- Timestamp:
12/04/14 16:27:01 (9 years ago)
- Author:
Gedare Bloom
- Comment:
Delete intro related to SOCIS2014
Legend:
- Unmodified
- Added
- Removed
- Modified
v363
v364
1 | 1 | = Open Projects = |
2 | | |
3 | | |
4 | | '''[http://sophia.estec.esa.int/socis/ ESA Summer of Code in Space 2014] students''' are highly encouraged to select from projects which improve our automated testing. High priority projects include reworking out Coverage Reports to report on a per software module or directory basis, integrating the coverage test executing with the new rtems-test infrastructure, adding more capabilities to the rtems-test infrastructure, and enhancing the RTEMS Source Builder to support more simulators and integrate testing. Some of these projects are described in the [wiki:Developer/OpenProjects#Testing Open Projects#Testing] section below. Please discuss your ideas with the RTEMS community. Together we will put together a project plan that maximizes your skill set and benefit to the RTEMS Project. |
5 | 2 | |
6 | 3 | Welcome! Whether you're here because of [wiki:GSoC Summer of Code (SOC)] or just want to scratch an itch to hack, we invite you to peruse our projects and ask about them on the [wiki:TBR/Website/RTEMSMailingLists RTEMS mailing list] or [wiki:Developer/IRC IRC]. If you plan to submit a proposal to do something for the RTEMS Project as part of a SOC, see [wiki:GSoC/GettingStarted Getting Started for SoC Students]. RTEMS projects span kernel hacking, adding support for a new board (BSP), improving the development environment, developing tests, and more. |
