# # ChangeLog for rtemsqual/glossary.py in rtems-central # # Generated by Trac 1.2.1.dev0 # 04/25/24 09:17:15 Sat, 09 May 2020 15:45:46 GMT Sebastian Huber [99c6449] * rtemsqual/content.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/tests/test_content.py (modified) * rtemsqual/validation.py (modified) content: Change gap after indent Wed, 06 May 2020 08:31:57 GMT Sebastian Huber [a5f3cc1] * rtemsqual/content.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/tests/spec-glossary/glos/term/t.yml (modified) * rtemsqual/tests/spec-sphinx/x.yml (added) * rtemsqual/tests/test_content_sphinx.py (modified) * rtemsqual/tests/test_glossary.py (modified) * spec/glos/term/asr.yml (modified) * spec/glos/term/assemblerlanguage.yml (modified) * spec/glos/term/atomicoperations.yml (modified) * spec/glos/term/bsp.yml (modified) * spec/glos/term/clanguage.yml (modified) * spec/glos/term/cpu.yml (modified) * spec/glos/term/errorcode.yml (modified) * spec/glos/term/fifo.yml (modified) * spec/glos/term/gnat.yml (modified) * spec/glos/term/interruptservice.yml (modified) * spec/glos/term/isr.yml (modified) * spec/glos/term/mpci.yml (modified) * spec/glos/term/partition.yml (modified) * spec/glos/term/ptcb.yml (modified) * spec/glos/term/pxcb.yml (modified) * spec/glos/term/qcb.yml (modified) * spec/glos/term/returncode.yml (modified) * spec/glos/term/returnvalue.yml (modified) * spec/glos/term/rncb.yml (modified) * spec/glos/term/smcb.yml (modified) * spec/glos/term/softwarecomponent.yml (modified) * spec/glos/term/softwareitem.yml (modified) * spec/glos/term/softwareproduct.yml (modified) * spec/glos/term/softwareunit.yml (modified) * spec/glos/term/statuscode.yml (modified) * spec/glos/term/task.yml (modified) * spec/glos/term/tcb.yml (modified) * spec/glos/term/thread.yml (modified) * spec/glos/term/tls.yml (modified) * spec/glos/term/tmcb.yml (modified) * spec/glos/term/usersupplied.yml (modified) spec: Use item mapper for glossary terms Wed, 06 May 2020 09:40:24 GMT Sebastian Huber [fa46b668] * rtemsqual/applconfig.py (modified) * rtemsqual/content.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/interface.py (modified) * rtemsqual/items.py (modified) * rtemsqual/validation.py (modified) Move license and copyright registration of items This avoids a ... Tue, 28 Apr 2020 11:27:38 GMT Sebastian Huber [520ba1dd] * rtemsqual/applconfig.py (modified) * rtemsqual/content.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/tests/test_content.py (added) * rtemsqual/tests/test_content_c.py (modified) * rtemsqual/tests/test_content_sphinx.py (modified) * rtemsqual/validation.py (modified) content: Rework API Use context managers for indent and comment blocks. Tue, 28 Apr 2020 09:29:48 GMT Sebastian Huber [9dad293] * rtemsqual/applconfig.py (modified) * rtemsqual/build.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/items.py (modified) * rtemsqual/tests/test_items_item.py (modified) * rtemsqual/validation.py (modified) items: Use generator functions for item links This enables an easy ... Mon, 20 Apr 2020 05:26:15 GMT Sebastian Huber [71d8b3c] * config.yml (modified) * rtems_spec_to_x.py (modified) * rtemsqual/applconfig.py (modified) * rtemsqual/glossary.py (modified) * rtemsqual/items.py (modified) * rtemsqual/tests/spec-applconfig/a.yml (modified) * rtemsqual/tests/spec-applconfig/b.yml (modified) * rtemsqual/tests/spec-applconfig/c.yml (modified) * rtemsqual/tests/spec-applconfig/e.yml (modified) * rtemsqual/tests/spec-applconfig/f.yml (modified) * rtemsqual/tests/spec-applconfig/h.yml (modified) * rtemsqual/tests/spec-applconfig/i.yml (modified) * rtemsqual/tests/spec-applconfig/j.yml (modified) * rtemsqual/tests/spec-applconfig/k.yml (modified) * rtemsqual/tests/spec-applconfig/l.yml (modified) * rtemsqual/tests/spec-applconfig/m.yml (modified) * rtemsqual/tests/spec-build/bsp.yml (modified) * rtemsqual/tests/spec-build/o.yml (modified) * rtemsqual/tests/spec-glossary/glos/g.yml (moved) * rtemsqual/tests/spec-glossary/glos/term/t.yml (moved) * rtemsqual/tests/spec-glossary/glos/term/u.yml (moved) * rtemsqual/tests/spec-glossary/glos/term/v.yml (moved) * rtemsqual/tests/spec-item-cache/d/c.yml (modified) * rtemsqual/tests/test_applconfig.py (modified) * rtemsqual/tests/test_build.py (modified) * rtemsqual/tests/test_glossary.py (modified) * rtemsqual/tests/test_items_item.py (modified) * rtemsqual/tests/test_items_itemcache.py (modified) * spec/.doorstop.yml (deleted) * spec/RTEMS-GLOSSARY.yml (deleted) * spec/acfg/.doorstop.yml (deleted) * spec/acfg/bdbuf.yml (moved) * spec/acfg/bsp.yml (moved) * spec/acfg/classic.yml (moved) * spec/acfg/classicinit.yml (moved) * spec/acfg/devdrv.yml (moved) * spec/acfg/eventrecord.yml (moved) * spec/acfg/filesystem.yml (moved) * spec/acfg/general.yml (moved) * spec/acfg/idle.yml (moved) * spec/acfg/mpci.yml (moved) * spec/acfg/opt/.doorstop.yml (deleted) * spec/acfg/opt/appldisablefilesystem.yml (moved) * spec/acfg/opt/appldoesnotneedclockdriver.yml (moved) * spec/acfg/opt/applextradrivers.yml (moved) * spec/acfg/opt/applneedsatadriver.yml (moved) * spec/acfg/opt/applneedsclockdriver.yml (moved) * spec/acfg/opt/applneedsconsoledriver.yml (moved) * spec/acfg/opt/applneedsframebufferdriver.yml (moved) * spec/acfg/opt/applneedsidedriver.yml (moved) * spec/acfg/opt/applneedslibblock.yml (moved) * spec/acfg/opt/applneedsnulldriver.yml (moved) * spec/acfg/opt/applneedsrtcdriver.yml (moved) * spec/acfg/opt/applneedssimpleconsoledriver.yml (moved) * spec/acfg/opt/applneedssimpletaskconsoledriver.yml (moved) * spec/acfg/opt/applneedsstubdriver.yml (moved) * spec/acfg/opt/applneedstimerdriver.yml (moved) * spec/acfg/opt/applneedswatchdogdriver.yml (moved) * spec/acfg/opt/applneedszerodriver.yml (moved) * spec/acfg/opt/applprerequisitedrivers.yml (moved) * spec/acfg/opt/atadrivertaskpriority.yml (moved) * spec/acfg/opt/bdbufbuffermaxsize.yml (moved) * spec/acfg/opt/bdbufbufferminsize.yml (moved) * spec/acfg/opt/bdbufcachememorysize.yml (moved) * spec/acfg/opt/bdbufmaxreadaheadblocks.yml (moved) * spec/acfg/opt/bdbufmaxwriteblocks.yml (moved) * spec/acfg/opt/bdbufreadaheadtaskpriority.yml (moved) * spec/acfg/opt/bdbuftaskstacksize.yml (moved) * spec/acfg/opt/bspidletaskbody.yml (moved) * spec/acfg/opt/bspidletaskstacksize.yml (moved) * spec/acfg/opt/bspinitialextension.yml (moved) * spec/acfg/opt/bspinterruptstacksize.yml (moved) * spec/acfg/opt/bspprerequisitedrivers.yml (moved) * spec/acfg/opt/cbsmaximumservers.yml (moved) * spec/acfg/opt/constraintbspappmin.yml (moved) * spec/acfg/opt/constraintidlestackarea.yml (moved) * spec/acfg/opt/constraintisrstackalign.yml (moved) * spec/acfg/opt/constraintisrstackarea.yml (moved) * spec/acfg/opt/constraintmemsz.yml (moved) * spec/acfg/opt/constraintposix.yml (moved) * spec/acfg/opt/constraintprioclassic.yml (moved) * spec/acfg/opt/constraintstackspace.yml (moved) * spec/acfg/opt/constraintunlimited.yml (moved) * spec/acfg/opt/constraintwkspace.yml (moved) * spec/acfg/opt/dirtymemory.yml (moved) * spec/acfg/opt/disablebspsettings.yml (moved) * spec/acfg/opt/disablenewlibreentrancy.yml (moved) * spec/acfg/opt/executiveramsize.yml (moved) * spec/acfg/opt/extrataskstacks.yml (moved) * spec/acfg/opt/filesystemall.yml (moved) * spec/acfg/opt/filesystemdosfs.yml (moved) * spec/acfg/opt/filesystemftpfs.yml (moved) * spec/acfg/opt/filesystemimfs.yml (moved) * spec/acfg/opt/filesystemjffs2.yml (moved) * spec/acfg/opt/filesystemnfs.yml (moved) * spec/acfg/opt/filesystemrfs.yml (moved) * spec/acfg/opt/filesystemtftpfs.yml (moved) * spec/acfg/opt/idletaskbody.yml (moved) * spec/acfg/opt/idletaskinitappl.yml (moved) * spec/acfg/opt/idletaskstacksize.yml (moved) * spec/acfg/opt/imfsdisablechmod.yml (moved) * spec/acfg/opt/imfsdisablechown.yml (moved) * spec/acfg/opt/imfsdisablelink.yml (moved) * spec/acfg/opt/imfsdisablemknod.yml (moved) * spec/acfg/opt/imfsdisablemknoddevice.yml (moved) * spec/acfg/opt/imfsdisablemknodfile.yml (moved) * spec/acfg/opt/imfsdisablemount.yml (moved) * spec/acfg/opt/imfsdisablereaddir.yml (moved) * spec/acfg/opt/imfsdisablereadlink.yml (moved) * spec/acfg/opt/imfsdisablerename.yml (moved) * spec/acfg/opt/imfsdisablermnod.yml (moved) * spec/acfg/opt/imfsdisablesymlink.yml (moved) * spec/acfg/opt/imfsdisableunmount.yml (moved) * spec/acfg/opt/imfsdisableutime.yml (moved) * spec/acfg/opt/imfsenablemkfifo.yml (moved) * spec/acfg/opt/imfsmemfilebytesperblock.yml (moved) * spec/acfg/opt/initialextensions.yml (moved) * spec/acfg/opt/inittaskarguments.yml (moved) * spec/acfg/opt/inittaskattributes.yml (moved) * spec/acfg/opt/inittaskentrypoint.yml (moved) * spec/acfg/opt/inittaskinitialmodes.yml (moved) * spec/acfg/opt/inittaskname.yml (moved) * spec/acfg/opt/inittaskpriority.yml (moved) * spec/acfg/opt/inittaskstacksize.yml (moved) * spec/acfg/opt/interruptstacksize.yml (moved) * spec/acfg/opt/mallocbspsupportssbrk.yml (moved) * spec/acfg/opt/mallocdirty.yml (moved) * spec/acfg/opt/maxbarriers.yml (moved) * spec/acfg/opt/maxdrivers.yml (moved) * spec/acfg/opt/maxfiledescriptors.yml (moved) * spec/acfg/opt/maxmessagequeues.yml (moved) * spec/acfg/opt/maxpartitions.yml (moved) * spec/acfg/opt/maxperiods.yml (moved) * spec/acfg/opt/maxports.yml (moved) * spec/acfg/opt/maxposixkeys.yml (moved) * spec/acfg/opt/maxposixkeyvaluepairs.yml (moved) * spec/acfg/opt/maxposixmessagequeues.yml (moved) * spec/acfg/opt/maxposixqueuedsignals.yml (moved) * spec/acfg/opt/maxposixsemaphores.yml (moved) * spec/acfg/opt/maxposixshms.yml (moved) * spec/acfg/opt/maxposixthreads.yml (moved) * spec/acfg/opt/maxposixtimers.yml (moved) * spec/acfg/opt/maxpriority.yml (moved) * spec/acfg/opt/maxprocessors.yml (moved) * spec/acfg/opt/maxregions.yml (moved) * spec/acfg/opt/maxsemaphores.yml (moved) * spec/acfg/opt/maxtasks.yml (moved) * spec/acfg/opt/maxthreadnamesize.yml (moved) * spec/acfg/opt/maxtimers.yml (moved) * spec/acfg/opt/maxuserextensions.yml (moved) * spec/acfg/opt/memoryoverhead.yml (moved) * spec/acfg/opt/messagebuffermemory.yml (moved) * spec/acfg/opt/microsecondspertick.yml (moved) * spec/acfg/opt/minposixthreadstacksize.yml (moved) * spec/acfg/opt/mintaskstacksize.yml (moved) * spec/acfg/opt/mpappl.yml (moved) * spec/acfg/opt/mpextraserverstack.yml (moved) * spec/acfg/opt/mpmaxglobalobjects.yml (moved) * spec/acfg/opt/mpmaxnodes.yml (moved) * spec/acfg/opt/mpmaxproxies.yml (moved) * spec/acfg/opt/mpmpcitablepointer.yml (moved) * spec/acfg/opt/mpnodenumber.yml (moved) * spec/acfg/opt/posixinitthreadentrypoint.yml (moved) * spec/acfg/opt/posixinitthreadstacksize.yml (moved) * spec/acfg/opt/posixinitthreadtable.yml (moved) * spec/acfg/opt/recordextensionsenabled.yml (moved) * spec/acfg/opt/recordfataldumpbase64.yml (moved) * spec/acfg/opt/recordfataldumpbase64zlib.yml (moved) * spec/acfg/opt/recordperprocessoritems.yml (moved) * spec/acfg/opt/rtemsinittaskstable.yml (moved) * spec/acfg/opt/schedulerassignments.yml (moved) * spec/acfg/opt/schedulercbs.yml (moved) * spec/acfg/opt/scheduleredf.yml (moved) * spec/acfg/opt/scheduleredfsmp.yml (moved) * spec/acfg/opt/schedulername.yml (moved) * spec/acfg/opt/schedulerpriority.yml (moved) * spec/acfg/opt/schedulerpriorityaffinitysmp.yml (moved) * spec/acfg/opt/schedulerprioritysmp.yml (moved) * spec/acfg/opt/schedulersimple.yml (moved) * spec/acfg/opt/schedulersimplesmp.yml (moved) * spec/acfg/opt/schedulerstrongapa.yml (moved) * spec/acfg/opt/scheduleruser.yml (moved) * spec/acfg/opt/stackcheckerenabled.yml (moved) * spec/acfg/opt/swapoutblockhold.yml (moved) * spec/acfg/opt/swapoutswapperiod.yml (moved) * spec/acfg/opt/swapouttaskpriority.yml (moved) * spec/acfg/opt/swapoutworkertaskpriority.yml (moved) * spec/acfg/opt/swapoutworkertasks.yml (moved) * spec/acfg/opt/taskstackallocator.yml (moved) * spec/acfg/opt/taskstackallocatorinit.yml (moved) * spec/acfg/opt/taskstackdeallocator.yml (moved) * spec/acfg/opt/taskstackfromalloc.yml (moved) * spec/acfg/opt/taskstacknowkspace.yml (moved) * spec/acfg/opt/tickspertimeslice.yml (moved) * spec/acfg/opt/unifiedworkareas.yml (moved) * spec/acfg/opt/unlimitedallocationsize.yml (moved) * spec/acfg/opt/unlimitedobjects.yml (moved) * spec/acfg/opt/usedevfsasbasefilesystem.yml (moved) * spec/acfg/opt/useminiimfsasbasefilesystem.yml (moved) * spec/acfg/opt/verbosesysteminit.yml (moved) * spec/acfg/opt/zeroworkspaceautomatically.yml (moved) * spec/acfg/posix.yml (moved) * spec/acfg/posixinit.yml (moved) * spec/acfg/schedgeneral.yml (moved) * spec/acfg/stackalloc.yml (moved) * spec/applconfig.yml (moved) * spec/glos/.doorstop.yml (deleted) * spec/glos/general.yml (moved) * spec/glos/term/.doorstop.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ASR.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ATOMICOPERATIONS.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-BSP.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-CPU.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ERRORCODE.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-FIFO.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-GNAT.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-ISR.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-MPCI.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-PTCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-PXCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-QCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-RETURNCODE.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-RNCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-SMCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREITEM.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREPRODUCT.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-TCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-THREAD.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-TMCB.yml (deleted) * spec/glos/term/RTEMS-GLOS-TERM-USERSUPPLIED.yml (deleted) * spec/glos/term/abi.yml (moved) * spec/glos/term/active.yml (moved) * spec/glos/term/aperiodictask.yml (moved) * spec/glos/term/api.yml (moved) * spec/glos/term/application.yml (moved) * spec/glos/term/asr.yml (added) * spec/glos/term/assemblerlanguage.yml (moved) * spec/glos/term/asynchronous.yml (moved) * spec/glos/term/asynchronoussignalroutine.yml (moved) * spec/glos/term/atomicoperations.yml (added) * spec/glos/term/awakened.yml (moved) * spec/glos/term/bigendian.yml (moved) * spec/glos/term/bitmapped.yml (moved) * spec/glos/term/block.yml (moved) * spec/glos/term/blockedtask.yml (moved) * spec/glos/term/boardsupportpackage.yml (moved) * spec/glos/term/broadcast.yml (moved) * spec/glos/term/bsp.yml (added) * spec/glos/term/buffer.yml (moved) * spec/glos/term/c11.yml (moved) * spec/glos/term/callingconvention.yml (moved) * spec/glos/term/ccb.yml (moved) * spec/glos/term/centralprocessingunit.yml (moved) * spec/glos/term/chain.yml (moved) * spec/glos/term/clanguage.yml (moved) * spec/glos/term/cluster.yml (moved) * spec/glos/term/coalesce.yml (moved) * spec/glos/term/configurationtable.yml (moved) * spec/glos/term/context.yml (moved) * spec/glos/term/contextswitch.yml (moved) * spec/glos/term/controlblock.yml (moved) * spec/glos/term/core.yml (moved) * spec/glos/term/cpu.yml (added) * spec/glos/term/criticalsection.yml (moved) * spec/glos/term/crt.yml (moved) * spec/glos/term/cxx11.yml (moved) * spec/glos/term/deadline.yml (moved) * spec/glos/term/device.yml (moved) * spec/glos/term/devicedriver.yml (moved) * spec/glos/term/devicedrivertable.yml (moved) * spec/glos/term/directives.yml (moved) * spec/glos/term/dispatch.yml (moved) * spec/glos/term/doorstop.yml (moved) * spec/glos/term/dormant.yml (moved) * spec/glos/term/dualported.yml (moved) * spec/glos/term/ears.yml (moved) * spec/glos/term/elf.yml (moved) * spec/glos/term/embedded.yml (moved) * spec/glos/term/entrypoint.yml (moved) * spec/glos/term/envelope.yml (moved) * spec/glos/term/errorcode.yml (added) * spec/glos/term/events.yml (moved) * spec/glos/term/exception.yml (moved) * spec/glos/term/executingtask.yml (moved) * spec/glos/term/executive.yml (moved) * spec/glos/term/exported.yml (moved) * spec/glos/term/externaladdress.yml (moved) * spec/glos/term/fifo.yml (added) * spec/glos/term/firstinfirstout.yml (moved) * spec/glos/term/floatingpointcoprocessor.yml (moved) * spec/glos/term/freed.yml (moved) * spec/glos/term/gcc.yml (moved) * spec/glos/term/global.yml (moved) * spec/glos/term/gnat.yml (added) * spec/glos/term/gnu.yml (moved) * spec/glos/term/handler.yml (moved) * spec/glos/term/hardrealtimesystem.yml (moved) * spec/glos/term/heap.yml (moved) * spec/glos/term/heirtask.yml (moved) * spec/glos/term/heterogeneous.yml (moved) * spec/glos/term/homogeneous.yml (moved) * spec/glos/term/id.yml (moved) * spec/glos/term/idletask.yml (moved) * spec/glos/term/interface.yml (moved) * spec/glos/term/internaladdress.yml (moved) * spec/glos/term/interrupt.yml (moved) * spec/glos/term/interruptlevel.yml (moved) * spec/glos/term/interruptservice.yml (moved) * spec/glos/term/interruptserviceroutine.yml (moved) * spec/glos/term/io.yml (moved) * spec/glos/term/isr.yml (added) * spec/glos/term/isvv.yml (moved) * spec/glos/term/kernel.yml (moved) * spec/glos/term/list.yml (moved) * spec/glos/term/littleendian.yml (moved) * spec/glos/term/local.yml (moved) * spec/glos/term/localoperation.yml (moved) * spec/glos/term/logicaladdress.yml (moved) * spec/glos/term/looselycoupled.yml (moved) * spec/glos/term/majornumber.yml (moved) * spec/glos/term/manager.yml (moved) * spec/glos/term/mcs.yml (moved) * spec/glos/term/memorypool.yml (moved) * spec/glos/term/message.yml (moved) * spec/glos/term/messagebuffer.yml (moved) * spec/glos/term/messagequeue.yml (moved) * spec/glos/term/messagequeuecontrolblock.yml (moved) * spec/glos/term/minornumber.yml (moved) * spec/glos/term/mode.yml (moved) * spec/glos/term/mpci.yml (added) * spec/glos/term/multiprocessing.yml (moved) * spec/glos/term/multiprocessor.yml (moved) * spec/glos/term/multiprocessorcommunicationsinterfacelayer.yml (moved) * spec/glos/term/multiprocessorconfigurationtable.yml (moved) * spec/glos/term/multitasking.yml (moved) * spec/glos/term/mutualexclusion.yml (moved) * spec/glos/term/nested.yml (moved) * spec/glos/term/node.yml (moved) * spec/glos/term/nonexistent.yml (moved) * spec/glos/term/numa.yml (moved) * spec/glos/term/numericcoprocessor.yml (moved) * spec/glos/term/object.yml (moved) * spec/glos/term/objectoriented.yml (moved) * spec/glos/term/operatingsystem.yml (moved) * spec/glos/term/overhead.yml (moved) * spec/glos/term/packet.yml (moved) * spec/glos/term/partition.yml (moved) * spec/glos/term/partitioncontrolblock.yml (moved) * spec/glos/term/pending.yml (moved) * spec/glos/term/periodictask.yml (moved) * spec/glos/term/physicaladdress.yml (moved) * spec/glos/term/poll.yml (moved) * spec/glos/term/pool.yml (moved) * spec/glos/term/portability.yml (moved) * spec/glos/term/posting.yml (moved) * spec/glos/term/preempt.yml (moved) * spec/glos/term/priority.yml (moved) * spec/glos/term/priorityboosting.yml (moved) * spec/glos/term/priorityinheritance.yml (moved) * spec/glos/term/priorityinversion.yml (moved) * spec/glos/term/processorutilization.yml (moved) * spec/glos/term/proxy.yml (moved) * spec/glos/term/proxycontrolblock.yml (moved) * spec/glos/term/ptcb.yml (added) * spec/glos/term/pxcb.yml (added) * spec/glos/term/qcb.yml (added) * spec/glos/term/quantum.yml (moved) * spec/glos/term/queue.yml (moved) * spec/glos/term/readytask.yml (moved) * spec/glos/term/realtime.yml (moved) * spec/glos/term/reentrant.yml (moved) * spec/glos/term/region.yml (moved) * spec/glos/term/regioncontrolblock.yml (moved) * spec/glos/term/registers.yml (moved) * spec/glos/term/remote.yml (moved) * spec/glos/term/remoteoperation.yml (moved) * spec/glos/term/reqif.yml (moved) * spec/glos/term/resource.yml (moved) * spec/glos/term/resume.yml (moved) * spec/glos/term/returncode.yml (added) * spec/glos/term/returnvalue.yml (moved) * spec/glos/term/rncb.yml (added) * spec/glos/term/roundrobin.yml (moved) * spec/glos/term/rs232.yml (moved) * spec/glos/term/rtems.yml (moved) * spec/glos/term/running.yml (moved) * spec/glos/term/schedulable.yml (moved) * spec/glos/term/schedule.yml (moved) * spec/glos/term/scheduledtask.yml (moved) * spec/glos/term/scheduler.yml (moved) * spec/glos/term/schedulerinstance.yml (moved) * spec/glos/term/segments.yml (moved) * spec/glos/term/semaphore.yml (moved) * spec/glos/term/semaphorecontrolblock.yml (moved) * spec/glos/term/sharedmemory.yml (moved) * spec/glos/term/signal.yml (moved) * spec/glos/term/signalset.yml (moved) * spec/glos/term/smcb.yml (added) * spec/glos/term/smp.yml (moved) * spec/glos/term/smpbarriers.yml (moved) * spec/glos/term/smplocks.yml (moved) * spec/glos/term/softrealtimesystem.yml (moved) * spec/glos/term/softwarecomponent.yml (moved) * spec/glos/term/softwareitem.yml (added) * spec/glos/term/softwareproduct.yml (added) * spec/glos/term/softwareunit.yml (moved) * spec/glos/term/sourcecode.yml (moved) * spec/glos/term/sporadictask.yml (moved) * spec/glos/term/stack.yml (moved) * spec/glos/term/statuscode.yml (moved) * spec/glos/term/suspend.yml (moved) * spec/glos/term/synchronous.yml (moved) * spec/glos/term/systemcall.yml (moved) * spec/glos/term/target.yml (moved) * spec/glos/term/tas.yml (moved) * spec/glos/term/task.yml (moved) * spec/glos/term/taskcontrolblock.yml (moved) * spec/glos/term/taskmigration.yml (moved) * spec/glos/term/taskprocessoraffinity.yml (moved) * spec/glos/term/taskswitch.yml (moved) * spec/glos/term/tcb.yml (added) * spec/glos/term/thread.yml (added) * spec/glos/term/threaddispatch.yml (moved) * spec/glos/term/tick.yml (moved) * spec/glos/term/tightlycoupled.yml (moved) * spec/glos/term/timeout.yml (moved) * spec/glos/term/timer.yml (moved) * spec/glos/term/timercontrolblock.yml (moved) * spec/glos/term/timeslice.yml (moved) * spec/glos/term/timeslicing.yml (moved) * spec/glos/term/tls.yml (moved) * spec/glos/term/tmcb.yml (added) * spec/glos/term/transientoverload.yml (moved) * spec/glos/term/ttas.yml (moved) * spec/glos/term/userextensions.yml (moved) * spec/glos/term/userextensiontable.yml (moved) * spec/glos/term/userinitializationtaskstable.yml (moved) * spec/glos/term/userprovided.yml (moved) * spec/glos/term/usersupplied.yml (added) * spec/glos/term/vector.yml (moved) * spec/glos/term/waitqueue.yml (moved) * spec/glos/term/yaml.yml (moved) * spec/glos/term/yield.yml (moved) * spec/glossary.yml (added) Remove Doorstop specifics Sat, 18 Apr 2020 12:51:08 GMT Sebastian Huber [a4e08c5] * Makefile (modified) * rtemsqual/glossary.py (modified) * rtemsqual/tests/spec-applconfig/j.yml (modified) * rtemsqual/tests/spec-applconfig/m.yml (added) * rtemsqual/tests/spec-build/bsp2.yml (added) * rtemsqual/tests/test_applconfig.py (modified) * rtemsqual/tests/test_content_sphinx.py (modified) Enable branch coverage Tue, 17 Mar 2020 13:29:56 GMT Sebastian Huber [dfca4bc] * rtemsqual/glossary.py (modified) * rtemsqual/items.py (modified) content: Add method to register license/copyrights Tue, 17 Mar 2020 14:50:14 GMT Sebastian Huber [9144b6b] * rtemsqual/content.py (modified) * rtemsqual/glossary.py (modified) * tests/test_content.py (modified) content: Make lines for definition item Tue, 25 Feb 2020 12:54:17 GMT Sebastian Huber [c0ac12a] * .gitignore (added) * .gitmodules (added) * Makefile (added) * README.md (added) * config.ini (added) * external/rtems (added) * external/rtems-docs (added) * requirements.txt (added) * rtems_spec_to_x.py (added) * rtemsqual/__init__.py (added) * rtemsqual/applconfig.py (added) * rtemsqual/content.py (added) * rtemsqual/glossary.py (added) * rtemsqual/items.py (added) * spec/.doorstop.yml (added) * spec/RTEMS-GLOSSARY.yml (added) * spec/glos/.doorstop.yml (added) * spec/glos/RTEMS-GLOS-GENERAL.yml (added) * spec/glos/term/.doorstop.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ABI.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ACTIVE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-APERIODICTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-API.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-APPLICATION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ASR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ASYNCHRONOUS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ASYNCHRONOUSSIGNALROUTINE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ATOMICOPERATIONS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-AWAKENED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BIGENDIAN.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BITMAPPED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BLOCKEDTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BOARDSUPPORTPACKAGE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BROADCAST.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BSP.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-BUFFER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-C11.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CALLINGCONVENTION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CENTRALPROCESSINGUNIT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CHAIN.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CLUSTER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-COALESCE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CONFIGURATIONTABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CONTEXT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CONTEXTSWITCH.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CORE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CPU.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CRITICALSECTION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CRT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-CXX11.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DEADLINE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DEVICE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DEVICEDRIVER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DEVICEDRIVERTABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DIRECTIVES.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DISPATCH.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DOORSTOP.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DORMANT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-DUALPORTED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EARS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EMBEDDED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ENTRYPOINT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ENVELOPE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ERRORCODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EVENTS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EXCEPTION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EXECUTINGTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EXECUTIVE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EXPORTED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-EXTERNALADDRESS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-FIFO.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-FIRSTINFIRSTOUT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-FLOATINGPOINTCOPROCESSOR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-FREED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-GCC.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-GLOBAL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-GNAT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-GNU.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HANDLER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HARDREALTIMESYSTEM.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HEAP.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HEIRTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HETEROGENEOUS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-HOMOGENEOUS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ID.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-IDLETASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERFACE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERNALADDRESS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERRUPT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERRUPTLEVEL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-INTERRUPTSERVICEROUTINE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-IO.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ISR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ISVV.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-KERNEL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LIST.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LITTLEENDIAN.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LOCAL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LOCALOPERATION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LOGICALADDRESS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-LOOSELYCOUPLED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MAJORNUMBER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MANAGER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MCS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MEMORYPOOL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MESSAGE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MESSAGEBUFFER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MESSAGEQUEUE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MESSAGEQUEUECONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MINORNUMBER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MPCI.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MULTIPROCESSING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MULTIPROCESSOR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MULTIPROCESSORCOMMUNICATIONSINTERFACELAYER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MULTIPROCESSORCONFIGURATIONTABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MULTITASKING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-MUTUALEXCLUSION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-NESTED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-NODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-NONEXISTENT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-NUMA.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-NUMERICCOPROCESSOR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-OBJECT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-OBJECTORIENTED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-OPERATINGSYSTEM.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-OVERHEAD.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PACKET.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PARTITION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PARTITIONCONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PENDING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PERIODICTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PHYSICALADDRESS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-POLL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-POOL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PORTABILITY.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-POSTING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PREEMPT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PRIORITY.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PRIORITYBOOSTING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PRIORITYINHERITANCE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PRIORITYINVERSION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PROCESSORUTILIZATION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PROXY.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PROXYCONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PTCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-PXCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-QCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-QUANTUM.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-QUEUE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-READYTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REALTIME.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REENTRANT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REGION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REGIONCONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REGISTERS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REMOTE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REMOTEOPERATION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-REQIF.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RESOURCE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RESUME.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RETURNCODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RETURNVALUE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RNCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-ROUNDROBIN.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RS232.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RTEMS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-RUNNING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SCHEDULABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SCHEDULE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SCHEDULEDTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SCHEDULER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SCHEDULERINSTANCE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SEGMENTS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SEMAPHORE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SEMAPHORECONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SHAREDMEMORY.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SIGNAL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SIGNALSET.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SMCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SMP.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SMPBARRIERS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SMPLOCKS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SOFTREALTIMESYSTEM.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREITEM.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SOFTWAREPRODUCT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SOURCECODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SPORADICTASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-STACK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-STATUSCODE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SUSPEND.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SYNCHRONOUS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-SYSTEMCALL.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TARGET.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TAS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASKCONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASKMIGRATION.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASKPROCESSORAFFINITY.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TASKSWITCH.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-THREAD.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-THREADDISPATCH.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TICK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIGHTLYCOUPLED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIMEOUT.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIMER.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIMERCONTROLBLOCK.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIMESLICE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TIMESLICING.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TLS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TMCB.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TRANSIENTOVERLOAD.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-TTAS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-USEREXTENSIONS.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-USEREXTENSIONTABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-USERINITIALIZATIONTASKSTABLE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-USERPROVIDED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-USERSUPPLIED.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-VECTOR.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-WAITQUEUE.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-YAML.yml (added) * spec/glos/term/RTEMS-GLOS-TERM-YIELD.yml (added) * tests/spec-glossary/RTEMS-GLOS-TERM-T.yml (added) * tests/spec-glossary/RTEMS-GLOS-TERM-U.yml (added) * tests/spec-glossary/RTEMS-GLOS-TERM-V.yml (added) * tests/spec-glossary/doc.rst (added) * tests/spec-glossary/g.yml (added) * tests/spec-glossary/glossary.rst (added) * tests/spec-item-cache/.z.yml (added) * tests/spec-item-cache/d/c.yml (added) * tests/spec-item-cache/empty.txt (added) * tests/spec-item-cache/p.yml (added) * tests/test_content.py (added) * tests/test_glossary.py (added) * tests/test_items.py (added) Initial import
