- Timestamp:
02/24/17 03:22:35 (7 years ago)
- Author:
trac
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v1
v2
1 | | = Unicode Support in Trac = |
| 1 | = Unicode Support in Trac |
| 2 | |
2 | 3 | [[TracGuideToc]] |
3 | 4 | |
4 | | Trac stores all text using UTF-8 encoding, including text in tickets and wiki pages. Internal processing of text uses true Unicode representations. |
| 5 | Trac encodes all text using [wikipedia:UTF-8], including text in tickets and wiki pages. Internal processing of text uses true [wikipedia:Unicode] representations. As such, it supports most commonly used character encodings. |
5 | 6 | |
6 | | As such, it supports most (all?) commonly used character encodings. |
7 | | |
8 | | If the default encoding in your source code repository is not UTF-8, you can specify it in the [TracIni#trac-section trac.ini], for example: |
9 | | {{{ |
| 7 | If the default encoding in your source code repository is not UTF-8, you can specify it in your [TracIni#trac-section trac.ini] file: |
| 8 | {{{#!ini |
10 | 9 | default_charset = gbk |
11 | 10 | }}} |
12 | 11 | |
13 | | You also must make sure that your [trac:DatabaseBackend database backend] stores its data in UTF-8; otherwise strange things will happen. |
| 12 | Also ensure that your [trac:DatabaseBackend database] stores its data in UTF-8, otherwise results may be unpredictable. |
14 | 13 | |
15 | | To convert your database to UTF-8, the easiest way is to dump the database, convert the dump into UTF-8 and then import the converted dump back into the database.[[BR]] |
16 | | You can use [http://www.gnu.org/software/libiconv/documentation/libiconv/iconv.1.html iconv] to convert the dump. |
| 14 | To convert your database to UTF-8, the easiest way is to create a dump of the database, convert it into UTF-8, for example using [http://www.gnu.org/software/libiconv/documentation/libiconv/iconv.1.html iconv], and then import it back into the database. |
17 | 15 | |
| 16 | == Examples |
18 | 17 | |
19 | | == Examples == |
| 18 | === Arabic |
20 | 19 | |
21 | | === Arabic === |
22 | 20 | تراك يقوم بحفظ كل الكلمات باستخدام صيغة UTF-8، بما في ذلك الكلمات المستخدمة في صفحات التيكت والويكي. |
23 | 21 | |
24 | | === Bulgarian === |
| 22 | === Bulgarian |
| 23 | |
25 | 24 | Българският език работи ли? |
26 | 25 | |
27 | | === Česky === |
| 26 | === Česky |
| 27 | |
28 | 28 | Čeština v kódování UTF-8, žádný problém. |
29 | 29 | |
30 | | === Chinese === |
31 | | Traditional: 繁體中文, 漢字測試; Simplified: 简体中文,汉字测试 |
| 30 | === Chinese |
32 | 31 | |
33 | | === Croatian === |
34 | | Ako podržava srpski i slovenski mora podržavati i Hrvatski - čćžšđ ČĆŽŠĐ |
| 32 | Traditional: 繁體中文, 漢字測試 |
35 | 33 | |
36 | | === English === |
| 34 | Simplified: 简体中文,汉字测试 |
| 35 | |
| 36 | === Croatian |
| 37 | |
| 38 | Ako podržava srpski i slovenski mora podržavati i Hrvatski - čćžšđ ČĆŽŠĐ. |
| 39 | |
| 40 | === English |
| 41 | |
37 | 42 | Yes indeed, Trac supports English. Fully. |
38 | 43 | |
39 | | === Français === |
40 | | Il est possible d'écrire en Français : à, ç, û, ... |
| 44 | === Français |
41 | 45 | |
42 | | === German === |
43 | | Trac-Wiki muß auch deutsche Umlaute richtig anzeigen: ö, ä, ü, Ä, Ö, Ü; und das scharfe ß |
| 46 | Il est possible d'écrire en Français : à, ç, û. |
44 | 47 | |
45 | | === Greek === |
| 48 | === German |
| 49 | |
| 50 | Trac-Wiki muß auch deutsche Umlaute richtig anzeigen: ö, ä, ü, Ä, Ö, Ü; und das scharfe ß. |
| 51 | |
| 52 | === Greek |
| 53 | |
46 | 54 | Τα Ελληνικά υποστηρίζονται επαρκώς επίσης. |
47 | 55 | |
48 | | === Hebrew === |
| 56 | === Hebrew |
| 57 | |
49 | 58 | אני יכול לאכול זכוכית וזה לא מזיק לי |
50 | 59 | |
51 | | === Hindi === |
| 60 | === Hindi |
| 61 | |
52 | 62 | अब हिन्दी में। |
53 | 63 | |
54 | | === Hungarian === |
55 | | Árvíztűrő tükörfúrógép |
| 64 | === Hungarian |
56 | 65 | |
57 | | === Icelandic === |
| 66 | Árvíztűrő tükörfúrógép. |
| 67 | |
| 68 | === Icelandic |
| 69 | |
58 | 70 | Ævar sagði við ömmu sína: Sjáðu hvað ég er stór! |
59 | 71 | |
60 | | === Japanese === |
| 72 | === Japanese |
| 73 | |
61 | 74 | 漢字 ひらがな カタカナ ハンカクカナ 日本語試験 |
62 | 75 | |
63 | | === Korean === |
64 | | 이번에는 한글로 써보겠습니다. 잘 보이나요? 한글 |
| 76 | === Korean |
65 | 77 | |
66 | | === Latvian === |
| 78 | 이번에는 한글로 써보겠습니다. 잘 보이나요? 한글. |
| 79 | |
| 80 | === Latvian |
67 | 81 | |
68 | 82 | Latviešu valoda arī strādā! |
69 | 83 | |
70 | | === Lithuanian === |
71 | | Sudalyvaukime ir mes. Ar veikia lietuviškos raidės? ąčęėįšųūž ĄČĘĖĮŠŲŪŽ Žinoma, kad veikia :) |
72 | | Kas tie mes? |
| 84 | === Lithuanian |
73 | 85 | |
74 | | === Persian (Farsi) === |
| 86 | Sudalyvaukime ir mes. Ar veikia lietuviškos raidės? ąčęėįšųūž ĄČĘĖĮŠŲŪŽ Žinoma, kad veikia. Kas tie mes? |
| 87 | |
| 88 | === Persian (Farsi) |
| 89 | |
75 | 90 | این یک متن فارسی است ولی امکان نوشتن مستقیم فارسی نیست چون حالت متن از راست به چپ و جود ندارد برای فارسی نوشتن باید از HTML استفاده کنید. |
76 | 91 | {{{ |
84 | 99 | }}} |
85 | 100 | |
86 | | === Polish === |
87 | | Pchnąć w tę łódź jeża lub osiem skrzyń fig; Nocna gżegżółka zawsze dzienną przekuka. |
| 101 | === Polish |
88 | 102 | |
89 | | === Portuguese === |
| 103 | Pchnąć w tę łódź jeża lub osiem skrzyń fig. Nocna gżegżółka zawsze dzienną przekuka. |
| 104 | |
| 105 | === Portuguese |
| 106 | |
90 | 107 | É possível guardar caracteres especias da língua portuguesa, incluindo o símbolo da moeda européia '€', trema 'ü', crase 'à', agudos 'áéíóú', circunflexos 'âêô', til 'ãõ', cedilha 'ç', ordinais 'ªº', grau '°¹²³'. |
91 | 108 | |
92 | | === Russian === |
93 | | Проверка русского языка: кажется работает... И буква "ё" есть... |
| 109 | === Russian |
94 | 110 | |
95 | | === Serbian === |
| 111 | Проверка русского языка: кажется работает. И буква "ё" есть. |
| 112 | |
| 113 | === Serbian |
| 114 | |
96 | 115 | Podržan, uprkos činjenici da se za njegovo pisanje koriste чак два алфабета. |
97 | 116 | |
98 | | === Slovenian === |
| 117 | === Slovenian |
| 118 | |
99 | 119 | Ta suhi škafec pušča vodo že od nekdaj! |
100 | 120 | |
101 | | === Spanish === |
102 | | Esto es un pequeño texto en Español, donde el veloz murciélago hindú comía cardlllo y kiwi |
| 121 | === Spanish |
103 | 122 | |
104 | | === Swedish === |
| 123 | Esto es un pequeño texto en Español, donde el veloz murciélago hindú comía cardillo y kiwi. |
| 124 | |
| 125 | === Swedish |
| 126 | |
105 | 127 | Räven raskar över isen med luva på. |
106 | 128 | |
107 | | === Thai === |
| 129 | === Thai |
| 130 | |
108 | 131 | Trac แสดงภาษาไทยได้อย่างถูกต้อง! |
109 | 132 | |
110 | | === Ukrainian === |
111 | | Перевірка української мови... |
| 133 | === Ukrainian |
112 | 134 | |
113 | | === Urdu === |
| 135 | Перевірка української мови. |
| 136 | |
| 137 | === Urdu |
| 138 | |
114 | 139 | ٹریک اردو بھی سپورٹ کرتا ہے۔ |
115 | 140 | |
116 | | === Vietnamese === |
| 141 | === Vietnamese |
| 142 | |
117 | 143 | Viết tiếng Việt cũng được. |
