- Timestamp:
11/20/17 22:25:31 (6 years ago)
- Author:
Hesham Almatary
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v31
v32
8 | 8 | * i386/pc386 -- This is a BSP for PCs which can be tested by simulators and virtual environments such as Bochs, [wiki:Developer/VirtualMachines/VMWareSetup VMWare], QEMU, and [wiki:RTEMS_on_Virtualbox_ VirtualBox]. [wiki:TBR/UserManual/QEMU QEMU] provides PC emulation and is often used to test RTEMS. ''[wiki:Developer/VirtualMachines/VMWareSetup MinGW:Grub2:VMWare Development Environment Setup]'' describes how to setup a development host environment with MinGW, Grub2 and VMWare to build, boot and simulate RTEMS on Windows, and ''[wiki:Developer/Simulators/VMWare Simulate Serial Communication Application]'' demonstrates how to use such environment to develop applications involving peripherals. And an example of how remote debugging works with VMWare can be found at [wiki:Developer/Eclipse/Plugin RTEMS Eclipse Plug-in]. |
9 | 9 | |
10 | | * mips/jmr3904 - Toshiba MIPS TX3904 simulator in gdb. |
| 10 | * mips/jmr3904 - Toshiba MIPS TX3904 simulator in gdb. |
| 11 | * mips/malta - runs on QEMU with -M malta. |
11 | 12 | * powerpc/psim -- synthetic PPC603 based-board simulated in gdb. See [wiki:TBR/BSP/Psim PSIM BSP] for more information |
| 13 | * riscv/riscv_generic -- Runs on Spike which supports both RV32 and RV64 (tested with priv-1.10). |
12 | 14 | * sparc/erc32 -- BSP for ERC32 with and without floating point unit which is simulated by [http://www.gaisler.com/ TSIM]. |
13 | 15 | * sparc/sis -- BSP for ERC32 with and without floating point unit which is simulated by the SPARC Instruction Simulator (SIS) in gdb. |
