@f84493d
10/13/98 13:55:51 |
Joel Sherrill |
Changed to clarify how to set the network address.
4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
@14cbc50
08/21/98 15:36:09 |
Joel Sherrill |
Removed reference to TRACE_NETWORK_DRIVER which was KA9Q specific.
@5271dd3
08/21/98 13:36:35 |
Joel Sherrill |
changed version to 980821
@4ce159c
08/21/98 13:34:19 |
Joel Sherrill |
changed version to 980326
@e26f48e
08/21/98 13:29:48 |
Joel Sherrill |
New file
@7ba2ac5
08/21/98 13:26:06 |
Joel Sherrill |
Added CVS Id Strings which were missing
@0c9330e
08/21/98 13:22:35 |
Joel Sherrill |
KA9Q -> FreeBSD changes from Eric Norum
@4cfe89f
08/21/98 13:19:35 |
Joel Sherrill |
Removed -- now provided by RTEMS
@8cfa3aa
08/21/98 13:13:06 |
Joel Sherrill |
New files
@3b67d88
08/12/98 23:15:45 |
Joel Sherrill |
Added gratuitous arp and commented out a confusing printf.
@af0dafa
08/12/98 23:07:14 |
Joel Sherrill |
Added foreground task which can print KA9Q tables.
@db1377f
08/12/98 23:06:59 |
Joel Sherrill |
Added CVS Id.
@19a33c6
08/12/98 23:06:42 |
Joel Sherrill |
Added support for non-bootp servers
@7c81a8b
08/12/98 23:06:16 |
Joel Sherrill |
Cleaned up USE_BOOTP conditional for initialization.
Get info from …
@cf04c14
08/12/98 23:04:57 |
Joel Sherrill |
Added info on telnet servers needed by netdemo.
Added info on tftp …
@d265bbf
08/12/98 16:14:27 |
Joel Sherrill |
Added undef of delay to avoid errors on some targets.
@bc09324
08/12/98 16:14:11 |
Joel Sherrill |
Added code to turn on debug.
@062f725
08/11/98 14:36:23 |
Joel Sherrill |
new file
@adf2267
08/11/98 14:32:20 |
Joel Sherrill |
New file.
@f3b4c5a
08/11/98 13:31:51 |
Joel Sherrill |
New test from Emmanuel Raguet <raguet@…>.
@554367a
08/08/98 17:51:30 |
Joel Sherrill |
Added print.
@d3c5e78
07/30/98 22:41:17 |
Joel Sherrill |
Moved debugging hints to new file.
@f7b674f
07/30/98 22:41:09 |
Joel Sherrill |
New file.
@9399732
07/30/98 22:38:15 |
Joel Sherrill |
Switched to using a single usercfg.h file.
@2ddb68f
07/30/98 22:36:04 |
Joel Sherrill |
New files.
@497f13d
07/30/98 22:35:45 |
Joel Sherrill |
Switched to using "../user.cfg"
@481950e
07/30/98 21:46:06 |
Joel Sherrill |
Added notes from Eric to README.
Added CVS $Id$ to all files.
@f444fb8
07/30/98 14:42:29 |
Joel Sherrill |
This commit was generated by cvs2svn to compensate for changes in r2, …
@c87143a
07/30/98 14:42:29 |
Joel Sherrill |
base from Eric Norum -- Demos.30May1998.tar.gz
4.11ERIC-NORUMnetdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
Demos-30May1998
