source: network-demos
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @7ba2ac5   Aug 21, 1998, 1:26:06 PM Joel Sherrill Added CVS Id Strings which were missing 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @0c9330e   Aug 21, 1998, 1:22:35 PM Joel Sherrill KA9Q -> FreeBSD changes from Eric Norum 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @4cfe89f   Aug 21, 1998, 1:19:35 PM Joel Sherrill Removed -- now provided by RTEMS 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @8cfa3aa   Aug 21, 1998, 1:13:06 PM Joel Sherrill New files 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @3b67d88   Aug 12, 1998, 11:15:45 PM Joel Sherrill Added gratuitous arp and commented out a confusing printf. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @af0dafa   Aug 12, 1998, 11:07:14 PM Joel Sherrill Added foreground task which can print KA9Q tables. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @db1377f   Aug 12, 1998, 11:06:59 PM Joel Sherrill Added CVS Id. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @19a33c6   Aug 12, 1998, 11:06:42 PM Joel Sherrill Added support for non-bootp servers 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @7c81a8b   Aug 12, 1998, 11:06:16 PM Joel Sherrill Cleaned up USE_BOOTP conditional for initialization. Get info from … 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @cf04c14   Aug 12, 1998, 11:04:57 PM Joel Sherrill Added info on telnet servers needed by netdemo. Added info on tftp … 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @d265bbf   Aug 12, 1998, 4:14:27 PM Joel Sherrill Added undef of delay to avoid errors on some targets. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @bc09324   Aug 12, 1998, 4:14:11 PM Joel Sherrill Added code to turn on debug. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @062f725   Aug 11, 1998, 2:36:23 PM Joel Sherrill new file 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @adf2267   Aug 11, 1998, 2:32:20 PM Joel Sherrill New file. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @f3b4c5a   Aug 11, 1998, 1:31:51 PM Joel Sherrill New test from Emmanuel Raguet <raguet@…>. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @554367a   Aug 8, 1998, 5:51:30 PM Joel Sherrill Added print. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @d3c5e78   Jul 30, 1998, 10:41:17 PM Joel Sherrill Moved debugging hints to new file. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @f7b674f   Jul 30, 1998, 10:41:09 PM Joel Sherrill New file. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @9399732   Jul 30, 1998, 10:38:15 PM Joel Sherrill Switched to using a single usercfg.h file. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @2ddb68f   Jul 30, 1998, 10:36:04 PM Joel Sherrill New files. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @497f13d   Jul 30, 1998, 10:35:45 PM Joel Sherrill Switched to using "../user.cfg" 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @481950e   Jul 30, 1998, 9:46:06 PM Joel Sherrill Added notes from Eric to README. Added CVS $Id$ to all files. 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(edit) @f444fb8   Jul 30, 1998, 2:42:29 PM Joel Sherrill This commit was generated by cvs2svn to compensate for changes in r2, … 4.11netdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch
(add) @c87143a   Jul 30, 1998, 2:42:29 PM Joel Sherrill base from Eric Norum -- Demos.30May1998.tar.gz 4.11ERIC-NORUMnetdemos-4-5-branchnetwork-demos-4-10-branchnetwork-demos-4-6-branchnetwork-demos-4-7-branchnetwork-demos-4-8-branchnetwork-demos-4-9-branchrtems-4-5-branch Demos-30May1998
