# # ChangeLog for spec/rtems/message in rtems-central # # Generated by Trac 1.2.1.dev0 # 05/06/24 02:47:11 Wed, 30 Sep 2020 15:05:45 GMT Sebastian Huber [a5428a7] * spec/rtems/message/req/construct-errors.yml (modified) * spec/rtems/task/req/construct-errors.yml (modified) spec: Canonicalize name and id checks Wed, 30 Sep 2020 10:44:44 GMT Sebastian Huber [f253c3a] * spec/rtems/barrier/req/ident.yml (modified) * spec/rtems/message/req/ident.yml (modified) * spec/rtems/part/req/ident.yml (modified) * spec/rtems/ratemon/req/ident.yml (modified) * spec/rtems/sem/req/ident.yml (modified) * spec/rtems/task/req/ident.yml (modified) * spec/rtems/timer/req/ident.yml (modified) * spec/rtems/userext/req/ident.yml (modified) spec: Fix references in text attributes Mon, 28 Sep 2020 11:27:14 GMT Sebastian Huber [cfbad2a] * spec/rtems/message/val/ident.yml (modified) spec: Use rtems_message_queue_construct() Fri, 25 Sep 2020 07:02:19 GMT Sebastian Huber [ca758d1] * spec/rtems/message/if/buffer.yml (added) * spec/rtems/message/if/config.yml (added) * spec/rtems/message/if/construct.yml (added) * spec/rtems/message/req/construct-errors.yml (added) * spec/score/msgq/if/buffer.yml (added) * spec/score/msgq/if/header.yml (added) * spec/score/msgq/if/header2.yml (added) spec: Add rtems_message_queue_construct() Fri, 18 Sep 2020 08:12:48 GMT Sebastian Huber [a1c17c5] * spec/rtems/barrier/val/ident.yml (modified) * spec/rtems/message/val/ident.yml (modified) * spec/rtems/part/val/ident.yml (modified) * spec/rtems/ratemon/val/ident.yml (modified) * spec/rtems/sem/val/ident.yml (modified) * spec/rtems/task/req/ident.yml (modified) * spec/rtems/timer/val/ident.yml (modified) * spec/rtems/userext/val/ident.yml (modified) spec: Delete resources in validation tests Wed, 16 Sep 2020 09:48:29 GMT Sebastian Huber [3bdf817] * config.yml (modified) * spec/acfg/if/appl-disable-filesystem.yml (added) * spec/acfg/if/appl-does-not-need-clock-driver.yml (moved) * spec/acfg/if/appl-extra-drivers.yml (added) * spec/acfg/if/appl-needs-ata-driver.yml (moved) * spec/acfg/if/appl-needs-clock-driver.yml (moved) * spec/acfg/if/appl-needs-console-driver.yml (added) * spec/acfg/if/appl-needs-framebuffer-driver.yml (moved) * spec/acfg/if/appl-needs-ide-driver.yml (moved) * spec/acfg/if/appl-needs-libblock.yml (moved) * spec/acfg/if/appl-needs-null-driver.yml (moved) * spec/acfg/if/appl-needs-rtc-driver.yml (moved) * spec/acfg/if/appl-needs-simple-console-driver.yml (added) * spec/acfg/if/appl-needs-simple-task-console-driver.yml (added) * spec/acfg/if/appl-needs-stub-driver.yml (moved) * spec/acfg/if/appl-needs-timer-driver.yml (moved) * spec/acfg/if/appl-needs-watchdog-driver.yml (moved) * spec/acfg/if/appl-needs-zero-driver.yml (moved) * spec/acfg/if/appl-prerequisite-drivers.yml (added) * spec/acfg/if/ata-driver-task-priority.yml (moved) * spec/acfg/if/bdbuf-buffer-max-size.yml (moved) * spec/acfg/if/bdbuf-buffer-min-size.yml (added) * spec/acfg/if/bdbuf-cache-memory-size.yml (added) * spec/acfg/if/bdbuf-max-read-ahead-blocks.yml (added) * spec/acfg/if/bdbuf-max-write-blocks.yml (added) * spec/acfg/if/bdbuf-read-ahead-task-priority.yml (moved) * spec/acfg/if/bdbuf-swapout-block-hold.yml (added) * spec/acfg/if/bdbuf-swapout-swap-period.yml (added) * spec/acfg/if/bdbuf-swapout-task-priority.yml (moved) * spec/acfg/if/bdbuf-swapout-worker-taskp-riority.yml (moved) * spec/acfg/if/bdbuf-swapout-worker-tasks.yml (added) * spec/acfg/if/bdbuf-task-stack-size.yml (added) * spec/acfg/if/bsp-idle-task-body.yml (moved) * spec/acfg/if/bsp-idle-task-stack-size.yml (moved) * spec/acfg/if/bsp-initial-extension.yml (added) * spec/acfg/if/bsp-interrupt-stack-size.yml (moved) * spec/acfg/if/bsp-prerequisite-drivers.yml (added) * spec/acfg/if/cbs-max-servers.yml (added) * spec/acfg/if/constraint-bspappmin.yml (moved) * spec/acfg/if/constraint-idlestackarea.yml (added) * spec/acfg/if/constraint-isrstackalign.yml (added) * spec/acfg/if/constraint-isrstackarea.yml (added) * spec/acfg/if/constraint-memsz.yml (moved) * spec/acfg/if/constraint-posix.yml (moved) * spec/acfg/if/constraint-prioclassic.yml (moved) * spec/acfg/if/constraint-stackspace.yml (added) * spec/acfg/if/constraint-unlimited.yml (added) * spec/acfg/if/constraint-wkspace.yml (added) * spec/acfg/if/dirty-memory.yml (moved) * spec/acfg/if/disable-bsp-settings.yml (moved) * spec/acfg/if/disable-newlib-reentrancy.yml (added) * spec/acfg/if/executive-ram-size.yml (added) * spec/acfg/if/extra-task-stacks.yml (moved) * spec/acfg/if/filesystem-all.yml (moved) * spec/acfg/if/filesystem-dosfs.yml (moved) * spec/acfg/if/filesystem-ftpfs.yml (moved) * spec/acfg/if/filesystem-imfs.yml (moved) * spec/acfg/if/filesystem-jffs2.yml (moved) * spec/acfg/if/filesystem-nfs.yml (moved) * spec/acfg/if/filesystem-rfs.yml (moved) * spec/acfg/if/filesystem-tftpfs.yml (moved) * spec/acfg/if/group-bdbuf.yml (added) * spec/acfg/if/group-bsp.yml (added) * spec/acfg/if/group-classic.yml (added) * spec/acfg/if/group-classicinit.yml (added) * spec/acfg/if/group-devdrv.yml (added) * spec/acfg/if/group-eventrecord.yml (added) * spec/acfg/if/group-filesystem.yml (added) * spec/acfg/if/group-general.yml (added) * spec/acfg/if/group-idle.yml (added) * spec/acfg/if/group-mpci.yml (added) * spec/acfg/if/group-posix.yml (added) * spec/acfg/if/group-posixinit.yml (added) * spec/acfg/if/group-schedgeneral.yml (added) * spec/acfg/if/group-stackalloc.yml (added) * spec/acfg/if/idle-task-body.yml (moved) * spec/acfg/if/idle-task-init-appl.yml (moved) * spec/acfg/if/idle-task-stack-size.yml (moved) * spec/acfg/if/imfs-disable-chmod.yml (added) * spec/acfg/if/imfs-disable-chown.yml (added) * spec/acfg/if/imfs-disable-link.yml (added) * spec/acfg/if/imfs-disable-mknod-device.yml (moved) * spec/acfg/if/imfs-disable-mknod-file.yml (moved) * spec/acfg/if/imfs-disable-mknod.yml (added) * spec/acfg/if/imfs-disable-mount.yml (added) * spec/acfg/if/imfs-disable-readdir.yml (added) * spec/acfg/if/imfs-disable-readlink.yml (added) * spec/acfg/if/imfs-disable-rename.yml (added) * spec/acfg/if/imfs-disable-rmnod.yml (added) * spec/acfg/if/imfs-disable-symlink.yml (added) * spec/acfg/if/imfs-disable-unmount.yml (added) * spec/acfg/if/imfs-disable-utime.yml (added) * spec/acfg/if/imfs-enable-mkfifo.yml (added) * spec/acfg/if/imfs-memfile-bytes-per-block.yml (moved) * spec/acfg/if/init-task-arguments.yml (added) * spec/acfg/if/init-task-attributes.yml (added) * spec/acfg/if/init-task-entrypoint.yml (moved) * spec/acfg/if/init-task-initial-modes.yml (added) * spec/acfg/if/init-task-name.yml (added) * spec/acfg/if/init-task-priority.yml (moved) * spec/acfg/if/init-task-stack-size.yml (moved) * spec/acfg/if/initial-extensions.yml (added) * spec/acfg/if/interrupt-stack-size.yml (added) * spec/acfg/if/malloc-bsp-supports-sbrk.yml (added) * spec/acfg/if/malloc-dirty.yml (added) * spec/acfg/if/max-barriers.yml (moved) * spec/acfg/if/max-drivers.yml (added) * spec/acfg/if/max-file-descriptors.yml (added) * spec/acfg/if/max-message-queues.yml (moved) * spec/acfg/if/max-partitions.yml (moved) * spec/acfg/if/max-periods.yml (moved) * spec/acfg/if/max-ports.yml (moved) * spec/acfg/if/max-posix-key-value-pairs.yml (added) * spec/acfg/if/max-posix-keys.yml (moved) * spec/acfg/if/max-posix-message-queues.yml (moved) * spec/acfg/if/max-posix-queued-signals.yml (moved) * spec/acfg/if/max-posix-semaphores.yml (added) * spec/acfg/if/max-posix-shms.yml (moved) * spec/acfg/if/max-posix-threads.yml (moved) * spec/acfg/if/max-posix-timers.yml (moved) * spec/acfg/if/max-priority.yml (moved) * spec/acfg/if/max-processors.yml (added) * spec/acfg/if/max-regions.yml (moved) * spec/acfg/if/max-semaphores.yml (moved) * spec/acfg/if/max-tasks.yml (moved) * spec/acfg/if/max-thread-local-storage-size.yml (added) * spec/acfg/if/max-thread-name-size.yml (added) * spec/acfg/if/max-timers.yml (moved) * spec/acfg/if/max-user-extensions.yml (moved) * spec/acfg/if/memory-overhead.yml (moved) * spec/acfg/if/message-buffer-memory.yml (moved) * spec/acfg/if/microseconds-per-tick.yml (moved) * spec/acfg/if/min-posix-thread-stack-size.yml (moved) * spec/acfg/if/min-task-stack-size.yml (added) * spec/acfg/if/min-tasks-with-user-provided-storage.yml (added) * spec/acfg/if/mp-appl.yml (moved) * spec/acfg/if/mp-extra-server-stack.yml (added) * spec/acfg/if/mp-max-global-objects.yml (added) * spec/acfg/if/mp-max-nodes.yml (added) * spec/acfg/if/mp-max-proxies.yml (added) * spec/acfg/if/mp-mpci-table-pointer.yml (added) * spec/acfg/if/mp-node-number.yml (added) * spec/acfg/if/posix-init-thread-entry-point.yml (moved) * spec/acfg/if/posix-init-thread-stack-size.yml (moved) * spec/acfg/if/posix-init-thread-table.yml (moved) * spec/acfg/if/record-extensions-enabled.yml (moved) * spec/acfg/if/record-fatal-dump-base64-zlib.yml (moved) * spec/acfg/if/record-fatal-dump-base64.yml (moved) * spec/acfg/if/record-per-processor-items.yml (added) * spec/acfg/if/rtems-init-tasks-table.yml (moved) * spec/acfg/if/scheduler-assignments.yml (moved) * spec/acfg/if/scheduler-cbs.yml (moved) * spec/acfg/if/scheduler-edf-smp.yml (moved) * spec/acfg/if/scheduler-edf.yml (moved) * spec/acfg/if/scheduler-name.yml (added) * spec/acfg/if/scheduler-priority-affinity-smp.yml (moved) * spec/acfg/if/scheduler-priority-smp.yml (moved) * spec/acfg/if/scheduler-priority.yml (moved) * spec/acfg/if/scheduler-simple-smp.yml (moved) * spec/acfg/if/scheduler-simple.yml (moved) * spec/acfg/if/scheduler-strong-apa.yml (moved) * spec/acfg/if/scheduler-user.yml (moved) * spec/acfg/if/stack-checker-enabled.yml (moved) * spec/acfg/if/task-stack-allocator-init.yml (added) * spec/acfg/if/task-stack-allocator.yml (moved) * spec/acfg/if/task-stack-deallocator.yml (moved) * spec/acfg/if/task-stack-from-alloc.yml (moved) * spec/acfg/if/task-stack-no-workspace.yml (moved) * spec/acfg/if/ticks-per-time-slice.yml (added) * spec/acfg/if/unified-work-areas.yml (moved) * spec/acfg/if/unlimited-allocation-size.yml (added) * spec/acfg/if/unlimited-objects.yml (moved) * spec/acfg/if/use-devfs-as-base-filesystem.yml (moved) * spec/acfg/if/use-miniimfs-as-base-filesystem.yml (moved) * spec/acfg/if/verbose-system-init.yml (added) * spec/acfg/if/zero-workspace-automatically.yml (moved) * spec/build-options/if/ada.yml (moved) * spec/build-options/if/container.yml (added) * spec/build-options/if/cpuopts.yml (added) * spec/build-options/if/debug.yml (moved) * spec/build-options/if/domain.yml (moved) * spec/build-options/if/drvmgr.yml (moved) * spec/build-options/if/multiprocessing.yml (moved) * spec/build-options/if/networking.yml (moved) * spec/build-options/if/paravirt.yml (moved) * spec/build-options/if/posix.yml (moved) * spec/build-options/if/profiling.yml (moved) * spec/build-options/if/smp.yml (moved) * spec/c/if/bool.yml (moved) * spec/c/if/chmod.yml (moved) * spec/c/if/chown.yml (moved) * spec/c/if/cpu_set_t.yml (moved) * spec/c/if/domain.yml (moved) * spec/c/if/errno-header.yml (added) * spec/c/if/errno.yml (moved) * spec/c/if/false.yml (moved) * spec/c/if/free.yml (moved) * spec/c/if/int16_t.yml (moved) * spec/c/if/int32_t.yml (moved) * spec/c/if/int64_t.yml (moved) * spec/c/if/int8_t.yml (moved) * spec/c/if/intmax_t.yml (moved) * spec/c/if/intptr_t.yml (moved) * spec/c/if/link.yml (moved) * spec/c/if/malloc.yml (moved) * spec/c/if/mkfifo.yml (moved) * spec/c/if/mknod.yml (moved) * spec/c/if/null.yml (moved) * spec/c/if/offsetof.yml (moved) * spec/c/if/printf.yml (moved) * spec/c/if/pthread.yml (added) * spec/c/if/pthread_setspecific.yml (moved) * spec/c/if/readdir.yml (moved) * spec/c/if/readlink.yml (moved) * spec/c/if/rename.yml (moved) * spec/c/if/rmnod.yml (moved) * spec/c/if/sbrk.yml (moved) * spec/c/if/sem_init.yml (moved) * spec/c/if/sem_open.yml (moved) * spec/c/if/semaphore.yml (added) * spec/c/if/size_max.yml (moved) * spec/c/if/size_t.yml (moved) * spec/c/if/stdatomic.yml (added) * spec/c/if/stdbool.yml (added) * spec/c/if/stddef.yml (added) * spec/c/if/stdint.yml (added) * spec/c/if/stdio.yml (added) * spec/c/if/stdlib.yml (added) * spec/c/if/string.yml (added) * spec/c/if/symlink.yml (moved) * spec/c/if/sys-cpuset.yml (added) * spec/c/if/sys-impl-timespec.yml (added) * spec/c/if/sys-impl-timeval.yml (added) * spec/c/if/sys-stat.yml (added) * spec/c/if/sys-types.yml (added) * spec/c/if/time.yml (added) * spec/c/if/time_t.yml (moved) * spec/c/if/timespec.yml (moved) * spec/c/if/timeval.yml (moved) * spec/c/if/true.yml (moved) * spec/c/if/uint16_t.yml (moved) * spec/c/if/uint32_max.yml (moved) * spec/c/if/uint32_t.yml (moved) * spec/c/if/uint64_t.yml (moved) * spec/c/if/uint8_t.yml (moved) * spec/c/if/uintmax_t.yml (moved) * spec/c/if/uintptr_max.yml (moved) * spec/c/if/uintptr_t.yml (moved) * spec/c/if/unistd.yml (added) * spec/c/if/utime.yml (moved) * spec/compiler/if/asm.yml (moved) * spec/compiler/if/builtin-choose-expr.yml (moved) * spec/compiler/if/builtin-expect.yml (moved) * spec/compiler/if/builtin-return-address.yml (moved) * spec/compiler/if/builtin-types-compatible-p.yml (moved) * spec/compiler/if/builtin-unreachable.yml (moved) * spec/compiler/if/container.yml (added) * spec/compiler/if/cplusplus.yml (moved) * spec/compiler/if/domain.yml (moved) * spec/compiler/if/gnuc.yml (moved) * spec/compiler/if/stdc-version.yml (moved) * spec/compiler/if/typeof.yml (moved) * spec/compiler/if/user-label-prefix.yml (moved) * spec/if/acfg/appl-disable-filesystem.yml (deleted) * spec/if/acfg/appl-extra-drivers.yml (deleted) * spec/if/acfg/appl-needs-console-driver.yml (deleted) * spec/if/acfg/appl-needs-simple-console-driver.yml (deleted) * spec/if/acfg/appl-needs-simple-task-console-driver.yml (deleted) * spec/if/acfg/appl-prerequisite-drivers.yml (deleted) * spec/if/acfg/bdbuf-buffer-min-size.yml (deleted) * spec/if/acfg/bdbuf-cache-memory-size.yml (deleted) * spec/if/acfg/bdbuf-max-read-ahead-blocks.yml (deleted) * spec/if/acfg/bdbuf-max-write-blocks.yml (deleted) * spec/if/acfg/bdbuf-swapout-block-hold.yml (deleted) * spec/if/acfg/bdbuf-swapout-swap-period.yml (deleted) * spec/if/acfg/bdbuf-swapout-worker-tasks.yml (deleted) * spec/if/acfg/bdbuf-task-stack-size.yml (deleted) * spec/if/acfg/bsp-initial-extension.yml (deleted) * spec/if/acfg/bsp-prerequisite-drivers.yml (deleted) * spec/if/acfg/cbs-max-servers.yml (deleted) * spec/if/acfg/constraint-idlestackarea.yml (deleted) * spec/if/acfg/constraint-isrstackalign.yml (deleted) * spec/if/acfg/constraint-isrstackarea.yml (deleted) * spec/if/acfg/constraint-stackspace.yml (deleted) * spec/if/acfg/constraint-unlimited.yml (deleted) * spec/if/acfg/constraint-wkspace.yml (deleted) * spec/if/acfg/disable-newlib-reentrancy.yml (deleted) * spec/if/acfg/executive-ram-size.yml (deleted) * spec/if/acfg/group-bdbuf.yml (deleted) * spec/if/acfg/group-bsp.yml (deleted) * spec/if/acfg/group-classic.yml (deleted) * spec/if/acfg/group-classicinit.yml (deleted) * spec/if/acfg/group-devdrv.yml (deleted) * spec/if/acfg/group-eventrecord.yml (deleted) * spec/if/acfg/group-filesystem.yml (deleted) * spec/if/acfg/group-general.yml (deleted) * spec/if/acfg/group-idle.yml (deleted) * spec/if/acfg/group-mpci.yml (deleted) * spec/if/acfg/group-posix.yml (deleted) * spec/if/acfg/group-posixinit.yml (deleted) * spec/if/acfg/group-schedgeneral.yml (deleted) * spec/if/acfg/group-stackalloc.yml (deleted) * spec/if/acfg/imfs-disable-chmod.yml (deleted) * spec/if/acfg/imfs-disable-chown.yml (deleted) * spec/if/acfg/imfs-disable-link.yml (deleted) * spec/if/acfg/imfs-disable-mknod.yml (deleted) * spec/if/acfg/imfs-disable-mount.yml (deleted) * spec/if/acfg/imfs-disable-readdir.yml (deleted) * spec/if/acfg/imfs-disable-readlink.yml (deleted) * spec/if/acfg/imfs-disable-rename.yml (deleted) * spec/if/acfg/imfs-disable-rmnod.yml (deleted) * spec/if/acfg/imfs-disable-symlink.yml (deleted) * spec/if/acfg/imfs-disable-unmount.yml (deleted) * spec/if/acfg/imfs-disable-utime.yml (deleted) * spec/if/acfg/imfs-enable-mkfifo.yml (deleted) * spec/if/acfg/init-task-arguments.yml (deleted) * spec/if/acfg/init-task-attributes.yml (deleted) * spec/if/acfg/init-task-initial-modes.yml (deleted) * spec/if/acfg/init-task-name.yml (deleted) * spec/if/acfg/initial-extensions.yml (deleted) * spec/if/acfg/interrupt-stack-size.yml (deleted) * spec/if/acfg/malloc-bsp-supports-sbrk.yml (deleted) * spec/if/acfg/malloc-dirty.yml (deleted) * spec/if/acfg/max-drivers.yml (deleted) * spec/if/acfg/max-file-descriptors.yml (deleted) * spec/if/acfg/max-posix-key-value-pairs.yml (deleted) * spec/if/acfg/max-posix-semaphores.yml (deleted) * spec/if/acfg/max-processors.yml (deleted) * spec/if/acfg/max-thread-local-storage-size.yml (deleted) * spec/if/acfg/max-thread-name-size.yml (deleted) * spec/if/acfg/min-task-stack-size.yml (deleted) * spec/if/acfg/min-tasks-with-user-provided-storage.yml (deleted) * spec/if/acfg/mp-extra-server-stack.yml (deleted) * spec/if/acfg/mp-max-global-objects.yml (deleted) * spec/if/acfg/mp-max-nodes.yml (deleted) * spec/if/acfg/mp-max-proxies.yml (deleted) * spec/if/acfg/mp-mpci-table-pointer.yml (deleted) * spec/if/acfg/mp-node-number.yml (deleted) * spec/if/acfg/record-per-processor-items.yml (deleted) * spec/if/acfg/scheduler-name.yml (deleted) * spec/if/acfg/task-stack-allocator-init.yml (deleted) * spec/if/acfg/ticks-per-time-slice.yml (deleted) * spec/if/acfg/unlimited-allocation-size.yml (deleted) * spec/if/acfg/verbose-system-init.yml (deleted) * spec/if/api.yml (modified) * spec/if/applconfig.yml (deleted) * spec/if/build-options/container.yml (deleted) * spec/if/build-options/cpuopts.yml (deleted) * spec/if/c/errno-header.yml (deleted) * spec/if/c/pthread.yml (deleted) * spec/if/c/semaphore.yml (deleted) * spec/if/c/stdatomic.yml (deleted) * spec/if/c/stdbool.yml (deleted) * spec/if/c/stddef.yml (deleted) * spec/if/c/stdint.yml (deleted) * spec/if/c/stdio.yml (deleted) * spec/if/c/stdlib.yml (deleted) * spec/if/c/string.yml (deleted) * spec/if/c/sys-cpuset.yml (deleted) * spec/if/c/sys-impl-timespec.yml (deleted) * spec/if/c/sys-impl-timeval.yml (deleted) * spec/if/c/sys-stat.yml (deleted) * spec/if/c/sys-types.yml (deleted) * spec/if/c/time.yml (deleted) * spec/if/c/unistd.yml (deleted) * spec/if/compiler/container.yml (deleted) * spec/if/domain.yml (moved) * spec/if/impl/assert-unreachable.yml (deleted) * spec/if/impl/context/header.yml (deleted) * spec/if/impl/cpu/header.yml (deleted) * spec/if/impl/dequalify-types-not-compatible.yml (deleted) * spec/if/impl/heap/header.yml (deleted) * spec/if/impl/interr/header.yml (deleted) * spec/if/impl/isr/header-2.yml (deleted) * spec/if/impl/isr/header-3.yml (deleted) * spec/if/impl/isr/header.yml (deleted) * spec/if/impl/maximum-priority.yml (deleted) * spec/if/impl/memory/header.yml (deleted) * spec/if/impl/mpci/header-2.yml (deleted) * spec/if/impl/mpci/header.yml (deleted) * spec/if/impl/object/header.yml (deleted) * spec/if/impl/smp/header-2.yml (deleted) * spec/if/impl/smp/header.yml (deleted) * spec/if/impl/stack/header.yml (deleted) * spec/if/impl/thread/header.yml (deleted) * spec/if/impl/tod-to-seconds.yml (deleted) * spec/if/impl/tod-validate.yml (deleted) * spec/if/impl/userext/header.yml (deleted) * spec/if/impl/watchdog/header.yml (deleted) * spec/if/impl/wkspace/header.yml (deleted) * spec/if/rtems/attr/attribute.yml (deleted) * spec/if/rtems/attr/group.yml (deleted) * spec/if/rtems/attr/header.yml (deleted) * spec/if/rtems/barrier/create.yml (deleted) * spec/if/rtems/barrier/delete.yml (deleted) * spec/if/rtems/barrier/group.yml (deleted) * spec/if/rtems/barrier/header.yml (deleted) * spec/if/rtems/barrier/ident.yml (deleted) * spec/if/rtems/barrier/release.yml (deleted) * spec/if/rtems/barrier/wait.yml (deleted) * spec/if/rtems/basedefs/alias.yml (deleted) * spec/if/rtems/basedefs/aligned.yml (deleted) * spec/if/rtems/basedefs/alloc-align.yml (deleted) * spec/if/rtems/basedefs/alloc-size-2.yml (deleted) * spec/if/rtems/basedefs/alloc-size.yml (deleted) * spec/if/rtems/basedefs/compiler-memory-barrier.yml (deleted) * spec/if/rtems/basedefs/const.yml (deleted) * spec/if/rtems/basedefs/container-of.yml (deleted) * spec/if/rtems/basedefs/define-global-symbol.yml (deleted) * spec/if/rtems/basedefs/deprecated.yml (deleted) * spec/if/rtems/basedefs/dequalify-depthx.yml (deleted) * spec/if/rtems/basedefs/group.yml (deleted) * spec/if/rtems/basedefs/have-member-same-type.yml (deleted) * spec/if/rtems/basedefs/header.yml (deleted) * spec/if/rtems/basedefs/inline-routine.yml (deleted) * spec/if/rtems/basedefs/malloclike.yml (deleted) * spec/if/rtems/basedefs/no-inline.yml (deleted) * spec/if/rtems/basedefs/no-return.yml (deleted) * spec/if/rtems/basedefs/obfuscate-variable.yml (deleted) * spec/if/rtems/basedefs/packed.yml (deleted) * spec/if/rtems/basedefs/predict-false.yml (deleted) * spec/if/rtems/basedefs/predict-true.yml (deleted) * spec/if/rtems/basedefs/printflike.yml (deleted) * spec/if/rtems/basedefs/pure.yml (deleted) * spec/if/rtems/basedefs/return-address.yml (deleted) * spec/if/rtems/basedefs/section.yml (deleted) * spec/if/rtems/basedefs/static-assert.yml (deleted) * spec/if/rtems/basedefs/symbol-name.yml (deleted) * spec/if/rtems/basedefs/typeof-refx.yml (deleted) * spec/if/rtems/basedefs/unreachable.yml (deleted) * spec/if/rtems/basedefs/unused.yml (deleted) * spec/if/rtems/basedefs/used.yml (deleted) * spec/if/rtems/basedefs/warn-unused-result.yml (deleted) * spec/if/rtems/basedefs/weak-alias.yml (deleted) * spec/if/rtems/basedefs/weak.yml (deleted) * spec/if/rtems/basedefs/zero-length-array.yml (deleted) * spec/if/rtems/cache/aligned-malloc.yml (deleted) * spec/if/rtems/cache/coherent-add-area.yml (deleted) * spec/if/rtems/cache/coherent-allocate.yml (deleted) * spec/if/rtems/cache/flush-multiple-data-lines.yml (deleted) * spec/if/rtems/cache/get-data-line-size.yml (deleted) * spec/if/rtems/cache/get-data-size.yml (deleted) * spec/if/rtems/cache/get-instruction-line-size.yml (deleted) * spec/if/rtems/cache/get-instruction-size.yml (deleted) * spec/if/rtems/cache/get-maximal-line-size.yml (deleted) * spec/if/rtems/cache/group.yml (deleted) * spec/if/rtems/cache/header.yml (deleted) * spec/if/rtems/cache/instruction-sync-after-code-change.yml (deleted) * spec/if/rtems/cache/invalidate-multiple-data-lines.yml (deleted) * spec/if/rtems/cache/invalidate-multiple-instruction-lines.yml (deleted) * spec/if/rtems/clock/get-seconds-since-epoch.yml (deleted) * spec/if/rtems/clock/get-ticks-per-second.yml (deleted) * spec/if/rtems/clock/get-ticks-since-boot.yml (deleted) * spec/if/rtems/clock/get-tod-timeval.yml (deleted) * spec/if/rtems/clock/get-tod.yml (deleted) * spec/if/rtems/clock/get-uptime-nanoseconds.yml (deleted) * spec/if/rtems/clock/get-uptime-seconds.yml (deleted) * spec/if/rtems/clock/get-uptime-timeval.yml (deleted) * spec/if/rtems/clock/get-uptime.yml (deleted) * spec/if/rtems/clock/group.yml (deleted) * spec/if/rtems/clock/header.yml (deleted) * spec/if/rtems/clock/set.yml (deleted) * spec/if/rtems/clock/tick-before.yml (deleted) * spec/if/rtems/clock/tick-later-usec.yml (deleted) * spec/if/rtems/clock/tick-later.yml (deleted) * spec/if/rtems/clock/tick.yml (deleted) * spec/if/rtems/config/api-table.yml (deleted) * spec/if/rtems/config/get-do-zero-of-workspace.yml (deleted) * spec/if/rtems/config/get-idle-task-stack-size.yml (deleted) * spec/if/rtems/config/get-idle-task.yml (deleted) * spec/if/rtems/config/get-interrupt-stack-size.yml (deleted) * spec/if/rtems/config/get-maximum-barriers.yml (deleted) * spec/if/rtems/config/get-maximum-extensions.yml (deleted) * spec/if/rtems/config/get-maximum-message-queues.yml (deleted) * spec/if/rtems/config/get-maximum-partitions.yml (deleted) * spec/if/rtems/config/get-maximum-periods.yml (deleted) * spec/if/rtems/config/get-maximum-ports.yml (deleted) * spec/if/rtems/config/get-maximum-processors.yml (deleted) * spec/if/rtems/config/get-maximum-regions.yml (deleted) * spec/if/rtems/config/get-maximum-semaphores.yml (deleted) * spec/if/rtems/config/get-maximum-tasks.yml (deleted) * spec/if/rtems/config/get-maximum-timers.yml (deleted) * spec/if/rtems/config/get-microseconds-per-tick.yml (deleted) * spec/if/rtems/config/get-milliseconds-per-tick.yml (deleted) * spec/if/rtems/config/get-nanoseconds-per-tick.yml (deleted) * spec/if/rtems/config/get-number-of-initial-extensions.yml (deleted) * spec/if/rtems/config/get-stack-allocate-hook.yml (deleted) * spec/if/rtems/config/get-stack-allocate-init-hook.yml (deleted) * spec/if/rtems/config/get-stack-allocator-avoids-work-space.yml (deleted) * spec/if/rtems/config/get-stack-free-hook.yml (deleted) * spec/if/rtems/config/get-stack-space-size.yml (deleted) * spec/if/rtems/config/get-ticks-per-timeslice.yml (deleted) * spec/if/rtems/config/get-unified-work-area.yml (deleted) * spec/if/rtems/config/get-user-extension-table.yml (deleted) * spec/if/rtems/config/get-user-multiprocessing-table.yml (deleted) * spec/if/rtems/config/get-work-space-size.yml (deleted) * spec/if/rtems/config/group.yml (deleted) * spec/if/rtems/config/has-hardware-fp.yml (deleted) * spec/if/rtems/config/header-2.yml (deleted) * spec/if/rtems/config/header.yml (deleted) * spec/if/rtems/config/resource-is-unlimited.yml (deleted) * spec/if/rtems/config/resource-maximum-per-allocation.yml (deleted) * spec/if/rtems/config/stack-allocate-hook.yml (deleted) * spec/if/rtems/config/stack-allocate-init-hook.yml (deleted) * spec/if/rtems/config/stack-free-hook.yml (deleted) * spec/if/rtems/config/unlimited-objects.yml (deleted) * spec/if/rtems/dpmem/create.yml (deleted) * spec/if/rtems/dpmem/delete.yml (deleted) * spec/if/rtems/dpmem/external-to-internal.yml (deleted) * spec/if/rtems/dpmem/group.yml (deleted) * spec/if/rtems/dpmem/header.yml (deleted) * spec/if/rtems/dpmem/ident.yml (deleted) * spec/if/rtems/dpmem/internal-to-external.yml (deleted) * spec/if/rtems/event/group.yml (deleted) * spec/if/rtems/event/header.yml (deleted) * spec/if/rtems/event/receive.yml (deleted) * spec/if/rtems/event/send.yml (deleted) * spec/if/rtems/event/set.yml (deleted) * spec/if/rtems/event/system-receive.yml (deleted) * spec/if/rtems/event/system-send.yml (deleted) * spec/if/rtems/event/transient-clear.yml (deleted) * spec/if/rtems/event/transient-receive.yml (deleted) * spec/if/rtems/event/transient-send.yml (deleted) * spec/if/rtems/fatal/error-occurred.yml (deleted) * spec/if/rtems/fatal/exception-frame-print.yml (deleted) * spec/if/rtems/fatal/exception-frame.yml (deleted) * spec/if/rtems/fatal/fatal.yml (deleted) * spec/if/rtems/fatal/group.yml (deleted) * spec/if/rtems/fatal/header.yml (deleted) * spec/if/rtems/fatal/internal-error-text.yml (deleted) * spec/if/rtems/fatal/panic.yml (deleted) * spec/if/rtems/fatal/source-text.yml (deleted) * spec/if/rtems/group.yml (deleted) * spec/if/rtems/header.yml (deleted) * spec/if/rtems/init/group.yml (deleted) * spec/if/rtems/init/header.yml (deleted) * spec/if/rtems/init/initialize-executive.yml (deleted) * spec/if/rtems/init/shutdown-executive.yml (deleted) * spec/if/rtems/intr/catch.yml (deleted) * spec/if/rtems/intr/disable.yml (deleted) * spec/if/rtems/intr/enable.yml (deleted) * spec/if/rtems/intr/flash.yml (deleted) * spec/if/rtems/intr/group.yml (deleted) * spec/if/rtems/intr/header.yml (deleted) * spec/if/rtems/intr/is-in-progress.yml (deleted) * spec/if/rtems/intr/isr-entry.yml (deleted) * spec/if/rtems/intr/isr.yml (deleted) * spec/if/rtems/intr/level.yml (deleted) * spec/if/rtems/intr/local-disable.yml (deleted) * spec/if/rtems/intr/local-enable.yml (deleted) * spec/if/rtems/intr/lock-acquire-isr.yml (deleted) * spec/if/rtems/intr/lock-acquire.yml (deleted) * spec/if/rtems/intr/lock-context.yml (deleted) * spec/if/rtems/intr/lock-declare.yml (deleted) * spec/if/rtems/intr/lock-define.yml (deleted) * spec/if/rtems/intr/lock-destroy.yml (deleted) * spec/if/rtems/intr/lock-initialize.yml (deleted) * spec/if/rtems/intr/lock-initializer.yml (deleted) * spec/if/rtems/intr/lock-isr-disable.yml (deleted) * spec/if/rtems/intr/lock-member.yml (deleted) * spec/if/rtems/intr/lock-reference.yml (deleted) * spec/if/rtems/intr/lock-release-isr.yml (deleted) * spec/if/rtems/intr/lock-release.yml (deleted) * spec/if/rtems/intr/lock.yml (deleted) * spec/if/rtems/intr/vector-number.yml (deleted) * spec/if/rtems/io/close.yml (deleted) * spec/if/rtems/io/control.yml (deleted) * spec/if/rtems/io/device-driver.yml (deleted) * spec/if/rtems/io/device-major-number.yml (deleted) * spec/if/rtems/io/device-minor-number.yml (deleted) * spec/if/rtems/io/driver-error.yml (deleted) * spec/if/rtems/io/group.yml (deleted) * spec/if/rtems/io/header.yml (deleted) * spec/if/rtems/io/initialize.yml (deleted) * spec/if/rtems/io/open.yml (deleted) * spec/if/rtems/io/read.yml (deleted) * spec/if/rtems/io/register-driver.yml (deleted) * spec/if/rtems/io/register-name.yml (deleted) * spec/if/rtems/io/unregister-driver.yml (deleted) * spec/if/rtems/io/write.yml (deleted) * spec/if/rtems/message/broadcast.yml (deleted) * spec/if/rtems/message/create.yml (deleted) * spec/if/rtems/message/delete.yml (deleted) * spec/if/rtems/message/flush.yml (deleted) * spec/if/rtems/message/get-number-pending.yml (deleted) * spec/if/rtems/message/group.yml (deleted) * spec/if/rtems/message/header.yml (deleted) * spec/if/rtems/message/ident.yml (deleted) * spec/if/rtems/message/receive.yml (deleted) * spec/if/rtems/message/send.yml (deleted) * spec/if/rtems/message/urgent.yml (deleted) * spec/if/rtems/modes/group.yml (deleted) * spec/if/rtems/modes/header.yml (deleted) * spec/if/rtems/modes/interrupt-level-body.yml (deleted) * spec/if/rtems/modes/interrupt-mask-variable.yml (deleted) * spec/if/rtems/modes/interrupt-mask.yml (deleted) * spec/if/rtems/modes/mode.yml (deleted) * spec/if/rtems/mp/group.yml (deleted) * spec/if/rtems/mp/header.yml (deleted) * spec/if/rtems/object/api-class-information.yml (deleted) * spec/if/rtems/object/build-id.yml (deleted) * spec/if/rtems/object/build-name.yml (deleted) * spec/if/rtems/object/get-class-information.yml (deleted) * spec/if/rtems/object/get-classic-name.yml (deleted) * spec/if/rtems/object/get-local-node.yml (deleted) * spec/if/rtems/object/get-name.yml (deleted) * spec/if/rtems/object/group.yml (deleted) * spec/if/rtems/object/header.yml (deleted) * spec/if/rtems/object/id-api-maximum.yml (deleted) * spec/if/rtems/object/id-api-minimum.yml (deleted) * spec/if/rtems/object/id-final-index.yml (deleted) * spec/if/rtems/object/id-final.yml (deleted) * spec/if/rtems/object/id-get-api.yml (deleted) * spec/if/rtems/object/id-get-class.yml (deleted) * spec/if/rtems/object/id-get-index.yml (deleted) * spec/if/rtems/object/id-get-node.yml (deleted) * spec/if/rtems/object/id-initial-index.yml (deleted) * spec/if/rtems/object/id-initial.yml (deleted) * spec/if/rtems/object/search-all-nodes.yml (deleted) * spec/if/rtems/object/search-local-node.yml (deleted) * spec/if/rtems/object/search-other-nodes.yml (deleted) * spec/if/rtems/object/set-name.yml (deleted) * spec/if/rtems/object/who-am-i.yml (deleted) * spec/if/rtems/options/group.yml (deleted) * spec/if/rtems/options/header.yml (deleted) * spec/if/rtems/options/option.yml (deleted) * spec/if/rtems/part/create.yml (deleted) * spec/if/rtems/part/delete.yml (deleted) * spec/if/rtems/part/get-buffer.yml (deleted) * spec/if/rtems/part/group.yml (deleted) * spec/if/rtems/part/header.yml (deleted) * spec/if/rtems/part/ident.yml (deleted) * spec/if/rtems/part/return-buffer.yml (deleted) * spec/if/rtems/ratemon/cancel.yml (deleted) * spec/if/rtems/ratemon/create.yml (deleted) * spec/if/rtems/ratemon/delete.yml (deleted) * spec/if/rtems/ratemon/get-statistics.yml (deleted) * spec/if/rtems/ratemon/get-status.yml (deleted) * spec/if/rtems/ratemon/group.yml (deleted) * spec/if/rtems/ratemon/header.yml (deleted) * spec/if/rtems/ratemon/ident.yml (deleted) * spec/if/rtems/ratemon/period-statistics.yml (deleted) * spec/if/rtems/ratemon/period-status-define.yml (deleted) * spec/if/rtems/ratemon/period-status.yml (deleted) * spec/if/rtems/ratemon/period.yml (deleted) * spec/if/rtems/ratemon/printer.yml (deleted) * spec/if/rtems/ratemon/reset-statistics.yml (deleted) * spec/if/rtems/region/create.yml (deleted) * spec/if/rtems/region/delete.yml (deleted) * spec/if/rtems/region/extend.yml (deleted) * spec/if/rtems/region/get-free-information.yml (deleted) * spec/if/rtems/region/get-information.yml (deleted) * spec/if/rtems/region/get-segment-size.yml (deleted) * spec/if/rtems/region/get-segment.yml (deleted) * spec/if/rtems/region/group.yml (deleted) * spec/if/rtems/region/header.yml (deleted) * spec/if/rtems/region/ident.yml (deleted) * spec/if/rtems/region/resize-segment.yml (deleted) * spec/if/rtems/region/return-segment.yml (deleted) * spec/if/rtems/scheduler/add-processor.yml (deleted) * spec/if/rtems/scheduler/get-maximum-priority.yml (deleted) * spec/if/rtems/scheduler/get-processor-maximum.yml (deleted) * spec/if/rtems/scheduler/get-processor-set.yml (deleted) * spec/if/rtems/scheduler/get-processor.yml (deleted) * spec/if/rtems/scheduler/ident-by-processor-set.yml (deleted) * spec/if/rtems/scheduler/ident-by-processor.yml (deleted) * spec/if/rtems/scheduler/ident.yml (deleted) * spec/if/rtems/scheduler/map-priority-from-posix.yml (deleted) * spec/if/rtems/scheduler/map-priority-to-posix.yml (deleted) * spec/if/rtems/scheduler/remove-processor.yml (deleted) * spec/if/rtems/sem/create.yml (deleted) * spec/if/rtems/sem/delete.yml (deleted) * spec/if/rtems/sem/flush.yml (deleted) * spec/if/rtems/sem/group.yml (deleted) * spec/if/rtems/sem/header.yml (deleted) * spec/if/rtems/sem/ident.yml (deleted) * spec/if/rtems/sem/obtain.yml (deleted) * spec/if/rtems/sem/release.yml (deleted) * spec/if/rtems/sem/set-priority.yml (deleted) * spec/if/rtems/signal/catch.yml (deleted) * spec/if/rtems/signal/group.yml (deleted) * spec/if/rtems/signal/header-2.yml (deleted) * spec/if/rtems/signal/header.yml (deleted) * spec/if/rtems/signal/send.yml (deleted) * spec/if/rtems/signal/set.yml (deleted) * spec/if/rtems/status/group.yml (deleted) * spec/if/rtems/status/header.yml (deleted) * spec/if/rtems/status/is-equal.yml (deleted) * spec/if/rtems/status/is-successful.yml (deleted) * spec/if/rtems/support/group.yml (deleted) * spec/if/rtems/support/header.yml (deleted) * spec/if/rtems/support/is-name-valid.yml (deleted) * spec/if/rtems/support/microseconds-to-ticks.yml (deleted) * spec/if/rtems/support/milliseconds-to-ticks.yml (deleted) * spec/if/rtems/support/name-to-characters.yml (deleted) * spec/if/rtems/support/workspace-allocate.yml (deleted) * spec/if/rtems/support/workspace-free.yml (deleted) * spec/if/rtems/support/workspace-get-information.yml (deleted) * spec/if/rtems/support/workspace-greedy-allocate-all-except-largest.yml (deleted) * spec/if/rtems/support/workspace-greedy-allocate.yml (deleted) * spec/if/rtems/tasks/argument.yml (deleted) * spec/if/rtems/tasks/config.yml (deleted) * spec/if/rtems/tasks/construct.yml (deleted) * spec/if/rtems/tasks/create.yml (deleted) * spec/if/rtems/tasks/delete.yml (deleted) * spec/if/rtems/tasks/exit.yml (deleted) * spec/if/rtems/tasks/get-affinity.yml (deleted) * spec/if/rtems/tasks/get-priority.yml (deleted) * spec/if/rtems/tasks/get-scheduler.yml (deleted) * spec/if/rtems/tasks/group.yml (deleted) * spec/if/rtems/tasks/header.yml (deleted) * spec/if/rtems/tasks/ident.yml (deleted) * spec/if/rtems/tasks/initialization-table.yml (deleted) * spec/if/rtems/tasks/is-suspended.yml (deleted) * spec/if/rtems/tasks/maximum-priority.yml (deleted) * spec/if/rtems/tasks/minimum-stack-size.yml (deleted) * spec/if/rtems/tasks/mode.yml (deleted) * spec/if/rtems/tasks/priority.yml (deleted) * spec/if/rtems/tasks/restart.yml (deleted) * spec/if/rtems/tasks/resume.yml (deleted) * spec/if/rtems/tasks/self-define.yml (deleted) * spec/if/rtems/tasks/self.yml (deleted) * spec/if/rtems/tasks/set-affinity.yml (deleted) * spec/if/rtems/tasks/set-priority.yml (deleted) * spec/if/rtems/tasks/set-scheduler.yml (deleted) * spec/if/rtems/tasks/start.yml (deleted) * spec/if/rtems/tasks/storage-alignment.yml (deleted) * spec/if/rtems/tasks/storage-size.yml (deleted) * spec/if/rtems/tasks/suspend.yml (deleted) * spec/if/rtems/tasks/visitor.yml (deleted) * spec/if/rtems/tasks/wake-after.yml (deleted) * spec/if/rtems/tasks/wake-when.yml (deleted) * spec/if/rtems/tasks/yield-processor.yml (deleted) * spec/if/rtems/timer/cancel.yml (deleted) * spec/if/rtems/timer/create.yml (deleted) * spec/if/rtems/timer/delete.yml (deleted) * spec/if/rtems/timer/fire-after.yml (deleted) * spec/if/rtems/timer/fire-when.yml (deleted) * spec/if/rtems/timer/get-information.yml (deleted) * spec/if/rtems/timer/group.yml (deleted) * spec/if/rtems/timer/header.yml (deleted) * spec/if/rtems/timer/ident.yml (deleted) * spec/if/rtems/timer/information.yml (deleted) * spec/if/rtems/timer/initiate-server.yml (deleted) * spec/if/rtems/timer/reset.yml (deleted) * spec/if/rtems/timer/server-default-priority.yml (deleted) * spec/if/rtems/timer/server-fire-after.yml (deleted) * spec/if/rtems/timer/server-fire-when.yml (deleted) * spec/if/rtems/timer/service-routine-entry.yml (deleted) * spec/if/rtems/types/group.yml (deleted) * spec/if/rtems/types/header.yml (deleted) * spec/if/rtems/types/id-none.yml (deleted) * spec/if/rtems/types/id.yml (deleted) * spec/if/rtems/types/interval.yml (deleted) * spec/if/rtems/types/minimum-packet-size.yml (deleted) * spec/if/rtems/types/minimun-hetero-conversion.yml (deleted) * spec/if/rtems/types/mp-packet-classes.yml (deleted) * spec/if/rtems/types/mpci-get-packet-entry.yml (deleted) * spec/if/rtems/types/mpci-initialization-entry.yml (deleted) * spec/if/rtems/types/mpci-receive-packet-entry.yml (deleted) * spec/if/rtems/types/mpci-return-packet-entry.yml (deleted) * spec/if/rtems/types/mpci-send-packet-entry.yml (deleted) * spec/if/rtems/types/mpci-table.yml (deleted) * spec/if/rtems/types/multiprocessing-table.yml (deleted) * spec/if/rtems/types/name.yml (deleted) * spec/if/rtems/types/no-timeout.yml (deleted) * spec/if/rtems/types/packet-prefix.yml (deleted) * spec/if/rtems/types/time-of-day.yml (deleted) * spec/if/rtems/userext/create.yml (deleted) * spec/if/rtems/userext/delete.yml (deleted) * spec/if/rtems/userext/fatal-code.yml (deleted) * spec/if/rtems/userext/fatal-source.yml (deleted) * spec/if/rtems/userext/fatal.yml (deleted) * spec/if/rtems/userext/group.yml (deleted) * spec/if/rtems/userext/header.yml (deleted) * spec/if/rtems/userext/ident.yml (deleted) * spec/if/rtems/userext/table.yml (deleted) * spec/if/rtems/userext/task-begin.yml (deleted) * spec/if/rtems/userext/task-create.yml (deleted) * spec/if/rtems/userext/task-delete.yml (deleted) * spec/if/rtems/userext/task-exitted.yml (deleted) * spec/if/rtems/userext/task-restart.yml (deleted) * spec/if/rtems/userext/task-start.yml (deleted) * spec/if/rtems/userext/task-switch.yml (deleted) * spec/if/rtems/userext/task-terminate.yml (deleted) * spec/if/use/container.yml (deleted) * spec/req/applconfig.yml (added) * spec/req/rtems/attr/bit-set.yml (deleted) * spec/req/rtems/attr/default.yml (deleted) * spec/req/rtems/attr/semaphore-class.yml (deleted) * spec/req/rtems/attr/unique.yml (deleted) * spec/req/rtems/attr/val/attr.yml (deleted) * spec/req/rtems/barrier/ident.yml (deleted) * spec/req/rtems/barrier/val/ident.yml (deleted) * spec/req/rtems/event/receive.yml (deleted) * spec/req/rtems/event/send.yml (deleted) * spec/req/rtems/event/system-receive.yml (deleted) * spec/req/rtems/event/system-send.yml (deleted) * spec/req/rtems/event/val/send-receive.yml (deleted) * spec/req/rtems/event/val/system-send-receive.yml (deleted) * spec/req/rtems/message/ident.yml (deleted) * spec/req/rtems/message/val/ident.yml (deleted) * spec/req/rtems/modes/bit-set.yml (deleted) * spec/req/rtems/modes/default.yml (deleted) * spec/req/rtems/modes/masks-all.yml (deleted) * spec/req/rtems/modes/masks-unique.yml (deleted) * spec/req/rtems/modes/masks.yml (deleted) * spec/req/rtems/modes/unique.yml (deleted) * spec/req/rtems/modes/val/modes.yml (deleted) * spec/req/rtems/options/bit-set.yml (deleted) * spec/req/rtems/options/default.yml (deleted) * spec/req/rtems/options/unique.yml (deleted) * spec/req/rtems/options/val/options.yml (deleted) * spec/req/rtems/part/ident.yml (deleted) * spec/req/rtems/part/val/ident.yml (deleted) * spec/req/rtems/ratemon/ident.yml (deleted) * spec/req/rtems/ratemon/val/ident.yml (deleted) * spec/req/rtems/sem/ident.yml (deleted) * spec/req/rtems/sem/val/ident.yml (deleted) * spec/req/rtems/tasks/construct-errors.yml (deleted) * spec/req/rtems/tasks/ident.yml (deleted) * spec/req/rtems/timer/ident.yml (deleted) * spec/req/rtems/timer/val/ident.yml (deleted) * spec/req/rtems/userext/ident.yml (deleted) * spec/req/rtems/userext/val/ident.yml (deleted) * spec/req/system.yml (moved) * spec/rtems/attr/if/application-task.yml (moved) * spec/rtems/attr/if/attribute.yml (added) * spec/rtems/attr/if/barrier-automatic-release.yml (moved) * spec/rtems/attr/if/barrier-manual-release.yml (moved) * spec/rtems/attr/if/binary-semaphore.yml (moved) * spec/rtems/attr/if/counting-semaphore.yml (moved) * spec/rtems/attr/if/default.yml (moved) * spec/rtems/attr/if/fifo.yml (moved) * spec/rtems/attr/if/floating-point.yml (moved) * spec/rtems/attr/if/global.yml (moved) * spec/rtems/attr/if/group.yml (added) * spec/rtems/attr/if/header.yml (added) * spec/rtems/attr/if/inherit-priority.yml (moved) * spec/rtems/attr/if/local.yml (moved) * spec/rtems/attr/if/multiprocessor-resource-sharing.yml (moved) * spec/rtems/attr/if/no-floating-point.yml (moved) * spec/rtems/attr/if/no-inherit-priority.yml (moved) * spec/rtems/attr/if/no-multiprocessor-resource-sharing.yml (moved) * spec/rtems/attr/if/no-priority-ceiling.yml (moved) * spec/rtems/attr/if/priority-ceiling.yml (moved) * spec/rtems/attr/if/priority.yml (moved) * spec/rtems/attr/if/semaphore-class.yml (moved) * spec/rtems/attr/if/simple-binary-semaphore.yml (moved) * spec/rtems/attr/if/system-task.yml (moved) * spec/rtems/attr/req/bit-set.yml (added) * spec/rtems/attr/req/default.yml (added) * spec/rtems/attr/req/semaphore-class.yml (added) * spec/rtems/attr/req/unique.yml (added) * spec/rtems/attr/val/attr.yml (added) * spec/rtems/barrier/if/create.yml (added) * spec/rtems/barrier/if/delete.yml (added) * spec/rtems/barrier/if/group.yml (added) * spec/rtems/barrier/if/header.yml (added) * spec/rtems/barrier/if/ident.yml (added) * spec/rtems/barrier/if/release.yml (added) * spec/rtems/barrier/if/wait.yml (added) * spec/rtems/barrier/req/ident.yml (added) * spec/rtems/barrier/val/ident.yml (added) * spec/rtems/basedefs/if/alias.yml (added) * spec/rtems/basedefs/if/align-down.yml (moved) * spec/rtems/basedefs/if/align-up.yml (moved) * spec/rtems/basedefs/if/aligned.yml (added) * spec/rtems/basedefs/if/alloc-align.yml (added) * spec/rtems/basedefs/if/alloc-size-2.yml (added) * spec/rtems/basedefs/if/alloc-size.yml (added) * spec/rtems/basedefs/if/array-size.yml (moved) * spec/rtems/basedefs/if/compiler-deprecated-attribute.yml (moved) * spec/rtems/basedefs/if/compiler-memory-barrier.yml (added) * spec/rtems/basedefs/if/compiler-no-return-attribute.yml (moved) * spec/rtems/basedefs/if/compiler-packed-attribute.yml (moved) * spec/rtems/basedefs/if/compiler-pure-attribute.yml (moved) * spec/rtems/basedefs/if/compiler-used-attribute.yml (moved) * spec/rtems/basedefs/if/concat.yml (moved) * spec/rtems/basedefs/if/const.yml (added) * spec/rtems/basedefs/if/container-of.yml (added) * spec/rtems/basedefs/if/declare-global-symbol.yml (moved) * spec/rtems/basedefs/if/deconst.yml (moved) * spec/rtems/basedefs/if/define-global-symbol.yml (added) * spec/rtems/basedefs/if/deprecated.yml (added) * spec/rtems/basedefs/if/dequalify-depthx.yml (added) * spec/rtems/basedefs/if/dequalify.yml (moved) * spec/rtems/basedefs/if/devolatile.yml (moved) * spec/rtems/basedefs/if/expand.yml (moved) * spec/rtems/basedefs/if/false.yml (moved) * spec/rtems/basedefs/if/group.yml (added) * spec/rtems/basedefs/if/have-member-same-type.yml (added) * spec/rtems/basedefs/if/header.yml (added) * spec/rtems/basedefs/if/inline-routine.yml (added) * spec/rtems/basedefs/if/malloclike.yml (added) * spec/rtems/basedefs/if/no-inline.yml (added) * spec/rtems/basedefs/if/no-return.yml (added) * spec/rtems/basedefs/if/obfuscate-variable.yml (added) * spec/rtems/basedefs/if/packed.yml (added) * spec/rtems/basedefs/if/predict-false.yml (added) * spec/rtems/basedefs/if/predict-true.yml (added) * spec/rtems/basedefs/if/printflike.yml (added) * spec/rtems/basedefs/if/pure.yml (added) * spec/rtems/basedefs/if/return-address.yml (added) * spec/rtems/basedefs/if/section.yml (added) * spec/rtems/basedefs/if/static-assert.yml (added) * spec/rtems/basedefs/if/string.yml (moved) * spec/rtems/basedefs/if/symbol-name.yml (added) * spec/rtems/basedefs/if/true.yml (moved) * spec/rtems/basedefs/if/typeof-refx.yml (added) * spec/rtems/basedefs/if/unreachable.yml (added) * spec/rtems/basedefs/if/unused.yml (added) * spec/rtems/basedefs/if/used.yml (added) * spec/rtems/basedefs/if/warn-unused-result.yml (added) * spec/rtems/basedefs/if/weak-alias.yml (added) * spec/rtems/basedefs/if/weak.yml (added) * spec/rtems/basedefs/if/xconcat.yml (moved) * spec/rtems/basedefs/if/xstring.yml (moved) * spec/rtems/basedefs/if/zero-length-array.yml (added) * spec/rtems/cache/if/aligned-malloc.yml (added) * spec/rtems/cache/if/coherent-add-area.yml (added) * spec/rtems/cache/if/coherent-allocate.yml (added) * spec/rtems/cache/if/coherent-free.yml (moved) * spec/rtems/cache/if/disable-data.yml (moved) * spec/rtems/cache/if/disable-instruction.yml (moved) * spec/rtems/cache/if/enable-data.yml (moved) * spec/rtems/cache/if/enable-instruction.yml (moved) * spec/rtems/cache/if/flush-entire-data.yml (moved) * spec/rtems/cache/if/flush-multiple-data-lines.yml (added) * spec/rtems/cache/if/freeze-data.yml (moved) * spec/rtems/cache/if/freeze-instruction.yml (moved) * spec/rtems/cache/if/get-data-line-size.yml (added) * spec/rtems/cache/if/get-data-size.yml (added) * spec/rtems/cache/if/get-instruction-line-size.yml (added) * spec/rtems/cache/if/get-instruction-size.yml (added) * spec/rtems/cache/if/get-maximal-line-size.yml (added) * spec/rtems/cache/if/group.yml (added) * spec/rtems/cache/if/header.yml (added) * spec/rtems/cache/if/instruction-sync-after-code-change.yml (added) * spec/rtems/cache/if/invalidate-entire-data.yml (moved) * spec/rtems/cache/if/invalidate-entire-instruction.yml (moved) * spec/rtems/cache/if/invalidate-multiple-data-lines.yml (added) * spec/rtems/cache/if/invalidate-multiple-instruction-lines.yml (added) * spec/rtems/cache/if/unfreeze-data.yml (moved) * spec/rtems/cache/if/unfreeze-instruction.yml (moved) * spec/rtems/clock/if/get-seconds-since-epoch.yml (added) * spec/rtems/clock/if/get-ticks-per-second.yml (added) * spec/rtems/clock/if/get-ticks-since-boot.yml (added) * spec/rtems/clock/if/get-tod-timeval.yml (added) * spec/rtems/clock/if/get-tod.yml (added) * spec/rtems/clock/if/get-uptime-nanoseconds.yml (added) * spec/rtems/clock/if/get-uptime-seconds.yml (added) * spec/rtems/clock/if/get-uptime-timeval.yml (added) * spec/rtems/clock/if/get-uptime.yml (added) * spec/rtems/clock/if/group.yml (added) * spec/rtems/clock/if/header.yml (added) * spec/rtems/clock/if/set.yml (added) * spec/rtems/clock/if/tick-before.yml (added) * spec/rtems/clock/if/tick-later-usec.yml (added) * spec/rtems/clock/if/tick-later.yml (added) * spec/rtems/clock/if/tick.yml (added) * spec/rtems/config/if/api-table.yml (added) * spec/rtems/config/if/get-api-configuration.yml (moved) * spec/rtems/config/if/get-copyright-notice.yml (moved) * spec/rtems/config/if/get-do-zero-of-workspace.yml (added) * spec/rtems/config/if/get-idle-task-stack-size.yml (added) * spec/rtems/config/if/get-idle-task.yml (added) * spec/rtems/config/if/get-interrupt-stack-size.yml (added) * spec/rtems/config/if/get-maximum-barriers.yml (added) * spec/rtems/config/if/get-maximum-extensions.yml (added) * spec/rtems/config/if/get-maximum-message-queues.yml (added) * spec/rtems/config/if/get-maximum-partitions.yml (added) * spec/rtems/config/if/get-maximum-periods.yml (added) * spec/rtems/config/if/get-maximum-ports.yml (added) * spec/rtems/config/if/get-maximum-processors.yml (added) * spec/rtems/config/if/get-maximum-regions.yml (added) * spec/rtems/config/if/get-maximum-semaphores.yml (added) * spec/rtems/config/if/get-maximum-tasks.yml (added) * spec/rtems/config/if/get-maximum-timers.yml (added) * spec/rtems/config/if/get-microseconds-per-tick.yml (added) * spec/rtems/config/if/get-milliseconds-per-tick.yml (added) * spec/rtems/config/if/get-nanoseconds-per-tick.yml (added) * spec/rtems/config/if/get-number-of-initial-extensions.yml (added) * spec/rtems/config/if/get-stack-allocate-hook.yml (added) * spec/rtems/config/if/get-stack-allocate-init-hook.yml (added) * spec/rtems/config/if/get-stack-allocator-avoids-work-space.yml (added) * spec/rtems/config/if/get-stack-free-hook.yml (added) * spec/rtems/config/if/get-stack-space-size.yml (added) * spec/rtems/config/if/get-ticks-per-timeslice.yml (added) * spec/rtems/config/if/get-unified-work-area.yml (added) * spec/rtems/config/if/get-user-extension-table.yml (added) * spec/rtems/config/if/get-user-multiprocessing-table.yml (added) * spec/rtems/config/if/get-version-string.yml (moved) * spec/rtems/config/if/get-work-space-size.yml (added) * spec/rtems/config/if/group.yml (added) * spec/rtems/config/if/has-hardware-fp.yml (added) * spec/rtems/config/if/header-2.yml (added) * spec/rtems/config/if/header.yml (added) * spec/rtems/config/if/resource-is-unlimited.yml (added) * spec/rtems/config/if/resource-maximum-per-allocation.yml (added) * spec/rtems/config/if/resource-unlimited.yml (moved) * spec/rtems/config/if/stack-allocate-hook.yml (added) * spec/rtems/config/if/stack-allocate-init-hook.yml (added) * spec/rtems/config/if/stack-free-hook.yml (added) * spec/rtems/config/if/unlimited-objects.yml (added) * spec/rtems/dpmem/if/create.yml (added) * spec/rtems/dpmem/if/delete.yml (added) * spec/rtems/dpmem/if/external-to-internal.yml (added) * spec/rtems/dpmem/if/group.yml (added) * spec/rtems/dpmem/if/header.yml (added) * spec/rtems/dpmem/if/ident.yml (added) * spec/rtems/dpmem/if/internal-to-external.yml (added) * spec/rtems/event/if/all-events.yml (moved) * spec/rtems/event/if/event-0.yml (moved) * spec/rtems/event/if/event-1.yml (moved) * spec/rtems/event/if/event-10.yml (moved) * spec/rtems/event/if/event-11.yml (moved) * spec/rtems/event/if/event-12.yml (moved) * spec/rtems/event/if/event-13.yml (moved) * spec/rtems/event/if/event-14.yml (moved) * spec/rtems/event/if/event-15.yml (moved) * spec/rtems/event/if/event-16.yml (moved) * spec/rtems/event/if/event-17.yml (moved) * spec/rtems/event/if/event-18.yml (moved) * spec/rtems/event/if/event-19.yml (moved) * spec/rtems/event/if/event-2.yml (moved) * spec/rtems/event/if/event-20.yml (moved) * spec/rtems/event/if/event-21.yml (moved) * spec/rtems/event/if/event-22.yml (moved) * spec/rtems/event/if/event-23.yml (moved) * spec/rtems/event/if/event-24.yml (moved) * spec/rtems/event/if/event-25.yml (moved) * spec/rtems/event/if/event-26.yml (moved) * spec/rtems/event/if/event-27.yml (moved) * spec/rtems/event/if/event-28.yml (moved) * spec/rtems/event/if/event-29.yml (moved) * spec/rtems/event/if/event-3.yml (moved) * spec/rtems/event/if/event-30.yml (moved) * spec/rtems/event/if/event-31.yml (moved) * spec/rtems/event/if/event-4.yml (moved) * spec/rtems/event/if/event-5.yml (moved) * spec/rtems/event/if/event-6.yml (moved) * spec/rtems/event/if/event-7.yml (moved) * spec/rtems/event/if/event-8.yml (moved) * spec/rtems/event/if/event-9.yml (moved) * spec/rtems/event/if/group.yml (added) * spec/rtems/event/if/header.yml (added) * spec/rtems/event/if/pending-events.yml (moved) * spec/rtems/event/if/receive.yml (added) * spec/rtems/event/if/send.yml (added) * spec/rtems/event/if/set.yml (added) * spec/rtems/event/if/system-network-close.yml (moved) * spec/rtems/event/if/system-network-sbwait.yml (moved) * spec/rtems/event/if/system-network-sosleep.yml (moved) * spec/rtems/event/if/system-receive.yml (added) * spec/rtems/event/if/system-send.yml (added) * spec/rtems/event/if/system-server-resume.yml (moved) * spec/rtems/event/if/system-server.yml (moved) * spec/rtems/event/if/system-transient.yml (moved) * spec/rtems/event/if/transient-clear.yml (added) * spec/rtems/event/if/transient-receive.yml (added) * spec/rtems/event/if/transient-send.yml (added) * spec/rtems/event/req/event-constant.yml (moved) * spec/rtems/event/req/events.yml (moved) * spec/rtems/event/req/receive.yml (added) * spec/rtems/event/req/send-receive.yml (moved) * spec/rtems/event/req/send.yml (added) * spec/rtems/event/req/system-receive.yml (added) * spec/rtems/event/req/system-send.yml (added) * spec/rtems/event/val/send-receive.yml (added) * spec/rtems/event/val/system-send-receive.yml (added) * spec/rtems/fatal/if/assert-context.yml (moved) * spec/rtems/fatal/if/error-occurred.yml (added) * spec/rtems/fatal/if/exception-frame-print.yml (added) * spec/rtems/fatal/if/exception-frame.yml (added) * spec/rtems/fatal/if/fatal.yml (added) * spec/rtems/fatal/if/group.yml (added) * spec/rtems/fatal/if/header.yml (added) * spec/rtems/fatal/if/internal-error-text.yml (added) * spec/rtems/fatal/if/panic.yml (added) * spec/rtems/fatal/if/source-text.yml (added) * spec/rtems/if/group.yml (added) * spec/rtems/if/header.yml (added) * spec/rtems/init/if/group.yml (added) * spec/rtems/init/if/header.yml (added) * spec/rtems/init/if/initialize-executive.yml (added) * spec/rtems/init/if/shutdown-executive.yml (added) * spec/rtems/intr/if/catch.yml (added) * spec/rtems/intr/if/cause.yml (moved) * spec/rtems/intr/if/clear.yml (moved) * spec/rtems/intr/if/disable.yml (added) * spec/rtems/intr/if/enable.yml (added) * spec/rtems/intr/if/flash.yml (added) * spec/rtems/intr/if/group.yml (added) * spec/rtems/intr/if/header.yml (added) * spec/rtems/intr/if/is-in-progress.yml (added) * spec/rtems/intr/if/isr-entry.yml (added) * spec/rtems/intr/if/isr.yml (added) * spec/rtems/intr/if/level.yml (added) * spec/rtems/intr/if/local-disable.yml (added) * spec/rtems/intr/if/local-enable.yml (added) * spec/rtems/intr/if/lock-acquire-isr.yml (added) * spec/rtems/intr/if/lock-acquire.yml (added) * spec/rtems/intr/if/lock-context.yml (added) * spec/rtems/intr/if/lock-declare.yml (added) * spec/rtems/intr/if/lock-define.yml (added) * spec/rtems/intr/if/lock-destroy.yml (added) * spec/rtems/intr/if/lock-initialize.yml (added) * spec/rtems/intr/if/lock-initializer.yml (added) * spec/rtems/intr/if/lock-isr-disable.yml (added) * spec/rtems/intr/if/lock-member.yml (added) * spec/rtems/intr/if/lock-reference.yml (added) * spec/rtems/intr/if/lock-release-isr.yml (added) * spec/rtems/intr/if/lock-release.yml (added) * spec/rtems/intr/if/lock.yml (added) * spec/rtems/intr/if/vector-number.yml (added) * spec/rtems/io/if/close.yml (added) * spec/rtems/io/if/control.yml (added) * spec/rtems/io/if/device-driver-entry.yml (moved) * spec/rtems/io/if/device-driver.yml (added) * spec/rtems/io/if/device-major-number.yml (added) * spec/rtems/io/if/device-minor-number.yml (added) * spec/rtems/io/if/driver-address-table.yml (moved) * spec/rtems/io/if/driver-error.yml (added) * spec/rtems/io/if/getchark.yml (moved) * spec/rtems/io/if/group.yml (added) * spec/rtems/io/if/header.yml (added) * spec/rtems/io/if/initialize.yml (added) * spec/rtems/io/if/mount.yml (moved) * spec/rtems/io/if/open.yml (added) * spec/rtems/io/if/printer.yml (moved) * spec/rtems/io/if/printk.yml (moved) * spec/rtems/io/if/putc.yml (moved) * spec/rtems/io/if/read.yml (added) * spec/rtems/io/if/register-driver.yml (added) * spec/rtems/io/if/register-name.yml (added) * spec/rtems/io/if/unmount.yml (moved) * spec/rtems/io/if/unregister-driver.yml (added) * spec/rtems/io/if/write.yml (added) * spec/rtems/message/if/broadcast.yml (added) * spec/rtems/message/if/create.yml (added) * spec/rtems/message/if/delete.yml (added) * spec/rtems/message/if/flush.yml (added) * spec/rtems/message/if/get-number-pending.yml (added) * spec/rtems/message/if/group.yml (added) * spec/rtems/message/if/header.yml (added) * spec/rtems/message/if/ident.yml (added) * spec/rtems/message/if/receive.yml (added) * spec/rtems/message/if/send.yml (added) * spec/rtems/message/if/urgent.yml (added) * spec/rtems/message/req/ident.yml (added) * spec/rtems/message/val/ident.yml (added) * spec/rtems/mode/if/all-mode-masks.yml (moved) * spec/rtems/mode/if/asr-mask.yml (moved) * spec/rtems/mode/if/asr.yml (moved) * spec/rtems/mode/if/current-mode.yml (moved) * spec/rtems/mode/if/default.yml (moved) * spec/rtems/mode/if/group.yml (added) * spec/rtems/mode/if/header.yml (added) * spec/rtems/mode/if/interrupt-level-body.yml (added) * spec/rtems/mode/if/interrupt-level.yml (moved) * spec/rtems/mode/if/interrupt-mask-variable.yml (added) * spec/rtems/mode/if/interrupt-mask.yml (added) * spec/rtems/mode/if/mode.yml (added) * spec/rtems/mode/if/no-asr.yml (moved) * spec/rtems/mode/if/no-preempt.yml (moved) * spec/rtems/mode/if/no-timeslice.yml (moved) * spec/rtems/mode/if/preempt-mask.yml (moved) * spec/rtems/mode/if/preempt.yml (moved) * spec/rtems/mode/if/timeslice-mask.yml (moved) * spec/rtems/mode/if/timeslice.yml (moved) * spec/rtems/mode/req/bit-set.yml (added) * spec/rtems/mode/req/default.yml (added) * spec/rtems/mode/req/masks-all.yml (added) * spec/rtems/mode/req/masks-unique.yml (added) * spec/rtems/mode/req/masks.yml (added) * spec/rtems/mode/req/unique.yml (added) * spec/rtems/mode/val/modes.yml (added) * spec/rtems/mp/if/announce.yml (moved) * spec/rtems/mp/if/group.yml (added) * spec/rtems/mp/if/header.yml (added) * spec/rtems/object/if/api-class-information.yml (added) * spec/rtems/object/if/api-maximum-class.yml (moved) * spec/rtems/object/if/api-minimum-class.yml (moved) * spec/rtems/object/if/build-id.yml (added) * spec/rtems/object/if/build-name.yml (added) * spec/rtems/object/if/get-api-class-name.yml (moved) * spec/rtems/object/if/get-api-name.yml (moved) * spec/rtems/object/if/get-class-information.yml (added) * spec/rtems/object/if/get-classic-name.yml (added) * spec/rtems/object/if/get-local-node.yml (added) * spec/rtems/object/if/get-name.yml (added) * spec/rtems/object/if/group.yml (added) * spec/rtems/object/if/header.yml (added) * spec/rtems/object/if/id-api-maximum-class.yml (moved) * spec/rtems/object/if/id-api-maximum.yml (added) * spec/rtems/object/if/id-api-minimum.yml (added) * spec/rtems/object/if/id-final-index.yml (added) * spec/rtems/object/if/id-final.yml (added) * spec/rtems/object/if/id-get-api.yml (added) * spec/rtems/object/if/id-get-class.yml (added) * spec/rtems/object/if/id-get-index.yml (added) * spec/rtems/object/if/id-get-node.yml (added) * spec/rtems/object/if/id-initial-index.yml (added) * spec/rtems/object/if/id-initial.yml (added) * spec/rtems/object/if/search-all-nodes.yml (added) * spec/rtems/object/if/search-local-node.yml (added) * spec/rtems/object/if/search-other-nodes.yml (added) * spec/rtems/object/if/set-name.yml (added) * spec/rtems/object/if/who-am-i.yml (added) * spec/rtems/option/if/default.yml (moved) * spec/rtems/option/if/event-all.yml (moved) * spec/rtems/option/if/event-any.yml (moved) * spec/rtems/option/if/group.yml (added) * spec/rtems/option/if/header.yml (added) * spec/rtems/option/if/no-wait.yml (moved) * spec/rtems/option/if/option.yml (added) * spec/rtems/option/if/wait.yml (moved) * spec/rtems/option/req/bit-set.yml (added) * spec/rtems/option/req/default.yml (added) * spec/rtems/option/req/unique.yml (added) * spec/rtems/option/val/options.yml (added) * spec/rtems/part/if/create.yml (added) * spec/rtems/part/if/delete.yml (added) * spec/rtems/part/if/get-buffer.yml (added) * spec/rtems/part/if/group.yml (added) * spec/rtems/part/if/header.yml (added) * spec/rtems/part/if/ident.yml (added) * spec/rtems/part/if/return-buffer.yml (added) * spec/rtems/part/req/ident.yml (added) * spec/rtems/part/val/ident.yml (added) * spec/rtems/ratemon/if/active.yml (moved) * spec/rtems/ratemon/if/cancel.yml (added) * spec/rtems/ratemon/if/create.yml (added) * spec/rtems/ratemon/if/delete.yml (added) * spec/rtems/ratemon/if/expired.yml (moved) * spec/rtems/ratemon/if/get-statistics.yml (added) * spec/rtems/ratemon/if/get-status.yml (added) * spec/rtems/ratemon/if/group.yml (added) * spec/rtems/ratemon/if/header.yml (added) * spec/rtems/ratemon/if/ident.yml (added) * spec/rtems/ratemon/if/inactive.yml (moved) * spec/rtems/ratemon/if/period-states.yml (moved) * spec/rtems/ratemon/if/period-statistics.yml (added) * spec/rtems/ratemon/if/period-status-define.yml (added) * spec/rtems/ratemon/if/period-status.yml (added) * spec/rtems/ratemon/if/period.yml (added) * spec/rtems/ratemon/if/printer.yml (added) * spec/rtems/ratemon/if/report-statistics-with-plugin.yml (moved) * spec/rtems/ratemon/if/report-statistics.yml (moved) * spec/rtems/ratemon/if/reset-all-statistics.yml (moved) * spec/rtems/ratemon/if/reset-statistics.yml (added) * spec/rtems/ratemon/req/ident.yml (added) * spec/rtems/ratemon/val/ident.yml (added) * spec/rtems/region/if/create.yml (added) * spec/rtems/region/if/delete.yml (added) * spec/rtems/region/if/extend.yml (added) * spec/rtems/region/if/get-free-information.yml (added) * spec/rtems/region/if/get-information.yml (added) * spec/rtems/region/if/get-segment-size.yml (added) * spec/rtems/region/if/get-segment.yml (added) * spec/rtems/region/if/group.yml (added) * spec/rtems/region/if/header.yml (added) * spec/rtems/region/if/ident.yml (added) * spec/rtems/region/if/resize-segment.yml (added) * spec/rtems/region/if/return-segment.yml (added) * spec/rtems/req/ident-local.yml (moved) * spec/rtems/req/ident.yml (moved) * spec/rtems/scheduler/if/add-processor.yml (added) * spec/rtems/scheduler/if/get-maximum-priority.yml (added) * spec/rtems/scheduler/if/get-processor-maximum.yml (added) * spec/rtems/scheduler/if/get-processor-set.yml (added) * spec/rtems/scheduler/if/get-processor.yml (added) * spec/rtems/scheduler/if/ident-by-processor-set.yml (added) * spec/rtems/scheduler/if/ident-by-processor.yml (added) * spec/rtems/scheduler/if/ident.yml (added) * spec/rtems/scheduler/if/map-priority-from-posix.yml (added) * spec/rtems/scheduler/if/map-priority-to-posix.yml (added) * spec/rtems/scheduler/if/remove-processor.yml (added) * spec/rtems/sem/if/create.yml (added) * spec/rtems/sem/if/delete.yml (added) * spec/rtems/sem/if/flush.yml (added) * spec/rtems/sem/if/group.yml (added) * spec/rtems/sem/if/header.yml (added) * spec/rtems/sem/if/ident.yml (added) * spec/rtems/sem/if/obtain.yml (added) * spec/rtems/sem/if/release.yml (added) * spec/rtems/sem/if/set-priority.yml (added) * spec/rtems/sem/req/ident.yml (added) * spec/rtems/sem/val/ident.yml (added) * spec/rtems/signal/if/asr-entry.yml (moved) * spec/rtems/signal/if/asr.yml (moved) * spec/rtems/signal/if/catch.yml (added) * spec/rtems/signal/if/group.yml (added) * spec/rtems/signal/if/header-2.yml (added) * spec/rtems/signal/if/header.yml (added) * spec/rtems/signal/if/send.yml (added) * spec/rtems/signal/if/set.yml (added) * spec/rtems/signal/if/signal-0.yml (moved) * spec/rtems/signal/if/signal-1.yml (moved) * spec/rtems/signal/if/signal-10.yml (moved) * spec/rtems/signal/if/signal-11.yml (moved) * spec/rtems/signal/if/signal-12.yml (moved) * spec/rtems/signal/if/signal-13.yml (moved) * spec/rtems/signal/if/signal-14.yml (moved) * spec/rtems/signal/if/signal-15.yml (moved) * spec/rtems/signal/if/signal-16.yml (moved) * spec/rtems/signal/if/signal-17.yml (moved) * spec/rtems/signal/if/signal-18.yml (moved) * spec/rtems/signal/if/signal-19.yml (moved) * spec/rtems/signal/if/signal-2.yml (moved) * spec/rtems/signal/if/signal-20.yml (moved) * spec/rtems/signal/if/signal-21.yml (moved) * spec/rtems/signal/if/signal-22.yml (moved) * spec/rtems/signal/if/signal-23.yml (moved) * spec/rtems/signal/if/signal-24.yml (moved) * spec/rtems/signal/if/signal-25.yml (moved) * spec/rtems/signal/if/signal-26.yml (moved) * spec/rtems/signal/if/signal-27.yml (moved) * spec/rtems/signal/if/signal-28.yml (moved) * spec/rtems/signal/if/signal-29.yml (moved) * spec/rtems/signal/if/signal-3.yml (moved) * spec/rtems/signal/if/signal-30.yml (moved) * spec/rtems/signal/if/signal-31.yml (moved) * spec/rtems/signal/if/signal-4.yml (moved) * spec/rtems/signal/if/signal-5.yml (moved) * spec/rtems/signal/if/signal-6.yml (moved) * spec/rtems/signal/if/signal-7.yml (moved) * spec/rtems/signal/if/signal-8.yml (moved) * spec/rtems/signal/if/signal-9.yml (moved) * spec/rtems/status/if/already-suspended.yml (moved) * spec/rtems/status/if/called-from-isr.yml (moved) * spec/rtems/status/if/code-to-errno.yml (moved) * spec/rtems/status/if/code.yml (moved) * spec/rtems/status/if/first.yml (moved) * spec/rtems/status/if/group.yml (added) * spec/rtems/status/if/header.yml (added) * spec/rtems/status/if/illegal-on-remote-object.yml (moved) * spec/rtems/status/if/illegal-on-self.yml (moved) * spec/rtems/status/if/incorrect-state.yml (moved) * spec/rtems/status/if/internal-error.yml (moved) * spec/rtems/status/if/interrupted.yml (moved) * spec/rtems/status/if/invalid-address.yml (moved) * spec/rtems/status/if/invalid-clock.yml (moved) * spec/rtems/status/if/invalid-id.yml (moved) * spec/rtems/status/if/invalid-name.yml (moved) * spec/rtems/status/if/invalid-node.yml (moved) * spec/rtems/status/if/invalid-number.yml (moved) * spec/rtems/status/if/invalid-priority.yml (moved) * spec/rtems/status/if/invalid-size.yml (moved) * spec/rtems/status/if/io-error.yml (moved) * spec/rtems/status/if/is-equal.yml (added) * spec/rtems/status/if/is-successful.yml (added) * spec/rtems/status/if/last.yml (moved) * spec/rtems/status/if/mp-not-configured.yml (moved) * spec/rtems/status/if/no-memory.yml (moved) * spec/rtems/status/if/not-configured.yml (moved) * spec/rtems/status/if/not-defined.yml (moved) * spec/rtems/status/if/not-implemented.yml (moved) * spec/rtems/status/if/not-owner-of-resource.yml (moved) * spec/rtems/status/if/object-was-deleted.yml (moved) * spec/rtems/status/if/proxy-blocking.yml (moved) * spec/rtems/status/if/resource-in-use.yml (moved) * spec/rtems/status/if/successful.yml (moved) * spec/rtems/status/if/task-exitted.yml (moved) * spec/rtems/status/if/text.yml (moved) * spec/rtems/status/if/timeout.yml (moved) * spec/rtems/status/if/too-many.yml (moved) * spec/rtems/status/if/unsatisfied.yml (moved) * spec/rtems/support/if/group.yml (added) * spec/rtems/support/if/header.yml (added) * spec/rtems/support/if/is-name-valid.yml (added) * spec/rtems/support/if/microseconds-to-ticks.yml (added) * spec/rtems/support/if/milliseconds-to-microseconds.yml (moved) * spec/rtems/support/if/milliseconds-to-ticks.yml (added) * spec/rtems/support/if/name-to-characters.yml (added) * spec/rtems/support/if/workspace-allocate.yml (added) * spec/rtems/support/if/workspace-free.yml (added) * spec/rtems/support/if/workspace-get-information.yml (added) * spec/rtems/support/if/workspace-greedy-allocate-all-except-largest.yml (added) * spec/rtems/support/if/workspace-greedy-allocate.yml (added) * spec/rtems/support/if/workspace-greedy-free.yml (moved) * spec/rtems/task/if/argument.yml (added) * spec/rtems/task/if/config.yml (added) * spec/rtems/task/if/configured-minimum-stack-size.yml (moved) * spec/rtems/task/if/construct.yml (added) * spec/rtems/task/if/create.yml (added) * spec/rtems/task/if/current-priority.yml (moved) * spec/rtems/task/if/delete.yml (added) * spec/rtems/task/if/entry.yml (moved) * spec/rtems/task/if/exit.yml (added) * spec/rtems/task/if/get-affinity.yml (added) * spec/rtems/task/if/get-priority.yml (added) * spec/rtems/task/if/get-scheduler.yml (added) * spec/rtems/task/if/group.yml (added) * spec/rtems/task/if/header.yml (added) * spec/rtems/task/if/ident.yml (added) * spec/rtems/task/if/initialization-table.yml (added) * spec/rtems/task/if/is-suspended.yml (added) * spec/rtems/task/if/iterate.yml (moved) * spec/rtems/task/if/maximum-priority.yml (added) * spec/rtems/task/if/minimum-priority.yml (moved) * spec/rtems/task/if/minimum-stack-size.yml (added) * spec/rtems/task/if/mode.yml (added) * spec/rtems/task/if/no-priority.yml (moved) * spec/rtems/task/if/priority.yml (added) * spec/rtems/task/if/restart.yml (added) * spec/rtems/task/if/resume.yml (added) * spec/rtems/task/if/self-define.yml (added) * spec/rtems/task/if/self.yml (added) * spec/rtems/task/if/set-affinity.yml (added) * spec/rtems/task/if/set-priority.yml (added) * spec/rtems/task/if/set-scheduler.yml (added) * spec/rtems/task/if/start.yml (added) * spec/rtems/task/if/storage-alignment.yml (added) * spec/rtems/task/if/storage-size.yml (added) * spec/rtems/task/if/suspend.yml (added) * spec/rtems/task/if/task.yml (moved) * spec/rtems/task/if/tcb.yml (moved) * spec/rtems/task/if/visitor.yml (added) * spec/rtems/task/if/wake-after.yml (added) * spec/rtems/task/if/wake-when.yml (added) * spec/rtems/task/if/yield-processor.yml (added) * spec/rtems/task/req/construct-errors.yml (added) * spec/rtems/task/req/ident.yml (added) * spec/rtems/timer/if/cancel.yml (added) * spec/rtems/timer/if/class-bit-not-dormant.yml (moved) * spec/rtems/timer/if/class-bit-on-task.yml (moved) * spec/rtems/timer/if/class-bit-time-of-day.yml (moved) * spec/rtems/timer/if/classes.yml (moved) * spec/rtems/timer/if/create.yml (added) * spec/rtems/timer/if/delete.yml (added) * spec/rtems/timer/if/dormant.yml (moved) * spec/rtems/timer/if/fire-after.yml (added) * spec/rtems/timer/if/fire-when.yml (added) * spec/rtems/timer/if/get-information.yml (added) * spec/rtems/timer/if/group.yml (added) * spec/rtems/timer/if/header.yml (added) * spec/rtems/timer/if/ident.yml (added) * spec/rtems/timer/if/information.yml (added) * spec/rtems/timer/if/initiate-server.yml (added) * spec/rtems/timer/if/interval-on-task.yml (moved) * spec/rtems/timer/if/interval.yml (moved) * spec/rtems/timer/if/reset.yml (added) * spec/rtems/timer/if/server-default-priority.yml (added) * spec/rtems/timer/if/server-fire-after.yml (added) * spec/rtems/timer/if/server-fire-when.yml (added) * spec/rtems/timer/if/service-routine-entry.yml (added) * spec/rtems/timer/if/service-routine.yml (moved) * spec/rtems/timer/if/time-of-day-on-task.yml (moved) * spec/rtems/timer/if/time-of-day.yml (moved) * spec/rtems/timer/req/ident.yml (added) * spec/rtems/timer/val/ident.yml (added) * spec/rtems/type/if/group.yml (added) * spec/rtems/type/if/header.yml (added) * spec/rtems/type/if/id-none.yml (added) * spec/rtems/type/if/id.yml (added) * spec/rtems/type/if/interval.yml (added) * spec/rtems/type/if/minimum-packet-size.yml (added) * spec/rtems/type/if/minimun-hetero-conversion.yml (added) * spec/rtems/type/if/mp-packet-classes.yml (added) * spec/rtems/type/if/mpci-entry.yml (moved) * spec/rtems/type/if/mpci-get-packet-entry.yml (added) * spec/rtems/type/if/mpci-initialization-entry.yml (added) * spec/rtems/type/if/mpci-receive-packet-entry.yml (added) * spec/rtems/type/if/mpci-return-packet-entry.yml (added) * spec/rtems/type/if/mpci-send-packet-entry.yml (added) * spec/rtems/type/if/mpci-table.yml (added) * spec/rtems/type/if/multiprocessing-table.yml (added) * spec/rtems/type/if/name.yml (added) * spec/rtems/type/if/no-timeout.yml (added) * spec/rtems/type/if/packet-prefix.yml (added) * spec/rtems/type/if/time-of-day.yml (added) * spec/rtems/userext/if/create.yml (added) * spec/rtems/userext/if/delete.yml (added) * spec/rtems/userext/if/fatal-code.yml (added) * spec/rtems/userext/if/fatal-source.yml (added) * spec/rtems/userext/if/fatal.yml (added) * spec/rtems/userext/if/group.yml (added) * spec/rtems/userext/if/header.yml (added) * spec/rtems/userext/if/ident.yml (added) * spec/rtems/userext/if/table.yml (added) * spec/rtems/userext/if/task-begin.yml (added) * spec/rtems/userext/if/task-create.yml (added) * spec/rtems/userext/if/task-delete.yml (added) * spec/rtems/userext/if/task-exitted.yml (added) * spec/rtems/userext/if/task-restart.yml (added) * spec/rtems/userext/if/task-start.yml (added) * spec/rtems/userext/if/task-switch.yml (added) * spec/rtems/userext/if/task-terminate.yml (added) * spec/rtems/userext/req/ident.yml (added) * spec/rtems/userext/val/ident.yml (added) * spec/score/context/if/fp-size.yml (moved) * spec/score/context/if/header.yml (added) * spec/score/cpu/if/all-tasks-are-fp.yml (moved) * spec/score/cpu/if/exception-frame-print.yml (moved) * spec/score/cpu/if/exception-frame.yml (moved) * spec/score/cpu/if/hardware-fp.yml (moved) * spec/score/cpu/if/header.yml (added) * spec/score/cpu/if/heap-alignment.yml (moved) * spec/score/cpu/if/interrupt-frame.yml (moved) * spec/score/cpu/if/interrupt-stack-alignment.yml (moved) * spec/score/cpu/if/isr-passes-frame-pointer.yml (moved) * spec/score/cpu/if/maximum-processors.yml (moved) * spec/score/cpu/if/modes-interrupt-mask.yml (moved) * spec/score/cpu/if/simple-vectored-interrupts.yml (moved) * spec/score/cpu/if/stack-minimum-size.yml (moved) * spec/score/cpu/if/uint32ptr.yml (moved) * spec/score/heap/if/header.yml (added) * spec/score/heap/if/information-block.yml (moved) * spec/score/if/assert-unreachable.yml (added) * spec/score/if/dequalify-types-not-compatible.yml (added) * spec/score/if/domain.yml (moved) * spec/score/if/maximum-priority.yml (added) * spec/score/if/tod-to-seconds.yml (added) * spec/score/if/tod-validate.yml (added) * spec/score/interr/if/code.yml (moved) * spec/score/interr/if/header.yml (added) * spec/score/interr/if/source.yml (moved) * spec/score/interr/if/terminate.yml (moved) * spec/score/isr/if/handler-entry.yml (moved) * spec/score/isr/if/handler.yml (moved) * spec/score/isr/if/header-2.yml (added) * spec/score/isr/if/header-3.yml (added) * spec/score/isr/if/header.yml (added) * spec/score/isr/if/is-in-progress.yml (moved) * spec/score/isr/if/level.yml (moved) * spec/score/isr/if/local-disable.yml (moved) * spec/score/isr/if/local-enable.yml (moved) * spec/score/isr/if/local-flash.yml (moved) * spec/score/isr/if/lock-context.yml (moved) * spec/score/isr/if/lock-control.yml (moved) * spec/score/isr/if/lock-declare.yml (moved) * spec/score/isr/if/lock-define.yml (moved) * spec/score/isr/if/lock-destroy.yml (moved) * spec/score/isr/if/lock-initialize.yml (moved) * spec/score/isr/if/lock-initializer.yml (moved) * spec/score/isr/if/lock-isr-disable-acquire.yml (moved) * spec/score/isr/if/lock-isr-disable.yml (moved) * spec/score/isr/if/lock-member.yml (moved) * spec/score/isr/if/lock-reference.yml (moved) * spec/score/isr/if/lock-release-isr-enable.yml (moved) * spec/score/isr/if/stack-size.yml (moved) * spec/score/isr/if/vector-number.yml (moved) * spec/score/memory/if/header.yml (added) * spec/score/memory/if/zero-before-use.yml (moved) * spec/score/mpci/if/configuration-type.yml (moved) * spec/score/mpci/if/configuration.yml (moved) * spec/score/mpci/if/control.yml (moved) * spec/score/mpci/if/entry.yml (moved) * spec/score/mpci/if/get-packet-entry.yml (moved) * spec/score/mpci/if/header-2.yml (added) * spec/score/mpci/if/header.yml (added) * spec/score/mpci/if/initialization-entry.yml (moved) * spec/score/mpci/if/packet-classes.yml (moved) * spec/score/mpci/if/packet-minimum-hetero-conversion.yml (moved) * spec/score/mpci/if/packet-minimum-size.yml (moved) * spec/score/mpci/if/packet-prefix.yml (moved) * spec/score/mpci/if/receive-entry.yml (moved) * spec/score/mpci/if/return-packet-entry.yml (moved) * spec/score/mpci/if/send-entry.yml (moved) * spec/score/object/if/apis-last.yml (moved) * spec/score/object/if/build-id.yml (moved) * spec/score/object/if/build-name.yml (moved) * spec/score/object/if/get-api.yml (moved) * spec/score/object/if/get-class.yml (moved) * spec/score/object/if/get-index.yml (moved) * spec/score/object/if/get-node.yml (moved) * spec/score/object/if/header.yml (added) * spec/score/object/if/id-final-index.yml (moved) * spec/score/object/if/id-final.yml (moved) * spec/score/object/if/id-initial-index.yml (moved) * spec/score/object/if/id-initial.yml (moved) * spec/score/object/if/id-none.yml (moved) * spec/score/object/if/id-of-self.yml (moved) * spec/score/object/if/id.yml (moved) * spec/score/object/if/internal-api.yml (moved) * spec/score/object/if/is-unlimited.yml (moved) * spec/score/object/if/local-node.yml (moved) * spec/score/object/if/maximum-per-allocation.yml (moved) * spec/score/object/if/search-all-nodes.yml (moved) * spec/score/object/if/search-local-nodes.yml (moved) * spec/score/object/if/search-other-nodes.yml (moved) * spec/score/object/if/unlimited-objects.yml (moved) * spec/score/object/if/who-am-i.yml (moved) * spec/score/smp/if/get-current-processor.yml (moved) * spec/score/smp/if/get-processor-maximum.yml (moved) * spec/score/smp/if/header-2.yml (added) * spec/score/smp/if/header.yml (added) * spec/score/smp/if/lock-acquire.yml (moved) * spec/score/smp/if/lock-release.yml (moved) * spec/score/smp/if/processor-configured-maximum.yml (moved) * spec/score/stack/if/allocator-allocate-type.yml (moved) * spec/score/stack/if/allocator-allocate.yml (moved) * spec/score/stack/if/allocator-avoids-workspace.yml (moved) * spec/score/stack/if/allocator-free-type.yml (moved) * spec/score/stack/if/allocator-free.yml (moved) * spec/score/stack/if/allocator-initialize-type.yml (moved) * spec/score/stack/if/allocator-initialize.yml (moved) * spec/score/stack/if/header.yml (added) * spec/score/stack/if/minimum-size.yml (moved) * spec/score/thread/if/header.yml (added) * spec/score/thread/if/idle-body.yml (moved) * spec/score/thread/if/idle-stack-size.yml (moved) * spec/score/userext/if/fatal.yml (moved) * spec/score/userext/if/header.yml (added) * spec/score/userext/if/initial-count.yml (moved) * spec/score/userext/if/initial-extensions.yml (moved) * spec/score/userext/if/table.yml (moved) * spec/score/userext/if/thread-begin.yml (moved) * spec/score/userext/if/thread-create.yml (moved) * spec/score/userext/if/thread-delete.yml (moved) * spec/score/userext/if/thread-exitted.yml (moved) * spec/score/userext/if/thread-restart.yml (moved) * spec/score/userext/if/thread-start.yml (moved) * spec/score/userext/if/thread-switch.yml (moved) * spec/score/userext/if/thread-terminate.yml (moved) * spec/score/watchdog/if/header.yml (added) * spec/score/watchdog/if/interval.yml (moved) * spec/score/watchdog/if/microseconds-per-tick.yml (moved) * spec/score/watchdog/if/nanoseconds-per-tick.yml (moved) * spec/score/watchdog/if/no-timeout.yml (moved) * spec/score/watchdog/if/ticks-per-second.yml (moved) * spec/score/watchdog/if/ticks-per-timeslice.yml (moved) * spec/score/watchdog/if/ticks-since-boot.yml (moved) * spec/score/wkspace/if/header.yml (added) * spec/score/wkspace/if/is-unified.yml (moved) * spec/score/wkspace/if/size.yml (moved) * spec/user/if/asm.yml (moved) * spec/user/if/container.yml (added) * spec/user/if/domain.yml (moved) * spec/user/if/false.yml (moved) * spec/user/if/true.yml (moved) spec: Group items by component
