- Timestamp:
02/17/15 12:46:33 (9 years ago)
- Author:
Gedare Bloom
- Comment:
Fix descriptions.
Legend:
- Unmodified
- Added
- Removed
- Modified
v402
v403
79 | 79 | = Board Support Package (BSP) = |
80 | 80 | |
81 | | * [wiki:Projects/Open/ImproveBeagleBSP Beagle BSP improvements] - More peripherals and other improvements for the Beagleboard family. Past: ''[wiki:Projects/GSoC/Beagle Beagle BSP improvements]''. |
82 | | * [wiki:Projects/Open/ImproveRaspberryPiBSP Raspberry Pi improvements] - More peripherals and other improvements for Raspberry Pi. Past: ''[wiki:GSoC/2013/Raspberry_Pi_BSP_Peripherals Raspberry Pi BSP Peripherals]''. |
| 81 | * [wiki:Projects/Open/ImproveBeagleBSP Beagle BSP improvements] - More peripherals and other improvements for the Beagleboard family. |
| 82 | * [wiki:Projects/Open/ImproveRaspberryPiBSP Raspberry Pi improvements] - More peripherals and other improvements for Raspberry Pi. |
83 | 83 | * [wiki:Projects/Open/Emulatei386BIOS x86 BIOS emulation for VESA] - This is Pavel Pisa's idea. |
84 | | * [wiki:Projects/Open/MicroblazePort Port RTEMS to Microblaze architecture] - A new architecture port, not just BSP. Include a BSP for GDB simulator. Also needs BSP for more complete HW on simulator. |
85 | | * [wiki:Projects/Open/SimulatorBSPs More BSPs for Simulators] - RTEMS can always use [wiki:TBR/Delete/MoreBSPsForSimulators more BSPs for Simulators] and readily available boards or open cores. |
86 | | * [wiki:Projects/Open/MemoryProtection Memory Protection] - Implement MMU low-level support code for more BSPs. Past: ''[wiki:Projects/MMU_Support MMU Support]'' |
| 84 | * [wiki:Projects/Open/MicroblazePort Port RTEMS to Microblaze architecture] - New architecture port. |
| 85 | * [wiki:Projects/Open/SimulatorBSPs More BSPs for Simulators] - RTEMS can always use more BSPs for simulators (and readily available boards or open cores). |
| 86 | * [wiki:Projects/Open/MemoryProtection Memory Protection] - Implement MMU low-level support code for more BSPs. |
87 | 87 | * [wiki:Projects/Open/RaspberryPi2BSP Raspberry Pi2] - on hold due to unavailability of open information |
88 | 88 | * [wiki:Projects/Open/EdisonBSP x86 Edison] - on hold due to unavailability of open information |
