@568342a
07/26/21 13:58:33 |
Sebastian Huber |
spec: Specify rtems_interrupt_handler_iterate()
@ffd083c
07/26/21 13:19:53 |
Sebastian Huber |
spec: Improve validation test
Cover also …
@d77baf8
07/26/21 12:40:26 |
Sebastian Huber |
spec: Specify support directives
@738bd49
07/26/21 12:23:01 |
Sebastian Huber |
spec: Simplify test descriptions
@3bec871
07/26/21 12:15:43 |
Sebastian Huber |
spec: Fix status specification
@115c284
07/26/21 11:57:22 |
Sebastian Huber |
modules: Update rtems
@1062dc1
07/26/21 11:57:01 |
Sebastian Huber |
spec: Fix rtems_object_get_local_node() validation
@004ee94
07/26/21 11:12:30 |
Sebastian Huber |
@80cbbed
07/26/21 11:11:00 |
Sebastian Huber |
spec: Fix bsp_interrupt_spurious() validation
@1d0351c
07/26/21 10:13:24 |
Sebastian Huber |
spec: Specify rtems_object_get_local_node()
@27a681d
07/26/21 10:00:21 |
Sebastian Huber |
spec: Specify status directives
@0769d59
07/26/21 09:23:04 |
Sebastian Huber |
@af941ca
07/26/21 07:23:42 |
Sebastian Huber |
@6c80527
07/26/21 07:14:15 |
Sebastian Huber |
spec: Adjust rtems_interrupt_get_affinity()
@d382499
07/23/21 14:48:39 |
Sebastian Huber |
config.yml: Update extra files
@038f8f1
07/23/21 14:32:31 |
Sebastian Huber |
@a415045
07/23/21 14:26:24 |
Sebastian Huber |
@fc3586f
07/23/21 08:47:35 |
frank.kuehndel |
spec: Fix unstable test of clock manager
The tests of specification …
@50aea7a
07/23/21 09:03:56 |
Sebastian Huber |
spec: Remove always enabled interrupt attribute
@e579dbc
07/22/21 14:41:54 |
Sebastian Huber |
spec: Fix typos
@b2f87ba
07/22/21 14:14:35 |
Sebastian Huber |
spec: Rename "cause" in "raise"
@4f5f877
07/22/21 12:52:10 |
Sebastian Huber |
specview.py: Filter items by validated status
@306c315
07/22/21 09:20:51 |
Sebastian Huber |
spec: Fix link which produced a cycle
@b31b812
07/22/21 05:28:37 |
Sebastian Huber |
@1f0f040
07/21/21 13:54:14 |
Sebastian Huber |
@938c279
07/16/21 13:34:40 |
Sebastian Huber |
spec: Add IRQ(A)MP support function
@24eb00e
07/15/21 17:00:16 |
Sebastian Huber |
spec: Add APBUART functions
@e54b1d7
07/15/21 12:11:03 |
Sebastian Huber |
spec: Add grlib register load/store
@bdbc189
05/04/21 12:46:51 |
Sebastian Huber |
spec: Add grlib register blocks
@7aa538b
07/16/21 07:06:06 |
Sebastian Huber |
interface: Do not add group dependencies
Do not use the interface …
@72508ab
05/03/21 08:36:15 |
Sebastian Huber |
interface: Add register-block support
@5f3d5fa8
07/15/21 13:32:49 |
Sebastian Huber |
validation: Support test cases in build objects
@94ac94d
07/21/21 05:59:35 |
Sebastian Huber |
spec: Reorder some interface groups
@8b34a18
07/21/21 14:12:54 |
Sebastian Huber |
specview.py: Display link roles
@61bd4d5
07/21/21 13:42:15 |
Sebastian Huber |
config.yml: Use gr712rc BSP
@9278d49
07/20/21 07:29:13 |
Sebastian Huber |
spec: Fix glossary references
@62d7a6f
07/20/21 07:42:39 |
Sebastian Huber |
specview.py: Substitute attributes during view
This helps to catch …
@5807c6f
07/15/21 08:26:02 |
Sebastian Huber |
spec: Fix format of some references
@5685f4b
07/15/21 08:06:35 |
Sebastian Huber |
spec: Fix sporadic test failures
@160a456
07/14/21 07:21:46 |
Sebastian Huber |
spec: Rework interrupt attributes
@500bde1
07/12/21 14:51:54 |
Sebastian Huber |
modules: Update rsb
@cb6eebf
07/12/21 13:16:10 |
Sebastian Huber |
@4696cd1
06/09/21 12:12:22 |
frank.kuehndel |
spec: Adding a test for timer_[server_]fire_when()
Extending the …
@9063300
07/06/21 11:27:03 |
Sebastian Huber |
spec: Specify bsp_interrupt_spurious()
@10982ce
07/06/21 08:36:02 |
Sebastian Huber |
spec: Specify rtems_interrupt_set_affinity()
@1f509ab
07/05/21 17:37:38 |
Sebastian Huber |
spec: Specify rtems_interrupt_get_affinity()
@c467bdb
07/05/21 14:14:41 |
Sebastian Huber |
spec: Specify rtems_interrupt_cause_on()
@4aaf82c
07/05/21 13:48:03 |
Sebastian Huber |
spec: Specify rtems_interrupt_is_pending()
@dd7ede6
07/05/21 12:01:36 |
Sebastian Huber |
spec: Specify rtems_interrupt_clear()
@b762862
07/02/21 18:16:56 |
Sebastian Huber |
spec: Specify rtems_interrupt_cause()
@caff701
06/30/21 06:12:37 |
Sebastian Huber |
spec: Specify rtems_interrupt_entry_remove()
@37dd801
06/26/21 15:09:37 |
Sebastian Huber |
spec: Specify rtems_interrupt_entry_install()
@e71edde
06/29/21 12:36:09 |
Sebastian Huber |
spec: Specify rtems_interrupt_vector_disable()
@a52a39f
06/29/21 08:22:47 |
Sebastian Huber |
spec: Specify rtems_interrupt_vector_enable()
@00862d3
06/29/21 07:29:25 |
Sebastian Huber |
spec: Specify rtems_interrupt_get_attributes()
@341b08c
06/28/21 14:36:06 |
Sebastian Huber |
spec: Specify rtems_interrupt_vector_is_enabled()
@b04d86d
06/17/21 12:20:07 |
Sebastian Huber |
spec: Add interrupt entry directives
@2ffb38e
06/16/21 06:37:49 |
Sebastian Huber |
spec: Add interrupt vector directives
@a615014
06/10/21 16:01:15 |
Sebastian Huber |
spec: Add interrupt manager extension
@eb97b54
06/26/21 15:13:39 |
Sebastian Huber |
specview.py: Do not print N/A states
@65f7a18
06/23/21 08:10:32 |
Sebastian Huber |
Revert "spec: Add unit test link role"
This reverts commit …
@dff03a3
06/23/21 08:06:08 |
Sebastian Huber |
@9c2bfab
06/16/21 10:37:00 |
Sebastian Huber |
spec: Fix parameter direction
@cdb62c9
06/16/21 17:06:38 |
Sebastian Huber |
validation: Split file
@45b1ab5
06/15/21 06:38:53 |
Sebastian Huber |
interface: Fix mapper prefix
@6ee44e1
06/11/21 07:20:23 |
Sebastian Huber |
spec: Use a common phrase for pointer parameters
@6179075
06/07/21 15:53:48 |
Sebastian Huber |
@dcf46cb
06/07/21 15:53:41 |
Sebastian Huber |
config.yml: Add extra files
@fb0c8b6
06/07/21 12:59:29 |
Sebastian Huber |
@09c6c35
05/28/21 12:41:36 |
Sebastian Huber |
@2330afe
05/28/21 12:38:08 |
Sebastian Huber |
spec: Add event manager requirements
@48b9e5e
05/28/21 11:54:01 |
Sebastian Huber |
spec: Add and use software architecture components
@2004cfa
05/28/21 11:38:35 |
Sebastian Huber |
spec: Add system events to hidden group
@0fe547c
05/28/21 09:31:03 |
Sebastian Huber |
items: Add ItemCache?.types
@b6c4b615
05/28/21 07:59:49 |
Sebastian Huber |
spec: Fix attribute references
@e336dd3
05/28/21 07:17:41 |
Sebastian Huber |
specview.py: Substitute text during view
This helps to catch invalid …
@d819025
05/28/21 06:59:16 |
Sebastian Huber |
spec: Fix links and references
@1b05bad
05/28/21 06:11:03 |
Sebastian Huber |
spec: Add documentation interface domain
@6cfdead
05/28/21 06:05:24 |
Sebastian Huber |
spec: Add group for dynamic memory allocation
@1625e71
05/28/21 05:59:39 |
Sebastian Huber |
spec: Fix link roles
@9a36c99
05/28/21 05:57:24 |
Sebastian Huber |
spec: Place RTEMS_UNREACHABLE() into a group
@6438f3d
05/28/21 05:43:26 |
Sebastian Huber |
spec: Add runtime performance requirements
@9dfeb84
05/28/21 05:21:53 |
Sebastian Huber |
spec: Add interface group for C and POSIX
@13e3d66
05/28/21 05:11:45 |
Sebastian Huber |
spec: Add "interface-ingroup-hidden" link role
This avoids orphaned items.
@fe615d6
05/28/21 04:50:47 |
Sebastian Huber |
spec: Document rtems_task_delete() error
@331d1dad
05/26/21 15:02:28 |
Sebastian Huber |
@fd80d1f
05/26/21 12:37:15 |
Sebastian Huber |
@bffa1e7
05/26/21 12:15:50 |
Sebastian Huber |
@a44b35b
05/26/21 12:00:55 |
Sebastian Huber |
spec: Use TCB in rtems_task_restart() validation
This simplifies the …
@c9abed8
05/19/21 11:39:30 |
Sebastian Huber |
spec: Specify rtems_task_restart()
@096c68f
05/19/21 06:17:04 |
Sebastian Huber |
spec: Specify rtems_task_exit()
@7c90eff
05/18/21 18:55:04 |
Sebastian Huber |
spec: Fix format
@2a85a7c
05/18/21 15:36:14 |
Sebastian Huber |
spec: Specify rtems_task_wake_after()
@d3c9a83
05/18/21 15:24:20 |
Sebastian Huber |
spec: Specify rtems_task_wake_when()
@e1c9210
05/18/21 07:31:59 |
Sebastian Huber |
spec: Specify clock_nanosleep()
@de73f18
05/17/21 07:02:32 |
Sebastian Huber |
@cb08a02
05/17/21 06:59:23 |
Sebastian Huber |
@ab240ca
05/17/21 06:13:25 |
Sebastian Huber |
@a55de0c
05/10/21 05:51:52 |
Sebastian Huber |
spec: Specify task manager directives
@fa868b2
05/14/21 09:03:59 |
frank.kuehndel |
spec: Add spec for rtems_timer_server_fire_when()
Adding a …
