- Timestamp:
02/24/17 03:22:35 (7 years ago)
- Author:
trac
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v1
v2
1 | | = Support for InterWiki links = |
| 1 | = Support for InterWiki links |
2 | 2 | |
3 | | ''(since [trac:milestone:0.10 0.10])'' |
| 3 | == Definition |
4 | 4 | |
5 | | == Definition == |
| 5 | An InterWiki link can be used for referring to a Wiki page located in another Wiki system, and by extension, to any object located in any other Web application, provided a simple URL mapping can be done. |
6 | 6 | |
7 | | An InterWiki link can be used for referring to a Wiki page |
8 | | located in another Wiki system, and by extension, to any object |
9 | | located in any other Web application, provided a simple URL |
10 | | mapping can be done. |
| 7 | InterWiki prefixes can even be used to simply introduce links to new protocols, such as `tsvn:` used by [trac:TortoiseSvn TortoiseSvn]. |
11 | 8 | |
12 | | At the extreme, InterWiki prefixes can even be used to simply introduce |
13 | | links to new protocols, such as `tsvn:` used by [trac:TortoiseSvn TortoiseSvn]. |
14 | | |
15 | | == Link Syntax == |
| 9 | == Link Syntax |
16 | 10 | |
17 | 11 | {{{ |
19 | 13 | }}} |
20 | 14 | |
21 | | The link is composed by the targeted Wiki (or system) name, |
22 | | followed by a colon (e.g. `MeatBall:`), |
23 | | followed by a page specification in the target. |
| 15 | The link is composed by the targeted Wiki (or system) name, followed by a colon, eg `MeatBall:`, followed by a page specification in the target. |
24 | 16 | Note that, as for InterTrac prefixes, '''InterWiki prefixes are case insensitive'''. |
25 | 17 | |
26 | 18 | The target Wiki URL is looked up in the `[interwiki]` section of TracIni or in the InterMapTxt wiki page, modeled after MeatBall:InterMapTxt. If a prefix is defined in both the `[interwiki]` section and InterMapTxt, the `[interwiki]` section takes precedence. |
27 | 19 | |
28 | | In addition to traditional InterWiki links, where the target |
29 | | is simply ''appended'' to the URL, |
30 | | Trac supports parametric InterWiki URLs: |
31 | | identifiers `$1`, `$2`, ... in the URL |
32 | | will be replaced by corresponding arguments. |
33 | | The argument list is formed by splitting the page identifier |
34 | | using the ":" separator. |
| 20 | In addition to traditional InterWiki links, where the target is simply ''appended'' to the URL, Trac supports parametric InterWiki URLs: |
| 21 | identifiers `$1`, `$2`, ... in the URL will be replaced by corresponding arguments. |
| 22 | The argument list is formed by splitting the page identifier using the ":" separator. |
35 | 23 | |
36 | | === [interwiki] === |
| 24 | === [interwiki] |
| 25 | |
37 | 26 | Every option in the `[interwiki]` section in TracIni defines one InterWiki prefix. The option name defines the prefix. The option value defines the URL, optionally followed by a description separated from the URL by whitespace. Parametric URLs are supported as well. |
38 | 27 | |
39 | 28 | '''Example:''' |
40 | | {{{ |
| 29 | {{{#!ini |
41 | 30 | [interwiki] |
42 | 31 | MeatBall = http://www.usemod.com/cgi-bin/mb.pl? |
45 | 34 | }}} |
46 | 35 | |
47 | | == Examples == |
| 36 | == Examples |
48 | 37 | |
49 | 38 | If the following is an excerpt of the InterMapTxt page: |
73 | 62 | |
74 | 63 | Then, |
75 | | * `MoinMoin:InterWikiMap` should be rendered as MoinMoin:InterWikiMap |
76 | | and the ''title'' for that link would be "!InterWikiMap in !MoinMoin" |
77 | | * `Trac-ML:4346` should be rendered as Trac-ML:4346 |
78 | | and the ''title'' for that link would be "Message 4346 in Trac Mailing List" |
| 64 | * `MoinMoin:InterWikiMap` should be rendered as MoinMoin:InterWikiMap and the ''title'' for that link would be "!InterWikiMap in !MoinMoin". |
| 65 | * `Trac-ML:4346` should be rendered as Trac-ML:4346 and the ''title'' for that link would be "Message 4346 in Trac Mailing List". |
79 | 66 | |
80 | 67 | ---- |
