure and platform types Thu, 04 Jun 2020 12:15:49 GMT Sebastian Huber [84280e6] * config.yml (modified) * rtemsqual/glossary.py (modified) * rtemsqual/tests/spec-glossary/g.yml (moved) * rtemsqual/tests/spec-glossary/glossary/t.yml (moved) * rtemsqual/tests/spec-glossary/glossary/u.yml (moved) * rtemsqual/tests/spec-glossary/glossary/v.yml (moved) * rtemsqual/tests/test_glossary.py (modified) * spec/glossary-general.yml (moved) * spec/glossary/abi.yml (moved) * spec/glossary/active.yml (moved) * spec/glossary/aperiodictask.yml (moved) * spec/glossary/api.yml (moved) * spec/glossary/application.yml (moved) * spec/glossary/asr.yml (moved) * spec/glossary/assemblerlanguage.yml (moved) * spec/glossary/asynchronous.yml (moved) * spec/glossary/asynchronoussignalroutine.yml (moved) * spec/glossary/atomicoperations.yml (moved) * spec/glossary/awakened.yml (moved) * spec/glossary/bigendian.yml (moved) * spec/glossary/bitmapped.yml (moved) * spec/glossary/block.yml (moved) * spec/glossary/blockedtask.yml (moved) * spec/glossary/boardsupportpackage.yml (moved) * spec/glossary/broadcast.yml (moved) * spec/glossary/bsp.yml (moved) * spec/glossary/buffer.yml (moved) * spec/glossary/c11.yml (moved) * spec/glossary/callingconvention.yml (moved) * spec/glossary/ccb.yml (moved) * spec/glossary/centralprocessingunit.yml (moved) * spec/glossary/chain.yml (moved) * spec/glossary/clanguage.yml (moved) * spec/glossary/cluster.yml (moved) * spec/glossary/coalesce.yml (moved) * spec/glossary/configurationtable.yml (moved) * spec/glossary/context.yml (moved) * spec/glossary/contextswitch.yml (moved) * spec/glossary/controlblock.yml (moved) * spec/glossary/core.yml (moved) * spec/glossary/cpu.yml (moved) * spec/glossary/criticalsection.yml (moved) * spec/glossary/crt.yml (moved) * spec/glossary/cxx11.yml (moved) * spec/glossary/deadline.yml (moved) * spec/glossary/device.yml (moved) * spec/glossary/devicedriver.yml (moved) * spec/glossary/devicedrivertable.yml (moved) * spec/glossary/directives.yml (moved) * spec/glossary/dispatch.yml (moved) * spec/glossary/doorstop.yml (moved) * spec/glossary/dormant.yml (moved) * spec/glossary/dualported.yml (moved) * spec/glossary/ears.yml (moved) * spec/glossary/elf.yml (moved) * spec/glossary/embedded.yml (moved) * spec/glossary/entrypoint.yml (moved) * spec/glossary/envelope.yml (moved) * spec/glossary/errorcode.yml (moved) * spec/glossary/events.yml (moved) * spec/glossary/exception.yml (moved) * spec/glossary/executingtask.yml (moved) * spec/glossary/executive.yml (moved) * spec/glossary/exported.yml (moved) * spec/glossary/externaladdress.yml (moved) * spec/glossary/fifo.yml (moved) * spec/glossary/firstinfirstout.yml (moved) * spec/glossary/floatingpointcoprocessor.yml (moved) * spec/glossary/freed.yml (moved) * spec/glossary/gcc.yml (moved) * spec/glossary/global.yml (moved) * spec/glossary/gnat.yml (moved) * spec/glossary/gnu.yml (moved) * spec/glossary/handler.yml (moved) * spec/glossary/hardrealtimesystem.yml (moved) * spec/glossary/heap.yml (moved) * spec/glossary/heirtask.yml (moved) * spec/glossary/heterogeneous.yml (moved) * spec/glossary/homogeneous.yml (moved) * spec/glossary/id.yml (moved) * spec/glossary/idletask.yml (moved) * spec/glossary/interface.yml (moved) * spec/glossary/internaladdress.yml (moved) * spec/glossary/interrupt.yml (moved) * spec/glossary/interruptlevel.yml (moved) * spec/glossary/interruptservice.yml (moved) * spec/glossary/interruptserviceroutine.yml (moved) * spec/glossary/io.yml (moved) * spec/glossary/isr.yml (moved) * spec/glossary/isvv.yml (moved) * spec/glossary/kernel.yml (moved) * spec/glossary/list.yml (moved) * spec/glossary/littleendian.yml (moved) * spec/glossary/local.yml (moved) * spec/glossary/localoperation.yml (moved) * spec/glossary/logicaladdress.yml (moved) * spec/glossary/looselycoupled.yml (moved) * spec/glossary/majornumber.yml (moved) * spec/glossary/manager.yml (moved) * spec/glossary/mcs.yml (moved) * spec/glossary/memorypool.yml (moved) * spec/glossary/message.yml (moved) * spec/glossary/messagebuffer.yml (moved) * spec/glossary/messagequeue.yml (moved) * spec/glossary/messagequeuecontrolblock.yml (moved) * spec/glossary/minornumber.yml (moved) * spec/glossary/mode.yml (moved) * spec/glossary/mpci.yml (moved) * spec/glossary/multiprocessing.yml (moved) * spec/glossary/multiprocessor.yml (moved) * spec/glossary/multiprocessorcommunicationsinterfacelayer.yml (moved) * spec/glossary/multiprocessorconfigurationtable.yml (moved) * spec/glossary/multitasking.yml (moved) * spec/glossary/mutualexclusion.yml (moved) * spec/glossary/nested.yml (moved) * spec/glossary/node.yml (moved) * spec/glossary/nonexistent.yml (moved) * spec/glossary/numa.yml (moved) * spec/glossary/numericcoprocessor.yml (moved) * spec/glossary/object.yml (moved) * spec/glossary/objectoriented.yml (moved) * spec/glossary/operatingsystem.yml (moved) * spec/glossary/overhead.yml (moved) * spec/glossary/packet.yml (moved) * spec/glossary/partition.yml (moved) * spec/glossary/partitioncontrolblock.yml (moved) * spec/glossary/pending.yml (moved) * spec/glossary/periodictask.yml (moved) * spec/glossary/physicaladdress.yml (moved) * spec/glossary/poll.yml (moved) * spec/glossary/pool.yml (moved) * spec/glossary/portability.yml (moved) * spec/glossary/posting.yml (moved) * spec/glossary/preempt.yml (moved) * spec/glossary/priority.yml (moved) * spec/glossary/priorityboosting.yml (moved) * spec/glossary/priorityinheritance.yml (moved) * spec/glossary/priorityinversion.yml (moved) * spec/glossary/processorutilization.yml (moved) * spec/glossary/proxy.yml (moved) * spec/glossary/proxycontrolblock.yml (moved) * spec/glossary/ptcb.yml (moved) * spec/glossary/pxcb.yml (moved) * spec/glossary/qcb.yml (moved) * spec/glossary/quantum.yml (moved) * spec/glossary/queue.yml (moved) * spec/glossary/readytask.yml (moved) * spec/glossary/realtime.yml (moved) * spec/glossary/reentrant.yml (moved) * spec/glossary/region.yml (moved) * spec/glossary/regioncontrolblock.yml (moved) * spec/glossary/registers.yml (moved) * spec/glossary/remote.yml (moved) * spec/glossary/remoteoperation.yml (moved) * spec/glossary/reqif.yml (moved) * spec/glossary/resource.yml (moved) * spec/glossary/resume.yml (moved) * spec/glossary/returncode.yml (moved) * spec/glossary/returnvalue.yml (moved) * spec/glossary/rncb.yml (moved) * spec/glossary/roundrobin.yml (moved) * spec/glossary/rs232.yml (moved) * spec/glossary/rtems.yml (moved) * spec/glossary/running.yml (moved) * spec/glossary/schedulable.yml (moved) * spec/glossary/schedule.yml (moved) * spec/glossary/scheduledtask.yml (moved) * spec/glossary/scheduler.yml (moved) * spec/glossary/schedulerinstance.yml (moved) * spec/glossary/segments.yml (moved) * spec/glossary/semaphore.yml (moved) * spec/glossary/semaphorecontrolblock.yml (moved) * spec/glossary/sharedmemory.yml (moved) * spec/glossary/signal.yml (moved) * spec/glossary/signalset.yml (moved) * spec/glossary/smcb.yml (moved) * spec/glossary/smp.yml (moved) * spec/glossary/smpbarriers.yml (moved) * spec/glossary/smplocks.yml (moved) * spec/glossary/softrealtimesystem.yml (moved) * spec/glossary/softwarecomponent.yml (moved) * spec/glossary/softwareitem.yml (moved) * spec/glossary/softwareproduct.yml (moved) * spec/glossary/softwareunit.yml (moved) * spec/glossary/sourcecode.yml (moved) * spec/glossary/sporadictask.yml (moved) * spec/glossary/stack.yml (moved) * spec/glossary/statuscode.yml (moved) * spec/glossary/suspend.yml (moved) * spec/glossary/synchronous.yml (moved) * spec/glossary/systemcall.yml (moved) * spec/glossary/target.yml (moved) * spec/glossary/tas.yml (moved) * spec/glossary/task.yml (moved) * spec/glossary/taskcontrolblock.yml (moved) * spec/glossary/taskmigration.yml (moved) * spec/glossary/taskprocessoraffinity.yml (moved) * spec/glossary/taskswitch.yml (moved) * spec/glossary/tcb.yml (moved) * spec/glossary/thread.yml (moved) * spec/glossary/threaddispatch.yml (moved) * spec/glossary/tick.yml (moved) * spec/glossary/tightlycoupled.yml (moved) * spec/glossary/timeout.yml (moved) * spec/glossary/timer.yml (moved) * spec/glossary/timercontrolblock.yml (moved) * spec/glossary/timeslice.yml (moved) * spec/glossary/timeslicing.yml (moved) * spec/glossary/tls.yml (moved) * spec/glossary/tmcb.yml (moved) * spec/glossary/transientoverload.yml (moved) * spec/glossary/ttas.yml (moved) * spec/glossary/userextensions.yml (moved) * spec/glossary/userextensiontable.yml (moved) * spec/glossary/userinitializationtaskstable.yml (moved) * spec/glossary/userprovided.yml (moved) * spec/glossary/usersupplied.yml (moved) * spec/glossary/vector.yml (moved) * spec/glossary/waitqueue.yml (moved) * spec/glossary/yaml.yml (moved) * spec/glossary/yield.yml (moved) * spec/spec/interface.yml (modified) * spec/spec/requirement-validation.yml (modified) * spec/spec/root.yml (modified) spec: Move glossary terms The previous structure was a relict of ... Thu, 28 May 2020 08:26:10 GMT Sebastian Huber [51d5741] * spec/spec/requirement-reference-list.yml (added) * spec/spec/requirement-reference-type.yml (added) * spec/spec/requirement-reference.yml (added) * spec/spec/requirement.yml (modified) spec: Add requirement references Thu, 28 May 2020 08:04:45 GMT Sebastian Huber [8832112] * spec/spec/interface.yml (modified) * spec/spec/link.yml (modified) * spec/spec/requirement-validation.yml (modified) * spec/spec/root.yml (modified) spec: Add content from engineering manual Thu, 28 May 2020 06:54:25 GMT Sebastian Huber [614b988] * spec/spec/build-ada-test-program.yml (modified) * spec/spec/build-bsp.yml (modified) * spec/spec/build-config-file.yml (modified) * spec/spec/build-group.yml (modified) * spec/spec/build-library.yml (modified) * spec/spec/build-objects.yml (modified) * spec/spec/build-option.yml (modified) * spec/spec/build-script.yml (modified) * spec/spec/build-start-file.yml (modified) * spec/spec/build-test-program.yml (modified) * spec/spec/enabled-by.yml (modified) * spec/spec/requirement.yml (modified) spec: Add examples Thu, 28 May 2020 06:47:13 GMT Sebastian Huber [f4eac19] * spec/spec/appl-config-option.yml (modified) * spec/spec/interface-description.yml (modified) spec: Reuse interface description and notes Thu, 28 May 2020 06:42:59 GMT Sebastian Huber [adb6e23] * rtemsqual/specverify.py (modified) * spec/spec/requirement-text.yml (modified) specverify: Improve contains operation Thu, 28 May 2020 05:08:55 GMT Sebastian Huber [a469257] * spec/spec/copyright.yml (modified) * spec/spec/requirement-functional-type.yml (modified) * spec/spec/requirement-non-functional-type.yml (modified) * spec/spec/spdx-license-identifier.yml (modified) * spec/spec/spec-assert-float-list.yml (modified) * spec/spec/spec-assert-float.yml (modified) * spec/spec/spec-assert-int-list.yml (modified) * spec/spec/spec-assert-int.yml (modified) * spec/spec/spec-assert-str-list.yml (modified) * spec/spec/spec-assert-str.yml (modified) * spec/spec/spec-attribute-value.yml (modified) * spec/spec/spec-attributes.yml (modified) * spec/spec/spec-bool.yml (modified) * spec/spec/spec-dict.yml (modified) * spec/spec/spec-float.yml (modified) * spec/spec/spec-generic-attributes.yml (modified) * spec/spec/spec-int.yml (modified) * spec/spec/spec-list.yml (modified) * spec/spec/spec-required-attributes.yml (modified) * spec/spec/spec-str.yml (modified) spec: Canonicalize specification of items Wed, 27 May 2020 14:18:19 GMT Sebastian Huber [f313e56] * rtemsqual/specdoc.py (modified) * rtemsqual/tests/spec-doc/root.yml (modified) * rtemsqual/tests/test_specdoc.py (modified) * spec/spec/appl-config-option-constraints.yml (modified) * spec/spec/appl-config-option.yml (modified) * spec/spec/build-action-set-test-state.yml (modified) * spec/spec/build-action.yml (modified) * spec/spec/build-ada-test-program.yml (modified) * spec/spec/build-config-file.yml (modified) * spec/spec/build-include.yml (modified) * spec/spec/build-install-path.yml (modified) * spec/spec/build-library.yml (modified) * spec/spec/build-test-program.yml (modified) * spec/spec/interface-container.yml (modified) * spec/spec/interface-domain.yml (modified) * spec/spec/interface-forward-declaration.yml (modified) * spec/spec/interface-header-file.yml (modified) * spec/spec/requirement-validation.yml (modified) specdoc: Use mapper substitutions for descriptions Wed, 27 May 2020 09:40:06 GMT Sebastian Huber [08c0232] * config.yml (modified) * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/command-line.yml (modified) * rtemsqual/tests/spec-interface/domain-abc.yml (moved) * rtemsqual/tests/spec-interface/domain-c.yml (moved) * rtemsqual/tests/spec-interface/domain-command-line.yml (added) * rtemsqual/tests/spec-interface/h.yml (modified) * rtemsqual/tests/spec-interface/h2.yml (modified) * rtemsqual/tests/spec-interface/h3.yml (modified) * rtemsqual/tests/spec-interface/h4.yml (modified) * rtemsqual/tests/spec-interface/math.yml (modified) * rtemsqual/tests/spec-interface/stdint.yml (modified) * rtemsqual/tests/test_interface.py (modified) * spec/if/build-options/ada.yml (modified) * spec/if/build-options/container.yml (added) * spec/if/build-options/cpuopts.yml (modified) * spec/if/build-options/debug.yml (modified) * spec/if/build-options/drvmgr.yml (modified) * spec/if/build-options/multiprocessing.yml (modified) * spec/if/build-options/networking.yml (modified) * spec/if/build-options/paravirt.yml (modified) * spec/if/build-options/posix.yml (modified) * spec/if/build-options/profiling.yml (modified) * spec/if/build-options/smp.yml (modified) * spec/if/c/stdatomic.yml (modified) * spec/if/c/stdbool.yml (modified) * spec/if/c/stddef.yml (modified) * spec/if/c/stdint.yml (modified) * spec/if/c/string.yml (modified) * spec/if/c/sys-types.yml (modified) * spec/if/c/time.yml (modified) * spec/if/compiler/builtin-choose-expr.yml (modified) * spec/if/compiler/builtin-expect.yml (modified) * spec/if/compiler/builtin-return-address.yml (modified) * spec/if/compiler/builtin-types-compatible-p.yml (modified) * spec/if/compiler/builtin-unreachable.yml (modified) * spec/if/compiler/container.yml (added) * spec/if/compiler/cplusplus.yml (modified) * spec/if/compiler/gnuc.yml (modified) * spec/if/compiler/stdc-version.yml (modified) * spec/if/compiler/typeof.yml (modified) * spec/if/compiler/user-label-prefix.yml (modified) * spec/if/domains/api.yml (added) * spec/if/domains/build-options.yml (added) * spec/if/domains/c.yml (added) * spec/if/domains/compiler.yml (added) * spec/if/domains/implementation.yml (added) * spec/if/domains/use.yml (added) * spec/if/impl/isr/header.yml (modified) * spec/if/impl/memory/header.yml (modified) * spec/if/impl/mpci/header.yml (modified) * spec/if/impl/object/header.yml (modified) * spec/if/impl/smp/header.yml (modified) * spec/if/impl/stack/header.yml (modified) * spec/if/impl/thread/header.yml (modified) * spec/if/impl/userext/header.yml (modified) * spec/if/impl/watchdog/header.yml (modified) * spec/if/impl/wkspace/header.yml (modified) * spec/if/rtems/basedefs/header.yml (modified) * spec/if/rtems/config/header-2.yml (modified) * spec/if/rtems/config/header.yml (modified) * spec/if/rtems/init/header.yml (modified) * spec/if/rtems/status/header.yml (modified) * spec/if/rtems/types/header.yml (modified) * spec/if/use/asm.yml (modified) * spec/if/use/container.yml (moved) * spec/if/use/false.yml (modified) * spec/if/use/true.yml (modified) * spec/spec/interface-container.yml (modified) * spec/spec/interface-domain.yml (added) * spec/spec/interface-header-file.yml (modified) spec: Add interface domain items Wed, 27 May 2020 09:29:14 GMT Sebastian Huber [c58ecfe] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/forward-decl.yml (modified) * spec/spec/interface-forward-declaration.yml (modified) * spec/spec/interface-target.yml (added) spec: Add interface-target link role Wed, 27 May 2020 08:51:43 GMT Sebastian Huber [ea17655] * spec/acfg/opt/constraintbspappmin.yml (modified) * spec/acfg/opt/constraintidlestackarea.yml (modified) * spec/acfg/opt/constraintisrstackalign.yml (modified) * spec/acfg/opt/constraintisrstackarea.yml (modified) * spec/acfg/opt/constraintmemsz.yml (modified) * spec/acfg/opt/constraintposix.yml (modified) * spec/acfg/opt/constraintprioclassic.yml (modified) * spec/acfg/opt/constraintstackspace.yml (modified) * spec/acfg/opt/constraintunlimited.yml (modified) * spec/acfg/opt/constraintwkspace.yml (modified) * spec/spec/constraint-role.yml (added) * spec/spec/constraint.yml (modified) spec: Add dedicated constraint items Tue, 26 May 2020 15:19:07 GMT Sebastian Huber [b211c8d] * spec/spec/requirement-validation-method.yml (added) * spec/spec/requirement-validation-role.yml (added) * spec/spec/requirement-validation.yml (added) spec: Add specification of requirement validation Tue, 26 May 2020 14:08:20 GMT Sebastian Huber [53d462f] * spec/spec/appl-config-group.yml (modified) * spec/spec/appl-config-option-constraints.yml (modified) * spec/spec/appl-config-option-feature-enable.yml (modified) * spec/spec/appl-config-option-feature.yml (modified) * spec/spec/appl-config-option-name.yml (modified) * spec/spec/appl-config-option-value.yml (modified) * spec/spec/appl-config-option.yml (modified) * spec/spec/build-asflag.yml (modified) * spec/spec/build-config-file.yml (modified) * spec/spec/build-config-header.yml (modified) * spec/spec/build-cppflag.yml (modified) * spec/spec/build-group.yml (modified) * spec/spec/build-install.yml (modified) * spec/spec/build-option-name.yml (modified) * spec/spec/build-script.yml (modified) * spec/spec/build-start-file.yml (modified) * spec/spec/build.yml (modified) * spec/spec/glossary-group.yml (modified) * spec/spec/glossary-term.yml (modified) * spec/spec/glossary.yml (modified) * spec/spec/interface-forward-declaration.yml (modified) * spec/spec/interface-include.yml (modified) * spec/spec/interface.yml (modified) * spec/spec/link.yml (modified) * spec/spec/links.yml (modified) * spec/spec/requirement-functional.yml (modified) * spec/spec/requirement-non-functional.yml (modified) * spec/spec/requirement.yml (modified) * spec/spec/root.yml (modified) * spec/spec/spdx-license-identifier.yml (modified) * spec/spec/spec-attribute-value.yml (modified) * spec/spec/spec-bool.yml (modified) * spec/spec/spec-dict.yml (modified) * spec/spec/spec-float.yml (modified) * spec/spec/spec-generic-attributes.yml (modified) * spec/spec/spec-info.yml (modified) * spec/spec/spec-int.yml (modified) * spec/spec/spec-list.yml (modified) * spec/spec/spec-refinement.yml (modified) * spec/spec/spec-str.yml (modified) * spec/spec/spec.yml (modified) spec: Canonicalize specification of specification Tue, 26 May 2020 14:10:36 GMT Sebastian Huber [95c3f2c] * spec/acfg/opt/constraintbspappmin.yml (modified) * spec/acfg/opt/constraintidlestackarea.yml (modified) * spec/acfg/opt/constraintisrstackalign.yml (modified) * spec/acfg/opt/constraintisrstackarea.yml (modified) * spec/acfg/opt/constraintmemsz.yml (modified) * spec/acfg/opt/constraintposix.yml (modified) * spec/acfg/opt/constraintprioclassic.yml (modified) * spec/acfg/opt/constraintstackspace.yml (modified) * spec/acfg/opt/constraintunlimited.yml (modified) * spec/acfg/opt/constraintwkspace.yml (modified) * spec/applconfig.yml (modified) * spec/glossary.yml (modified) * spec/spec/requirement.yml (modified) spec: Add rationale attribute to requirements Tue, 26 May 2020 13:02:04 GMT Sebastian Huber [7dfca46] * rtemsqual/applconfig.py (modified) * rtemsqual/tests/spec-applconfig/c.yml (modified) * rtemsqual/tests/spec-applconfig/h.yml (modified) * rtemsqual/tests/spec-applconfig/k.yml (modified) * spec/acfg/opt/applextradrivers.yml (modified) * spec/acfg/opt/applprerequisitedrivers.yml (modified) * spec/acfg/opt/bdbufbuffermaxsize.yml (modified) * spec/acfg/opt/bspidletaskbody.yml (modified) * spec/acfg/opt/bspinitialextension.yml (modified) * spec/acfg/opt/bspprerequisitedrivers.yml (modified) * spec/acfg/opt/idletaskbody.yml (modified) * spec/acfg/opt/initialextensions.yml (modified) * spec/acfg/opt/inittaskarguments.yml (modified) * spec/acfg/opt/inittaskattributes.yml (modified) * spec/acfg/opt/inittaskentrypoint.yml (modified) * spec/acfg/opt/inittaskinitialmodes.yml (modified) * spec/acfg/opt/inittaskname.yml (modified) * spec/acfg/opt/maxdrivers.yml (modified) * spec/acfg/opt/microsecondspertick.yml (modified) * spec/acfg/opt/mpextraserverstack.yml (modified) * spec/acfg/opt/mpmpcitablepointer.yml (modified) * spec/acfg/opt/posixinitthreadentrypoint.yml (modified) * spec/acfg/opt/recordperprocessoritems.yml (modified) * spec/acfg/opt/schedulerassignments.yml (modified) * spec/acfg/opt/schedulername.yml (modified) * spec/acfg/opt/taskstackallocator.yml (modified) * spec/acfg/opt/taskstackallocatorinit.yml (modified) * spec/acfg/opt/taskstackdeallocator.yml (modified) * spec/acfg/opt/taskstackfromalloc.yml (modified) * spec/acfg/opt/unlimitedallocationsize.yml (modified) * spec/spec/appl-config-option-constraints.yml (modified) * spec/spec/requirement-text-list.yml (added) Rename custom constraints attribute Uses "texts" to be in line with ... Tue, 26 May 2020 12:33:41 GMT Sebastian Huber [325e5bb] * rtemsqual/applconfig.py (modified) * rtemsqual/tests/spec-applconfig/c.yml (modified) * rtemsqual/tests/spec-applconfig/e.yml (modified) * rtemsqual/tests/spec-applconfig/f.yml (modified) * rtemsqual/tests/spec-applconfig/h.yml (modified) * rtemsqual/tests/spec-applconfig/i.yml (modified) * rtemsqual/tests/spec-applconfig/j.yml (modified) * rtemsqual/tests/spec-applconfig/k.yml (modified) * rtemsqual/tests/spec-applconfig/l.yml (modified) * rtemsqual/tests/spec-applconfig/m.yml (modified) * spec/acfg/opt/atadrivertaskpriority.yml (modified) * spec/acfg/opt/bdbufreadaheadtaskpriority.yml (modified) * spec/acfg/opt/bdbuftaskstacksize.yml (modified) * spec/acfg/opt/bspidletaskstacksize.yml (modified) * spec/acfg/opt/bspinterruptstacksize.yml (modified) * spec/acfg/opt/cbsmaximumservers.yml (modified) * spec/acfg/opt/executiveramsize.yml (modified) * spec/acfg/opt/extrataskstacks.yml (modified) * spec/acfg/opt/idletaskstacksize.yml (modified) * spec/acfg/opt/inittaskpriority.yml (modified) * spec/acfg/opt/inittaskstacksize.yml (modified) * spec/acfg/opt/interruptstacksize.yml (modified) * spec/acfg/opt/maxbarriers.yml (modified) * spec/acfg/opt/maxdrivers.yml (modified) * spec/acfg/opt/maxfiledescriptors.yml (modified) * spec/acfg/opt/maxmessagequeues.yml (modified) * spec/acfg/opt/maxpartitions.yml (modified) * spec/acfg/opt/maxperiods.yml (modified) * spec/acfg/opt/maxports.yml (modified) * spec/acfg/opt/maxposixkeys.yml (modified) * spec/acfg/opt/maxposixkeyvaluepairs.yml (modified) * spec/acfg/opt/maxposixmessagequeues.yml (modified) * spec/acfg/opt/maxposixqueuedsignals.yml (modified) * spec/acfg/opt/maxposixsemaphores.yml (modified) * spec/acfg/opt/maxposixshms.yml (modified) * spec/acfg/opt/maxposixthreads.yml (modified) * spec/acfg/opt/maxposixtimers.yml (modified) * spec/acfg/opt/maxregions.yml (modified) * spec/acfg/opt/maxsemaphores.yml (modified) * spec/acfg/opt/maxtasks.yml (modified) * spec/acfg/opt/maxthreadnamesize.yml (modified) * spec/acfg/opt/maxtimers.yml (modified) * spec/acfg/opt/maxuserextensions.yml (modified) * spec/acfg/opt/memoryoverhead.yml (modified) * spec/acfg/opt/messagebuffermemory.yml (modified) * spec/acfg/opt/minposixthreadstacksize.yml (modified) * spec/acfg/opt/mintaskstacksize.yml (modified) * spec/acfg/opt/posixinitthreadstacksize.yml (modified) * spec/acfg/opt/recordperprocessoritems.yml (modified) * spec/acfg/opt/swapouttaskpriority.yml (modified) * spec/acfg/opt/swapoutworkertaskpriority.yml (modified) * spec/spec/appl-config-option-constraints.yml (modified) * spec/spec/constraint.yml (added) Add constraint link role Tue, 26 May 2020 12:20:52 GMT Sebastian Huber [92ea0a0] * rtemsqual/applconfig.py (modified) * rtemsqual/tests/spec-applconfig/a.yml (modified) * rtemsqual/tests/spec-applconfig/b.yml (modified) * rtemsqual/tests/spec-applconfig/c.yml (modified) * rtemsqual/tests/spec-applconfig/e.yml (modified) * rtemsqual/tests/spec-applconfig/f.yml (modified) * rtemsqual/tests/spec-applconfig/g.yml (modified) * rtemsqual/tests/spec-applconfig/h.yml (modified) * rtemsqual/tests/spec-applconfig/i.yml (modified) * rtemsqual/tests/spec-applconfig/j.yml (modified) * rtemsqual/tests/spec-applconfig/k.yml (modified) * rtemsqual/tests/spec-applconfig/l.yml (modified) * rtemsqual/tests/spec-applconfig/m.yml (modified) * spec/acfg/bdbuf.yml (modified) * spec/acfg/bsp.yml (modified) * spec/acfg/classic.yml (modified) * spec/acfg/classicinit.yml (modified) * spec/acfg/devdrv.yml (modified) * spec/acfg/eventrecord.yml (modified) * spec/acfg/filesystem.yml (modified) * spec/acfg/general.yml (modified) * spec/acfg/idle.yml (modified) * spec/acfg/mpci.yml (modified) * spec/acfg/opt/appldisablefilesystem.yml (modified) * spec/acfg/opt/appldoesnotneedclockdriver.yml (modified) * spec/acfg/opt/applextradrivers.yml (modified) * spec/acfg/opt/applneedsatadriver.yml (modified) * spec/acfg/opt/applneedsclockdriver.yml (modified) * spec/acfg/opt/applneedsconsoledriver.yml (modified) * spec/acfg/opt/applneedsframebufferdriver.yml (modified) * spec/acfg/opt/applneedsidedriver.yml (modified) * spec/acfg/opt/applneedslibblock.yml (modified) * spec/acfg/opt/applneedsnulldriver.yml (modified) * spec/acfg/opt/applneedsrtcdriver.yml (modified) * spec/acfg/opt/applneedssimpleconsoledriver.yml (modified) * spec/acfg/opt/applneedssimpletaskconsoledriver.yml (modified) * spec/acfg/opt/applneedsstubdriver.yml (modified) * spec/acfg/opt/applneedstimerdriver.yml (modified) * spec/acfg/opt/applneedswatchdogdriver.yml (modified) * spec/acfg/opt/applneedszerodriver.yml (modified) * spec/acfg/opt/applprerequisitedrivers.yml (modified) * spec/acfg/opt/atadrivertaskpriority.yml (modified) * spec/acfg/opt/bdbufbuffermaxsize.yml (modified) * spec/acfg/opt/bdbufbufferminsize.yml (modified) * spec/acfg/opt/bdbufcachememorysize.yml (modified) * spec/acfg/opt/bdbufmaxreadaheadblocks.yml (modified) * spec/acfg/opt/bdbufmaxwriteblocks.yml (modified) * spec/acfg/opt/bdbufreadaheadtaskpriority.yml (modified) * spec/acfg/opt/bdbuftaskstacksize.yml (modified) * spec/acfg/opt/bspidletaskbody.yml (modified) * spec/acfg/opt/bspidletaskstacksize.yml (modified) * spec/acfg/opt/bspinitialextension.yml (modified) * spec/acfg/opt/bspinterruptstacksize.yml (modified) * spec/acfg/opt/bspprerequisitedrivers.yml (modified) * spec/acfg/opt/cbsmaximumservers.yml (modified) * spec/acfg/opt/dirtymemory.yml (modified) * spec/acfg/opt/disablebspsettings.yml (modified) * spec/acfg/opt/disablenewlibreentrancy.yml (modified) * spec/acfg/opt/executiveramsize.yml (modified) * spec/acfg/opt/extrataskstacks.yml (modified) * spec/acfg/opt/filesystemall.yml (modified) * spec/acfg/opt/filesystemdosfs.yml (modified) * spec/acfg/opt/filesystemftpfs.yml (modified) * spec/acfg/opt/filesystemimfs.yml (modified) * spec/acfg/opt/filesystemjffs2.yml (modified) * spec/acfg/opt/filesystemnfs.yml (modified) * spec/acfg/opt/filesystemrfs.yml (modified) * spec/acfg/opt/filesystemtftpfs.yml (modified) * spec/acfg/opt/idletaskbody.yml (modified) * spec/acfg/opt/idletaskinitappl.yml (modified) * spec/acfg/opt/idletaskstacksize.yml (modified) * spec/acfg/opt/imfsdisablechmod.yml (modified) * spec/acfg/opt/imfsdisablechown.yml (modified) * spec/acfg/opt/imfsdisablelink.yml (modified) * spec/acfg/opt/imfsdisablemknod.yml (modified) * spec/acfg/opt/imfsdisablemknoddevice.yml (modified) * spec/acfg/opt/imfsdisablemknodfile.yml (modified) * spec/acfg/opt/imfsdisablemount.yml (modified) * spec/acfg/opt/imfsdisablereaddir.yml (modified) * spec/acfg/opt/imfsdisablereadlink.yml (modified) * spec/acfg/opt/imfsdisablerename.yml (modified) * spec/acfg/opt/imfsdisablermnod.yml (modified) * spec/acfg/opt/imfsdisablesymlink.yml (modified) * spec/acfg/opt/imfsdisableunmount.yml (modified) * spec/acfg/opt/imfsdisableutime.yml (modified) * spec/acfg/opt/imfsenablemkfifo.yml (modified) * spec/acfg/opt/imfsmemfilebytesperblock.yml (modified) * spec/acfg/opt/initialextensions.yml (modified) * spec/acfg/opt/inittaskarguments.yml (modified) * spec/acfg/opt/inittaskattributes.yml (modified) * spec/acfg/opt/inittaskentrypoint.yml (modified) * spec/acfg/opt/inittaskinitialmodes.yml (modified) * spec/acfg/opt/inittaskname.yml (modified) * spec/acfg/opt/inittaskpriority.yml (modified) * spec/acfg/opt/inittaskstacksize.yml (modified) * spec/acfg/opt/interruptstacksize.yml (modified) * spec/acfg/opt/mallocbspsupportssbrk.yml (modified) * spec/acfg/opt/mallocdirty.yml (modified) * spec/acfg/opt/maxbarriers.yml (modified) * spec/acfg/opt/maxdrivers.yml (modified) * spec/acfg/opt/maxfiledescriptors.yml (modified) * spec/acfg/opt/maxmessagequeues.yml (modified) * spec/acfg/opt/maxpartitions.yml (modified) * spec/acfg/opt/maxperiods.yml (modified) * spec/acfg/opt/maxports.yml (modified) * spec/acfg/opt/maxposixkeys.yml (modified) * spec/acfg/opt/maxposixkeyvaluepairs.yml (modified) * spec/acfg/opt/maxposixmessagequeues.yml (modified) * spec/acfg/opt/maxposixqueuedsignals.yml (modified) * spec/acfg/opt/maxposixsemaphores.yml (modified) * spec/acfg/opt/maxposixshms.yml (modified) * spec/acfg/opt/maxposixthreads.yml (modified) * spec/acfg/opt/maxposixtimers.yml (modified) * spec/acfg/opt/maxpriority.yml (modified) * spec/acfg/opt/maxprocessors.yml (modified) * spec/acfg/opt/maxregions.yml (modified) * spec/acfg/opt/maxsemaphores.yml (modified) * spec/acfg/opt/maxtasks.yml (modified) * spec/acfg/opt/maxthreadnamesize.yml (modified) * spec/acfg/opt/maxtimers.yml (modified) * spec/acfg/opt/maxuserextensions.yml (modified) * spec/acfg/opt/memoryoverhead.yml (modified) * spec/acfg/opt/messagebuffermemory.yml (modified) * spec/acfg/opt/microsecondspertick.yml (modified) * spec/acfg/opt/minposixthreadstacksize.yml (modified) * spec/acfg/opt/mintaskstacksize.yml (modified) * spec/acfg/opt/mpappl.yml (modified) * spec/acfg/opt/mpextraserverstack.yml (modified) * spec/acfg/opt/mpmaxglobalobjects.yml (modified) * spec/acfg/opt/mpmaxnodes.yml (modified) * spec/acfg/opt/mpmaxproxies.yml (modified) * spec/acfg/opt/mpmpcitablepointer.yml (modified) * spec/acfg/opt/mpnodenumber.yml (modified) * spec/acfg/opt/posixinitthreadentrypoint.yml (modified) * spec/acfg/opt/posixinitthreadstacksize.yml (modified) * spec/acfg/opt/posixinitthreadtable.yml (modified) * spec/acfg/opt/recordextensionsenabled.yml (modified) * spec/acfg/opt/recordfataldumpbase64.yml (modified) * spec/acfg/opt/recordfataldumpbase64zlib.yml (modified) * spec/acfg/opt/recordperprocessoritems.yml (modified) * spec/acfg/opt/rtemsinittaskstable.yml (modified) * spec/acfg/opt/schedulerassignments.yml (modified) * spec/acfg/opt/schedulercbs.yml (modified) * spec/acfg/opt/scheduleredf.yml (modified) * spec/acfg/opt/scheduleredfsmp.yml (modified) * spec/acfg/opt/schedulername.yml (modified) * spec/acfg/opt/schedulerpriority.yml (modified) * spec/acfg/opt/schedulerpriorityaffinitysmp.yml (modified) * spec/acfg/opt/schedulerprioritysmp.yml (modified) * spec/acfg/opt/schedulersimple.yml (modified) * spec/acfg/opt/schedulersimplesmp.yml (modified) * spec/acfg/opt/schedulerstrongapa.yml (modified) * spec/acfg/opt/scheduleruser.yml (modified) * spec/acfg/opt/stackcheckerenabled.yml (modified) * spec/acfg/opt/swapoutblockhold.yml (modified) * spec/acfg/opt/swapoutswapperiod.yml (modified) * spec/acfg/opt/swapouttaskpriority.yml (modified) * spec/acfg/opt/swapoutworkertaskpriority.yml (modified) * spec/acfg/opt/swapoutworkertasks.yml (modified) * spec/acfg/opt/taskstackallocator.yml (modified) * spec/acfg/opt/taskstackallocatorinit.yml (modified) * spec/acfg/opt/taskstackdeallocator.yml (modified) * spec/acfg/opt/taskstackfromalloc.yml (modified) * spec/acfg/opt/taskstacknowkspace.yml (modified) * spec/acfg/opt/tickspertimeslice.yml (modified) * spec/acfg/opt/unifiedworkareas.yml (modified) * spec/acfg/opt/unlimitedallocationsize.yml (modified) * spec/acfg/opt/unlimitedobjects.yml (modified) * spec/acfg/opt/usedevfsasbasefilesystem.yml (modified) * spec/acfg/opt/useminiimfsasbasefilesystem.yml (modified) * spec/acfg/opt/verbosesysteminit.yml (modified) * spec/acfg/opt/zeroworkspaceautomatically.yml (modified) * spec/acfg/posix.yml (modified) * spec/acfg/posixinit.yml (modified) * spec/acfg/schedgeneral.yml (modified) * spec/acfg/stackalloc.yml (modified) * spec/spec/appl-config-group.yml (modified) * spec/spec/appl-config-option-constraints.yml (moved) * spec/spec/appl-config-option-feature.yml (modified) * spec/spec/appl-config-option-value.yml (modified) * spec/spec/appl-config-option.yml (modified) Rename application configuration attributes Tue, 26 May 2020 06:33:20 GMT Sebastian Huber [d8f8125] * spec/spec/test-case-action-list.yml (added) * spec/spec/test-case-action.yml (added) * spec/spec/test-case-check-list.yml (added) * spec/spec/test-case-check.yml (added) * spec/spec/test-case.yml (added) * spec/spec/test-name.yml (added) * spec/spec/test-suite.yml (added) spec: Add specification of test items Mon, 25 May 2020 07:42:37 GMT Sebastian Huber [06c7b22] * spec/spec/interface-brief.yml (added) * spec/spec/interface-compound-definition-kind.yml (added) * spec/spec/interface-compound.yml (added) * spec/spec/interface-container.yml (added) * spec/spec/interface-define.yml (added) * spec/spec/interface-definition-directive.yml (added) * spec/spec/interface-definition-variant-list.yml (added) * spec/spec/interface-definition-variant.yml (added) * spec/spec/interface-definition.yml (added) * spec/spec/interface-description.yml (added) * spec/spec/interface-enabled-by-list.yml (added) * spec/spec/interface-enabled-by.yml (added) * spec/spec/interface-enum-definition-kind.yml (added) * spec/spec/interface-enum.yml (added) * spec/spec/interface-enumerator-role.yml (added) * spec/spec/interface-enumerator.yml (added) * spec/spec/interface-forward-declaration.yml (added) * spec/spec/interface-function-definition-directive.yml (added) * spec/spec/interface-function-definition-variant-list.yml (added) * spec/spec/interface-function-definition-variant.yml (added) * spec/spec/interface-function-definition.yml (added) * spec/spec/interface-function.yml (added) * spec/spec/interface-group.yml (modified) * spec/spec/interface-header-file.yml (added) * spec/spec/interface-macro.yml (added) * spec/spec/interface-member-compound.yml (added) * spec/spec/interface-member-declaration.yml (added) * spec/spec/interface-member-definition-directive-list.yml (added) * spec/spec/interface-member-definition-directive.yml (added) * spec/spec/interface-member-definition-variant-list.yml (added) * spec/spec/interface-member-definition-variant.yml (added) * spec/spec/interface-member-definition.yml (added) * spec/spec/interface-notes.yml (added) * spec/spec/interface-param-dir.yml (added) * spec/spec/interface-param-list.yml (added) * spec/spec/interface-param.yml (added) * spec/spec/interface-return-directive.yml (added) * spec/spec/interface-return-value-list.yml (added) * spec/spec/interface-return-value.yml (added) * spec/spec/interface-typedef.yml (added) * spec/spec/interface-unspecified.yml (added) * spec/spec/interface-variable.yml (added) spec: Add specification of interface items Mon, 25 May 2020 07:29:03 GMT Sebastian Huber [37d648b] * spec/spec/interface-group-identifier.yml (added) * spec/spec/interface-group.yml (added) spec: Add specification of interface group items Mon, 25 May 2020 11:22:56 GMT Sebastian Huber [adb26ed] * spec/glos/term/abi.yml (modified) * spec/glos/term/active.yml (modified) * spec/glos/term/aperiodictask.yml (modified) * spec/glos/term/api.yml (modified) * spec/glos/term/application.yml (modified) * spec/glos/term/asr.yml (modified) * spec/glos/term/assemblerlanguage.yml (modified) * spec/glos/term/asynchronous.yml (modified) * spec/glos/term/asynchronoussignalroutine.yml (modified) * spec/glos/term/atomicoperations.yml (modified) * spec/glos/term/awakened.yml (modified) * spec/glos/term/bigendian.yml (modified) * spec/glos/term/bitmapped.yml (modified) * spec/glos/term/block.yml (modified) * spec/glos/term/blockedtask.yml (modified) * spec/glos/term/boardsupportpackage.yml (modified) * spec/glos/term/broadcast.yml (modified) * spec/glos/term/bsp.yml (modified) * spec/glos/term/buffer.yml (modified) * spec/glos/term/c11.yml (modified) * spec/glos/term/callingconvention.yml (modified) * spec/glos/term/ccb.yml (modified) * spec/glos/term/centralprocessingunit.yml (modified) * spec/glos/term/chain.yml (modified) * spec/glos/term/clanguage.yml (modified) * spec/glos/term/cluster.yml (modified) * spec/glos/term/coalesce.yml (modified) * spec/glos/term/configurationtable.yml (modified) * spec/glos/term/context.yml (modified) * spec/glos/term/contextswitch.yml (modified) * spec/glos/term/controlblock.yml (modified) * spec/glos/term/core.yml (modified) * spec/glos/term/cpu.yml (modified) * spec/glos/term/criticalsection.yml (modified) * spec/glos/term/crt.yml (modified) * spec/glos/term/cxx11.yml (modified) * spec/glos/term/deadline.yml (modified) * spec/glos/term/device.yml (modified) * spec/glos/term/devicedriver.yml (modified) * spec/glos/term/devicedrivertable.yml (modified) * spec/glos/term/directives.yml (modified) * spec/glos/term/dispatch.yml (modified) * spec/glos/term/doorstop.yml (modified) * spec/glos/term/dormant.yml (modified) * spec/glos/term/dualported.yml (modified) * spec/glos/term/ears.yml (modified) * spec/glos/term/elf.yml (modified) * spec/glos/term/embedded.yml (modified) * spec/glos/term/entrypoint.yml (modified) * spec/glos/term/envelope.yml (modified) * spec/glos/term/errorcode.yml (modified) * spec/glos/term/events.yml (modified) * spec/glos/term/exception.yml (modified) * spec/glos/term/executingtask.yml (modified) * spec/glos/term/executive.yml (modified) * spec/glos/term/exported.yml (modified) * spec/glos/term/externaladdress.yml (modified) * spec/glos/term/fifo.yml (modified) * spec/glos/term/firstinfirstout.yml (modified) * spec/glos/term/floatingpointcoprocessor.yml (modified) * spec/glos/term/freed.yml (modified) * spec/glos/term/gcc.yml (modified) * spec/glos/term/global.yml (modified) * spec/glos/term/gnat.yml (modified) * spec/glos/term/gnu.yml (modified) * spec/glos/term/handler.yml (modified) * spec/glos/term/hardrealtimesystem.yml (modified) * spec/glos/term/heap.yml (modified) * spec/glos/term/heirtask.yml (modified) * spec/glos/term/heterogeneous.yml (modified) * spec/glos/term/homogeneous.yml (modified) * spec/glos/term/id.yml (modified) * spec/glos/term/idletask.yml (modified) * spec/glos/term/interface.yml (modified) * spec/glos/term/internaladdress.yml (modified) * spec/glos/term/interrupt.yml (modified) * spec/glos/term/interruptlevel.yml (modified) * spec/glos/term/interruptservice.yml (modified) * spec/glos/term/interruptserviceroutine.yml (modified) * spec/glos/term/io.yml (modified) * spec/glos/term/isr.yml (modified) * spec/glos/term/isvv.yml (modified) * spec/glos/term/kernel.yml (modified) * spec/glos/term/list.yml (modified) * spec/glos/term/littleendian.yml (modified) * spec/glos/term/local.yml (modified) * spec/glos/term/localoperation.yml (modified) * spec/glos/term/logicaladdress.yml (modified) * spec/glos/term/looselycoupled.yml (modified) * spec/glos/term/majornumber.yml (modified) * spec/glos/term/manager.yml (modified) * spec/glos/term/mcs.yml (modified) * spec/glos/term/memorypool.yml (modified) * spec/glos/term/message.yml (modified) * spec/glos/term/messagebuffer.yml (modified) * spec/glos/term/messagequeue.yml (modified) * spec/glos/term/messagequeuecontrolblock.yml (modified) * spec/glos/term/minornumber.yml (modified) * spec/glos/term/mode.yml (modified) * spec/glos/term/mpci.yml (modified) * spec/glos/term/multiprocessing.yml (modified) * spec/glos/term/multiprocessor.yml (modified) * spec/glos/term/multiprocessorcommunicationsinterfacelayer.yml (modified) * spec/glos/term/multiprocessorconfigurationtable.yml (modified) * spec/glos/term/multitasking.yml (modified) * spec/glos/term/mutualexclusion.yml (modified) * spec/glos/term/nested.yml (modified) * spec/glos/term/node.yml (modified) * spec/glos/term/nonexistent.yml (modified) * spec/glos/term/numa.yml (modified) * spec/glos/term/numericcoprocessor.yml (modified) * spec/glos/term/object.yml (modified) * spec/glos/term/objectoriented.yml (modified) * spec/glos/term/operatingsystem.yml (modified) * spec/glos/term/overhead.yml (modified) * spec/glos/term/packet.yml (modified) * spec/glos/term/partition.yml (modified) * spec/glos/term/partitioncontrolblock.yml (modified) * spec/glos/term/pending.yml (modified) * spec/glos/term/periodictask.yml (modified) * spec/glos/term/physicaladdress.yml (modified) * spec/glos/term/poll.yml (modified) * spec/glos/term/pool.yml (modified) * spec/glos/term/portability.yml (modified) * spec/glos/term/posting.yml (modified) * spec/glos/term/preempt.yml (modified) * spec/glos/term/priority.yml (modified) * spec/glos/term/priorityboosting.yml (modified) * spec/glos/term/priorityinheritance.yml (modified) * spec/glos/term/priorityinversion.yml (modified) * spec/glos/term/processorutilization.yml (modified) * spec/glos/term/proxy.yml (modified) * spec/glos/term/proxycontrolblock.yml (modified) * spec/glos/term/ptcb.yml (modified) * spec/glos/term/pxcb.yml (modified) * spec/glos/term/qcb.yml (modified) * spec/glos/term/quantum.yml (modified) * spec/glos/term/queue.yml (modified) * spec/glos/term/readytask.yml (modified) * spec/glos/term/realtime.yml (modified) * spec/glos/term/reentrant.yml (modified) * spec/glos/term/region.yml (modified) * spec/glos/term/regioncontrolblock.yml (modified) * spec/glos/term/registers.yml (modified) * spec/glos/term/remote.yml (modified) * spec/glos/term/remoteoperation.yml (modified) * spec/glos/term/reqif.yml (modified) * spec/glos/term/resource.yml (modified) * spec/glos/term/resume.yml (modified) * spec/glos/term/returncode.yml (modified) * spec/glos/term/returnvalue.yml (modified) * spec/glos/term/rncb.yml (modified) * spec/glos/term/roundrobin.yml (modified) * spec/glos/term/rs232.yml (modified) * spec/glos/term/rtems.yml (modified) * spec/glos/term/running.yml (modified) * spec/glos/term/schedulable.yml (modified) * spec/glos/term/schedule.yml (modified) * spec/glos/term/scheduledtask.yml (modified) * spec/glos/term/scheduler.yml (modified) * spec/glos/term/schedulerinstance.yml (modified) * spec/glos/term/segments.yml (modified) * spec/glos/term/semaphore.yml (modified) * spec/glos/term/semaphorecontrolblock.yml (modified) * spec/glos/term/sharedmemory.yml (modified) * spec/glos/term/signal.yml (modified) * spec/glos/term/signalset.yml (modified) * spec/glos/term/smcb.yml (modified) * spec/glos/term/smp.yml (modified) * spec/glos/term/smpbarriers.yml (modified) * spec/glos/term/smplocks.yml (modified) * spec/glos/term/softrealtimesystem.yml (modified) * spec/glos/term/softwarecomponent.yml (modified) * spec/glos/term/softwareitem.yml (modified) * spec/glos/term/softwareproduct.yml (modified) * spec/glos/term/softwareunit.yml (modified) * spec/glos/term/sourcecode.yml (modified) * spec/glos/term/sporadictask.yml (modified) * spec/glos/term/stack.yml (modified) * spec/glos/term/statuscode.yml (modified) * spec/glos/term/suspend.yml (modified) * spec/glos/term/synchronous.yml (modified) * spec/glos/term/systemcall.yml (modified) * spec/glos/term/target.yml (modified) * spec/glos/term/tas.yml (modified) * spec/glos/term/task.yml (modified) * spec/glos/term/taskcontrolblock.yml (modified) * spec/glos/term/taskmigration.yml (modified) * spec/glos/term/taskprocessoraffinity.yml (modified) * spec/glos/term/taskswitch.yml (modified) * spec/glos/term/tcb.yml (modified) * spec/glos/term/thread.yml (modified) * spec/glos/term/threaddispatch.yml (modified) * spec/glos/term/tick.yml (modified) * spec/glos/term/tightlycoupled.yml (modified) * spec/glos/term/timeout.yml (modified) * spec/glos/term/timer.yml (modified) * spec/glos/term/timercontrolblock.yml (modified) * spec/glos/term/timeslice.yml (modified) * spec/glos/term/timeslicing.yml (modified) * spec/glos/term/tls.yml (modified) * spec/glos/term/tmcb.yml (modified) * spec/glos/term/transientoverload.yml (modified) * spec/glos/term/ttas.yml (modified) * spec/glos/term/userextensions.yml (modified) * spec/glos/term/userextensiontable.yml (modified) * spec/glos/term/userinitializationtaskstable.yml (modified) * spec/glos/term/userprovided.yml (modified) * spec/glos/term/usersupplied.yml (modified) * spec/glos/term/vector.yml (modified) * spec/glos/term/waitqueue.yml (modified) * spec/glos/term/yaml.yml (modified) * spec/glos/term/yield.yml (modified) * spec/spec/build-action-check-cc.yml (modified) * spec/spec/build-action-check-cxx.yml (modified) * spec/spec/build-action-set-test-state.yml (modified) * spec/spec/build-action.yml (modified) * spec/spec/build-config-header.yml (modified) * spec/spec/build-default-by-variant.yml (modified) * spec/spec/build-option.yml (modified) * spec/spec/build-script.yml (modified) * spec/spec/requirement.yml (modified) spec: Sort attributes Mon, 25 May 2020 06:48:50 GMT Sebastian Huber [f9cff66] * spec/glos/general.yml (modified) * spec/glossary.yml (modified) * spec/spec/glossary-group.yml (added) * spec/spec/glossary-term.yml (added) * spec/spec/glossary.yml (added) * spec/spec/requirement-non-functional-type.yml (modified) spec: Add specification of glossary items Fri, 22 May 2020 16:33:19 GMT Sebastian Huber [2a2fd6d] * spec/spec/bool-or-int-or-str.yml (added) * spec/spec/build-action-check-cc.yml (added) * spec/spec/build-action-check-cxx.yml (added) * spec/spec/build-action-list.yml (added) * spec/spec/build-action-set-test-state.yml (added) * spec/spec/build-action.yml (added) * spec/spec/build-ada-test-program.yml (added) * spec/spec/build-asflag.yml (added) * spec/spec/build-asflags.yml (added) * spec/spec/build-bsp.yml (modified) * spec/spec/build-config-file.yml (added) * spec/spec/build-config-header.yml (added) * spec/spec/build-default-by-variant-list.yml (added) * spec/spec/build-default-by-variant.yml (added) * spec/spec/build-group.yml (added) * spec/spec/build-include.yml (modified) * spec/spec/build-install-path.yml (added) * spec/spec/build-ldflag.yml (added) * spec/spec/build-ldflags.yml (added) * spec/spec/build-library.yml (added) * spec/spec/build-objects.yml (added) * spec/spec/build-option-name.yml (added) * spec/spec/build-option-value.yml (added) * spec/spec/build-option.yml (added) * spec/spec/build-script.yml (added) * spec/spec/build-start-file.yml (added) * spec/spec/build-target.yml (added) * spec/spec/build-test-program.yml (added) * spec/spec/build-test-state.yml (added) * spec/spec/build-use-after-list.yml (added) * spec/spec/build-use-after.yml (added) * spec/spec/build-use-before-list.yml (added) * spec/spec/build-use-before.yml (added) spec: Add specification of build items Thu, 21 May 2020 13:10:43 GMT Sebastian Huber [b75c6be] * spec/spec/appl-config-group-member.yml (added) * spec/spec/appl-config-group.yml (added) * spec/spec/appl-config-option-constraint.yml (added) * spec/spec/appl-config-option-feature-enable.yml (added) * spec/spec/appl-config-option-feature.yml (added) * spec/spec/appl-config-option-name.yml (added) * spec/spec/appl-config-option-value.yml (added) * spec/spec/appl-config-option.yml (added) * spec/spec/build-bsp.yml (added) * spec/spec/build-cflag.yml (added) * spec/spec/build-cflags.yml (added) * spec/spec/build-cppflag.yml (added) * spec/spec/build-cppflags.yml (added) * spec/spec/build-cxxflag.yml (added) * spec/spec/build-cxxflags.yml (added) * spec/spec/build-dependency.yml (added) * spec/spec/build-include.yml (added) * spec/spec/build-includes.yml (added) * spec/spec/build-install-list.yml (added) * spec/spec/build-install.yml (added) * spec/spec/build-source-list.yml (added) * spec/spec/build-source.yml (added) * spec/spec/build.yml (added) * spec/spec/glossary-member.yml (added) * spec/spec/int-or-str.yml (added) * spec/spec/interface-include.yml (added) * spec/spec/interface-ingroup.yml (added) * spec/spec/interface-placement.yml (added) * spec/spec/interface.yml (added) * spec/spec/list-int-or-str.yml (added) * spec/spec/list-str.yml (modified) * spec/spec/list-uid.yml (added) * spec/spec/requirement-functional-type.yml (added) * spec/spec/requirement-functional.yml (added) * spec/spec/requirement-non-functional-type.yml (added) * spec/spec/requirement-non-functional.yml (added) * spec/spec/requirement-refinement.yml (added) * spec/spec/requirement-text.yml (added) * spec/spec/requirement.yml (added) * spec/spec/spec-member.yml (modified) * spec/spec/spec-refinement.yml (modified) spec: Add specification of specification items Fri, 22 May 2020 08:34:35 GMT Sebastian Huber [e12cfeb] * rtemsqual/tests/spec-verify/spec/spdx-license-identifier.yml (modified) * spec/spec/spdx-license-identifier.yml (modified) spec: Fix description Mon, 18 May 2020 08:20:58 GMT Sebastian Huber [b9f3aa7] * spec/spec/copyright.yml (added) * spec/spec/copyrights.yml (added) * spec/spec/enabled-by-list.yml (added) * spec/spec/enabled-by.yml (added) * spec/spec/link.yml (added) * spec/spec/links.yml (added) * spec/spec/list-str.yml (added) * spec/spec/optional-str.yml (added) * spec/spec/root.yml (added) * spec/spec/spdx-license-identifier.yml (added) * spec/spec/spec-assert-float-list.yml (added) * spec/spec/spec-assert-float.yml (added) * spec/spec/spec-assert-int-list.yml (added) * spec/spec/spec-assert-int.yml (added) * spec/spec/spec-assert-str-list.yml (added) * spec/spec/spec-assert-str.yml (added) * spec/spec/spec-attribute-value.yml (added) * spec/spec/spec-attributes.yml (added) * spec/spec/spec-bool.yml (added) * spec/spec/spec-dict.yml (added) * spec/spec/spec-float.yml (added) * spec/spec/spec-generic-attributes.yml (added) * spec/spec/spec-info.yml (added) * spec/spec/spec-int.yml (added) * spec/spec/spec-list.yml (added) * spec/spec/spec-member.yml (added) * spec/spec/spec-refinement.yml (added) * spec/spec/spec-required-attributes.yml (added) * spec/spec/spec-str.yml (added) * spec/spec/spec.yml (added) spec: Add specification of specification items
