- Timestamp:
11/15/18 20:22:07 (6 years ago)
- Author:
Denth
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v6
v7
1 | 1 | = Please Read Before Creating a Ticket = |
2 | 2 | |
3 | | Thank you for your interest in submitting a bug report. Before you get started please read through this short document to better help us address the issue you will be reporting. |
| 3 | Thank you for your interest in submitting a bug report. Before you get started, please read through this short document to better help us address the issue you will be reporting. |
4 | 4 | |
5 | | [[Notice(Before submitting a ticket please try the following three things)]] |
| 5 | [[Notice(Before submitting a ticket, please try the following three things:)]] |
6 | 6 | |
7 | 7 | 1. View the [https://devel.rtems.org/query View Tickets] Page |
20 | 20 | ---- |
21 | 21 | = Required Information = |
22 | | It's not mandatory to fill in all information, but at the very least these fields are required: |
| 22 | It's not mandatory to fill in all the information, but at the very least, these fields are required: |
23 | 23 | |
24 | 24 | 1. '''Summary''' |
25 | | * Keep this short and concise to what your problem is. |
| 25 | * Keep this short and concise as to what your problem is. |
26 | 26 | 1. '''Description''' |
27 | 27 | * Include as many details of your problem as possible. |
34 | 34 | * '''enhancement''' - A feature request in the software, or addition to the documentation. |
35 | 35 | 1. '''Version''' |
36 | | * Set it to the version you're using, if it is the [wiki:Developer/Git Git] version (not an official release) then set it to ''master''. |
| 36 | * Set it to the version you're using. If it is the [wiki:Developer/Git Git] version (not an official release), then set it to ''master''. |
37 | 37 | 1. '''Test Cases''' |
38 | 38 | * Where possible, please attach or provide an in-line example that reproduces this problem. Try to make it the least possible amount of code to trigger the issue. |
39 | 39 | |
40 | 40 | == Attaching Files == |
41 | | If you have any external files such as screenshots or examples, please ''attach'' these as files to the ticket __do not use external hosting__, if you use external hosting then our historical record is broken when those files are no longer available. |
| 41 | If you have any external files, such as screenshots or examples, please ''attach'' these as files to the ticket. __Do not use external hosting__, as if you do use external hosting, then our historical record is broken when those files are no longer available. |
42 | 42 | |
43 | 43 | ---- |
44 | 44 | = Fields = |
45 | | Some fields should only be set by the developers as it's not always clear what they should be set to feel free to make your own choices. |
| 45 | Some fields should only be set by the developers, as it's not always clear what they should be set to. Feel free to make your own choices. |
46 | 46 | |
47 | 47 | |
48 | 48 | ---- |
49 | 49 | = Submitting a Ticket = |
50 | | In order to submit a ticket you must first [/register register]. |
| 50 | In order to submit a ticket, you must first [/register register]. |
51 | 51 | |
52 | | As long as you've read this page, then [/newticket submit a ticket!]. |
| 52 | If you've read this page, you can [/newticket submit a ticket]. |
53 | 53 | |
