- Timestamp:
04/16/18 00:00:43 (6 years ago)
- Author:
Chris Johns
- Comment:
Legend:
- Unmodified
- Added
- Removed
- Modified
v8
v9
28 | 28 | 1. The prefix `/opt/work/openocd` if just an example path, select a suitable local path for your host. |
29 | 29 | 1. On FreeBSD the `--disable-werror` option needs to be used to disable warnings being treated as errors. |
30 | | 1. You need `--enable-ftdi` option is need to support the Flyswatter2 pod. Other pod may require other options. |
| 30 | 1. You need `--enable-ftdi` option to support the Flyswatter2 pod. Other pod may require other options. |
