# # ChangeLog for netdemo in network-demos # # Generated by Trac 1.2.1.dev0 # 04/19/24 22:56:08 Wed, 10 Feb 1999 19:55:45 GMT Joel Sherrill [b8a1e4f] * netdemo/init.c (modified) Added call to rtems_bsdnet_show_inet_routes(). Fri, 21 Aug 1998 13:26:06 GMT Joel Sherrill [7ba2ac5] * dnstest/Makefile (modified) * dnstest/init.c (modified) * dnstest/test.c (modified) * netdemo/Makefile (modified) * netdemo/init.c (modified) * netdemo/test.c (modified) * socket/buffer.c (modified) * socket/buffer.h (modified) * socket/init.c (modified) * socket/pgmHost/clientTcp.c (modified) * socket/pgmHost/clientUdp.c (modified) * socket/pgmHost/serverTcp.c (modified) * socket/pgmHost/serverUdp.c (modified) * tftpTest/Makefile (modified) * tftpTest/init.c (modified) * tftpTest/test.c (modified) * ttcp/Makefile (modified) * ttcp/README (modified) * ttcp/init.c (modified) * ttcp/rtems_ttcp.c (modified) * ttcp/ttcp_orig/README (modified) * ttcp/ttcp_orig/ttcp.c (modified) Added CVS Id Strings which were missing Fri, 21 Aug 1998 13:22:35 GMT Joel Sherrill [0c9330e] * netdemo/Makefile (modified) * netdemo/init.c (modified) * netdemo/test.c (modified) * tftpTest/Makefile (modified) * tftpTest/init.c (modified) * tftpTest/test.c (modified) * ttcp/Makefile (modified) * ttcp/README (modified) * ttcp/init.c (modified) * ttcp/rtems_ttcp.c (modified) KA9Q -> FreeBSD changes from Eric Norum Wed, 12 Aug 1998 23:06:16 GMT Joel Sherrill [7c81a8b] * netdemo/init.c (modified) * netdemo/test.c (modified) Cleaned up USE_BOOTP conditional for initialization. Get info from ... Sat, 08 Aug 1998 17:51:30 GMT Joel Sherrill [554367a] * netdemo/test.c (modified) Added print. Thu, 30 Jul 1998 22:41:17 GMT Joel Sherrill [d3c5e78] * netdemo/README (modified) Moved debugging hints to new file. Thu, 30 Jul 1998 22:35:45 GMT Joel Sherrill [497f13d] * netdemo/init.c (modified) Switched to using "../user.cfg" Thu, 30 Jul 1998 21:46:06 GMT Joel Sherrill [481950e] * netdemo/Makefile (modified) * netdemo/README (modified) * netdemo/init.c (modified) * netdemo/test.c (modified) Added notes from Eric to README. Added CVS $Id$ to all files. Thu, 30 Jul 1998 14:42:29 GMT Joel Sherrill [c87143a] * netdemo/Makefile (added) * netdemo/README (added) * netdemo/init.c (added) * netdemo/test.c (added) * tftpTest/Makefile (added) * tftpTest/init.c (added) * tftpTest/test.c (added) * ttcp/Makefile (added) * ttcp/README (added) * ttcp/include/arpa/inet.h (added) * ttcp/include/netdb.h (added) * ttcp/include/netinet/in.h (added) * ttcp/include/netinet/tcp.h (added) * ttcp/include/sys/socket.h (added) * ttcp/init.c (added) * ttcp/rtems_ttcp.c (added) * ttcp/ttcp_orig/README (added) * ttcp/ttcp_orig/ttcp.1 (added) * ttcp/ttcp_orig/ttcp.c (added) base from Eric Norum -- Demos.30May1998.tar.gz
