- Timestamp:
09/20/17 15:48:11 (7 years ago)
- Author:
Mikail Yayla
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v19
v20
147 | 147 | * Draw diagram on how the FTS works, write a tutorial on how the FTS can be used, and work on documentation on how to add the FTS to an RTEMS system. |
148 | 148 | * Finish final report and the draft. |
149 | | * Meet with my mentor (Kuan) to discuss the coding period result, get evaluation on final report and fill out SOCIS form. |
| 149 | * Meet with my mentor (Kuan) to discuss the coding period result, get evaluation on final report. |
150 | 150 | * Plans for the next week: |
151 | | * Implement possible suggestions or improvements. |
| 151 | * Implement suggestions on report: Add information about the API. Add a chapter called miscellaneous, in which possibe pitfalls of the FTS are described. |
| 152 | * Improve exception handling in the code |
152 | 153 | = Final Report (RTEMS Fault Tolerance) = |
153 | 154 | * [https://github.com/myay/rtems_faulttolerance_SOCIS17/tree/master/final_report Final report] (WIP) |
155 | 156 | == Future Works == |
156 | 157 | * Test the Fault Tolerant Scheduler on other hardware, with realistic control tasks. This way, more research on the fault tolerance of control task can be done. |
157 | | * Use the BrickPi3 Base Kit to connect EV3 actuators and sensors. Test the FTS code by running RTEMS on a BrickPi3 robot, for example path tracker, two wheeled balancer, and robots with other control tasks. (message Kuan if you are interested in this project: kuan-hsun.chen@tu-dortmund.de) |
158 | | * Port RTEMS for the Lego EV3 robot and run the fault tolerance code on it. (message Kuan if you are interested in this project: kuan-hsun.chen@tu-dortmund.de) |
| 158 | * Use the BrickPi3 Base Kit to connect EV3 actuators and sensors. Test the FTS code by running RTEMS on a BrickPi3 robot, for example path tracker, two wheeled balancer, and robots with other control tasks. (contact Kuan if you are interested in this project: kuan-hsun.chen(at)tu-dortmund.de) |
| 159 | * Port RTEMS for the Lego EV3 robot and run the fault tolerance code on it. (contact Kuan if you are interested in this project: kuan-hsun.chen(at)tu-dortmund.de) |
