@6fc23e6
08/19/20 09:07:54 |
Sebastian Huber |
interface: Add automatically generated warning
@4ff33d6
08/19/20 09:03:48 |
Sebastian Huber |
specdoc: Add automatically generated warning
@3e4902a
08/19/20 09:00:29 |
Sebastian Huber |
content: Add add_automatically_generated_warning()
@3bd7242
08/17/20 08:40:50 |
Sebastian Huber |
doxygen: Sort group names
@f9b689f
08/17/20 07:49:30 |
Sebastian Huber |
build: Gather test header files
@dfaa801
08/17/20 07:13:42 |
Sebastian Huber |
validation: Add test documentation to group
@91c90d3
08/14/20 16:40:59 |
Sebastian Huber |
validation: Add ${step/123} support
@3e9b695
08/14/20 06:13:22 |
Sebastian Huber |
validation: Add test header for test cases
@48d7a68
08/14/20 06:57:04 |
Sebastian Huber |
spec: Unify test attribute keys
@b7e749b
08/14/20 05:41:24 |
Sebastian Huber |
spec: Add test header to test case item type
@65d5906
08/14/20 05:25:53 |
Sebastian Huber |
validation: Fix typos
@ed25048
08/14/20 05:23:59 |
Sebastian Huber |
items: Add Item.spec
@09213e2
08/14/20 05:19:01 |
Sebastian Huber |
validation: Use dictionary to gather items
@8e0b1ae
08/13/20 12:47:54 |
Sebastian Huber |
validation: Update due to test API changes
@91df79c
08/11/20 06:48:00 |
Sebastian Huber |
validation: Remove explicit test names
@82426ed
08/04/20 07:14:52 |
Sebastian Huber |
validation: Add test context support
@e3e1de7
08/04/20 07:04:40 |
Sebastian Huber |
validation: Add test cleanup
@c127fb3
08/04/20 05:08:38 |
Sebastian Huber |
validation: Add test early preparation
@1d3866a
08/11/20 06:48:25 |
Sebastian Huber |
content: Add to_camel_case()
@6df984e
08/19/20 08:18:31 |
Sebastian Huber |
spec: Fix item format
@4e31483
08/19/20 09:25:30 |
Sebastian Huber |
content: Strip function parameters
@abd798c
08/10/20 10:49:57 |
Sebastian Huber |
spec: Fix typo
@a25f7ea
08/17/20 12:06:16 |
Sebastian Huber |
spec: Synchronize with RTEMS
@6135d0a
08/04/20 04:58:34 |
Sebastian Huber |
validation: Move action code to separate function
@a581446
08/04/20 10:01:59 |
Sebastian Huber |
validation: Fix N/A scope description
@40bb555
08/07/20 09:09:29 |
Sebastian Huber |
validation: Clarify skip action transitions
@2ac3803
08/07/20 08:08:58 |
Sebastian Huber |
spec: Update RTEMS_ZERO_LENGTH_ARRAY
@33681ff
08/07/20 04:56:46 |
Sebastian Huber |
applconfig: Add automatically generated warning
@c4e460d
08/07/20 04:57:26 |
Sebastian Huber |
content: Add Content.comment_block()
@aae12a9
08/06/20 13:22:28 |
Sebastian Huber |
spec: Fix formatting
@361cf38
08/06/20 07:31:06 |
Sebastian Huber |
spec: Improve formatting
@79684a5
08/06/20 13:03:36 |
Sebastian Huber |
applconfig: Add references for unspec interfaces
@5c3d2c7
08/06/20 12:31:45 |
Sebastian Huber |
spec: Add references for some C types and defines
@61376c4
08/06/20 12:26:29 |
Sebastian Huber |
spec: Add reference to unspecified interfaces
@35d9ba4
08/06/20 08:27:29 |
Sebastian Huber |
spec: Improve references in appl config options
@e9312e2
08/06/20 08:24:16 |
Sebastian Huber |
applconfig: Improve interface mappings
@a89a5c6
08/06/20 08:23:27 |
Sebastian Huber |
content: Improve CContent.doxyfy()
Add replacement for :file:xyz .
@48e355a
08/06/20 08:26:49 |
Sebastian Huber |
spec: Add more unspecified interfaces
@486da1b
08/06/20 07:09:02 |
Sebastian Huber |
specdoc: Fix typo
@2485965
07/28/20 06:25:11 |
Sebastian Huber |
spec: Clarify event receive description
@3e303ed
07/28/20 04:57:22 |
Sebastian Huber |
spec: Clarify and use interface brief
@7617fcb
07/28/20 04:56:37 |
Sebastian Huber |
specdoc: Fix output format of regular expressions
@55e17d2
07/27/20 12:54:13 |
Sebastian Huber |
validation: Add ability to skip action transitions
@244b277
07/27/20 07:23:13 |
Sebastian Huber |
validation: Support N/A in the action transitions
Sometimes the …
@fd31f9d
07/27/20 05:38:53 |
Sebastian Huber |
config.yml: Fix UIDs
@6a3a664
07/27/20 05:08:34 |
Sebastian Huber |
items: Improve ItemCache? exception message
@1cf2bec
07/24/20 18:46:14 |
Sebastian Huber |
spec: Add top-level requirement for the system
@86dbbfa4
07/24/20 18:44:56 |
Sebastian Huber |
spec: Add requirements text to groups
@cead53e
07/24/20 18:08:13 |
Sebastian Huber |
spec: Move interface groups
@4ad78f2
07/24/20 10:25:31 |
Sebastian Huber |
spec: Add header file brief descriptions
@0e38d6d
07/24/20 07:19:59 |
Sebastian Huber |
config: Generate event manager documentation
@51eded1
07/23/20 14:13:01 |
Sebastian Huber |
spec: Add event manager documentation
@471eaef
07/23/20 14:12:37 |
Sebastian Huber |
spec: Fix semaphore manager description
@d9fa7d6
07/24/20 06:33:04 |
Sebastian Huber |
interfacedoc: Simplify interface references
@895ca28
07/23/20 10:41:53 |
Sebastian Huber |
Update rtems submodule
@e6371d9
07/23/20 10:41:22 |
Sebastian Huber |
spec: Fix rtems_isr_entry for some CPU ports
@ea321f4
07/23/20 10:40:38 |
Sebastian Huber |
validation: Use <rtems/test.h> instead of <t.h>
@e49c759
07/15/20 08:04:25 |
Sebastian Huber |
Rename "rtemsqual" in "rtemsspec"
@1dc8ffb
07/15/20 07:58:23 |
Sebastian Huber |
Rename "external" in "modules"
@b155fbb
07/07/20 07:09:31 |
Sebastian Huber |
applconfig: Add Doxygen output
@067a6cf
07/07/20 07:30:20 |
Sebastian Huber |
content: Move get value handlers for Doxygen
@6a0e467
07/07/20 06:53:01 |
Sebastian Huber |
spec: Avoid Sphinx-specific :file:
@b29dd73
07/07/20 06:49:58 |
Sebastian Huber |
spec: Use ${...} references in /if/acfg/*
This allows generation of …
@374e1bf
07/06/20 12:30:41 |
Sebastian Huber |
applconfig: Use item mapper for substitution
@6da4c69
07/03/20 12:58:33 |
Sebastian Huber |
applconfig: Add _ContentAdaptor class
@a07070a
07/03/20 11:12:19 |
Sebastian Huber |
applconfig: Simplify _resolve_constraint_links()
@a618c70
07/03/20 11:10:21 |
Sebastian Huber |
applconfig: Simplify gathering of items
@e6c4f94
07/06/20 07:57:27 |
Sebastian Huber |
applconfig: Sort options by name
@518d8c3
07/06/20 07:23:27 |
Sebastian Huber |
spec: Move application configuration items
@813f520
07/07/20 08:40:32 |
Sebastian Huber |
content: Add CContent.add_paragraph()
@c802878
07/06/20 13:53:06 |
Sebastian Huber |
content: Add CContent.doxyfy()
@6a14df1
07/07/20 05:46:14 |
Sebastian Huber |
content: Rename add_spdx_license_identifier()
@427606d
07/06/20 15:29:51 |
Sebastian Huber |
content: Add prepend_copyrights_and_licenses()
@6cdd89b
07/06/20 12:30:19 |
Sebastian Huber |
items: Add ItemMapper?.item property
@e254c5e
07/06/20 10:43:04 |
Sebastian Huber |
items: Fix ItemGetValueContext?.type_path_key
@05e1f1f
07/06/20 19:31:42 |
Sebastian Huber |
spec: Fix /if/acfg/max-processors minimum
@c116767
07/03/20 19:24:52 |
Sebastian Huber |
spec: Allow dual licensing
The items have the following copyright …
@5c6279c
07/03/20 08:36:44 |
Sebastian Huber |
@602a205
07/03/20 08:36:37 |
Sebastian Huber |
Update rtems-docs submodule
@041521b
07/03/20 08:25:58 |
Sebastian Huber |
spec: Fix typo
@2ac89cc
07/01/20 17:08:37 |
Sebastian Huber |
content: Simplify _split_includes()
@3eff552
07/01/20 15:24:59 |
Sebastian Huber |
interface: Simplify interface item mapper
@e382283c
07/01/20 12:54:20 |
Sebastian Huber |
items: Move item get value customization
@0dada04
06/26/20 18:01:46 |
Sebastian Huber |
items: Add ItemGetValueContext?
Use aggregated item type in …
@d93b4b5
06/26/20 16:26:08 |
Sebastian Huber |
items: Add support for aggregated item type
@ffe6e2b
06/30/20 11:59:24 |
Sebastian Huber |
items: Do not save internal attributes
@75adcfe
06/30/20 11:54:41 |
Sebastian Huber |
spec: Fix requirement items
@f0d6862
06/04/20 14:58:18 |
Sebastian Huber |
spec: Add object name to id actions
@5f53e80
06/25/20 07:41:27 |
Sebastian Huber |
spec: Add validation test suite
@2546129
06/24/20 14:20:32 |
Sebastian Huber |
spec: Document name to id directives
@d860350
06/24/20 09:32:43 |
Sebastian Huber |
spec: Specify <rtems.h>
@3e061f5
06/22/20 06:36:48 |
Sebastian Huber |
spec: Add /if/rtems/userext/*
@c4fe9f5
06/22/20 06:36:48 |
Sebastian Huber |
spec: Add /if/rtems/timer/*
@c51ff93
06/22/20 06:36:48 |
Sebastian Huber |
spec: Add /if/rtems/support/*
@8c90c5c
06/22/20 06:36:48 |
Sebastian Huber |
spec: Add /if/rtems/signal/*
@7446038
06/22/20 06:36:48 |
Sebastian Huber |
spec: Add /if/rtems/region/*
@dc70ea0
06/22/20 06:36:48 |
Sebastian Huber |
spec: Add /if/rtems/ratemon/*
@42ec363
06/22/20 06:36:48 |
Sebastian Huber |
spec: Add /if/rtems/part/*
@d40f9a1
06/22/20 06:36:47 |
Sebastian Huber |
spec: Add /if/rtems/object/*
@8e0fe05
06/22/20 06:36:47 |
Sebastian Huber |
spec: Add /if/rtems/mp/*
