# # ChangeLog for rtemsqual/interface.py in rtems-central # # Generated by Trac 1.2.1.dev0 # 04/25/24 04:31:45 Mon, 11 May 2020 07:00:49 GMT Sebastian Huber [05246b3] * rtemsqual/interface.py (modified) * rtemsqual/items.py (modified) * rtemsqual/tests/test_items_item.py (modified) items: Add and use Link.role Sun, 10 May 2020 18:31:10 GMT Sebastian Huber [4dbae73] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/ga.yml (modified) * rtemsqual/tests/spec-interface/gb.yml (modified) * rtemsqual/tests/spec-interface/gc.yml (modified) interface: Add group-identifier Sun, 10 May 2020 18:20:57 GMT Sebastian Huber [3276ce2] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/h.yml (modified) * rtemsqual/tests/spec-interface/h4.yml (added) * rtemsqual/tests/test_interface.py (modified) interface: Add support for interface includes Sun, 10 May 2020 18:15:30 GMT Sebastian Huber [e5d07e1] * rtemsqual/interface.py (modified) interface: Add item to HeaderFile Make HeaderFile an internal class. Sun, 10 May 2020 17:58:25 GMT Sebastian Huber [02c58ef] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/h.yml (modified) * rtemsqual/tests/spec-interface/h2.yml (modified) * rtemsqual/tests/spec-interface/h3.yml (modified) * rtemsqual/tests/spec-interface/math.yml (modified) * rtemsqual/tests/spec-interface/stdint.yml (modified) Rename path attributes Sat, 09 May 2020 15:47:24 GMT Sebastian Huber [0ee8226] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/asm.yml (added) * rtemsqual/tests/spec-interface/command-line.yml (added) * rtemsqual/tests/spec-interface/var.yml (modified) * rtemsqual/tests/test_interface.py (modified) interface: Support item-level enabled-by Fri, 08 May 2020 17:58:42 GMT Sebastian Huber [2f39499] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/enum.yml (modified) * rtemsqual/tests/spec-interface/enum2.yml (modified) * rtemsqual/tests/spec-interface/enum3.yml (modified) Rename "enumerator" role in "interface-enumerator" Fri, 08 May 2020 17:57:28 GMT Sebastian Huber [1530177] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/define.yml (modified) * rtemsqual/tests/spec-interface/enum.yml (modified) * rtemsqual/tests/spec-interface/enum2.yml (modified) * rtemsqual/tests/spec-interface/enum3.yml (modified) * rtemsqual/tests/spec-interface/func.yml (modified) * rtemsqual/tests/spec-interface/func2.yml (modified) * rtemsqual/tests/spec-interface/gb.yml (modified) * rtemsqual/tests/spec-interface/macro.yml (modified) * rtemsqual/tests/spec-interface/macro2.yml (modified) * rtemsqual/tests/spec-interface/s.yml (modified) * rtemsqual/tests/spec-interface/td.yml (modified) * rtemsqual/tests/spec-interface/td3.yml (modified) * rtemsqual/tests/spec-interface/var.yml (modified) Rename "ingroup" role in "interface-ingroup" Fri, 08 May 2020 17:55:04 GMT Sebastian Huber [21872d2] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/define.yml (modified) * rtemsqual/tests/spec-interface/enum.yml (modified) * rtemsqual/tests/spec-interface/enum2.yml (modified) * rtemsqual/tests/spec-interface/enum3.yml (modified) * rtemsqual/tests/spec-interface/enum4.yml (modified) * rtemsqual/tests/spec-interface/float_t.yml (modified) * rtemsqual/tests/spec-interface/forward-decl.yml (modified) * rtemsqual/tests/spec-interface/func.yml (modified) * rtemsqual/tests/spec-interface/func2.yml (modified) * rtemsqual/tests/spec-interface/ga.yml (modified) * rtemsqual/tests/spec-interface/gb.yml (modified) * rtemsqual/tests/spec-interface/gc.yml (modified) * rtemsqual/tests/spec-interface/macro.yml (modified) * rtemsqual/tests/spec-interface/macro2.yml (modified) * rtemsqual/tests/spec-interface/s.yml (modified) * rtemsqual/tests/spec-interface/td.yml (modified) * rtemsqual/tests/spec-interface/td3.yml (modified) * rtemsqual/tests/spec-interface/uint32_t.yml (modified) * rtemsqual/tests/spec-interface/var.yml (modified) Rename "include" role in "interface-placement" Fri, 08 May 2020 15:21:33 GMT Sebastian Huber [e2429ea] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/define-a.yml (added) * rtemsqual/tests/spec-interface/define-b.yml (added) * rtemsqual/tests/spec-interface/define-c.yml (added) * rtemsqual/tests/spec-interface/define.yml (modified) * rtemsqual/tests/test_interface.py (modified) interface: Use enabled_by_to_exp() Wed, 06 May 2020 10:39:04 GMT Sebastian Huber [1767cc8] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/h.yml (modified) * rtemsqual/tests/spec-interface/h2.yml (modified) * rtemsqual/tests/spec-interface/h3.yml (modified) * rtemsqual/tests/spec-interface/math.yml (modified) * rtemsqual/tests/spec-interface/stdint.yml (modified) * rtemsqual/tests/test_interface.py (modified) interface: Rename path-domain in interface-domain Wed, 06 May 2020 09:40:24 GMT Sebastian Huber [fa46b668] * rtemsqual/applconfig.py (modified) * rtemsqual/content.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/interface.py (modified) * rtemsqual/items.py (modified) * rtemsqual/validation.py (modified) Move license and copyright registration of items This avoids a ... Wed, 06 May 2020 08:13:03 GMT Sebastian Huber [aab2f5e] * rtemsqual/interface.py (modified) * rtemsqual/items.py (modified) * rtemsqual/tests/test_items_item.py (modified) * rtemsqual/tests/test_items_itemcache.py (modified) items: Rework item mapper Rename Item.get() in ... Mon, 04 May 2020 12:47:15 GMT Sebastian Huber [4fc185c] * rtemsqual/interface.py (modified) * rtemsqual/tests/spec-interface/s.yml (modified) * rtemsqual/tests/test_interface.py (modified) interface: Fix specification of compounds Use definition attribute ... Tue, 28 Apr 2020 07:31:39 GMT Sebastian Huber [ddbc8f7] * rtemsqual/interface.py (added) * rtemsqual/tests/spec-interface/define.yml (added) * rtemsqual/tests/spec-interface/enum.yml (added) * rtemsqual/tests/spec-interface/enum2.yml (added) * rtemsqual/tests/spec-interface/enum3.yml (added) * rtemsqual/tests/spec-interface/enum4.yml (added) * rtemsqual/tests/spec-interface/enumerator-0.yml (added) * rtemsqual/tests/spec-interface/enumerator-1.yml (added) * rtemsqual/tests/spec-interface/enumerator-2.yml (added) * rtemsqual/tests/spec-interface/enumerator-a.yml (added) * rtemsqual/tests/spec-interface/enumerator-b.yml (added) * rtemsqual/tests/spec-interface/float_t.yml (added) * rtemsqual/tests/spec-interface/forward-decl.yml (added) * rtemsqual/tests/spec-interface/func.yml (added) * rtemsqual/tests/spec-interface/func2.yml (added) * rtemsqual/tests/spec-interface/ga.yml (added) * rtemsqual/tests/spec-interface/gb.yml (added) * rtemsqual/tests/spec-interface/gc.yml (added) * rtemsqual/tests/spec-interface/h.yml (added) * rtemsqual/tests/spec-interface/h2.yml (added) * rtemsqual/tests/spec-interface/h3.yml (added) * rtemsqual/tests/spec-interface/macro.yml (added) * rtemsqual/tests/spec-interface/macro2.yml (added) * rtemsqual/tests/spec-interface/math.yml (added) * rtemsqual/tests/spec-interface/other.yml (added) * rtemsqual/tests/spec-interface/other2.yml (added) * rtemsqual/tests/spec-interface/other3.yml (added) * rtemsqual/tests/spec-interface/s.yml (added) * rtemsqual/tests/spec-interface/stdint.yml (added) * rtemsqual/tests/spec-interface/td.yml (added) * rtemsqual/tests/spec-interface/td3.yml (added) * rtemsqual/tests/spec-interface/uint32_t.yml (added) * rtemsqual/tests/spec-interface/var.yml (added) * rtemsqual/tests/spec-item-cache/p.yml (modified) * rtemsqual/tests/test_interface.py (added) interface: New module
