# # ChangeLog for ttcp in network-demos # # Generated by Trac 1.2.1.dev0 # 04/26/24 02:41:20 Thu, 01 Apr 1999 18:19:08 GMT Joel Sherrill [ba9c45c] * ttcp/rtems_ttcp.c (modified) Patch from Eric Norum to take advantage of ... Wed, 10 Feb 1999 19:57:04 GMT Joel Sherrill [ce34271] * ttcp/ttcp_orig/ttcp.c (modified) Added debug print when test can't get a buffer. This is probably a ... Wed, 10 Feb 1999 19:56:39 GMT Joel Sherrill [2b13801] * ttcp/rtems_ttcp.c (modified) Modified to delay at startup. Fri, 21 Aug 1998 13:26:06 GMT Joel Sherrill [7ba2ac5] * dnstest/Makefile (modified) * dnstest/init.c (modified) * dnstest/test.c (modified) * netdemo/Makefile (modified) * netdemo/init.c (modified) * netdemo/test.c (modified) * socket/buffer.c (modified) * socket/buffer.h (modified) * socket/init.c (modified) * socket/pgmHost/clientTcp.c (modified) * socket/pgmHost/clientUdp.c (modified) * socket/pgmHost/serverTcp.c (modified) * socket/pgmHost/serverUdp.c (modified) * tftpTest/Makefile (modified) * tftpTest/init.c (modified) * tftpTest/test.c (modified) * ttcp/Makefile (modified) * ttcp/README (modified) * ttcp/init.c (modified) * ttcp/rtems_ttcp.c (modified) * ttcp/ttcp_orig/README (modified) * ttcp/ttcp_orig/ttcp.c (modified) Added CVS Id Strings which were missing Fri, 21 Aug 1998 13:22:35 GMT Joel Sherrill [0c9330e] * netdemo/Makefile (modified) * netdemo/init.c (modified) * netdemo/test.c (modified) * tftpTest/Makefile (modified) * tftpTest/init.c (modified) * tftpTest/test.c (modified) * ttcp/Makefile (modified) * ttcp/README (modified) * ttcp/init.c (modified) * ttcp/rtems_ttcp.c (modified) KA9Q -> FreeBSD changes from Eric Norum Fri, 21 Aug 1998 13:19:35 GMT Joel Sherrill [4cfe89f] * STATUS (added) * networkconfig.h (added) * ttcp/include/arpa/inet.h (deleted) * ttcp/include/netdb.h (deleted) * ttcp/include/netinet/in.h (deleted) * ttcp/include/netinet/tcp.h (deleted) * ttcp/include/sys/socket.h (deleted) * usercfg.h (deleted) Removed -- now provided by RTEMS Wed, 12 Aug 1998 23:07:14 GMT Joel Sherrill [af0dafa] * ttcp/init.c (modified) * ttcp/rtems_ttcp.c (modified) Added foreground task which can print KA9Q tables. Wed, 12 Aug 1998 23:06:59 GMT Joel Sherrill [db1377f] * ttcp/README (modified) Added CVS Id. Wed, 12 Aug 1998 16:14:27 GMT Joel Sherrill [d265bbf] * ttcp/rtems_ttcp.c (modified) Added undef of delay to avoid errors on some targets. Wed, 12 Aug 1998 16:14:11 GMT Joel Sherrill [bc09324] * ttcp/init.c (modified) Added code to turn on debug. Thu, 30 Jul 1998 22:38:15 GMT Joel Sherrill [9399732] * tftpTest/init.c (modified) * ttcp/init.c (modified) Switched to using a single usercfg.h file. Thu, 30 Jul 1998 14:42:29 GMT Joel Sherrill [c87143a] * netdemo/Makefile (added) * netdemo/README (added) * netdemo/init.c (added) * netdemo/test.c (added) * tftpTest/Makefile (added) * tftpTest/init.c (added) * tftpTest/test.c (added) * ttcp/Makefile (added) * ttcp/README (added) * ttcp/include/arpa/inet.h (added) * ttcp/include/netdb.h (added) * ttcp/include/netinet/in.h (added) * ttcp/include/netinet/tcp.h (added) * ttcp/include/sys/socket.h (added) * ttcp/init.c (added) * ttcp/rtems_ttcp.c (added) * ttcp/ttcp_orig/README (added) * ttcp/ttcp_orig/ttcp.1 (added) * ttcp/ttcp_orig/ttcp.c (added) base from Eric Norum -- Demos.30May1998.tar.gz
