@6d35128
11/10/21 10:11:32 |
Sebastian Huber |
spec: Improve processor removal specification
@8cefdc1
11/09/21 14:51:10 |
Sebastian Huber |
modules: Update rtems
@283aa86
11/09/21 12:47:09 |
Sebastian Huber |
spec: Specify ask for help details
@3fcf994
11/08/21 14:34:48 |
Sebastian Huber |
spec: Specify scheduler yield
@77400c8
11/08/21 12:26:38 |
Sebastian Huber |
spec: Fix issue with RTEMS_DEBUG
@d2c27b8
11/08/21 08:58:04 |
Sebastian Huber |
spec: Remove processor special case
@d6db730
11/08/21 09:26:30 |
Sebastian Huber |
validation: Move support code before fixture
@91b8e87
11/05/21 19:16:20 |
Sebastian Huber |
spec: Fix integer constant
@08fd839
11/01/21 19:37:03 |
kinsey.moore |
spec: CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
@b10a624
10/29/21 17:44:06 |
Sebastian Huber |
@b955aff
10/29/21 17:29:47 |
Sebastian Huber |
spec: Improve set task priority specification
@80df20f
10/29/21 06:21:21 |
Sebastian Huber |
spec: Specify MrsP uniprocessor scheduler detail
@87720a6
10/29/21 05:12:20 |
Sebastian Huber |
spec: Check that NTP update second is not called
@a827b7c
10/28/21 19:21:10 |
Sebastian Huber |
spec: Fix typo
@7bdca91
10/28/21 18:57:40 |
Sebastian Huber |
@611b9a2
10/28/21 18:17:23 |
Sebastian Huber |
@45237bf
10/28/21 14:09:26 |
Sebastian Huber |
spec: Improve SMP-specific timecounter validation
@bcb0753
10/28/21 12:28:51 |
Sebastian Huber |
spec: Specify NTP support
@da36db3
10/28/21 11:06:16 |
Sebastian Huber |
spec: Specify _Timecounter_Tick_simple()
@94ed8b1
10/27/21 14:12:35 |
Sebastian Huber |
spec: Fix sporadic test failure
@940bfeb0
10/26/21 14:35:35 |
Sebastian Huber |
spec: Update documentation
@fd227bf
10/19/21 15:12:19 |
Sebastian Huber |
spec: Fix typo
@a312b2b
10/19/21 15:00:28 |
Sebastian Huber |
spec: Clarify boot time
@3207e03
10/19/21 14:51:29 |
Sebastian Huber |
spec: Add idle task stack allocator option
@dbfea64b
10/18/21 10:28:30 |
Sebastian Huber |
spec: Specify SMP EDF scheduler set affinity
@f30f7c3
10/15/21 08:25:12 |
Sebastian Huber |
spec: Fix rtems_cpu_usage_report() test
@cc7ef3a
10/13/21 14:34:40 |
Sebastian Huber |
spec: Specify MrsP semaphore obtain details
@24eafef
10/13/21 14:04:09 |
Sebastian Huber |
@505be2e
10/13/21 11:45:30 |
Sebastian Huber |
@40c6228
10/13/21 11:42:14 |
Sebastian Huber |
spec: Improve get time tests
@7a6feb3
10/13/21 11:31:06 |
Sebastian Huber |
spec: Refine timecounter tick
@96a7fdc
10/13/21 08:00:18 |
Sebastian Huber |
@331dc0cb
10/12/21 17:22:23 |
frank.kuehndel |
spec: add unit test to cover get_config_max()
@38fa740
10/12/21 09:03:06 |
frank.kuehndel |
spec: timer: improve test for branch coverage
Add code to reach …
@dad7f61
10/13/21 07:49:04 |
Sebastian Huber |
spec: Improve TQ timeout with priority inherit
@6146398
10/12/21 08:19:44 |
Sebastian Huber |
spec: Specify and test timecounters
@2e19aac
10/12/21 11:17:32 |
Sebastian Huber |
spec: Fix rate monotonic statistics
@7085cb7
10/11/21 13:28:47 |
Sebastian Huber |
spec: Add new clock directives
@e452f07
10/09/21 12:07:29 |
Sebastian Huber |
spec: Improve thread wait lock test case
@5cc13c7
10/09/21 10:00:43 |
Sebastian Huber |
spec: Fix sporadic test failures
@25c958b
10/09/21 09:31:55 |
Sebastian Huber |
spec: Refine TQ timeout with priority inherit
@82ec049
10/08/21 15:34:21 |
Sebastian Huber |
spec: Fix typo
@1e3984d
10/08/21 14:20:17 |
Sebastian Huber |
@16599e3
10/08/21 07:24:37 |
frank.kuehndel |
spec: ratemon: add glossery links in timeout
@ac20062
10/07/21 17:23:18 |
frank.kuehndel |
spec: Ratemon: add unittest for code coverage
@30504ee
10/06/21 17:05:56 |
frank.kuehndel |
spec: Ratemon: get_status() test reset case
Add test case which uses …
@09c7ca8
10/06/21 17:04:54 |
frank.kuehndel |
spec: Ratemon: remove outdated comment
@d1a02a2
10/06/21 13:15:54 |
frank.kuehndel |
spec: Ratemon test: Adapt to reset postponed jobs
There was a change …
@a384c76
10/08/21 13:45:55 |
Sebastian Huber |
spec: Refine TQ timeout priority inherit spec
@c85c24e
10/08/21 13:34:05 |
Sebastian Huber |
spec: Refine TQ surrender priority inherit spec
@3aa4f12
10/06/21 07:49:11 |
Sebastian Huber |
spec: Add TQ enqueue priority inherit spec
@a4bc020
10/06/21 07:42:42 |
Sebastian Huber |
spec: Improve wording in TQ enqueue specs
@822f2ff
10/08/21 05:08:01 |
Sebastian Huber |
modules: Update rsb
@4284b19
10/06/21 07:30:40 |
Sebastian Huber |
config.yml: Enable unit tests
@ce9dc44
10/06/21 07:30:31 |
Sebastian Huber |
@6f4f211
10/06/21 06:57:29 |
Sebastian Huber |
@0884c62
10/06/21 06:32:54 |
Sebastian Huber |
spec: Disable clock driver for some test suites
@bc4d8f5
10/06/21 05:49:11 |
Sebastian Huber |
spec: Add unit tests for red-black trees
@8d6b28b
10/04/21 11:45:53 |
Sebastian Huber |
@618e377
10/04/21 07:33:02 |
Sebastian Huber |
spec: Specify rate monotonic timeout
@d85282c
10/01/21 13:58:28 |
Sebastian Huber |
spec: Specify CPU usage reporting
@83d381e
10/01/21 13:10:45 |
Sebastian Huber |
spec: Improve rtems_task_set_affinity() spec
@f625305
10/01/21 06:00:14 |
Sebastian Huber |
items: Add support for arguments in substitutions
@409bd74
10/01/21 05:34:55 |
Sebastian Huber |
items: Remove support for pipe substitution
@23b95de
09/30/21 14:21:14 |
Sebastian Huber |
items: Add ItemMapper?.get_value_dictionary()
@17c938e
09/30/21 11:02:52 |
Sebastian Huber |
@2f48804
09/30/21 11:02:15 |
Sebastian Huber |
generate_membench.py: Add task create workaround
@3166d0e
09/30/21 10:45:23 |
Sebastian Huber |
@c4a758c
09/30/21 08:57:24 |
Sebastian Huber |
generate_membench.py: Add benchmarks
@740289e
09/30/21 07:15:55 |
Sebastian Huber |
spec: Move GRLIB group
@fdb80bd
09/29/21 12:20:13 |
Sebastian Huber |
@110de4b
09/28/21 16:09:50 |
Sebastian Huber |
spec: Improve mutex seize wait
@660c763
09/29/21 09:15:05 |
Sebastian Huber |
glossary: Add C*, EDF, Futex, MrsP, and OpenMP
@b944b8a
09/28/21 16:14:42 |
Sebastian Huber |
spec: Improve thread queue enqueue FIFO test
@512a4a2
09/28/21 14:09:40 |
Sebastian Huber |
spec: Improve semaphore surrender
@fc13d69
09/28/21 12:38:27 |
Sebastian Huber |
spec: Specify scheduler helping detail
@579f9db
09/28/21 09:37:56 |
Sebastian Huber |
@36095f1
09/28/21 09:37:44 |
Sebastian Huber |
spec: Use ts-config.h
@15922df
09/28/21 09:16:37 |
Sebastian Huber |
@4bee688
09/28/21 08:08:46 |
Sebastian Huber |
specview.py: Improve item validation
@94ce3d7
09/28/21 08:49:53 |
Sebastian Huber |
spec: Fix format
@5e94831
09/28/21 08:50:26 |
Sebastian Huber |
spec: Mark some directive as not pre-qualified
@b2880bc
09/28/21 08:10:15 |
Sebastian Huber |
spec: Mark some acfg options as not pre-qualified
@d7fab03
09/28/21 06:34:13 |
Sebastian Huber |
spec: Add application configuration requirements
@3eeb04c
09/27/21 05:13:50 |
Sebastian Huber |
spec: Specify thread queue deadlock details
@ef19747
09/24/21 14:03:46 |
Sebastian Huber |
@9955732
09/24/21 12:32:03 |
Sebastian Huber |
spec: Add usage constraints
@da64e79
09/24/21 12:10:46 |
Sebastian Huber |
specview.py: Enumerators do not need validation
@90ebc09
09/24/21 12:47:06 |
Sebastian Huber |
spec: Generalize register block specification
@65b3cf0
09/24/21 12:32:12 |
Sebastian Huber |
spec: Fix link role
@eb10db2
09/24/21 11:34:03 |
Sebastian Huber |
modules: Update rsb
@d05546b
09/24/21 11:32:06 |
Sebastian Huber |
@b22a800
09/21/21 07:58:20 |
frank.kuehndel |
spec: add unit tests for kern_tc.c
Parts of the file …
@d03e133
09/17/21 19:38:03 |
frank.kuehndel |
spec: Unit tests Messge Queue Handler
@9d34d88
09/20/21 14:33:41 |
frank.kuehndel |
spec: Remove unused struct member
@f256d34
09/16/21 16:55:57 |
frank.kuehndel |
spec: Add STATIC_ANALYSIS and NOINIT specs
This specification is up …
@2b81226
09/18/21 13:14:40 |
Sebastian Huber |
spec: Specify <sys/lock.h> mutexes
@878b86d
09/20/21 07:28:38 |
Sebastian Huber |
glossary: Add OMIP
@bb951a8
09/24/21 09:04:56 |
Sebastian Huber |
spec: Add "function-implementation" link role
@3c60360
09/20/21 13:48:41 |
Sebastian Huber |
spec: Generalize semaphore release
