# # ChangeLog for rtemsqual in rtems-central # # Generated by Trac 1.2.1.dev0 # 03/29/24 06:22:01 Tue, 17 Mar 2020 13:29:56 GMT Sebastian Huber [dfca4bc] * rtemsqual/glossary.py (modified) * rtemsqual/items.py (modified) content: Add method to register license/copyrights Tue, 17 Mar 2020 14:50:14 GMT Sebastian Huber [9144b6b] * rtemsqual/content.py (modified) * rtemsqual/glossary.py (modified) * tests/test_content.py (modified) content: Make lines for definition item Tue, 17 Mar 2020 14:45:40 GMT Sebastian Huber [28b8f50] * rtemsqual/content.py (modified) * tests/test_content.py (modified) content: Add helper to accept a string or a list Tue, 17 Mar 2020 13:29:26 GMT Sebastian Huber [a400958] * rtemsqual/content.py (modified) * tests/test_content.py (modified) content: Add method to add lines Tue, 25 Feb 2020 12:54:17 GMT Sebastian Huber [c0ac12a] * .gitignore (added) * .gitmodules (added) * Makefile (added) * README.md (added) * config.ini (added) * external/rtems (added) * external/rtems-docs (added) * requirements.txt (added) * rtems_spec_to_x.py (added) * rtemsqual/__init__.py (added) * rtemsqual/applconfig.py (added) * rtemsqual/content.py (added) * rtemsqual/glossary.py (added) * rtemsqual/items.py (added) * spec/.doorstop.yml (added) * spec/RTEMS-GLOSSARY.yml (added) * spec/glos/.doorstop.yml (added) * spec/glos/RTEMS-GLOS-GENERAL.yml (added) * spec/glos/term/.doorstop.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ABI.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ACTIVE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-APERIODICTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-API.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-APPLICATION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ASR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ASYNCHRONOUS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ASYNCHRONOUSSIGNALROUTINE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ATOMICOPERATIONS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-AWAKENED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BIGENDIAN.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BITMAPPED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BLOCKEDTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BOARDSUPPORTPACKAGE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BROADCAST.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BSP.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BUFFER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-C11.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CALLINGCONVENTION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CENTRALPROCESSINGUNIT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CHAIN.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CLUSTER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-COALESCE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CONFIGURATIONTABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CONTEXT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CONTEXTSWITCH.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CORE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CPU.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CRITICALSECTION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CRT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CXX11.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DEADLINE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DEVICE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DEVICEDRIVER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DEVICEDRIVERTABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DIRECTIVES.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DISPATCH.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DOORSTOP.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DORMANT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DUALPORTED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EARS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EMBEDDED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ENTRYPOINT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ENVELOPE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ERRORCODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EVENTS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EXCEPTION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EXECUTINGTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EXECUTIVE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EXPORTED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EXTERNALADDRESS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-FIFO.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-FIRSTINFIRSTOUT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-FLOATINGPOINTCOPROCESSOR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-FREED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-GCC.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-GLOBAL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-GNAT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-GNU.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HANDLER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HARDREALTIMESYSTEM.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HEAP.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HEIRTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HETEROGENEOUS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HOMOGENEOUS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ID.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-IDLETASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERFACE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERNALADDRESS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERRUPT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERRUPTLEVEL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERRUPTSERVICEROUTINE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-IO.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ISR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ISVV.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-KERNEL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LIST.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LITTLEENDIAN.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LOCAL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LOCALOPERATION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LOGICALADDRESS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LOOSELYCOUPLED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MAJORNUMBER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MANAGER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MCS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MEMORYPOOL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MESSAGE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MESSAGEBUFFER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MESSAGEQUEUE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MESSAGEQUEUECONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MINORNUMBER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MPCI.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MULTIPROCESSING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MULTIPROCESSOR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MULTIPROCESSORCOMMUNICATIONSINTERFACELAYER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MULTIPROCESSORCONFIGURATIONTABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MULTITASKING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MUTUALEXCLUSION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-NESTED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-NODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-NONEXISTENT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-NUMA.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-NUMERICCOPROCESSOR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-OBJECT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-OBJECTORIENTED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-OPERATINGSYSTEM.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-OVERHEAD.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PACKET.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PARTITION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PARTITIONCONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PENDING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PERIODICTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PHYSICALADDRESS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-POLL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-POOL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PORTABILITY.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-POSTING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PREEMPT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PRIORITY.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PRIORITYBOOSTING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PRIORITYINHERITANCE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PRIORITYINVERSION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PROCESSORUTILIZATION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PROXY.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PROXYCONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PTCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PXCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-QCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-QUANTUM.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-QUEUE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-READYTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REALTIME.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REENTRANT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REGION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REGIONCONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REGISTERS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REMOTE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REMOTEOPERATION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REQIF.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RESOURCE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RESUME.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RETURNCODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RETURNVALUE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RNCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ROUNDROBIN.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RS232.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RTEMS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RUNNING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SCHEDULABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SCHEDULE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SCHEDULEDTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SCHEDULER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SCHEDULERINSTANCE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SEGMENTS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SEMAPHORE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SEMAPHORECONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SHAREDMEMORY.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SIGNAL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SIGNALSET.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SMCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SMP.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SMPBARRIERS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SMPLOCKS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SOFTREALTIMESYSTEM.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREITEM.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREPRODUCT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SOURCECODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SPORADICTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-STACK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-STATUSCODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SUSPEND.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SYNCHRONOUS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SYSTEMCALL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TARGET.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TAS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASKCONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASKMIGRATION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASKPROCESSORAFFINITY.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASKSWITCH.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-THREAD.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-THREADDISPATCH.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TICK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIGHTLYCOUPLED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIMEOUT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIMER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIMERCONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIMESLICE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIMESLICING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TLS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TMCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TRANSIENTOVERLOAD.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TTAS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-USEREXTENSIONS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-USEREXTENSIONTABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-USERINITIALIZATIONTASKSTABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-USERPROVIDED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-USERSUPPLIED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-VECTOR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-WAITQUEUE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-YAML.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-YIELD.yml (added) * tests/spec-glossary/RTEMS-GLOS-TERM-T.yml (added) * tests/spec-glossary/RTEMS-GLOS-TERM-U.yml (added) * tests/spec-glossary/RTEMS-GLOS-TERM-V.yml (added) * tests/spec-glossary/doc.rst (added) * tests/spec-glossary/g.yml (added) * tests/spec-glossary/glossary.rst (added) * tests/spec-item-cache/.z.yml (added) * tests/spec-item-cache/d/c.yml (added) * tests/spec-item-cache/empty.txt (added) * tests/spec-item-cache/p.yml (added) * tests/test_content.py (added) * tests/test_glossary.py (added) * tests/test_items.py (added) Initial import
