# # ChangeLog for spec/glos/term/partition.yml in rtems-central # # Generated by Trac 1.2.1.dev0 # 05/17/24 05:50:36 Wed, 06 May 2020 08:31:57 GMT Sebastian Huber [a5f3cc1] * rtemsqual/content.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/tests/spec-glossary/glos/term/t.yml (modified) * rtemsqual/tests/spec-sphinx/x.yml (added) * rtemsqual/tests/test_content_sphinx.py (modified) * rtemsqual/tests/test_glossary.py (modified) * spec/glos/term/asr.yml (modified) * spec/glos/term/assemblerlanguage.yml (modified) * spec/glos/term/atomicoperations.yml (modified) * spec/glos/term/bsp.yml (modified) * spec/glos/term/clanguage.yml (modified) * spec/glos/term/cpu.yml (modified) * spec/glos/term/errorcode.yml (modified) * spec/glos/term/fifo.yml (modified) * spec/glos/term/gnat.yml (modified) * spec/glos/term/interruptservice.yml (modified) * spec/glos/term/isr.yml (modified) * spec/glos/term/mpci.yml (modified) * spec/glos/term/partition.yml (modified) * spec/glos/term/ptcb.yml (modified) * spec/glos/term/pxcb.yml (modified) * spec/glos/term/qcb.yml (modified) * spec/glos/term/returncode.yml (modified) * spec/glos/term/returnvalue.yml (modified) * spec/glos/term/rncb.yml (modified) * spec/glos/term/smcb.yml (modified) * spec/glos/term/softwarecomponent.yml (modified) * spec/glos/term/softwareitem.yml (modified) * spec/glos/term/softwareproduct.yml (modified) * spec/glos/term/softwareunit.yml (modified) * spec/glos/term/statuscode.yml (modified) * spec/glos/term/task.yml (modified) * spec/glos/term/tcb.yml (modified) * spec/glos/term/thread.yml (modified) * spec/glos/term/tls.yml (modified) * spec/glos/term/tmcb.yml (modified) * spec/glos/term/usersupplied.yml (modified) spec: Use item mapper for glossary terms Mon, 20 Apr 2020 05:26:15 GMT Sebastian Huber [71d8b3c] * config.yml (modified) * rtems_spec_to_x.py (modified) * rtemsqual/applconfig.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/items.py (modified) * rtemsqual/tests/spec-applconfig/a.yml (modified) * rtemsqual/tests/spec-applconfig/b.yml (modified) * rtemsqual/tests/spec-applconfig/c.yml (modified) * rtemsqual/tests/spec-applconfig/e.yml (modified) * rtemsqual/tests/spec-applconfig/f.yml (modified) * rtemsqual/tests/spec-applconfig/h.yml (modified) * rtemsqual/tests/spec-applconfig/i.yml (modified) * rtemsqual/tests/spec-applconfig/j.yml (modified) * rtemsqual/tests/spec-applconfig/k.yml (modified) * rtemsqual/tests/spec-applconfig/l.yml (modified) * rtemsqual/tests/spec-applconfig/m.yml (modified) * rtemsqual/tests/spec-build/bsp.yml (modified) * rtemsqual/tests/spec-build/o.yml (modified) * rtemsqual/tests/spec-glossary/glos/g.yml (moved) * rtemsqual/tests/spec-glossary/glos/term/t.yml (moved) * rtemsqual/tests/spec-glossary/glos/term/u.yml (moved) * rtemsqual/tests/spec-glossary/glos/term/v.yml (moved) * rtemsqual/tests/spec-item-cache/d/c.yml (modified) * rtemsqual/tests/test_applconfig.py (modified) * rtemsqual/tests/test_build.py (modified) * rtemsqual/tests/test_glossary.py (modified) * rtemsqual/tests/test_items_item.py (modified) * rtemsqual/tests/test_items_itemcache.py (modified) * spec/.doorstop.yml (deleted) * spec/RTEMS-GLOSSARY.yml (deleted) * spec/acfg/.doorstop.yml (deleted) * spec/acfg/bdbuf.yml (moved) * spec/acfg/bsp.yml (moved) * spec/acfg/classic.yml (moved) * spec/acfg/classicinit.yml (moved) * spec/acfg/devdrv.yml (moved) * spec/acfg/eventrecord.yml (moved) * spec/acfg/filesystem.yml (moved) * spec/acfg/general.yml (moved) * spec/acfg/idle.yml (moved) * spec/acfg/mpci.yml (moved) * spec/acfg/opt/.doorstop.yml (deleted) * spec/acfg/opt/appldisablefilesystem.yml (moved) * spec/acfg/opt/appldoesnotneedclockdriver.yml (moved) * spec/acfg/opt/applextradrivers.yml (moved) * spec/acfg/opt/applneedsatadriver.yml (moved) * spec/acfg/opt/applneedsclockdriver.yml (moved) * spec/acfg/opt/applneedsconsoledriver.yml (moved) * spec/acfg/opt/applneedsframebufferdriver.yml (moved) * spec/acfg/opt/applneedsidedriver.yml (moved) * spec/acfg/opt/applneedslibblock.yml (moved) * spec/acfg/opt/applneedsnulldriver.yml (moved) * spec/acfg/opt/applneedsrtcdriver.yml (moved) * spec/acfg/opt/applneedssimpleconsoledriver.yml (moved) * spec/acfg/opt/applneedssimpletaskconsoledriver.yml (moved) * spec/acfg/opt/applneedsstubdriver.yml (moved) * spec/acfg/opt/applneedstimerdriver.yml (moved) * spec/acfg/opt/applneedswatchdogdriver.yml (moved) * spec/acfg/opt/applneedszerodriver.yml (moved) * spec/acfg/opt/applprerequisitedrivers.yml (moved) * spec/acfg/opt/atadrivertaskpriority.yml (moved) * spec/acfg/opt/bdbufbuffermaxsize.yml (moved) * spec/acfg/opt/bdbufbufferminsize.yml (moved) * spec/acfg/opt/bdbufcachememorysize.yml (moved) * spec/acfg/opt/bdbufmaxreadaheadblocks.yml (moved) * spec/acfg/opt/bdbufmaxwriteblocks.yml (moved) * spec/acfg/opt/bdbufreadaheadtaskpriority.yml (moved) * spec/acfg/opt/bdbuftaskstacksize.yml (moved) * spec/acfg/opt/bspidletaskbody.yml (moved) * spec/acfg/opt/bspidletaskstacksize.yml (moved) * spec/acfg/opt/bspinitialextension.yml (moved) * spec/acfg/opt/bspinterruptstacksize.yml (moved) * spec/acfg/opt/bspprerequisitedrivers.yml (moved) * spec/acfg/opt/cbsmaximumservers.yml (moved) * spec/acfg/opt/constraintbspappmin.yml (moved) * spec/acfg/opt/constraintidlestackarea.yml (moved) * spec/acfg/opt/constraintisrstackalign.yml (moved) * spec/acfg/opt/constraintisrstackarea.yml (moved) * spec/acfg/opt/constraintmemsz.yml (moved) * spec/acfg/opt/constraintposix.yml (moved) * spec/acfg/opt/constraintprioclassic.yml (moved) * spec/acfg/opt/constraintstackspace.yml (moved) * spec/acfg/opt/constraintunlimited.yml (moved) * spec/acfg/opt/constraintwkspace.yml (moved) * spec/acfg/opt/dirtymemory.yml (moved) * spec/acfg/opt/disablebspsettings.yml (moved) * spec/acfg/opt/disablenewlibreentrancy.yml (moved) * spec/acfg/opt/executiveramsize.yml (moved) * spec/acfg/opt/extrataskstacks.yml (moved) * spec/acfg/opt/filesystemall.yml (moved) * spec/acfg/opt/filesystemdosfs.yml (moved) * spec/acfg/opt/filesystemftpfs.yml (moved) * spec/acfg/opt/filesystemimfs.yml (moved) * spec/acfg/opt/filesystemjffs2.yml (moved) * spec/acfg/opt/filesystemnfs.yml (moved) * spec/acfg/opt/filesystemrfs.yml (moved) * spec/acfg/opt/filesystemtftpfs.yml (moved) * spec/acfg/opt/idletaskbody.yml (moved) * spec/acfg/opt/idletaskinitappl.yml (moved) * spec/acfg/opt/idletaskstacksize.yml (moved) * spec/acfg/opt/imfsdisablechmod.yml (moved) * spec/acfg/opt/imfsdisablechown.yml (moved) * spec/acfg/opt/imfsdisablelink.yml (moved) * spec/acfg/opt/imfsdisablemknod.yml (moved) * spec/acfg/opt/imfsdisablemknoddevice.yml (moved) * spec/acfg/opt/imfsdisablemknodfile.yml (moved) * spec/acfg/opt/imfsdisablemount.yml (moved) * spec/acfg/opt/imfsdisablereaddir.yml (moved) * spec/acfg/opt/imfsdisablereadlink.yml (moved) * spec/acfg/opt/imfsdisablerename.yml (moved) * spec/acfg/opt/imfsdisablermnod.yml (moved) * spec/acfg/opt/imfsdisablesymlink.yml (moved) * spec/acfg/opt/imfsdisableunmount.yml (moved) * spec/acfg/opt/imfsdisableutime.yml (moved) * spec/acfg/opt/imfsenablemkfifo.yml (moved) * spec/acfg/opt/imfsmemfilebytesperblock.yml (moved) * spec/acfg/opt/initialextensions.yml (moved) * spec/acfg/opt/inittaskarguments.yml (moved) * spec/acfg/opt/inittaskattributes.yml (moved) * spec/acfg/opt/inittaskentrypoint.yml (moved) * spec/acfg/opt/inittaskinitialmodes.yml (moved) * spec/acfg/opt/inittaskname.yml (moved) * spec/acfg/opt/inittaskpriority.yml (moved) * spec/acfg/opt/inittaskstacksize.yml (moved) * spec/acfg/opt/interruptstacksize.yml (moved) * spec/acfg/opt/mallocbspsupportssbrk.yml (moved) * spec/acfg/opt/mallocdirty.yml (moved) * spec/acfg/opt/maxbarriers.yml (moved) * spec/acfg/opt/maxdrivers.yml (moved) * spec/acfg/opt/maxfiledescriptors.yml (moved) * spec/acfg/opt/maxmessagequeues.yml (moved) * spec/acfg/opt/maxpartitions.yml (moved) * spec/acfg/opt/maxperiods.yml (moved) * spec/acfg/opt/maxports.yml (moved) * spec/acfg/opt/maxposixkeys.yml (moved) * spec/acfg/opt/maxposixkeyvaluepairs.yml (moved) * spec/acfg/opt/maxposixmessagequeues.yml (moved) * spec/acfg/opt/maxposixqueuedsignals.yml (moved) * spec/acfg/opt/maxposixsemaphores.yml (moved) * spec/acfg/opt/maxposixshms.yml (moved) * spec/acfg/opt/maxposixthreads.yml (moved) * spec/acfg/opt/maxposixtimers.yml (moved) * spec/acfg/opt/maxpriority.yml (moved) * spec/acfg/opt/maxprocessors.yml (moved) * spec/acfg/opt/maxregions.yml (moved) * spec/acfg/opt/maxsemaphores.yml (moved) * spec/acfg/opt/maxtasks.yml (moved) * spec/acfg/opt/maxthreadnamesize.yml (moved) * spec/acfg/opt/maxtimers.yml (moved) * spec/acfg/opt/maxuserextensions.yml (moved) * spec/acfg/opt/memoryoverhead.yml (moved) * spec/acfg/opt/messagebuffermemory.yml (moved) * spec/acfg/opt/microsecondspertick.yml (moved) * spec/acfg/opt/minposixthreadstacksize.yml (moved) * spec/acfg/opt/mintaskstacksize.yml (moved) * spec/acfg/opt/mpappl.yml (moved) * spec/acfg/opt/mpextraserverstack.yml (moved) * spec/acfg/opt/mpmaxglobalobjects.yml (moved) * spec/acfg/opt/mpmaxnodes.yml (moved) * spec/acfg/opt/mpmaxproxies.yml (moved) * spec/acfg/opt/mpmpcitablepointer.yml (moved) * spec/acfg/opt/mpnodenumber.yml (moved) * spec/acfg/opt/posixinitthreadentrypoint.yml (moved) * spec/acfg/opt/posixinitthreadstacksize.yml (moved) * spec/acfg/opt/posixinitthreadtable.yml (moved) * spec/acfg/opt/recordextensionsenabled.yml (moved) * spec/acfg/opt/recordfataldumpbase64.yml (moved) * spec/acfg/opt/recordfataldumpbase64zlib.yml (moved) * spec/acfg/opt/recordperprocessoritems.yml (moved) * spec/acfg/opt/rtemsinittaskstable.yml (moved) * spec/acfg/opt/schedulerassignments.yml (moved) * spec/acfg/opt/schedulercbs.yml (moved) * spec/acfg/opt/scheduleredf.yml (moved) * spec/acfg/opt/scheduleredfsmp.yml (moved) * spec/acfg/opt/schedulername.yml (moved) * spec/acfg/opt/schedulerpriority.yml (moved) * spec/acfg/opt/schedulerpriorityaffinitysmp.yml (moved) * spec/acfg/opt/schedulerprioritysmp.yml (moved) * spec/acfg/opt/schedulersimple.yml (moved) * spec/acfg/opt/schedulersimplesmp.yml (moved) * spec/acfg/opt/schedulerstrongapa.yml (moved) * spec/acfg/opt/scheduleruser.yml (moved) * spec/acfg/opt/stackcheckerenabled.yml (moved) * spec/acfg/opt/swapoutblockhold.yml (moved) * spec/acfg/opt/swapoutswapperiod.yml (moved) * spec/acfg/opt/swapouttaskpriority.yml (moved) * spec/acfg/opt/swapoutworkertaskpriority.yml (moved) * spec/acfg/opt/swapoutworkertasks.yml (moved) * spec/acfg/opt/taskstackallocator.yml (moved) * spec/acfg/opt/taskstackallocatorinit.yml (moved) * spec/acfg/opt/taskstackdeallocator.yml (moved) * spec/acfg/opt/taskstackfromalloc.yml (moved) * spec/acfg/opt/taskstacknowkspace.yml (moved) * spec/acfg/opt/tickspertimeslice.yml (moved) * spec/acfg/opt/unifiedworkareas.yml (moved) * spec/acfg/opt/unlimitedallocationsize.yml (moved) * spec/acfg/opt/unlimitedobjects.yml (moved) * spec/acfg/opt/usedevfsasbasefilesystem.yml (moved) * spec/acfg/opt/useminiimfsasbasefilesystem.yml (moved) * spec/acfg/opt/verbosesysteminit.yml (moved) * spec/acfg/opt/zeroworkspaceautomatically.yml (moved) * spec/acfg/posix.yml (moved) * spec/acfg/posixinit.yml (moved) * spec/acfg/schedgeneral.yml (moved) * spec/acfg/stackalloc.yml (moved) * spec/applconfig.yml (moved) * spec/glos/.doorstop.yml (deleted) * spec/glos/general.yml (moved) * spec/glos/term/.doorstop.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ASR.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ATOMICOPERATIONS.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-BSP.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-CPU.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ERRORCODE.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-FIFO.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-GNAT.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ISR.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-MPCI.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-PTCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-PXCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-QCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-RETURNCODE.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-RNCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-SMCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREITEM.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREPRODUCT.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-TCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-THREAD.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-TMCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-USERSUPPLIED.yml (deleted) * spec/glos/term/abi.yml (moved) * spec/glos/term/active.yml (moved) * spec/glos/term/aperiodictask.yml (moved) * spec/glos/term/api.yml (moved) * spec/glos/term/application.yml (moved) * spec/glos/term/asr.yml (added) * spec/glos/term/assemblerlanguage.yml (moved) * spec/glos/term/asynchronous.yml (moved) * spec/glos/term/asynchronoussignalroutine.yml (moved) * spec/glos/term/atomicoperations.yml (added) * spec/glos/term/awakened.yml (moved) * spec/glos/term/bigendian.yml (moved) * spec/glos/term/bitmapped.yml (moved) * spec/glos/term/block.yml (moved) * spec/glos/term/blockedtask.yml (moved) * spec/glos/term/boardsupportpackage.yml (moved) * spec/glos/term/broadcast.yml (moved) * spec/glos/term/bsp.yml (added) * spec/glos/term/buffer.yml (moved) * spec/glos/term/c11.yml (moved) * spec/glos/term/callingconvention.yml (moved) * spec/glos/term/ccb.yml (moved) * spec/glos/term/centralprocessingunit.yml (moved) * spec/glos/term/chain.yml (moved) * spec/glos/term/clanguage.yml (moved) * spec/glos/term/cluster.yml (moved) * spec/glos/term/coalesce.yml (moved) * spec/glos/term/configurationtable.yml (moved) * spec/glos/term/context.yml (moved) * spec/glos/term/contextswitch.yml (moved) * spec/glos/term/controlblock.yml (moved) * spec/glos/term/core.yml (moved) * spec/glos/term/cpu.yml (added) * spec/glos/term/criticalsection.yml (moved) * spec/glos/term/crt.yml (moved) * spec/glos/term/cxx11.yml (moved) * spec/glos/term/deadline.yml (moved) * spec/glos/term/device.yml (moved) * spec/glos/term/devicedriver.yml (moved) * spec/glos/term/devicedrivertable.yml (moved) * spec/glos/term/directives.yml (moved) * spec/glos/term/dispatch.yml (moved) * spec/glos/term/doorstop.yml (moved) * spec/glos/term/dormant.yml (moved) * spec/glos/term/dualported.yml (moved) * spec/glos/term/ears.yml (moved) * spec/glos/term/elf.yml (moved) * spec/glos/term/embedded.yml (moved) * spec/glos/term/entrypoint.yml (moved) * spec/glos/term/envelope.yml (moved) * spec/glos/term/errorcode.yml (added) * spec/glos/term/events.yml (moved) * spec/glos/term/exception.yml (moved) * spec/glos/term/executingtask.yml (moved) * spec/glos/term/executive.yml (moved) * spec/glos/term/exported.yml (moved) * spec/glos/term/externaladdress.yml (moved) * spec/glos/term/fifo.yml (added) * spec/glos/term/firstinfirstout.yml (moved) * spec/glos/term/floatingpointcoprocessor.yml (moved) * spec/glos/term/freed.yml (moved) * spec/glos/term/gcc.yml (moved) * spec/glos/term/global.yml (moved) * spec/glos/term/gnat.yml (added) * spec/glos/term/gnu.yml (moved) * spec/glos/term/handler.yml (moved) * spec/glos/term/hardrealtimesystem.yml (moved) * spec/glos/term/heap.yml (moved) * spec/glos/term/heirtask.yml (moved) * spec/glos/term/heterogeneous.yml (moved) * spec/glos/term/homogeneous.yml (moved) * spec/glos/term/id.yml (moved) * spec/glos/term/idletask.yml (moved) * spec/glos/term/interface.yml (moved) * spec/glos/term/internaladdress.yml (moved) * spec/glos/term/interrupt.yml (moved) * spec/glos/term/interruptlevel.yml (moved) * spec/glos/term/interruptservice.yml (moved) * spec/glos/term/interruptserviceroutine.yml (moved) * spec/glos/term/io.yml (moved) * spec/glos/term/isr.yml (added) * spec/glos/term/isvv.yml (moved) * spec/glos/term/kernel.yml (moved) * spec/glos/term/list.yml (moved) * spec/glos/term/littleendian.yml (moved) * spec/glos/term/local.yml (moved) * spec/glos/term/localoperation.yml (moved) * spec/glos/term/logicaladdress.yml (moved) * spec/glos/term/looselycoupled.yml (moved) * spec/glos/term/majornumber.yml (moved) * spec/glos/term/manager.yml (moved) * spec/glos/term/mcs.yml (moved) * spec/glos/term/memorypool.yml (moved) * spec/glos/term/message.yml (moved) * spec/glos/term/messagebuffer.yml (moved) * spec/glos/term/messagequeue.yml (moved) * spec/glos/term/messagequeuecontrolblock.yml (moved) * spec/glos/term/minornumber.yml (moved) * spec/glos/term/mode.yml (moved) * spec/glos/term/mpci.yml (added) * spec/glos/term/multiprocessing.yml (moved) * spec/glos/term/multiprocessor.yml (moved) * spec/glos/term/multiprocessorcommunicationsinterfacelayer.yml (moved) * spec/glos/term/multiprocessorconfigurationtable.yml (moved) * spec/glos/term/multitasking.yml (moved) * spec/glos/term/mutualexclusion.yml (moved) * spec/glos/term/nested.yml (moved) * spec/glos/term/node.yml (moved) * spec/glos/term/nonexistent.yml (moved) * spec/glos/term/numa.yml (moved) * spec/glos/term/numericcoprocessor.yml (moved) * spec/glos/term/object.yml (moved) * spec/glos/term/objectoriented.yml (moved) * spec/glos/term/operatingsystem.yml (moved) * spec/glos/term/overhead.yml (moved) * spec/glos/term/packet.yml (moved) * spec/glos/term/partition.yml (moved) * spec/glos/term/partitioncontrolblock.yml (moved) * spec/glos/term/pending.yml (moved) * spec/glos/term/periodictask.yml (moved) * spec/glos/term/physicaladdress.yml (moved) * spec/glos/term/poll.yml (moved) * spec/glos/term/pool.yml (moved) * spec/glos/term/portability.yml (moved) * spec/glos/term/posting.yml (moved) * spec/glos/term/preempt.yml (moved) * spec/glos/term/priority.yml (moved) * spec/glos/term/priorityboosting.yml (moved) * spec/glos/term/priorityinheritance.yml (moved) * spec/glos/term/priorityinversion.yml (moved) * spec/glos/term/processorutilization.yml (moved) * spec/glos/term/proxy.yml (moved) * spec/glos/term/proxycontrolblock.yml (moved) * spec/glos/term/ptcb.yml (added) * spec/glos/term/pxcb.yml (added) * spec/glos/term/qcb.yml (added) * spec/glos/term/quantum.yml (moved) * spec/glos/term/queue.yml (moved) * spec/glos/term/readytask.yml (moved) * spec/glos/term/realtime.yml (moved) * spec/glos/term/reentrant.yml (moved) * spec/glos/term/region.yml (moved) * spec/glos/term/regioncontrolblock.yml (moved) * spec/glos/term/registers.yml (moved) * spec/glos/term/remote.yml (moved) * spec/glos/term/remoteoperation.yml (moved) * spec/glos/term/reqif.yml (moved) * spec/glos/term/resource.yml (moved) * spec/glos/term/resume.yml (moved) * spec/glos/term/returncode.yml (added) * spec/glos/term/returnvalue.yml (moved) * spec/glos/term/rncb.yml (added) * spec/glos/term/roundrobin.yml (moved) * spec/glos/term/rs232.yml (moved) * spec/glos/term/rtems.yml (moved) * spec/glos/term/running.yml (moved) * spec/glos/term/schedulable.yml (moved) * spec/glos/term/schedule.yml (moved) * spec/glos/term/scheduledtask.yml (moved) * spec/glos/term/scheduler.yml (moved) * spec/glos/term/schedulerinstance.yml (moved) * spec/glos/term/segments.yml (moved) * spec/glos/term/semaphore.yml (moved) * spec/glos/term/semaphorecontrolblock.yml (moved) * spec/glos/term/sharedmemory.yml (moved) * spec/glos/term/signal.yml (moved) * spec/glos/term/signalset.yml (moved) * spec/glos/term/smcb.yml (added) * spec/glos/term/smp.yml (moved) * spec/glos/term/smpbarriers.yml (moved) * spec/glos/term/smplocks.yml (moved) * spec/glos/term/softrealtimesystem.yml (moved) * spec/glos/term/softwarecomponent.yml (moved) * spec/glos/term/softwareitem.yml (added) * spec/glos/term/softwareproduct.yml (added) * spec/glos/term/softwareunit.yml (moved) * spec/glos/term/sourcecode.yml (moved) * spec/glos/term/sporadictask.yml (moved) * spec/glos/term/stack.yml (moved) * spec/glos/term/statuscode.yml (moved) * spec/glos/term/suspend.yml (moved) * spec/glos/term/synchronous.yml (moved) * spec/glos/term/systemcall.yml (moved) * spec/glos/term/target.yml (moved) * spec/glos/term/tas.yml (moved) * spec/glos/term/task.yml (moved) * spec/glos/term/taskcontrolblock.yml (moved) * spec/glos/term/taskmigration.yml (moved) * spec/glos/term/taskprocessoraffinity.yml (moved) * spec/glos/term/taskswitch.yml (moved) * spec/glos/term/tcb.yml (added) * spec/glos/term/thread.yml (added) * spec/glos/term/threaddispatch.yml (moved) * spec/glos/term/tick.yml (moved) * spec/glos/term/tightlycoupled.yml (moved) * spec/glos/term/timeout.yml (moved) * spec/glos/term/timer.yml (moved) * spec/glos/term/timercontrolblock.yml (moved) * spec/glos/term/timeslice.yml (moved) * spec/glos/term/timeslicing.yml (moved) * spec/glos/term/tls.yml (moved) * spec/glos/term/tmcb.yml (added) * spec/glos/term/transientoverload.yml (moved) * spec/glos/term/ttas.yml (moved) * spec/glos/term/userextensions.yml (moved) * spec/glos/term/userextensiontable.yml (moved) * spec/glos/term/userinitializationtaskstable.yml (moved) * spec/glos/term/userprovided.yml (moved) * spec/glos/term/usersupplied.yml (added) * spec/glos/term/vector.yml (moved) * spec/glos/term/waitqueue.yml (moved) * spec/glos/term/yaml.yml (moved) * spec/glos/term/yield.yml (moved) * spec/glossary.yml (added) Remove Doorstop specifics
