# # ChangeLog for ttcp in network-demos # # Generated by Trac 1.2.1.dev0 # Dec 15, 2019, 3:30:32 PM Tue, 25 Sep 2007 16:16:41 GMT Joel Sherrill [034dc82] * ttcp/.cvsignore (added) * ttcp/ChangeLog (modified) 2007-09-25 Joel Sherrill * ... Tue, 25 Sep 2007 16:09:21 GMT Joel Sherrill [d6b60f5] * ttcp/ChangeLog (modified) * ttcp/Makefile (modified) * ttcp/rtems_ttcp.c (modified) 2007-09-25 Joel Sherrill * ... Thu, 16 Aug 2007 17:27:52 GMT Joel Sherrill [5ee0701] * ttcp/ChangeLog (modified) * ttcp/init.c (modified) * ttcp/rtems_ttcp.c (modified) * ttcp/ttcp_orig/ttcp.c (modified) 2007-08-16 Joel Sherrill * ... Thu, 21 Jun 2007 18:26:30 GMT Joel Sherrill [ba33011] * dnstest/ChangeLog (modified) * dnstest/init.c (modified) * http/ChangeLog (modified) * http/init.c (modified) * netlink/ChangeLog (modified) * netlink/init.c (modified) * ntp/ChangeLog (modified) * ntp/init.c (modified) * ttcp/ChangeLog (modified) * ttcp/init.c (modified) 2007-06-21 Joel Sherrill * ... Thu, 21 Jun 2007 18:00:35 GMT Joel Sherrill [6a19a29] * ttcp/ChangeLog (modified) * ttcp/rtems_ttcp.c (modified) * ttcp/ttcp_orig/ttcp.c (modified) 2007-06-21 Joel Sherrill * ... Thu, 21 Jun 2007 15:13:05 GMT Joel Sherrill [faa85e6] * dnstest/ChangeLog (modified) * dnstest/init.c (modified) * netdemo/ChangeLog (modified) * netdemo/init.c (modified) * ntp/ChangeLog (modified) * ntp/init.c (modified) * rpc_demo/ChangeLog (modified) * rpc_demo/init.c (modified) * select/ChangeLog (modified) * select/init.c (modified) * tftpTest/ChangeLog (modified) * tftpTest/init.c (modified) * ttcp/ChangeLog (modified) * ttcp/init.c (modified) 2007-06-21 Joel Sherrill * ... Thu, 21 Jun 2007 15:11:36 GMT Joel Sherrill [5c663c0] * dnstest/ChangeLog (modified) * dnstest/init.c (modified) * http/ChangeLog (modified) * http/init.c (modified) * netdemo/ChangeLog (modified) * netdemo/init.c (modified) * netlink/ChangeLog (modified) * netlink/init.c (modified) * ntp/ChangeLog (modified) * ntp/init.c (modified) * rpc_demo/ChangeLog (modified) * rpc_demo/init.c (modified) * select/ChangeLog (modified) * select/init.c (modified) * tftpTest/ChangeLog (modified) * tftpTest/init.c (modified) * ttcp/ChangeLog (modified) * ttcp/init.c (modified) 2007-06-21 Joel Sherrill * ... Tue, 28 Jan 2003 22:21:21 GMT Joel Sherrill [6e16c55] * netdemo/ChangeLog (modified) * netdemo/init.c (modified) * netlink/ChangeLog (modified) * netlink/init.c (modified) * ntp/ChangeLog (modified) * ntp/init.c (modified) * rpc_demo/ChangeLog (modified) * rpc_demo/init.c (modified) * select/ChangeLog (modified) * select/init.c (modified) * tftpTest/ChangeLog (modified) * tftpTest/init.c (modified) * ttcp/ChangeLog (modified) * ttcp/init.c (modified) 2003-01-28 Joel Sherrill * init.c: ... Thu, 14 Dec 2000 14:15:04 GMT Joel Sherrill [3ba2f22] * ChangeLog (added) * dnstest/ChangeLog (added) * http/ChangeLog (added) * netdemo/ChangeLog (added) * netlink/ChangeLog (added) * ntp/ChangeLog (added) * rpc_demo/ChangeLog (added) * select/ChangeLog (added) * tftpTest/ChangeLog (added) * ttcp/ChangeLog (added) 2000-12-14 Joel Sherrill * ... Tue, 14 Dec 1999 13:23:56 GMT Joel Sherrill [7054195] * dnstest/init.c (modified) * http/init.c (modified) * netdemo/init.c (modified) * netlink/Makefile (modified) * netlink/init.c (modified) * ntp/init.c (modified) * select/init.c (modified) * tftpTest/init.c (modified) * ttcp/init.c (modified) Changed CONFIGURATION_MICROSECONDS_PER_TICK definition to a more ... Thu, 01 Apr 1999 18:19:08 GMT Joel Sherrill [ba9c45c] * ttcp/rtems_ttcp.c (modified) Patch from Eric Norum to take advantage of ... Wed, 10 Feb 1999 19:57:04 GMT Joel Sherrill [ce34271] * ttcp/ttcp_orig/ttcp.c (modified) Added debug print when test can't get a buffer. This is probably a ... Wed, 10 Feb 1999 19:56:39 GMT Joel Sherrill [2b13801] * ttcp/rtems_ttcp.c (modified) Modified to delay at startup. Fri, 21 Aug 1998 13:26:06 GMT Joel Sherrill [7ba2ac5] * dnstest/Makefile (modified) * dnstest/init.c (modified) * dnstest/test.c (modified) * netdemo/Makefile (modified) * netdemo/init.c (modified) * netdemo/test.c (modified) * socket/buffer.c (modified) * socket/buffer.h (modified) * socket/init.c (modified) * socket/pgmHost/clientTcp.c (modified) * socket/pgmHost/clientUdp.c (modified) * socket/pgmHost/serverTcp.c (modified) * socket/pgmHost/serverUdp.c (modified) * tftpTest/Makefile (modified) * tftpTest/init.c (modified) * tftpTest/test.c (modified) * ttcp/Makefile (modified) * ttcp/README (modified) * ttcp/init.c (modified) * ttcp/rtems_ttcp.c (modified) * ttcp/ttcp_orig/README (modified) * ttcp/ttcp_orig/ttcp.c (modified) Added CVS Id Strings which were missing Fri, 21 Aug 1998 13:22:35 GMT Joel Sherrill [0c9330e] * netdemo/Makefile (modified) * netdemo/init.c (modified) * netdemo/test.c (modified) * tftpTest/Makefile (modified) * tftpTest/init.c (modified) * tftpTest/test.c (modified) * ttcp/Makefile (modified) * ttcp/README (modified) * ttcp/init.c (modified) * ttcp/rtems_ttcp.c (modified) KA9Q -> FreeBSD changes from Eric Norum Fri, 21 Aug 1998 13:19:35 GMT Joel Sherrill [4cfe89f] * STATUS (added) * networkconfig.h (added) * ttcp/include/arpa/inet.h (deleted) * ttcp/include/netdb.h (deleted) * ttcp/include/netinet/in.h (deleted) * ttcp/include/netinet/tcp.h (deleted) * ttcp/include/sys/socket.h (deleted) * usercfg.h (deleted) Removed -- now provided by RTEMS Wed, 12 Aug 1998 23:07:14 GMT Joel Sherrill [af0dafa] * ttcp/init.c (modified) * ttcp/rtems_ttcp.c (modified) Added foreground task which can print KA9Q tables. Wed, 12 Aug 1998 23:06:59 GMT Joel Sherrill [db1377f] * ttcp/README (modified) Added CVS Id. Wed, 12 Aug 1998 16:14:27 GMT Joel Sherrill [d265bbf] * ttcp/rtems_ttcp.c (modified) Added undef of delay to avoid errors on some targets. Wed, 12 Aug 1998 16:14:11 GMT Joel Sherrill [bc09324] * ttcp/init.c (modified) Added code to turn on debug. Thu, 30 Jul 1998 22:38:15 GMT Joel Sherrill [9399732] * tftpTest/init.c (modified) * ttcp/init.c (modified) Switched to using a single usercfg.h file. Thu, 30 Jul 1998 14:42:29 GMT Joel Sherrill [c87143a] * netdemo/Makefile (added) * netdemo/README (added) * netdemo/init.c (added) * netdemo/test.c (added) * tftpTest/Makefile (added) * tftpTest/init.c (added) * tftpTest/test.c (added) * ttcp/Makefile (added) * ttcp/README (added) * ttcp/include/arpa/inet.h (added) * ttcp/include/netdb.h (added) * ttcp/include/netinet/in.h (added) * ttcp/include/netinet/tcp.h (added) * ttcp/include/sys/socket.h (added) * ttcp/init.c (added) * ttcp/rtems_ttcp.c (added) * ttcp/ttcp_orig/README (added) * ttcp/ttcp_orig/ttcp.1 (added) * ttcp/ttcp_orig/ttcp.c (added) base from Eric Norum -- Demos.30May1998.tar.gz
