- Timestamp:
07/13/16 15:00:19 (8 years ago)
- Author:
Deval Shah
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v68
v69
88 | 88 | * June 24: I have successfully ported the bcm283x_dwcotg driver for the Raspberry Pi. I ran init0 test on my Raspberry Pi Model 1/B+. Driver loaded successfully without hanging. Changes can be seen [https://github.com/deval-maker/rtems-libbsd/commit/fd650f7ded413a0d891b5395abb0c8768d71acc7 here]. Apart from that I am getting error in mailbox functions (failed to set power state, err=-2). As far as I know Pavel and Mudit are looking into this problem. I will start working with them for the same. I can not move to next part before solving this. Also, I gave the work done till now for code review. |
89 | 89 | * June 29: Mailbox Error resolved. bcm283x_dwcotg ported successfully.Currently I am trying to port usb_ethernet driver. Resolving errors while compiling. |
90 | | * July 13: I have added files for usb_ethernet and bcm283x_dwcotg till now. I am stuck at the point where I have to connect both of them. I have started the [ https://lists.rtems.org/pipermail/devel/2016-July/015564.html email thread] regarding this issue. Alan and Chris are looking into the problem with me. |
| 90 | * July 13: I have added files for usb_ethernet and bcm283x_dwcotg till now. I am stuck at the point where I have to connect both of them. I have started the [https://lists.rtems.org/pipermail/devel/2016-July/015564.html email thread] regarding this issue. Alan and Chris are looking into the problem with me. |
91 | 91 | |
92 | 92 | == Wonjun Hwang == |
